Go to Post For every hour you spend screwing pieces of your robot together, 20 hours of important stuff goes on behind your back. - Eric Bareiss [more]
Unread 14-01-2015, 19:36
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: 8 wheel Kilough
Originally Posted by Nate Laverdure View Post
I have some recent experience
[/b]Each wheel needs to be individually powered and controlled. You can't couple any of the wheels together and still retain holonomic motion.
If the wheels which are powered together drive in the same direction along the same line, you should still have holonomic motion - with the understanding that by virtue of the chain or timing belt, the two (or more) wheels are not independent degrees of freedom, but are effectively the same actuator. I say should because I have not actually tried this yet. I would like to play with a 6-wheel kiwi; it might be a decent platform for a hexagonal or circular 'bot.
