Go to Post Look at 71's 'walking' bot from last year. One dosn't need wheels/track to move. All you need is an idea. - Jack [more]
Unread 14-01-2015, 18:49
Nathan Powell's Avatar
Nathan Powell Nathan Powell is offline
The Prime Function
FRC #2582 (PantherBots)
Nathan Powell is an unknown quantity at this point
CAN for Pneumatics in C++
Greetings, all.
My team is opting to use pneumatics in our tote-acquisition part of the robot this year. Pneumatics coding and wiring require a controller area network, or CAN. I have never heard of CAN until this year...would someone be able to assist me in programming a CAN for a pneumatic solenoid and compressor?
"What's this I keep hearing about always blame programming?"
Unread 14-01-2015, 18:54
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: CAN for Pneumatics in C++
There is no need to program CAN for the pneumatics. You only need to use the CAN cables on the PCM, and connect them to the roboRIO or PDP. The code is nearly exactly the same as last year, and the compressor is actually closed-loop this year! Just declare a solenoid, and the compressor should run by itself.
Hope that helped.
Unread 14-01-2015, 18:59
The Prime Function
That is quite helpful. It bothered my coach a bit (who was convinced that a CAN needed some type of special programming) but this cleared up a lot of inconsistency, and at least to me makes more sense. Thank you for your help.
Unread 14-01-2015, 20:08
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Some helpful links... You can re-find them by searching "PCM" in the FRC Screensteps search bar.
http://wpilib.screenstepslive.com/s/...control-module
This one has some examples, probably the most useful.
http://wpilib.screenstepslive.com/s/...anual-id=13810
Porting guide if you have code from previous cRIO system you want to use.
http://wpilib.screenstepslive.com/s/...e-2014-to-2015
Unread 14-01-2015, 21:23
AKA: Ahad Bawany
no team (None)
In case this up again in the future: CAN programming is only needed if you're running a CAN motor controller. Despite my team beta testing, we haven't used an SRX yet, so I can't help you there. The built in CAN on the roboRIO, PDP, and PRM require no special programming. They do make wiring a lot simpler though!
Unread 19-01-2015, 22:36
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
It really takes very little special programming to run TalonSRX using CAN. Create a CANTalon class object for each and construct your RobotDrive using those.
You will need to use the roboRio's web page to locate each Talon and assign it a unique CAN bus ID (used when constructing the CANTalon object).
