Go to Post "When you lose you don't say anything. When you win you say even less." - Clinton Bolinger [more]
Unread 15-01-2015, 15:40
DrewG's Avatar
DrewG DrewG is offline
FRC #0306 (CRT)
DrewG is on a distinguished road
FRC Labview 2015 alpha separate from 2014?
I have followed all installation and update instructions to the letter, yet when I open Labview I am presented with the 2014 launch screen with only default templates, rather than the FRC 2015 with the roboRIO templates. Is the proper version a separate program or did something fail to install properly?
Unread 15-01-2015, 15:50
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Re: FRC Labview 2015 alpha separate from 2014?
Did you install the FRC Update Suite located here?
https://decibel.ni.com/content/docs/DOC-34731
You should see LabVIEW FRC 2015 on the Getting Started screen when LabVIEW loads.
Eric
Unread 15-01-2015, 16:05
DrewG's Avatar
FRC #0306 (CRT)
I have installed the update, but do not have that option. This is the screen I get upon launch Click image for larger version
Unread 15-01-2015, 19:58
You may want to open up the NI License manager and see what it says is installed from NI. Particularly, the 2015 FRC packages need to be reviewed to see if they are present.
Because this may get detailed, if you don't see the issue, you may want to get with an NI support engineers and have them talk you through it.
Greg McKaskle
Unread 16-01-2015, 15:22
DrewG's Avatar
FRC #0306 (CRT)
License manager could only find parts of the update. A reinstall seems to have fixed the issue. Thanks for the help
