Go to Post This isn't a science fair, sometimes it's okay to give away the answer, especially if they learned something on the way there. - Karthik [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 15-01-2015, 01:55
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Polycord on tote intake: recipe for disaster?
Our initial mockup for a horizontal roller gripper calls for about 14 small wheels (7 for each side) in order to get the shape we want, and when you consider that they all need to be powered, it starts looking slightly ridiculous.
One alternative we have considered is using polycord or double sided timing belts, but our small amount of experience with these items on an intake has us worried that they will ride out of the pulleys if any vertical forces are involved.
This is a valid concern, right?
Any examples of polycord intakes which could stand up to axial loads? maybe we're missing an obvious way to keep them in their groove
Thanks!
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 15-01-2015, 02:03
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
Re: Polycord on tote intake: recipe for disaster?
Make sure the grooves are decently sized. Assuming you are using round polycord, a semicircle of the same diameter as the polycord should provide good security.
Unread 15-01-2015, 02:09
Best Available Data
FRC #1778 (Chill Out!)
We have found that polycord does a pretty garbage job of gripping to the totes. If you are using polycord, one thing I've seen used with grooves in the past is to to use a "comb" on the backside of the loop where they aren't touching gamepieces to keep them in line.
See this picture for an example.1276's 2009 robot
Unread 15-01-2015, 05:45
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
I concur with Ian. Without the comb, they will walk out of pulley grooves. Even with a comb, they still have a good chance. Flat belt can be a bit more stable if you put a small crown under the center of the shaft.
Unread 15-01-2015, 08:13
Squeakypig's Avatar
Squeakypig Squeakypig is offline
AKA: Mike Coyle
FRC #2851 (Crevolution)
Squeakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond repute
Just remember to tension it every 6". At least that is our experience, some say you can get away with more, I don't trust them.
Unread 15-01-2015, 09:22
Professional Stat Padder
We've had success with polycord intakes in the past by making our own pulleys for the cord to ride along.
Additionally, in our 2013 intake, we used the polycord like a chain or a belt between the sets of wheels. This made it so it all rotated unless the disc couldn't push further up in our hopper, in which case the polycord would break traction with the pulleys and not destroy the discs.
We don't plan on using any polycord in our rollers this year, but best of luck to you!
(2015-Present)
Unread 15-01-2015, 10:51
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
In 2012 we used polycord to move the basketballs through our robot, and we made our rollers out or 2" (IIRC) PVC pipe that we bolted to the driven shaft, using PVC endcaps drilled out in the center to keep the rollers concentric with the shafts. Then we cut small rings out of the endcaps and slid those to where we wanted the belts on our pulleys, to create guides on the rollers. You might have decent luck using some sort of similar system, perhaps also putting tread on the PVC to grip the totes better at the front and then use gaps in the tread to align the polycord.
I can't comment on how well the polycord grips the totes, but it had a decent grip on the rollers when properly tensioned. Hope this helps, good luck!
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 15-01-2015, 11:00
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (Ctrl-Z)
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
We subtract 10% of the total length on poly cord. Example: slacked length needed = 10in, cut and weld a 9in piece. I wouldn't recommend super long segments (<20"). Also, we use custom pulleys, they work like a charm. Remember, poly cord is meant to slip a little. If you don't want slip, use belts or chain.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 15-01-2015, 16:54
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Thanks for the input everyone. We decided to go with wheels on the input and keeping the polycord for the pulleys that will drive the wheels.
Hopefully this will eliminate any possibility of polycord climbing out since there should be no side forces.
-Paraphrasing JFK
