Go to Post The best [fundraiser] that we did was our various little things this year, such as calanders and other things. The worst is not doing one at all. - Joe Matt [more]
Unread 03-01-2015, 13:35
temper22 temper22 is offline
FRC #0133
temper22 is an unknown quantity at this point
maximum # of game object
hey,
did anyone see a rule regarding a certain number of totes allowed on the robot simultanously? or can we carry as many totes / containers as we want?
thakns!
Unread 03-01-2015, 14:10
Anstrilator Anstrilator is offline
FRC #9999
Anstrilator is an unknown quantity at this point
Re: maximum # of game object
I also didn't see anything in the manual about this.
Unread 03-01-2015, 14:13
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
I was going to start a thread on this, but I went through the rules on the subject first.
I didn't find anything relating to the maximum number of game pieces a robot can have in its possession at any given time.
Unread 03-01-2015, 14:22
AutodeskGeek's Avatar
AutodeskGeek AutodeskGeek is offline
FRC #2062 (C.O.R.E. - Community Of Robotic Engineers)
Team Role: Driver
AutodeskGeek is an unknown quantity at this point
I can't find anything in the rules limiting the number of totes you can carry. Since there's no xz size limit either, you're only limited by the robot weight and how much you can compact your mechanisms.
¤ Autodesk Geek
Unread 03-01-2015, 14:36
Sky Captain's Avatar
Sky Captain Sky Captain is offline
Lead Software Mentor
AKA: Will
FRC #0386 (Voltage)
Sky Captain is an unknown quantity at this point
Send a message via AIM to Sky Captain
Our team has a question about this at well. How many pieces of litter can a robot carry at once?
Unread 03-01-2015, 14:49
If there is no restriction stated, then no restriction exists.
But if you're not sure, feel free to ask Q&A.
Unread 03-01-2015, 15:07
chrisfl chrisfl is offline
FRC #1991 (Dragons)
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
Don't forget the height restriction and the TRANSPORT CONFIGURATION rule.
Unread 03-01-2015, 15:08
FRC #9999
What does transport config have to do with it?
Unread 03-01-2015, 16:36
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
FRC #1058 (PVC Pirates)
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
I'm reasonably sure there is no such restriction this season, which would give teams free reign in this area for the first time in a while(definitely since 2011, if not since 2009).
I think an intended strategy in this game is the ability to make a stack, and then move it somewhere else. For example, it might be possible to create an assembly line of sorts, where one robot makes stacks of say, 3 totes, another moves these stacks to the scoring zone, and the third caps these stacks with recycle bins.
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
Unread 03-01-2015, 16:39
Awesomegamer235 Awesomegamer235 is offline
None #4607
Awesomegamer235 is an unknown quantity at this point
you can carry as many totes as you want but make sure your robot can handle all the weight
Unread 03-01-2015, 18:27
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
There doesn't seem to be a limit, but good luck on carrying multiple pool noodles and scoring each one when you can only score one per container. If you've focused a significant portion of your bot on the noodles, you are probably at a large disadvantage seeing as you are relying on the fact that your containers will be stacked.
Unread 16-01-2015, 00:18
Ubiquity Ubiquity is offline
FRC #5027
Ubiquity is an unknown quantity at this point
A valid strategy might be grabbing two totes side by side, assembling them in a multiple stack and scoring that, doubling your scoring per cycle. I think a major decision for most teams will be do they want to be a tote handler/stacker or a container bot. Hard to see how you can do both. The highest scoring alliances will have at least one of each kind of robot.
....and while thinking about your autonomous strategy is fine, first figure out what you are doing in teleop, build your robot, figure out what it ACTUALLY can do; then plan your autonomous strategy. If you try to build a robot that can do everything, be prepared to live with disappointment.
For rookies:
1 Build a base that moves.
2 Learn to drive it.
3 Add an attachment that can push one or more totes onto the step without knocking stuff down.
4 Add a drive forward 10 feet autonomous program
5 - Only then figure out how to build a grabber, stacker, hold a container up to get litter put into it.
Experienced teams have an advantage over rookies because they already know how to do 1-4.
Unread 16-01-2015, 00:22
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Unless your design is capable of getting all the noodles and you are confident enough in driver skill that you can end with your robot and said noodles all neatly in the landfill
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 16-01-2015, 00:24
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
One point each.
