Go to Post For our next exercise, we should define Beauty and Truth. :) - Taylor [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
  #46   Spotlight this post!
Unread 29-12-2014, 18:46
Gearheads1 Gearheads1 is online now
AKA: Brian Holmgren
FRC #4455 (The Burger Bots)
Gearheads1 is an unknown quantity at this point
Re: Good Material For Bottom of Chassis
Amazon is also a good source for Baltic Birch plywood in a variety of sizes and thicknesses.
  #47   Spotlight this post!
Unread 29-12-2014, 19:38
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
While it is pretty typical our experience might be useful for someone. We used a piece of 1/16 aluminum sheet on our WCD which is quite a bit thinner than most teams use (254 uses .1 so they can tap it I believe) which was nice as we didn't have to pocket it which would of taken a lot of water jet time. We were worried about it breaking especially around the battery but it worked great. It also added ton of rigidity to the chassis which improved handling IMO.
2016: FRC 865 Mentor
  #48   Spotlight this post!
Unread 29-12-2014, 21:01
AdamHeard's Avatar
Lead Mentor
I'm going to toot my own horn for a moment....
We've done
1) 1/16" G-10/FR4 Garolitem (2009, 2009 offseason, 2010, 2012)
Pros
-Looks darn good (glossy black)
-Very Stiff/strong
-Easy enough to drill, but vacuum the mess!
Cons
-Expensive
-Waterjet delaminates it, so they pierce 3-4" away from final cut and feed over. We did some external slots to act as rivet holes, then match drill rest on robot.
2) 6mm (~1/4") 5 ply baltic Birch (2012 offseason, 2013 season, 2014 offseason, 2015 season)
Pros
-Easy to cut
-Cheap
-Very HIGH stiffness to weight
-Can thread fasteners right into it for components
-When painted, looks nice enough.
Cons
-Termites
-Ignorant teams look down on it. This is fine, it just points out their lack of understanding of material properties and basic math
3) .125 6061-T6 diamond pattern (Waterjetted/lasercut). (2011 season, 2011 offseason, 2014 season)
Pros
-Hypetrain
-Forces you to do layout
Cons
-Expensive resource wise
-Not as stiff as the other 3 items
-One and done, no mods
4) .25 ABS (if you count 294). This is similar enough to (2007 season)
-It's really just a heaver version of plywood. I'd use plywood over this.
I highly recommend the wood, no need to laminate or do anything to it. Just use it as is. If your frail ego can't handle the wood, garolite is a great option at 1/16" thick but requires more tools to work with.
The diamond bellypan is nice... but in nearly all cases is a huge resource waste. Many subsystem gearboxes and gussets could be cut in the same time.
  #49   Spotlight this post!
Unread 29-12-2014, 21:10
mman1506's Avatar
no team (WARP7)
I
I've never understood the diamond belly pan thing is their any other advantage over a thinner sheet besides being able to tap it?
  #50   Spotlight this post!
Unread 29-12-2014, 21:21
FRC #1836 (MilkenKnights)
We like that it makes it super easy to zip tie wires down. You can do this with wood too, but you have to drill a hole wherever you want to put a zip tie in.
  #51   Spotlight this post!
Unread 29-12-2014, 21:24
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
No need to drill holes through the wood.
http://m.homedepot.com/p/Commercial-...5665/202520055
  #52   Spotlight this post!
Unread 29-12-2014, 21:27
AdamHeard's Avatar
Lead Mentor
Drilling holes through wood is so hard Instead I will waterjet GIANT holes
  #53   Spotlight this post!
Unread 29-12-2014, 21:30
In the cases where we are replacing stuff in the middle of competition I like to be able to easily add and remove cable ties. Clearly it doesn't matter that much, but it's the only reason we've continued to do metal bellypans on our comp bot.
  #54   Spotlight this post!
Unread 29-12-2014, 22:22
cxcad cxcad is offline
FRC #1683 (Techno Titans)
cxcad will become famous soon enoughcxcad will become famous soon enough
[quote=AdamHeard;1417870]
QUOTE]
Don't you want to go back to Einstein? Lol. I'm sure 973 will do fine without the fancy belly pan.
Dumb question, why do you switch from year to year?
  #55   Spotlight this post!
Unread 29-12-2014, 23:17
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
We use this stuff:
http://www.piedmontplastics.com/land...ate-sheet.aspx
It's often called "twin-wall" or corrugated polycarbonate. I believe McMaster sells it but I'm not sure what variety they have. We typically aim for a thickness between 1/4th and 1/8th. Anything less than an 1/8th can be too flexible.
It's lightweight and reasonably priced from our local vendors. It's also easily machined... and by machined, I mean you can drill holes into it or cut it with a knife/razor. I highly suggest learning how to cut it and mount it to take advantage of it's inherit perpendicular strength (perpendicular to the inner walls that is).
We've been very happy with it over the years.
  #56   Spotlight this post!
Unread 09-01-2015, 21:22
Would something like this work fine? http://www.homedepot.com/p/Unbranded...1178/203183010
Or does it have to be baltic birch?
  #57   Spotlight this post!
Unread 16-01-2015, 12:12
Jrizo's Avatar
Jrizo Jrizo is offline
FRC #4335 (Metallic Clouds)
Jrizo is an unknown quantity at this point
We have a sponsor willing to cut a pan out of sheet metal for us this year. Does any team use sheet metal instead of aluminum? If so what gauge? Or does any team use stainless steel. Just wondering short of the electrical issues that could occur if we were not careful, are there any other downfalls to using sheet metal. We normally use .25 lexan and have really not had any issues with it but it is expensive. and a pain to cut
  #58   Spotlight this post!
Unread 16-01-2015, 13:04
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
I agree with other posts further up: say thank you to the sponsor, but use plywood.
  #59   Spotlight this post!
Unread 16-01-2015, 13:42
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
You can also use this stuff. It's good enough for our entire chassis, so an electronics board will be no problem. Has a very nice finish.
http://www.homedepot.com/p/Unbranded...9023/100073744
  #60   Spotlight this post!
Unread 16-01-2015, 23:39
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
The nominal 1/2" and 3/4" sizes of that plywood is what we used to make all of the PNW's road cases that are used to transport the field and all of the production equipment. It is nice stuff.
