Go to Post We don't build robots because it's easy, we do it because it's hard. Maybe we can work on giving new members a warmer and gentler welcome, because it's hard ;). - Winged Globe [more]
Unread 11-01-2015, 08:57
Omer Katz Omer Katz is offline
FRC #1577
Omer Katz is an unknown quantity at this point
Question Recycling Container Placement
I have a Question and i want to see your opinions
How long do you think it will take to place a Recycling Container on a stack of 6 Totes?
I'm not looking for one straight answer but your general opinion.
Thanks for the help
Unread 11-01-2015, 09:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Recycling Container Placement
I guess that depends on which team is doing it? It will depend on the robot design, and operator skill. We're hoping to make it about a ten second process, but then again we're not intending to place a container on a stack of 6 totes...only a stack of 5, at most. 4, more often.
Unread 12-01-2015, 10:16
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
It will also depend on the situation... Making a stack from the landfill will likely take a little longer than from the loading station...
Under ideal conditions (our autonomous went perfectly, we quickly grab a container, run over to the feeder station, our intake deals perfectly with the tumbling totes and we line up ideally in the scoring zone on our first attempt, we could stack five and a container in 15 seconds.
Of course:
1) Rarely do things work out perfectly.
2) Right now, we only have a "theoretical" robot.... Or, perhaps I should say, "several parts of a 'theoretical' robot..." The other parts are in the mail - unless they are on back-order.....
Unread 12-01-2015, 13:00
Zekoku Zekoku is offline
FRC #2170
Zekoku is an unknown quantity at this point
If I remember correctly 6 totes is 78 inches and the max robot height is also 78 inches so I believe you have to place a container on before you stack 6 totes.
Unread 12-01-2015, 13:04
Rangel(kf7fdb)'s Avatar
Rangel(kf7fdb) Rangel(kf7fdb) is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond repute
For the average robot, about a 20-30 seconds with high chance of fail. For top tier teams, 5-10 seconds with very little chance of failure.
2011-2014 Arizona Regional Winners
2012 Dean's List Winner
2012-2013 Team President
2013 8th Place Robosub Competition
2014-? Mentor
Unread 12-01-2015, 13:21
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Actually, each tote is 12.1 inches tall, according to the manual.
12.1 * 6 = 72.6
That leaves your robot 78 - 72.6 = 5.4 inches.
Of course, the scoring platform is 2 inches tall...so... 3.4 inches.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 13-01-2015, 12:21
StephenNutt StephenNutt is online now
FRC #0172 (Falgor)
StephenNutt is an unknown quantity at this point
12.1 * 6 = 72.6
When you stack totes they mat sit inside of each other, and I think each tote is around 11.875 tall.
12.1 + 5 * 11.875 = 71.475
That leaves your robot 78 - 71.475 = 6.525 inches, or 4.525 when taking into account the scoring platform.
Note: I am not certain the distance from the bottom to the top of the lid is 11.875, please verify if you will be using my math.
Unread 13-01-2015, 13:26
AKA: Matt B
FRC #1771 (1771)
Well that makes it even easier...
1771- Mentor (2015)
Unread 13-01-2015, 13:49
TCMJ1816's Avatar
TCMJ1816 TCMJ1816 is offline
Peter
AKA: Peter Hartnett
FRC #1816 ("The Green Machine" (Alumnus))
TCMJ1816 will become famous soon enough
The Scoring Platform doesn't count towards total robot height, so you can build a robot 78'' tall and still drive on the scoring platform. Having said that lifting a bin ~5'' from the bottom doesn't seem feasible for most teams, I just can't see it being stable enough once 8' in the air.
Unread 13-01-2015, 14:22
MrForbes's Avatar
AKA: Jim
We got our first container mechanism prototyped last night, and we'll make some changes to see if we can make it more stable when grasping at the bottom of the container. It looks like it will almost work with what we have already. Bonus, it will also work on totes, and we can probably use it (by adding another degree of freedom, which is also needed to meet size requirements) to pick up tipped containers.
Unread 14-01-2015, 18:08
Linkathon1986's Avatar
Linkathon1986 Linkathon1986 is offline
That One Person
AKA: Jonathon Erickson
FRC #2512 (Duluth East Daredevils)
Team Role: Tactician
Rookie Year: 2015
Linkathon1986 is a splendid one to beholdLinkathon1986 is a splendid one to beholdLinkathon1986 is a splendid one to beholdLinkathon1986 is a splendid one to beholdLinkathon1986 is a splendid one to beholdLinkathon1986 is a splendid one to beholdLinkathon1986 is a splendid one to behold
12.1 * 6 = 72.6
But if you're wanting to work with litter, you will need to place the litter before you stack.
Unread 14-01-2015, 19:48
tindleroot tindleroot is offline
Free Scouting Help to All
AKA: Casey LeeVan
FRC #4272 (Maverick Boiler Robotics)
tindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond repute
We measured a nested stack of 6 and it came out at almost exactly 72 inches - you have 6 inches to work with or 4 if you take into account the scoring platform.
2012-2013: FTC 4601 (student)
2014-2015: FRC 135 (student) - 5 banners in 2 years!
2016-present: FRC 4272 (mentor)
Thanks to all of our alliance partners!
11, 51, 68, 201, 234, 868, 1108, 1241, 1760, 3147, 3301, 3487, 3865, 4269, 4485, 4580, 5188
Unread 15-01-2015, 14:07
Addison4300's Avatar
Addison4300 Addison4300 is offline
FRC is love, FRC is life
AKA: Addison
FRC #4300 (The Lion Kings)
Addison4300 is on a distinguished road
It all depends on the strength and speed of your motors/pneumatics that you use, how many you use, and how well you are lined up with the stack.
Unread 16-01-2015, 12:05
mitchklong mitchklong is offline
None #4859
mitchklong is an unknown quantity at this point
I dont expect to see a lot of teams doing that.
I think it would be easier to make a 4 tote stack, then put a 2 tote bin stack on top (or other variations).
One of the things I like about this years game is working out the effort required/center of gravity issues.
