Go to Post The major items of FIRST are still what they always were.....understand the game, build a reliable quality machine to play it, train you drivers to use it to its full potential. If you do these things, you can win with or without any specific machine feature. - Jim Zondag [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 15-01-2015, 15:02
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: CAN Jaguar Firmware Update Problems
Originally Posted by Joe Wilson View Post
We have to resort to the command line version once the jag light starts refusing to turn on. The GUI version assumes there is no jag connected and won't let you update, whereas the command-line version lets you force it to try to update, which worked for the first one.
This is because the Jaguar has gone into recovery mode. When there is no light on the Jaguar anymore, yet it is being powered, select (IIRC) Recover Firmware instead of Update Firmware. It should still be under the File menu. Make sure it is the only Jaguar connected when using this method, and it should recover itself.
I'm right 90% of the time, so why worry about the other 3%?
