Go to Post "The devil" isn't in the details... The devil is having a loud house party with lots of other devils and demons in the details. And laughing, and laughing... - pfreivald [more]
Unread 15-01-2015, 13:12
swodaem's Avatar
swodaem swodaem is offline
FRC #2197 (Las Pumas)
Team Role: Photography
swodaem is an unknown quantity at this point
Launchpad issue?
So, we are trying to figure out what to do to get this Launchpad F5529 working, and i have no idea. I followed the documentation, but i can't seem to find out where to hook my button up to on the Launchpad, so when i enable the driver station i get an indicator on the joystick panel in the DS showing i am pressing a button.
Las Pumas 2197
Steps to a Successful Program
1. Load labview software
2. Try to build program
3. Fail to save program on cRIO
4. Look on internet for help
5. Throw chair
6. Drop computer out window
7. Hate life
8. Want to strangle your mentor
-seathroath
Unread 15-01-2015, 13:29
Re: Launchpad issue?
http://processors.wiki.ti.com/index....cs_Competition
Unread 15-01-2015, 13:38
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Originally Posted by Alan Anderson View Post
That link is a good resource, but is designed around the Stellaris/Tiva C LaunchPad instead of the MSP430 included in the kit. Please use the following link for the MSP430F5529 LaunchPad in this year's kit of parts:
After you program the device, if you look at the pinout options, you need to connect one of the blue Digital Buttons to the 3.3V pin for the driverstation indicator to turn 'On', and connect it to the GND pin to turn it 'Off'. The schematic in the documentation shows how you should connect your button in this case.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 15-01-2015, 15:26
swodaem's Avatar
Thank you Alan! You always reply first to my posts haha. Also, i have looked at
http://processors.wiki.ti.com/index....cs_Competition but it doesn't show a backview of the Launchpad, and its hard for me to picture how the buttons hook up. I also have hooked up the 3.3v and GND, but when i ran my driver station nothing shows up as being pressed.
Las Pumas 2197
5. Throw chair
7. Hate life
-seathroath
Unread 15-01-2015, 15:43
swodaem's Avatar
So i was looking at all of the pictures of the examples on that link, and something just popped to mind. Am i supposed to connect my buttons via a ribbon cable to the pins on the top of the board?
Las Pumas 2197
5. Throw chair
7. Hate life
-seathroath
Unread 15-01-2015, 16:09
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
Swodaem, we used the ribbon cables in the examples, but you dont have to. They provided an easy way to breakout all the signals to solderable connections, and hold really well to the LaunchPad pin headers.
I've also had success using header wires like these: http://www.amazon.com/Jumper-Wires-P...s=header+wires
You just chop off one end and its easy to solder to your switches.
Or, you can desolder the headers that are on there, and solder straight to the board. The connection and buttons are all to you. All the LaunchPad cares about is getting the 3.3V signal.
Unread 15-01-2015, 16:43
swodaem's Avatar
Sweet! Hopefully it will work!
Las Pumas 2197
5. Throw chair
7. Hate life
-seathroath
