Go to Post wow!! Andy Baker really is a pig farmer!! and all this time i thought that paul copioli was stereotyping! - RogerR [more]
Unread 15-01-2015, 21:16
N00bfirst N00bfirst is offline
FRC #4992
N00bfirst is an unknown quantity at this point
A relatively dumb question...
How do I program an ultrasonic sensor with an analog input and convert it into digital so I can use it for programming?
Let's say that the ultrasonic sensor is in port # 0 in the analog input part of the controller.
How would I set up the Ultrasonic class in a way that takes the analog port as the input.
Right now, it's only giving me an error.
Unread 15-01-2015, 21:23
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
AlexBrinister will become famous soon enough
Re: A relatively dumb question...
Could you post your code?
Alex Brinister
Unread 15-01-2015, 21:26
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
Use:
AnalogInput ultraSonic = new AnalogInput(0);
Then to get a reading:
ultrasonic.getVoltage();
Then you need to scale the voltage (0-5) to a distance, using a constant which should be in the documentation for the ultrasonic sensor.
Unread 16-01-2015, 10:03
FRC #4992
Originally Posted by TFleig78 View Post
Use:
How would I use that for the input and output?
This is our code.
AnalogInput inUltra = new AnalogInput(0);
AnalogOutput outUltra = new AnalogOutput(0);
inUltra.getVoltage();
Ultrasonic ultra = new Ultrasonic(0,0);
ultra.setAutomaticMode(true);
double range = ultra.getRangeInches();
String what = Double.toString(range);
for(int i = 1; i < 10; i++){
SmartDashboard.putNumber(what, range);
Unread 16-01-2015, 10:53
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
You have to convert the voltage to a distance value. The sensor should have a spec for mV/in or mV/m or something relating voltage and distance.
For example, the MaxBotics MB1010 LV-EZ1 has a spec of 9.8mV/in with a 5V supply. So, if you read 0.392V from the sensor, this would result in a distance of 40 inches. (0.392 / 0.0098)
Some simple code you could use.
AnalogInput ultrasonic(0);
float voltage(0);
float distance(0);
const float volts_to_inches(0.0098);
voltage = ultrasonic.GetVoltage();
distance = voltage / volts_to_inches;
These sensors tend to be pretty noisy, so I would suggest a simple low pass filter.
const float filter_alpha = 0.5;
distance = distance + filter_alpha * ((voltage / volts_to_inches) - distance);
Hope that helps!
EDIT: Didn't realize this was in the Java forum and I wrote C++. Should still give you an idea of what to do.
Unread 16-01-2015, 11:11
TFleig78's Avatar
AKA: Tyler
What model ultrasonic sensor do you have? We use a Maxbotix sensor and there is an analog output pin. We don't need an analog output, just analog in.
Also, you can also use this method to reduce noise.
ultraSonic.getAverageVoltage()
