Go to Post Some may call it an obsession and they may be right, but I call it a huge learning experience. - Elgin Clock [more]
Unread 16-01-2015, 14:16
RafaelRamosV RafaelRamosV is offline
FRC #5312
RafaelRamosV is an unknown quantity at this point
can we still use the CPR-360?
As the title says, can we still using this converter http://www.andymark.com/product-p/am-0899.htm ?
Unread 16-01-2015, 14:18
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
Re: can we still use the CPR-360?
If the use is for the radio then there is no need for it since we now have the Voltage regulator module, If it is for something else the voltage regulator module also has an empty port or 2 that has the same effect as the converter.
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 16-01-2015, 14:21
FRC #5312
It's for take the signal of a sensor from 12 VDC to 5 VDC so it can be detected for the roboRIO, so in ths way we don't have to build a costum circuit
Unread 16-01-2015, 14:24
audietron's Avatar
Are you not able to use one of the 12v to 5v ports on the VRM?
Unread 16-01-2015, 14:28
FRC #5312
No, because that for powering, and I want to use the CPR-360 for signal conditioning
Unread 16-01-2015, 14:30
audietron's Avatar
Oh, I see , from what I can see there is nothing against using it for custom circuits in updates/ the manual. I would suggest asking in the Q and A to be sure though.
Unread 16-01-2015, 14:37
It won't do that very well, if at all.
Based on earlier posts about a 12V sensor, I think the proper solution is a very simple custom circuit: use two resistors to make a voltage divider.
Connect the output of the sensor to one end a 1.5 kilohm resistor. Connect the other end of the 1.5k resistor to the roboRIO's signal input pin, and also to one end of a 1 kilohm resistor. Connect the other end of the 1k resistor to the negative pin on the roboRIO's input. When the sensor supplies 12 volts, the roboRIO will see approximately 4.8 volts.
Unread 16-01-2015, 14:49
FRC #5312
I know, it's even better a zener regulator, that way I don't lose any current, contrary what could happen with the voltage divider, it's just that talking with the team we want to use all that we have in our hands instead that starting to build stuff, but yeah I will try voltage divider and zener regulator.
