Go to Post Not winning is different than being a loser. - seanwitte [more]
Unread 06-01-2015, 10:18
u2fletch u2fletch is offline
FRC #4610 (BearTecs)
u2fletch is an unknown quantity at this point
FRCSim Mecanum Drive example help
Installed FRCSim on my Ubuntu system last night in an effort to get an example of Mecanum drive up and running to show our programming team today.
Was able to run the Gearsbot sample code, (although my gamepad mapping was not correct, can fix that) but was wondering if anyone else has gotten the simple drive examples to run. All the code that I think is the bare minimum to run looks like it is there in the code examples, but I cannot get the simulated bot to respond.
Really would like to give my new programmers something to work with this week.
Unread 06-01-2015, 16:10
Re: FRCSim Mecanum Drive example help
Okay, so broke down and used RobotBuilder to build a sample robot. 4 motor config with a single Sidewinder3D joystick. Here is the code for the Drivetrain class:
public void takeJoyStickInput(Joystick joy){
robotDrive41.mecanumDrive_Cartesian(joy.getRawAxis (1),joy.getRawAxis(2),joy.getRawAxis(0),0);
Needed to use the getRawAxis() function to map the axes properly on the Sidewinder, but the problem is that the FRCSim robot drives just like tankdrive. Fore-aft joystick moves as expected, twist rotates the robot, but left-right joystick just gives you forward and back just like the fore-aft.
The RobotBuilder says it supports holonomic drive under the 4 motor controller, so I am wondering if FRCSim does NOT model that type of drive?
Unread 06-01-2015, 16:20
That's correct. Both the gearsbot and pacgoat models are tank drive.
Unread 06-01-2015, 19:50
Good news is that the programming students were very excited about being able to test their code from RobotBuilder in the sim. You can't go sideways, but the rest of the simulation works well.
Unread 12-01-2015, 09:18
Cinnamon Toast's Avatar
Cinnamon Toast Cinnamon Toast is offline
FRC #3641 (The Flying Toasters)
Cinnamon Toast is an unknown quantity at this point
Hi Guys,
This seems to be a good place to put my questions. I noticed that u2fletch in his code for mecanum_cartisian used 0 for the 4th argument of the robot drive object. From my understanding (and please correct me if I'm wrong) I believe a gyro is used so that you get field centric strafing when driving. This means that when no matter what your rotation, the robot will still straif to left (therefore the robot itself is moving backwards) right? Say I don't want field centric movement like this, and would like robot centric drive. Does that 0 value make the drive robot centric? Any help is really appreciated. Thanks guys!
Unread 15-01-2015, 15:32
jman1783 jman1783 is offline
FRC #2900 (Mighty Penguins)
jman1783 is an unknown quantity at this point
I was able to switch the controls at some point between Tank and Arcade drive. I forgot how I did it, though Let me dig up my code and see what I changed - I know I modified it to work with the Logitech joystick with a yaw axis.
OSRF has not yet attempted modeling a mecanum drive setup for an FRC robot, but we're excited that teams are trying things like this. If you pull it off, and it continues to run in real-time, let us know! This would be great to share with the community.
"Just remember - whether you think you can or you think you can't, you're right." -Stewart Gilligan Griffin
Unread 15-01-2015, 15:35
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Originally Posted by Cinnamon Toast View Post
Hi Guys,
Yes, including the 0 in the mecanumDrive_Cartesian object causes the robot to always think it is facing away from the driver, effectively creating robot-centric drive.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
