Go to Post Our behavior – both good and bad – is contagious. Set a good example, behave in a mature, reasoned, professional manner and we will find that others around us will too. - dlavery [more]
Unread 14-01-2015, 15:14
anthonygraff24 anthonygraff24 is offline
FRC #2872 (CyberCats)
anthonygraff24 is an unknown quantity at this point
Need help creating a winch and pulley system to pull a component up the robot
We are planning to use a winch and pulley system to pull a component up our robot. We have a pulley and some cable and we're trying to figure out how to make a small winch. We're not sure what to use as a "Spool" for the winch. We've thought of using a pneumatic wheel without the tire or the plastic mounting things used for the robot wheels. Are there any other good ideas of things to use as a spool for this purpose? Any ideas/pictures would be appreciated.
Unread 14-01-2015, 15:22
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Re: Need help creating a winch and pulley system to pull a component up the robot
How about an actual spool?
You can use a left over 3d filament spool, old fishing rod parts, wire spool, auto winch parts from the junk yard, plumbing parts. I have even seen lathed down wooden 4x4..
So many spools and spool simulants
Try the hardware store, they might have something they can donate
Now when you get a spool the trick is .... interfacing it with your motor/transmission.
Good luck this season.
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 14-01-2015, 15:27
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
This is the spool we used last year to pull down our catapult. It mounts on a 1/2" hex shaft. We printed it solid on our Makerbot 2x, and it worked perfectly the entire season!. Just print the two sides, stick them together, put the guide around the whole thing, and slide the shaft in. Use a bolt (I think it was a 10-32) through the provided hole to go through a looped end of a 1" wide nylon strap.
http://www.thingiverse.com/thing:254530
Obviously, it can probably be modified/adjusted based on your desired use!. We used a vex pro ball shifter with the optional third stage reduction and a single CIM motor to power it, mounting this right on our output shaft.
2016: Lake Superior WFFA
Unread 14-01-2015, 17:43
Quazar's Avatar
Quazar Quazar is offline
FRC #4765 (PWR UP)
Quazar is an unknown quantity at this point
We used a wench last year - it was formed by putting two aluminum VersaHubs face-to-face. We drove it using a VersaPlanetary gearbox driven by a BAG motor. It worked very well for us.
Cheers,
- Dean
Unread 14-01-2015, 18:45
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Cheers,
- Dean
We did pretty much the same thing, excecpt we used the old AM hubs and we added a piece of polycarb to extend the diameter of the winch. We drove ours using a ballshifter with a beefed up cylinder.
Unread 14-01-2015, 19:37
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Thirding the use of two hex hubs with polycarb discs (attached to a commercial gearbox). We used Andymark hubs last year because they have a solid flange. We drilled the aluminum flange of both so that we could pass a #10 x ~2" bolt across the gap, through both flanges. We passed the bolt through the sewn loop of some 1" tie-down straps, and then the strap rolled up on top of the bolt (and hubs). We also built a guide for the strap, but it probably isn't necessary. Easy build - did it in one meeting.
Unread 14-01-2015, 19:55
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
One thing to keep in mind is how the radius of the spool affects your other design choices. If you can fit a larger spool on your bot, you can avoid winding difficulties; however, your motor+gearbox and brake will have to handle more torque.
Unread 15-01-2015, 15:20
We just printed this part and we're putting it all together now and it seems like it will work like a charm! Thanks for the help!
Unread 15-01-2015, 18:37
Zyrano Zyrano is offline
AKA: Alvin
FRC #1967
Zyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to behold
Send a message via AIM to Zyrano
In case you don't have a 3d printer... you can make a spool with pvc pipe and end caps, you can match drill the end caps with a hub adapter, and mount it all together.. I kind of miss the days of literally looking for things and making them work....
W.R.R.F. Board member, 2007-??
Mentor, 2007-??, NDSJ Robotics FRC Team 1967
Mentor, 2013-15 Evasive Robotics FTC Team 6223
Supporter, 2006-11, Bulldogs Robotics FRC Team 581
Supporter, 2007-??, Pioneer HS Robotics FRC Team 668
Supporter, 2011-??, Dark Matter FRC Team 2643
Student, 1999- GRT FRC Team 192
