Go to Post There's more than one way to skin a cat. - Al Skierkiewicz [more]
Unread 14-01-2015, 19:00
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
Connect to Shaft of RS 775 Motor
What is the best way to connect to the shaft of an RS775 Motor. We can machine a part just not sure how to mechanically attach to it. Any idea, or examples, or products. We want a direct drive 1:1 so a versa planetary is not ideal unless I am missing something. Thanks
Unread 14-01-2015, 19:02
Re: Connect to Shaft of RS 775 Motor
Originally Posted by amesmich View Post
What is the best way to connect to the shaft of an RS775 Motor ... We want a direct drive 1:1
May I ask what you are intending to direct drive?
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
1:1 is not common as the free speed of these motors is so high.
The most common mechanical connection is a press fit to the motor shaft.
Jim
Unread 14-01-2015, 19:07
either 5700 or 13000, depending on which 775 motor he is referring to.
Unread 14-01-2015, 19:13
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
We used a VersaPlanetary in a 1:1 configuration for Aerial Assist. You can buy a 1:1 base kit and use it as is, just assemble and go. The input gear meshes just fine with the output shaft. You can choose different output shafts too, depending on what your use is.
I'm right 90% of the time, so why worry about the other 3%?
Unread 14-01-2015, 19:28
amesmich's Avatar
FRC #4638 (Jagbots)
Lead Screw
Looking at the 18v did the calcs we will use two of these on 8tpi lead screws. Got the torque and speed figured out even with voltage drop. Now we just need to figure out how to couple the lead screw to the motor. We will can up a coupler once we know how to effectively attach it. Found this online and if you click on the model numbers you get a real cool interactive torque, voltage, rpm, efficiency calculator.
Obviously the free speed will not be th eloaded speed. We plan to load the motor with about 30 - 40 oz/inch of torque.
Unread 14-01-2015, 19:38
Found this online
What does the pronoun "this" refer to?
Was there supposed to be a link?
Unread 14-01-2015, 19:52
amesmich's Avatar
FRC #4638 (Jagbots)
Sorry got sidetracked and forgot the link
http://www.mabuchi-motor.co.jp/cgi-b..._ID=rs_775vcwc
Unread 14-01-2015, 21:39
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Banebots sells 10tooth pinion gears to use with RS775 motors. Other gears with a press fit for a 5mm shaft should also work (or you could bore it yourself).
http://banebots.com/p/S24P-GMC1-50
Unread 14-01-2015, 22:03
droswell's Avatar
droswell droswell is offline
FRC #2370 (iBots)
droswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to behold
I might be confused, but it sounds like you're attaching the motor directly to a lead screw?
If this is the case, I would reconsider. Running most lead screws at > 1000 rpm is probably not a good idea. Even fine threaded screws will move extremely rapidly at this speed, if they have enough torque to even turn the screw. This is the perfect case for using a gearbox, such as a VersaPlanetary from VEX or a P60 from Banebots.
Unread 14-01-2015, 22:15
Jared's Avatar
Jared Jared is offline
Check out this document for some lead screw calculations/guidelines:
http://www.thomsonbsa.com/pdf/bsa_en...og_section.pdf
Unread 14-01-2015, 23:44
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
For Ultimate Ascent we attached a lead screw to a Versaplanetary with the 1/2" socket from this set (since we had 1/2" output shaft VPs) http://www.harborfreight.com/7-pc-38...set-67929.html because we needed the swivel aspect.
We used a nominal 3/8" lead screw drilled and tapped it to put a bolt through the pin retainer hole and then drilled through the socket and VP output shaft for a cotter pin to retain the socket to the output shaft. We did choose to turn the end of the VP output shaft so that it would extend into the round hole in the socket because we did not feel the shallow depth of that socket didn't have sufficient room for the cotter pin.
If you do not need a swivel head to NAPA and get a single 1/2" impact socket in either 3/8" or 1/2" drive depending on the lead screw you are using.
As others have mentioned you can use a VP as a 1 to 1 but I think you'll find that a little fast. But you can always try it and if it is deemed too fast put a reduction stage in.
Unread 15-01-2015, 06:52
amesmich's Avatar
FRC #4638 (Jagbots)
Thanks for all the feedback. It does not fall on deaf ears. The speed is a good point. We are considering a gearbox but needed to plan for any possibility.
Thanks
Unread 15-01-2015, 08:45
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I use the green bearing retainer Loctite with a tite slip fit. Getting the press fit just right & bending the motor shaft is right next to each other.
When you say voltage drop do you mean your adjusting the 18 volt curves for the 12 V available?
Unread 15-01-2015, 20:56
amesmich's Avatar
FRC #4638 (Jagbots)
We readjusted for the 12v and then accounted for a non-ideal power source. So voltage drop of battery under load or after some time. Not a big factor for us but not forgotten either.
