Go to Post Just because you haven't witnessed parts leaving the flywheel yet, doesn't mean it won't happen. - Al Skierkiewicz [more]
Unread 15-01-2015, 11:02
mitchklong mitchklong is offline
None #4859
mitchklong is an unknown quantity at this point
How far does the tote drop out of feeder station?
Due to design constraints our bot cant easily grab an object closer then 3" to the wall.
Can anyone who might have a mockup of the feeder station tell me how far the tote typically drops from the wall ?
Unread 15-01-2015, 11:08
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: How far does the tote drop out of feeder station?
Given that a tote is 17" wide and 27" long, how does not grabbing something 3" from the wall constrain you from grabbing a tote?
Academic Student (Forever)
Unread 15-01-2015, 11:13
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
My guess would be that they are grabbing from the long end and their gripper won't fit around the tote if it is closer than 3" to the wall.
Unread 15-01-2015, 11:16
Professional Stat Padder
Totes seem to drop differently every time they come out of the feeder station, and often in different orientations.
The community here might be able to help more if you gave a few more specifics about your mechanism, maybe pictures or CAD renderings.
(2015-Present)
Unread 15-01-2015, 11:20
earlybird's Avatar
earlybird earlybird is offline
They tried to ship me 2 competition
AKA: Robbie Oehrli
FRC #2849 (Team Ursa Major)
earlybird is a jewel in the roughearlybird is a jewel in the roughearlybird is a jewel in the rough
It looks like you shouldn't have too much of a problem looking at one of the Robot in 3 days videos. I don't know what material they used for the chute though, it might make a difference because of the coefficient of friction difference between plywood and the HDPE.
Robbie Oehrli
University of Maryland Baltimore County
B.S. Mechanical Engineering 14'
Maryland FLL Head Referee
Team 2849 Founding Member
Team 2849 Mentor
Unread 15-01-2015, 11:21
None #4859
If you looked down from about the bot is shaped like a U with totes going into the u.
The depth of the U is what we are considering. a 30" depth makes it quite stable but if we try to stack a tote touching the wall the stack is out of alignment.
If the totes fall 3" from the wall I dont think its an issue.
Do they ?
Unread 15-01-2015, 11:35
Do they ?
I would encourage you to adapt your design to the unpredictability of totes falling from the tote chute, as they vary quite a bit.
If this does turn out to be a problem for you, there are some relatively simple solutions available.
The "Passive Hook" Mechanism from Build Blitz (found here: http://www.buildblitz.com/what-is-th...o-move-a-tote/) is an easy way to pull a tote along the ground away from the wall if this becomes a problem, or to pluck totes from the landfill to grab instead.
If you really want to get some data on how totes fall, or see how your robot interacts with the game elements, it's not difficult to build a feeder station out of plywood from resources provided by FIRST (here: https://rps01.usfirst.org/frc/manual..._Versions.pdf), and put down some carpet and test yourself.
(2015-Present)
Unread 15-01-2015, 11:38
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Also consider what type of flooring the tote is dropping on. We've noticed a lot of difference in dropping the totes on a carpeted vs. shop (concrete) floor.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 15-01-2015, 12:25
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
These statements are interesting to me; in our tests, the totes come out exactly the same way every single time.
We are testing on carpet floor, with a slick chute surface similar to HDPE.
We have noticed that there is a tendency for the tote to do a nose-dive when exiting the chute and stand on end when on carpet. On a tile floor, the tote slides to a horizontal orientation.
Hi!
Unread 15-01-2015, 13:21
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Every single one of our tote-drops through the wooden setup onto an official FRC carpet have ended nose-down. If you look at some of the field videos from kickoff, some people do a tote drop and it does the same thing.
Unread 15-01-2015, 13:36
Hallry's Avatar
Hallry Hallry is online now
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Totes landing nose-down on official field: https://www.youtube.com/watch?v=Y1-3u9NEeO4#t=58
Unread 15-01-2015, 13:45
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Same thing here. It always lands nose down. We use HDPE in our chute with a polycarb door. I think our carpet is the same as the official ones this year (its from 2012 or 2013 vendor but I have to double check that)
3309 confirmed the same thing with their 2013 spec carpet.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
We played around with the official field and that was how they came out every time.
1058 PVC Pirates 2016 - xxxx
Unread 15-01-2015, 14:06
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
Has anyone tried putting them in upside down? I haven't seen any videos of it, and I haven't been able to build a chute yet.
Unread 15-01-2015, 14:22
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
That's because they do not fit in the chute upside down.
