Go to Post Thank you to all of the mentors, You ARE changing the future. - chellyzee93 [more]
Unread 01-15-2015, 04:20 PM
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
Re: Arcade drive/Talon controller problems
First of all, the l_motor(1.0) call doesn't work because to drive the motor, you need to use the set function: l_motor.Set(1.0). What you have is meaningless, as l_motor is an object, not a function.
As for the arcade drive, I would try first using the ArcadeDrive function with constant inputs (ie ArcadeDrive(1.0, 0.0) ) and see what happens. That way you know the issue isn't with your joystick. It looks like you're using Talons for everything, but if the drive motors aren't talons then the way you initialized dragonBot won't work.
For testing purposes, don't bother with all the loops and timing; just try to run the motor if the button is pressed. The more complicated the code, the harder it is to find what's wrong.
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
