Go to Post Kids should already be motivated to build the best robot they can, and learn as much as they can. They shouldn't need extra incentives. - Matt382 [more]
Unread 13-01-2015, 19:45
H$H4RK H$H4RK is offline
FRC #4103
H$H4RK is an unknown quantity at this point
Question How to display Microsoft webcam on frc driver station camera view
Hello, I am new to FRC and i am wondering how do i display image feed from a microsoft HD webcam plugged in into the usb port on roboRio to the camera view option on FRC driver station.
Unread 13-01-2015, 19:48
Re: How to display Microsoft webcam on frc driver station camera view
What language are you programming in?
Unread 13-01-2015, 20:05
SquishyIce's Avatar
SquishyIce SquishyIce is offline
FRC #1405 (Finney Falcons)
Team Role: Electrical
SquishyIce can only hope to improve
/http://www.chiefdelphi.com/forums/showthread.php?t=132714
My reply on this thread turned out to not be as relevant as I thought towards OP's question, but maybe it can help you. DISCLAIMER: This is java-specific. You might want to specify what language you're coding in.
"MAKE IT WORK, DAVID"
Unread 14-01-2015, 20:20
FRC #4103
I found a solution at http://www.chiefdelphi.com/forums/showthread.php?t=132686 turns out there is no need to code if you are using the default dashboard to display the camera view
Unread 14-01-2015, 23:00
Correct, if you are using LabVIEW.
Unread 15-01-2015, 10:47
FRC #4103
One more question: do the Microsoft USB camera take less bandwidth than the axis cameras?
Unread 15-01-2015, 18:49
FRC #4103
Question Re: How to display Microsoft webcam on frc driver station camera view
Hello guys, i just tested the instruction above on the robot, the camera was on but no images appeared on the FRC control panel. How do I solve that problem?
Unread 15-01-2015, 18:56
FRC #4103
PS: the blue light on the Microsoft HD Camera 3000 flashes twice but turns off after that.
Unread 18-01-2015, 09:13
Was the camera plugged in when you booted the roboRIO? If not, I would try that. And make sure you have selected USB HW or USB SW on the dashboard.
