Go to Post A VERY credible statement ... coming from a 400-pound Pooh Bear - Rich Kressly [more]
Unread 14-01-2015, 21:10
Mr.Roboto3335's Avatar
Mr.Roboto3335 Mr.Roboto3335 is offline
Wait, What?
AKA: Jimmy
FRC #3335 (Cy-Borgs)
Mr.Roboto3335 is an unknown quantity at this point
How do deploy code with Eclipse?
I've been trying to deploy code to the roborio for a few days now. It's not connecting to the driver station either. It finds it in eclipse but it shows this
    [echo] [athena-deploy] Copying code over.
      [scp] Connecting to roboRIO-3335.local:22
      [scp] done.
      [scp] done.
     [echo] [athena-deploy] Starting program.
  [sshexec] Connecting to roboRIO-3335.local:22
  [sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
  [sshexec] start-stop-daemon: warning: killing process 3227: No such process
BUILD SUCCESSFUL
Total time: 8 seconds
and here's the code
package org.usfirst.frc.team3335.robot;
/* Copyright (c) FIRST 2008. All Rights Reserved.                             */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
import edu.wpi.first.wpilibj.*;
import edu.wpi.first.wpilibj.vision.*;
public class Robot extends IterativeRobot {
    private Joystick controller;
    private RobotDrive drive;
    private SpeedController one, two, three, four, lift;
    private AxisCamera camera;
    private DigitalInput limit;
    public void robotInit() {
        joystickInit();
        sensorInit();
        robotDriveInit();
        speedControllerInit();
    public void sensorInit() {
        limit = new DigitalInput(1);
    public void joystickInit() {
        controller = new Joystick(1);
    public void robotDriveInit() {
        drive = new RobotDrive(one, two, three, four);
    public void speedControllerInit() {
        one = new Talon(1);
        two = new Talon(2);
        three = new Talon(3);
        four = new Talon(4);
        lift = new Talon(5);
    public void autonomousPeriodic() {
    public void teleopPeriodic() {
        double y = getDeadZone(controller.getY(), 0.1);
        double x = getDeadZone(controller.getThrottle(), 0.1);
        drive.arcadeDrive(y, x);
         if (controller.getAxis(Joystick.AxisType.kZ) > 0.8) {
                two.set(-1);
            } else if (controller.getAxis(Joystick.AxisType.kZ) < -0.8 && limit.get()) {
                two.set(1);
            } else {
                two.set(0);
    public void testPeriodic() {
    public double getDeadZone(double axis, double zone) {
        return Math.abs(axis) > zone ? axis : 0;
does this mean it was successful? I'm so confused. This is my first time using eclipse. And if anyone knows as to the roborio's:confused not wanting to show up on the driver station, it'd be a great help.
Wait, what?
Unread 14-01-2015, 21:13
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Re: How do deploy code with Eclipse?
Yes, that looks like a successful code deployment. If you're having issues though you should check for errors in the driver station log.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 14-01-2015, 21:20
Wait, What?
AKA: Jimmy
What is Error 44009 on the driver station?
Wait, what?
Unread 14-01-2015, 21:36
Wait, What?
AKA: Jimmy
Never mind. I still don't understand why it won't connect. All the firmware has been uploaded and the image updated. The code has been deployed and yet nothing.
Wait, what?
Unread 14-01-2015, 22:10
AKA: Spencer Lanman
Alright I'll ask the somewhat obvious questions lol.
Are you using the new driverstation, have you entered your team number into the driverstation, and how are you connecting to the rRIO?
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 15-01-2015, 11:08
Wait, What?
AKA: Jimmy
It is the new driverstation, I have entered the team number into the driverstation, and I'm connected via ethernet cable. I've also tried with the type a to type b usb cable.
Wait, what?
Unread 15-01-2015, 11:20
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Also, joysticks (and talons?) have a 0-index now. That code won't run unless your joystick is in slot 2.
Unread 15-01-2015, 20:11
Wait, What?
AKA: Jimmy
Are you saying I should put controller = new Joystick(2); ?
Wait, what?
Unread 15-01-2015, 20:24
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
What he's saying is that the roboRIO uses something called 0-indexed IO This means that the joystick (and all other IO identifiers) numbers go 0, 1, 2, 3. For the first, second, third and fourth ports respecivly
Your code:
sets up joystick in port 1, which is actually the SECOND port.
To solve this you can either
a) change the code to
controller = new Joystick(0);
b) change the driverstation so that the joystick goes into the SECOND port.
I recomend the first.
Onto your main problem.
When connected via ethernet, could you post the output of "ipconfig"
Are you getting No Robot Code, Comunications, or is it just not doing anything when you enable?
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 15-01-2015, 20:27
Wait, What?
AKA: Jimmy
Now I'm getting communications. It just says there's no robot code.
/* the project.                                                               */
        joystickInit();
        sensorInit();
        robotDriveInit();
        limit = new DigitalInput(0);
        one = new Victor(0);
        two = new Victor(1);
        three = new Victor(2);
        four = new Victor(3);
        lift = new Victor(4);
        drive.arcadeDrive(y,x);
                two.set(-1);
                two.set(1);
            } else {
                two.set(0);
This should work, right?
Wait, what?
Unread 15-01-2015, 20:57
Wait, What?
AKA: Jimmy
Okay. There is a problem in the code. When I remove the RobotDrive, the robot code shows up on the driverstation. What's happening here?
Wait, what?
Unread 15-01-2015, 21:26
AKA: Spencer Lanman
Your SpeedController objects should have a type of Victor, not SpeedController.
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 16-01-2015, 00:51
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
No, that's fine. What is likely happening is that you're initializing your speed controllers AFTER you initialize drive. They are null when passed to new RobotDrive(), which should throw a null pointer exception and crash. Try initializing the controllers before the drive.
Unread 16-01-2015, 13:34
Wait, What?
AKA: Jimmy
How silly of me x.x I forget that it matters which initialize first. Thank you for your help!
Wait, what?
Unread 16-01-2015, 18:33
Wait, What?
AKA: Jimmy
Everything's working now. Thank you everybody!
Wait, what?
