Go to Post P.S. could we get Kanagasabapathy added to the spell check? or will it not handle words that big? :) - Holtzman [more]
Unread 14-01-2015, 18:45
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Need help creating a winch and pulley system to pull a component up the robot
Originally Posted by Quazar View Post
We used a wench last year - it was formed by putting two aluminum VersaHubs face-to-face. We drove it using a VersaPlanetary gearbox driven by a BAG motor. It worked very well for us.
Cheers,
- Dean
We did pretty much the same thing, excecpt we used the old AM hubs and we added a piece of polycarb to extend the diameter of the winch. We drove ours using a ballshifter with a beefed up cylinder.
Unread 14-01-2015, 19:37
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Thirding the use of two hex hubs with polycarb discs (attached to a commercial gearbox). We used Andymark hubs last year because they have a solid flange. We drilled the aluminum flange of both so that we could pass a #10 x ~2" bolt across the gap, through both flanges. We passed the bolt through the sewn loop of some 1" tie-down straps, and then the strap rolled up on top of the bolt (and hubs). We also built a guide for the strap, but it probably isn't necessary. Easy build - did it in one meeting.
