Thread Tools |
Rating:
Display Modes |
Re: CAN Jaguar Firmware Update Problems
Hopefully we can recreate the first result, though the last time, when it froze in the command-line version, it locked up the cmd window and wouldn't respond to ctrl-c, killall, or taskmanager force quits. Fingers crossed I guess. Quote:
Sorry for the confusion, and thanks for the correction Joe. |
Ok excellent, we will try tonight after verifying there are no problems with our cables or the contacts on the jags.
Does this Recover Firmware flash the new firmware to it as well, or will we have to retry Update Firmware after they are recovered? Thanks for the help! |
It will load the firmware as normal, (hopefully) making it usable again. Are you using a USB to serial adapter? (If you have access to one) try using a computer with a native serial port on it. I have heard reports of some adapters working fine for everything but the update process. (For reference, I have been using a Keyspan USA-19HS for years without problems.)
We are using a USB-serial adapter. If the problems persist we'll give it a go on one of the school's desktops with native serial. Thanks for the tip.
