Go to Post Who would have thought a triangular robot would fit into a triangular goal :rolleyes: - Wayne Doenges [more]
Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
  #226   Spotlight this post!
Unread 20-11-2014, 21:08
Ideal_Nerd's Avatar
Ideal_Nerd Ideal_Nerd is offline
Team Caption
FRC #3591 (Wild Warbots)
Team Role: Driver
Ideal_Nerd has a spectacular aura aboutIdeal_Nerd has a spectacular aura about
Re: blog; Motor Controller Options for 2015
Just got word from vex saying that the new talons will not be available to order till late December.
Evan
Team Captain, CAD leader FRC team #3591.
Westerville Ohio.
  #227   Spotlight this post!
Unread 29-11-2014, 17:07
Originally Posted by Andrew Schreiber View Post
And how's the error recovery for if we lose power or connection mid flash?
Can't speak for the Talon SRX, but I just played around with error recovery for the PCM. I pulled PCM power towards the beginning of the flash, towards the middle of the flash, and towards the end of the flash. In all cases I was able to recover.
  #228   Spotlight this post!
Unread 01-12-2014, 10:41
Data Nerd
FRC #0079
Sweet. That was one of my big concerns when flashing CAN Jags.
  #229   Spotlight this post!
Unread 03-12-2014, 02:20
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Do the new talons communicate with CAN over the PWM cable? If so that's awesome.
2016: FRC 865 Mentor
  #230   Spotlight this post!
Unread 03-12-2014, 02:32
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Yes but its the other way around (I.e The new Talon SRX will run PWM over the CAN wires).
The new Talon will auto detect whether you are connect to a can bus or a pwm source.
On FRC you only need two wires for PWMs (signal and ground) to an FRC legal motor controller because all FRC motor controllors ignore the center power pin (these are only used for servos)
You can wire the 2 CAN wires on the Talon SRX to PWM signal and ground and it will auto detect PWM.
CAN_H = PWM Signal
CAN_L = PWM Ground
The Victor SP (which has a 3-pin PWM) can only be used in PWM mode, no CAN available
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
  #231   Spotlight this post!
Unread 03-12-2014, 16:25
mman1506's Avatar
no team (WARP7)
CAN_H = PWM Signal
CAN_L = PWM Ground
Hope this helps,
Kevin
Thanks, can you change PID values and configuration over CAN without a separate utility?
  #232   Spotlight this post!
Unread 16-01-2015, 11:04
The body is made of aluminum, and it is isolated from the electronics inside. If you're concerned about cooling, rub some thermal paste on it and bolt it to an aluminum plate.
Originally Posted by cgmv123 View Post
Or don't risk violating the rule against modifying electronics and add a fan instead.
What rule did you have in mind, that prohibits mounting a motor controller using the provided mounting holes?
The thermal paste could be omitted, if that is the concern.
Yes, that would be the concern.
Just so everyone is aware, now that the 2015 rules are released:
R55 G
  #233   Spotlight this post!
Unread 02-02-2015, 11:14
AdamHeard's Avatar
Lead Mentor
I think it's fair to point out that we are nearing the end of build season, and presumably most teams have got their big orders in...
Vex is still in stock.
WCProducts is still in stock.
Andymark is still in stock.
RobotSpace is still in stock (For Victors, Talons are out. Based on everyone else having stock, I'm sure they will get replenished soon.)
So................. They handled it awesome in my opinion.
