Go to Post I have also emailed Dean Kamen for more information regarding our team and its future, as I may have confused myself a bit. - ExcuseBoy [more]
Unread 16-01-2015, 15:21
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Re: RobotPy D eploy Error? What are we missing?
Originally Posted by Peter Johnson View Post
Is your robot script named robot.py? Are there any files in the py directory? I'm not the author of the pyfrc parts, virtuald is (he frequents Chief Delphi as well), but it looks like pyfrc's deploy feature may always make robotCommand call robot.py, rather than using the actual name of the script used when deploying. As a workaround, try renaming your script to robot.py if it isn't already.
If there are no files in the py directory, it could also be permissions related since you were uploading as admin previously--if that's the case, try logging in as admin, removing /home/lvuser/py, and then retrying your upload as lvuser.
Ok so I deleted the directory and I tried to upload the code again(see pic). I think the problem is that the command line saved my username and password for admin. How do I make it so I log in as lvuser after it already saved the info in cache? Thanks again!
