Go to Post Well I have to admit, most of the people on our team are geeks. I think that it's a title of honor considering it might as well be "boss" or "head supervisor" or something along those lines. - Cyberguy34000 [more]
Unread 15-01-2015, 02:11
Omena Mushale's Avatar
Omena Mushale Omena Mushale is offline
Head of Media
FRC #0701 (RoboVikes)
Team Role: Webmaster
Omena Mushale is an unknown quantity at this point
pic: 2015 Prototype Electrical Board
Unread 15-01-2015, 02:12
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: pic: 2015 Prototype Electrical Board
What's the reason for the PowerPoles on the input side of the speed controllers when they're right at the PDP already, and why do you have terminals on the CAN wires?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 15-01-2015, 02:21
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
It makes it much easier to quickly replace motor controllers if necessary.
Unread 15-01-2015, 02:46
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Maybe, but the wago connector's are very fast as well.
And Anderson Power Poles are $$$.
Seems like an unnecessary waste of money to stick any sort of crimp on the PDP side of the new Talons and Victors (as long as you can package the speed controllers close to the PDP)
Kudos for getting a test-bed up and running quickly! Always a good idea!
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 15-01-2015, 08:00
tech2077 tech2077 is offline
AKA: Matthew Skolaut
FRC #3847 (Spectrum 3847)
tech2077 is an unknown quantity at this point
-Mike
From what I've seen with the new Talons, the high strand count wire fatigues and strands begin to break at the pinch point inside the wago connector (though to what extent will be told by the season), and with the new Talon wire not being replaceable, the crimps work well for quick replacement and long term reusability. With previous years it wouldn't have made sense to do so though due to terminals being present on the speed controllers.
Unread 15-01-2015, 09:21
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Beta teams reported that tinning the ends of the wires with solder helped with this issue.
Unread 15-01-2015, 09:49
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
I'll do a +1 for the Anderson's on both ends.
1) All controllers become interchangeable.
2) The Roborio and the PDU gets tucked away to keep them from being damaged. The little pig tails make it easy to swap out controllers without trying to climb into the middle of the robot. It also allow for late season "Well this has to go there so that PDU needs to move"
Or the phrase "that controller is in the way, it needs to move". It's just then an issue of making a new extension.
3) You can design/build a switch that you can quickly plug in place of the controller to test without working robot code.
4) Assembly from Transport / Play configuration. Elements can now have the controller with them or not. It's a quick plug the power pole moment to give you lots of flexibility.
The only thing I would have done is use green/white connectors on the end so that the motors didn't accidentally get plugged into the 12v supply. Or that the 12v power does not get plugged into the wrong end of the controller. (Never underestimate the ability of a rookie roboteer)
I get the cost part, since 100 connectors / covers / roll pins will set you back almost $75. On the other hand if it saves you 30 mins of bag open time it's well worth it.
Nice job! Having an electrical test bed in Week Two is a great thing to have.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 15-01-2015, 10:15
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Correct me if I am wrong, but it was my understanding that inserting tinned wires into the WAGO connectors on the PDB was not recommended.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 15-01-2015, 10:57
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
-Mike
Thanks Mike! This is our first of 3 electrical boards and modularity for the components is what we need now. We need our first drive chassis up and running this weekend for some testing. If all goes well they will be transferred to more refined chassis the next week, then the competition chassis and bellypan the following week. We have another untouched set of talons/electronics for the competition bot.
Cost of an anderson powerpole is ~ $1. Cost of students learning how to be competent at crimping and wiring ~ Priceless!!
Unread 15-01-2015, 17:47
Team Role: CAD
Where do you buy powerpoles at $75/100 pairs?
Unread 15-01-2015, 18:02
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
The best I've found is http://www.powerwerx.com/anderson-po...owerpole-sets/
30A bonded goes for ~$70/100
30A unbonded goes for ~$86/100
45A goes is a bit over and 15A is a bit under.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 15-01-2015, 18:23
Yep, Powerwerx is your best bet. I've been buying from them for years. Plus they have all those pretty colors.
Its well worth the investment in a good crimper.
