HELP!
is there any tutorials on the new java??
Re: HELP!
I personally don't know anything about programming, but you could check the internet if you haven't yet. Here, let me help.
http://lmgtfy.com/?q=java+tutorials Last edited by bobjones227 : 15-01-2015 at 17:51. |
Re: HELP!
What about the new Java?
Are you looking for documentation on the WPI Library APIs that we use in FRC? If so, all of the previous documentation is more or less applicable- those haven't changed much at all. If you are looking for documentation on new features that we get by switching to Java 8 SE, then I would recommend starting with the Java 8 release notes from Oracle. You will also want to search for the Java 7, Java 6, and Java 5 release notes. You can also find an countless number of tutorials, guides, and tips for Java 5-8 online. |
Re: HELP!
Re: HELP!
In general, breaking up code like this can be helpful since it helps keep issues isolated. If something needs to be rewritten, it is probably going to be limited to one class instead of the entirety of the project. |
#7
Re: HELP!
Re: HELP!
Well, I'm my specific case It is just me working on our code. So I programmed for every possible drive train except swereve because my team doesn't know what their doing for a drive train, we have had talks of all of them...I'm going to update my github repositories today and that code has examples for all the drive possible except swerve. Most of them are not fully tested.
#10
Re: HELP!
explanation of each package: Robot.Subsystem: This package contains classes to hold motor instances, sensors, pnumatics. In each class there are also methods to move each motor and read the sensors. Robot.Commands: This package contains the classes that tell the subsystems how to act. For example the class DriveStraight class tells the driveTrain subsystem to drive untill X condition happens. Robot: This package contains the 3 main classes: Robot, RobotMap, OI
#11
Re: HELP!
Since this is an article about getting help, I wanted to ask how to begin a thread on chief delphi. I might just be completely overlooking something, but I don't know how to ask questions on this site. If anybody could give an answer, that would be of great help. Thanks
#12
Re: HELP!
