Go to Post OOO-GAH! OOOO-GAH! GRACIOUS PROFESSIONALISM ALERT! - Billfred [more]
Unread 15-01-2015, 05:08
Hoover's Avatar
Hoover Hoover is offline
no team (None)
Hoover is a name known to allHoover is a name known to allHoover is a name known to allHoover is a name known to allHoover is a name known to allHoover is a name known to all
Re: Compressor and No Selenoid
Originally Posted by Team3266Spencer View Post
The PCM is controlled via CAN. So make sure you daisy chained a CAN cable from the rRIO to the PCM and then to the PDP. You can force the compressor to start without a solenoid by creating a compressor in the code and then setting closed loop control to true.
This is the point of confusion. We've never used CAN before and so it isn't in our vocabulary yet. I haven't found a document which clearly shows this wiring. But I have Google'd and found a picture posted by team 385 showing the PCM wiring including the CAN daisy chain. I will wire this tomorrow.
The PCM blinking red is the No CAN Comm. and not a solenoid fault as I had first thought.
From this document I can see the diagram at the top shows where CAN connects. But from the rest of the document they don't really emphasize it in any picture. Has anyone else been confused by this?
https://wpilib.screenstepslive.com/s...he-2015-system
Unread 15-01-2015, 08:51
Look here about halfway down or search for PCM.
It demonstrates the CAN wiring.
https://wpilib.screenstepslive.com/s...control-system
Unread 15-01-2015, 12:15
Hoover's Avatar
no team (None)
This was a much better reference page. Mailed link to myself. Thanks!
