Go to Post If we're engineers, I feel we shouldn't be content with the what without the why... - Chris is me [more]
Unread 16-01-2015, 15:20
Travis_Team2619 Travis_Team2619 is offline
FRC #2619
Travis_Team2619 is an unknown quantity at this point
CAN port on roboRIO seems to be damaged
With our roboRIO we went to plug in the CAN cables yesterday, and the spring loaded release wasn't working on the CAN-High signal. This is a major problem for our roboRIO because we can't do any firmware flashing for or TalonSRX's and we can't do several other things.
Is there some sort of fix for this? Or do we have to buy a whole new roboRIO?
Unread 16-01-2015, 15:44
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Re: CAN port on roboRIO seems to be damaged
When you press the white latch the wire should release.... should.
But if it doesn't, then try a couple of things. One, press the white release which a screw driver HARD and pull the wire HARD. This will free up a wire that might be crimped around the latch.
If that doesn't work, try pressing the latch HARD, push DOWN on the wire, then pull it out.
We've found this to usually work.
Unread 16-01-2015, 16:01
You were trying to plug in, but the release wasn't working? I don't understand. What does "wasn't working" mean here, exactly?
Unread 16-01-2015, 16:31
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
A short video on how the Weidmuller connectors work. It might be helpful to you:
https://www.youtube.com/watch?v=Zsnro-9_ZfQ
Unread 16-01-2015, 20:35
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Have you tried using solid instead of stranded wire? Looks like you can just push in solid wire without having to press the release.
Brian K
Team 1225 Robotics Mentor
