Go to Post Why subject your robot to a potential sensor failure when you can train a monkey (or a student, if monkeys are lacking) to put the tube at the right height every time? - JVN [more]
Unread 15-01-2015, 19:03
MariOlsen MariOlsen is offline
FRC #5416
MariOlsen will become famous soon enough
RoboRIO Modes Switched & Test Code?
We're having issues with our RoboRIO. It's definitely not an electrical issue - we tested each connection several times.
The modes are switched - when the driver console is in Autonomous mode the Mode light on the RoboRio is yellow (for Teleop) and when the driver is in Teleop the light turns green on the RoboRio (for Auto). We tried reimaging and it's had no effect. It doesn't do anything else in either mode though.
We think it may be an issue with our code. Does anyone have some extremely basic LabVIEW test code that you know works so we can see if that's the problem? Thank you in advance
Unread 15-01-2015, 20:10
Re: RoboRIO Modes Switched & Test Code?
I'd create a brand new robot project. Just set the team number, open Robot Main, run, and do a practice mode test.
Greg McKaskle
