Go to Post Sure, whining is easier than working, but what's more rewarding? - PayneTrain [more]
Unread 09-01-2015, 16:13
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Vision system help
I am currently making some code so the robot can recognize if there is a tote in the camera's field of view.
1. When I create a new axis camera object and set the ip address of the camera to 10.30.19.20, which works In my web browser, but gives a timeout error when connecting it to the Robot RIO. Am I using the wrong camera (axis m1013)? Am I supposed to use a Usb camera?
2. How am I supposed to use the particle filter criteria?
Unread 12-01-2015, 15:20
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
Re: Vision system help
The camera will probably not have a static IP address. If it has at all been configured to work with how control system works this year, it's IP address is dynamically allocated using DHCP. You may wish to assign it a static address.
ORB Haow!
Unread 12-01-2015, 19:21
Head programmer
So it looks like last years part of the library has been outdated or designed for the Crio not the robotRio. I think first wants us to use NIVision.imaq but theres a problem with the native libraries and the lack of documentation.
NIVision.IMAQdxGrab(Robot.session, Robot.RGBImage, 1);
NIVision.imaqSavePattern(Robot.RGBImage, "imagergb.png");
NIVision.imaqColorThreshold(Robot.GREYImage, Robot.RGBImage, 255, NIVision.ColorMode.HSL, RobotMap.HueRange,RobotMap.SaterationRange,RobotMap.ValueRange);
NIVision.imaqFillHoles(Robot.GREYImage,Robot.GREYImage, 4);
GetParticleInfoResult resault = NIVision.imaqGetParticleInfo(Robot.GREYImage, 4, NIVision.ParticleInfoMode.ALL_INFO);
ParticleReport[] array = resault.array;
SmartDashboard.putNumber("NumberOfParticles", array.length);
for (int i = 0; i < array.length; i++) {
        targetFound(array[i], i++);
error given
/usr/local/frc/JRE/bin/java: symbol lookup error: /var/volatile/tmp/libwpilibJavaJNI3257654380311841301.so: undefined symbol: imaqGetParticleInfo
but with the native libraries it seems like its missing the getparticleinfo class with the java wrapper.
Unread 15-01-2015, 02:37
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Originally Posted by Fauge7 View Post
The java wrapper incorrectly provided that function as the wrappers were generated from the header file instead of looking at what symbols are actually in the library. Unfortunately, the nivision library does not implement imaqGetParticleInfo, so you'll need to use a different function (e.g. imaqMeasureParticle).
I've been fixing a lot of bugs recently in the nivision Java wrappers so you'll almost certainly run into bugs using it right now. The next release should be a lot more functional.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 15-01-2015, 15:49
Head programmer
Is there an estimated release date
Unread 15-01-2015, 19:34
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
You can download an early release from the Jenkins build website for the allwpilib repository http://frcjenkins.wpi.edu/job/allwpilib/
Unread 16-01-2015, 00:45
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
That's not going to solve the issue yet, the relevant fixes are currently in code review. I don't want to give you a hard date, but we are hoping for this weekend at the latest.
Unread 03-02-2016, 16:14
ScottRhine ScottRhine is offline
FRC #3840
ScottRhine is an unknown quantity at this point
This may sound like a stupid question, but I just spent days trying to get ni-imaq dlls on my windows box so that the example code doesn't crash trying to do a new Image(). They don't seem to come with the FRC update. The jni can't find _imaqCreateImage. NI refused to answer questions on anything but labview. My suspicion is that the example code can *only* run on the roborio.
can anyone confirm?
