Go to Post Learning by failure is quite common. - Gdeaver [more]
Unread 10-01-2015, 15:51
PDP required firmware version
Just checking to make sure I didn't miss it a rule requiring a specific firmware version for the PDP. I found them for the roboRIO, PCM, Talon SRX, and Jaguars, but not the PDP. Did I miss it?
Unread 10-01-2015, 18:05
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: PDP required firmware version
Did a document search for both "firmware" and "PDP" and found no requirements.
Unread 12-01-2015, 15:36
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Since the PDP isn't an output/active device and can't impact robot performance due to software, that's likely why there isn't a rule.
Unread 15-01-2015, 23:42
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
As far as I'm concerned the PDP doesn't have firmware. It has no computing power whatsoever. The CAN wire leads go into a terminator.
College sux yo
Unread 15-01-2015, 23:50
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
As of Team Update 2015-01-13, there is a required firmware version:
R61 The PDP CAN interface must be connected to the CAN-bus on the roboRIO (either directly or daisy-chained via another CAN-bus device). The firmware on the PDP must be updated to at least version 1.37.
(The highlighted text was added on Tuesday.)
--Jacob
Illinois FTC FTA
Unread 15-01-2015, 23:56
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The fact it can respond to can traffic means it has computing power. If First requires a specific firmware, it will be on there before you get your inspection sticker. Your (and mine BTW) does not matter.
Unread 16-01-2015, 00:47
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
The TalonSRX firmware version requirement for TalonSRX's hooked up via PWM (R41) is going to be a bit of a pain for inspectors. How are they supposed to verify it without moving wires around? Or were all TalonSRX's distributed to teams firmware version 0.28 or newer? I wonder if this might be a good Q&A question.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 16-01-2015, 00:54
FTC FTA
See pages 12-14 of this document Talon SRX User's Guide. They pretty much directly answer your questions.
--Jacob
Illinois FTC FTA
Unread 16-01-2015, 12:44
Lord of Lazy
My what now? haha
I always thought that the terminator was just a resistor to stop the CAN circuit. Guess I'll need to do more research.
College sux yo
Unread 16-01-2015, 12:47
Volunteer, WPILib Contributor
no team (Waiting for 2021)
My what now? haha
The terminator is there to end the circuit, but before it goes through the resistor is goes through the board and connects the board to the CAN circuit. This is what allows the roboRIO to sense current for each of the motors.
Team 4488 - Mentor 2013-2016
Unread 16-02-2015, 19:35
Dolphin07 Dolphin07 is offline
FRC #5568 (Solid Rock)
Rookie Year: 2015
Dolphin07 is an unknown quantity at this point
We tried to update the firmware on our pdp,but NI won't let is into our accounts. We've tried several accounts and can't log in to any of them to update the firmware. Any ideas?
Unread 16-02-2015, 19:37
Rookie Year: 2015
Talking Re: PDP required firmware version
Never mind. We found that you simply have to sign in as "admin ".
Unread 16-02-2015, 19:43
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
jimbo493 has a spectacular aura aboutjimbo493 has a spectacular aura about
The PDP can send current sensing data back, there was an update to it regarding some false readings. It actually has quite a bit of computing things that it does.
Unread 16-02-2015, 21:53
ozrien's Avatar
Omar Zrien
AKA: Omar
Yep, that's mentioned under "Updating CAN Node Firmware"
http://wpilib.screenstepslive.com/s/...ribution-panel
