Thread Tools |
Rating:
Display Modes |
Re: PID programming help
While you are waiting for responses, here are some links where you might find useful information: https://www.google.com/?gws_rd=ssl#q....com+%22PID%22 http://www.ni.com/white-paper/3782/en/ http://www.chiefdelphi.com/forums/sh...45&postcount=6 http://brettbeauregard.com/blog/2011...-introduction/ https://decibel.ni.com/content/servl...20Tutorial.pdf http://www.controlguru.com/pages/table.html http://www.inpharmix.com/jps/PID_Con...ms_Robots.html http://www.chiefdelphi.com/forums/sh...2&postcount=12 http://brettbeauregard.com/blog/2011...-introduction/ http://www.education.rec.ri.cmu.edu/...edmovement.pdf If you would give some details about what you are seeking to control with PID you will likely get more targeted answers here. For example, you mentioned the gyro. Are you trying to do field-centric control? Or are you trying the correct for drivetrain anomalies to make the bot travel in a straight line? etc. Last edited by Ether : 15-01-2015 at 10:18. |
Ether, thank you for all links. We will review the ones that we haven’t looked at yet.
The best application would be very close to your example of correcting a drivetrain to travel in a straight line but we can not have the PID directly feed the device hence the reason we just what the value from the PID. We have yet to find a way to just retrieve the PID correction value. From a pure teaching point of view, it would be nice to see what the result would be with given input values. |
Given the very nature of the design "device" It would take a novel to explain.
To Ether and Ross,
Thank you for the links and information, it helped up to a point but we have found, like many others that our single very precious resource was being used up at an alarming rate. So we have chalk this one up to; yes failure is an option but lets learn from it and move forward. Perhaps after regional’s we might re-visit the task but a “101 Programming a PID function with examples” would sure help. Just in case, the “precious resource” is TIME. Five weeks is just to short. We lose a week for exams ![]() Post #12 http://www.chiefdelphi.com/forums/sh...hreadid=133100 also has a very nice to help understand what a PID does. Last edited by Tem1514 Mentor : 18-01-2015 at 10:33. Reason: more info found |
Look at the crab speed class in our code from last year. I think it does what you are looking for. Crates a generic class that he PIDController will write to that you can get with something else.
https://github.com/FRCTeam16/TMW2014 |
#7
