Go to Post Good drivers know the limits of their machines, but great drivers have machines with no limits. - sanddrag [more]
Unread 15-01-2015, 09:31
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Bit Buckets 2015 Prototype Drive Pod
Neat drive module. I like the single reduction, very simple. What sort of fasteners are you using to tie everything together?
Originally Posted by orangemoore View Post
Well, that is assuming no one else has access to a laser cutter.
Cough Cough
Originally Posted by z_beeblebrox View Post
Our off-season chassis took about 4 hours of laser time, including setup. This module took 9 minutes.
It's a pretty neat tool to have; we can make 2D parts faster than literally any other team.
Edit: At least as fast as any other team.
Does a 4'x8' CNC plasma cutter count? Each of these parts took 4-5 minutes of cut time (1/4in 6061 T6), and that long cut time is due to the dozens of pierces for the lightening pattern.
http://i.imgur.com/QCryxlE.jpg
https://www.youtube.com/watch?v=2HHVwJ_C31M
The side-panels took less than 2 min each to cut from 0.032 5052 Al.
http://i.imgur.com/gU6AhRa.jpg
Or a 4'x4' CNC router? All of these parts together took about 17min of cut time, most of which was in the pocketing.
http://i.imgur.com/FgtZxiL.jpg
Unread 15-01-2015, 10:42
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Exactly what wood are you burning with your laser. I say exactly because I have access to a 160 watt laser and have tried cutting 1/4 Baltic birch and if it will cut depends on where I get it.
Some cuts real nice and some will only seem to cut to the glue line then just starts burning. So, if you have any details on what you are using it would be appreciated.
Thanks
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 15-01-2015, 10:47
AdamHeard's Avatar
Lead Mentor
We're using Killough drive, so robot speed is 1/sqrt(2) wheel speed. We also like the simplicity of a single reduction gearbox.
I'm not certain; I think 60 or 75 W.
I think a killough actually has a root2 speed up.
Unread 15-01-2015, 12:14
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
I hadn't put much thought into it, but I believe you are correct. Those modules will probably need another reduction stage.
Unread 15-01-2015, 13:20
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
Thanks
Some plywoods have glues or fillers that don't cut well, which would explain it. 160W is otherwise overkill for 1/4" plywood.
Unread 15-01-2015, 13:40
Bruceb's Avatar
Yes it will cut an inch of pine but not some plywoods.
Unread 15-01-2015, 14:06
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Likely true. I'll look into it today.
.25" 5-ply Baltic Birch plyood from Woodworkers Source.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 15-01-2015, 23:27
Custom User Title
AKA: Cal
Version 2, ready to be cut tomorrow. Two stages of reduction, for an adjusted robot speed of ~10 fps. Adding a reduction stage only made it ~.25" longer and wider.
Our mostly complete chassis. This will also (hopefully) be cut out tomorrow.
Unread 15-01-2015, 23:44
BHS_STopping's Avatar
BHS_STopping BHS_STopping is offline
The Freshman
BHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant future
I'm just taking the conservation of energy route.
Assume constant power output P. P = force * velocity (dot product used here). Since the force of the wheel along the direction of motion is effectively reduced by a factor of 1/sqrt(2), the velocity must increase by a factor of sqrt(2) to maintain that power output.
[/The Freshman]
Unread 16-01-2015, 01:36
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
What settings does your team use for the cut? I just realized we have a 60W 30x15 laser cutter sitting in the other room at school.
(2015-?): 973
(2012-2015): 955
Unread 16-01-2015, 08:44
Custom User Title
AKA: Cal
I'm not sure; the settings for our laser aren't "real" units like Watts or Inches/ second. I'd suggest you just try different settings until you find something that works. But do try it; the laser is an amazing resource to have available.
Unread 16-01-2015, 08:55
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Most laser cutters are different. If you want know the setting you can figure them out. But a good starting point is the internet and research into the laser cutter you have.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 16-01-2015, 11:38
Pumped
AKA: Ryan
Definitely, I wasn't trying to just copy paste settings. That rarely works in my experience. I was curious about the speeds you're able to go. Although if the laser doesn't use real units that's disapointing .
(2015-?): 973
(2012-2015): 955
