Go to Post Perhaps we should just have signs put up that say "Please remove your head and tail before entering". - Molten [more]
Unread 15-01-2015, 15:00
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
pic: A little programming excercise
Unread 15-01-2015, 15:01
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
Re: pic: A little programming excercise
What depth camera do you use?
Unread 15-01-2015, 15:22
faust1706's Avatar
It's configured for the Microsoft kinect but can be easily adjusted for any other one, such as the asus xtion. The only thing that would have to be changed is the distance calculation because it's different for every depth camera you use.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 15-01-2015, 17:07
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
That's going to be impressive once 20+ totes in varying sized stacks are all over the field! Should make navigating between scoring platforms a bit smoother at end-game.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 15-01-2015, 19:13
faust1706's Avatar
That's the idea, kind of. It's mainly going to be used for autonomous piece pick up and stacking it to my understanding. It could be used for that, sure. We have generated paths before based on the what the depth map sees. Then you could use the poofs code to drive on that curve if you're daring.
I think I accounted for everything. Depth returns distance, x rotation to the center of the object, how many degrees the tote is offset if it is a tote, how many totes high the stack is, if it is a yellow or gray tote or green bin, and soon if it has a bin on it. If there is something I didn't account for, please let me know and I'll see if it I can incorporate it.
