Go to Post they just build excellence and silently wait to deploy their creation on the unsuspecting masses - Koko Ed [more]
Unread 15-01-2015, 17:18
Andrew Taylor Andrew Taylor is offline
FRC #5125
Andrew Taylor will become famous soon enough
Vex Solenoid Base Mount Configuration
Hi, My team cant figure out hot to configure the solenoid base mount provided by VEX. Does anyone have any tips or a video you can share with us?
http://www.vexrobotics.com/solenoids-and-manifolds.html
Unread 15-01-2015, 17:26
zcohen zcohen is offline
AKA: Zac
FRC #1111 (Power Hawks)
zcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to behold
Re: Vex Solenoid Base Mount Configuration
Check out this link:
http://content.vexrobotics.com/vexpr...s-20141010.PDF
You can see on the side of the mounts you have exhaust ports--just let these be, and a pressure input in the middle. You have you incoming air from your tanks go to this port. You then attach the solenoids along the top, as shown on the second page. The coresponding ports on the side are where you hook up the air to go out as the solenoid is activated. If you have a spare port open, you need to cover it using the blank station kit or else it will leak out of that hole.
Zachary Cohen
Team 1111 head mentor 2012-
Team 1712 mentor 2007-2012, 2006 alum
Technology and Engineering teacher
PLTW, STEM Magnet School
South River High School
Unread 05-02-2015, 07:57
JPM0887's Avatar
JPM0887 JPM0887 is offline
FRC #1289 (Gearheadz)
JPM0887 is an unknown quantity at this point
Are the exhaust ports on both sides designed to be left open or should one side be plugged?
Unread 05-02-2015, 08:12
Exhaust ports are designed to be left alone and open.
Air won't move if it has no place to go.
