Go to Post There is no such thing as reading too much into things. Such ideas are blasphemous in nature! - Guppy294 [more]
  #31   Spotlight this post!
Unread 15-01-2015, 14:04
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
Re: Stacking vs Capping vs ???
Looking at this from an eliminations standpoint, only two robots should need the feeder station at any given time with maybe one overlap. If you have one robot stacking stacks of three or four on the ramp, one robot collecting recycle containers and placing them on the three high stacks, and one robot stacking a three high with a container onto another three high. Your quickest stacker does the stacks of three, your best manipulator does the final stacking, and the last robot does as many containers as you can. Three unique roles. Although they are lifting just the same for the totes, it is different enough to that at any median level regional atleast two of the roles wouldn't be interchangable, of course this would change at champs, but for the most part there are three independent roles, and that's with ignoring the noodles.
  #32   Spotlight this post!
Unread 15-01-2015, 14:11
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
One thing that makes this game interesting is that you are going to have to approach the game a little differently each match, depending on the capabilities of your allies. The real trick is for alliances to figure out how to maximize points and not overlapping abilities.
It will be important to figure out which robot/s can quickly stack totes and bins at the feeder station so that the third can claim the recycling containers on the step. Or, better, if a single robot is able to make three stacks at the feeder station (with recycling containers, of course!), it would make sense to send both of the other two to the step immediately - even if they are able to, as individual bots, stack more quickly from the feeder.
How many points should the alliance try to score during autonomous? It might be worthwhile for an alliance to forfeit some autonomous points so as to get a jump on the recycling bins on the step... This might depend not just on your alliance, but on the capabilities of the opposing alliance..
Is the other alliance capable of participating in coopertition? If so, will it be worth the effort to do it? Etc.
I just see so many variables that I do not believe that any full strategy can be worked out before truly sitting down and assessing the capabilities of all the robots on the field... I also think we will see a lot of math being done as robots are waiting in line to get onto the field...
  #33   Spotlight this post!
Unread 15-01-2015, 14:56
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is online now
FRC #4536 (MinuteBots)
Originally Posted by wesbass23 View Post
However if there is 5 seconds left in the match and you have no chance of getting in a noodle in a bin, by all means get the noodle on the other side of the field or get it in the landfill.
How are you going to get a litter onto the other side of the field or into the landfill with 5 seconds left in the match?
  #34   Spotlight this post!
Unread 15-01-2015, 14:58
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Throw it over the alliance wall.
  #35   Spotlight this post!
Unread 15-01-2015, 15:07
Kevin Sheridan's Avatar
Kevin Sheridan Kevin Sheridan is offline
Kevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond repute
G33
LITTER may be introduced onto the FIELD only during TELEOP and only in the following ways:
A. through the LITTER CHUTE, or
B. over the ALLIANCE WALL prior to the last twenty (20) seconds of the MATCH.
VIOLATION: FOUL per LITTER.
  #36   Spotlight this post!
Unread 15-01-2015, 15:20
Flywheel Police
Originally Posted by Kevin Sheridan View Post
G33
Good point. I forgot about the last 20 seconds.
  #37   Spotlight this post!
Unread 15-01-2015, 15:23
wesbass23 wesbass23 is offline
FRC #1732 (Hilltopper Robotics)
wesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud of
As did I xD
However getting a piece of litter into the landfill with 5 seconds remaining is slightly more legal.
2014 Wisconsin Regional Winners with 2481 and 2202
2014 Midwest Regional Finalists with 2338 and 3936
2014 Midwest RCA Winner
2013 Wisconsin Regional Winner with 111 and 2338
2013 MARC Winners with 1718 and 1023
2012 Boilermaker RCA Winner
  #38   Spotlight this post!
Unread 15-01-2015, 16:04
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
I believe that the strongest alliances will have two robots that can stack 6 totes tall. Of those two, one will get totes from the feeder station while the other collects from the field. The third robot will get as many recycling bins from the center as it can, fill them with litter, and then top off the already made stacks.
  #39   Spotlight this post!
Unread 15-01-2015, 18:37
BethMo BethMo is offline
FRC #0948 (NRG (Newport Robotics Group))
BethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to behold
The top of a stack of 6 totes on the scoring platform is just over 6'2" off the floor. The top of the manipulator is only allowed to reach 6'6" tall. Do you really think that we'll see robots that can securely grip a recycling bin using no more than the bottom 3" of it and then put it on top of these stacks without tipping?
It's physically possible, but seems unlikely to me, and the failure modes are bad. I think bottom-stacking* is the only way we're likely to see max height stacks with bins on top.
*EDIT: or stacking a stack-with-bin on top of a stack-without-bin.
  #40   Spotlight this post!
Unread 15-01-2015, 19:30
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
I'm pretty sure at this point that making it into eliminations will be done independent of alliance partners. The robots that have the highest average score (the "winners") will be those that can score totes and bins both, independently, and quickly. The winners of eliminations will be the team that gets the bins from the step the quickest.
This is a very challenging game. Well played, GDC.
  #41   Spotlight this post!
Unread 17-01-2015, 20:46
Gweiss96's Avatar
Gweiss96 Gweiss96 is offline
AKA: Garrett Weiss
FRC #3309 (Friarbots)
Team Role: Operator
Gweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to behold
Originally Posted by Dief Chelphi View Post
What does that even say???
Kevin Sheridam is some troll trying to be like Kevin Sheridan.
  #42   Spotlight this post!
Unread 17-01-2015, 20:57
mrnoble's Avatar
teacher/coach
In reverse.
  #43   Spotlight this post!
Unread 17-01-2015, 22:27
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
That totally fooled me. Thanks for pointing that out.
  #44   Spotlight this post!
Unread 18-01-2015, 15:41
Bruceb's Avatar
Bruceb Bruceb is online now
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
we have a mechanism that will securely grip a container in the last 4 inches and is not likely to let go.
We will see but the wooden prototype worked well, the aluminum one should work better.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
  #45   Spotlight this post!
Unread 24-01-2015, 13:33
Random42 Random42 is offline
FRC #4533
Random42 is an unknown quantity at this point
No one here is talking about a robot that can stack totes and deliver stacks to the scoring zone at the same time. The rules allow such a robot this year.
