Go to Post With computers, every once in a while you see something that makes you think "I could have done this, why didn't I think of it? It would have made my life so much easier." Now is one of those times. - Nadav Zingerman [more]
Unread 15-01-2015, 08:45
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Connect to Shaft of RS 775 Motor
I use the green bearing retainer Loctite with a tite slip fit. Getting the press fit just right & bending the motor shaft is right next to each other.
When you say voltage drop do you mean your adjusting the 18 volt curves for the 12 V available?
Unread 15-01-2015, 20:56
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
We readjusted for the 12v and then accounted for a non-ideal power source. So voltage drop of battery under load or after some time. Not a big factor for us but not forgotten either.
