Go to Post This year may be one of the first years where there is a drastic difference in Regional level and Championship level strategies that drive robot design. - tim-tim [more]
Unread 14-01-2015, 20:45
Alchemy99's Avatar
Alchemy99 Alchemy99 is offline
AKA: Josh Cote
FRC #3141 (Team Alchemy)
Alchemy99 is an unknown quantity at this point
Send a message via AIM to Alchemy99 Send a message via Yahoo to Alchemy99
Watchdog mecanum 2015
error 44061.
We are trying the initial code from WPI, didnt change anything. and the DriverStation is reporting "4 motors in the vi path robot main...."
we changed nothing. we do not have the camera pluged in.
Unread 15-01-2015, 09:48
Re: Watchdog mecanum 2015
Is the -44061 message showing up only once, or is it displayed repeatedly? The usual meaning is that your drive motors aren't being commanded by the code at least ten times per second. Might you have selected Autonomous or Practice mode instead of Teleop?
Unread 15-01-2015, 10:20
Alchemy99's Avatar
AKA: Josh Cote
the error pops up in teleop. it happens when we change the "z" axis, than return it to zero. It has came up repeatedly, but not concurrently. it pops up when we let everything go back to normal, than we drive a little and stop again and it errors again.
we are using the original attack 3 joysticks, with the throttle as the z axis until we get the new 3d joysticks.
how would we feed the watchdog if we are letting the robot sit?
Unread 15-01-2015, 10:39
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Just keep feeding values of "0.00" into the RobotDrive VI.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 15-01-2015, 13:54
Alchemy99's Avatar
AKA: Josh Cote
Wouldn't the default code do that? It reads the joystick position and gives it to the drive.
Unread 15-01-2015, 13:56
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
It should do that, yes.
Does your code ever stop reading the joystick values, for some reason?
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 15-01-2015, 14:15
Alchemy99's Avatar
AKA: Josh Cote
no, we changed nothing in the code.
Unread 15-01-2015, 19:06
Alchemy99's Avatar
AKA: Josh Cote
Thanks everyone. The problem was not havin a camera.
