Go to Post ...the hardest part of engineering is communication. - EricVanWyk [more]
Unread 14-01-2015, 14:56
jagow100's Avatar
jagow100 jagow100 is offline
FRC #3539 (Byting Bulldogs)
jagow100 is an unknown quantity at this point
Exclamation Issue putting the java on the roboRIO
For whatever reason, when using the Java installer tool on the roboRIO, it keeps getting stuck on deploying the JRE to the roboRIO, and it says tarring created JRE under the loading bar, which is empty. I have switched computer but I have not switched roboRIOs. Is this a known problem or should I change roboRIOs? The reason I haven't switched roboRIOs already is because I only took one of the roboRIOs home.
Unread 14-01-2015, 15:34
Re: Issue putting the java on the roboRIO
The JRE installer spits out a log (I think it is in the same directory as the jar file of the tool itself). Can you post that?
Unread 14-01-2015, 15:58
jagow100's Avatar
14/Jan/2015 14:37:03,670- InternetController: Starting internet check
14/Jan/2015 14:37:03,784- InternetController: Internet check successful, moving to download
14/Jan/2015 14:37:03,924- DownloadController: Loading download page page
14/Jan/2015 14:37:03,925- DownloadController: Loading download page page
14/Jan/2015 14:37:05,893- DownloadController: Loading download page page
14/Jan/2015 14:37:58,396- DownloadController: Loading unknown page
14/Jan/2015 14:37:58,397- DownloadController: Loading unknown page
14/Jan/2015 14:37:59,822- DownloadController: Loading unknown page
14/Jan/2015 14:37:59,849- DownloadController: Loading login page
14/Jan/2015 14:38:00,847- DownloadController: Loading login page
14/Jan/2015 14:38:10,657- DownloadController: Loading unknown page
14/Jan/2015 14:38:10,908- DownloadController: Loading unknown page
14/Jan/2015 14:38:10,918- DownloadController: Loading login page
14/Jan/2015 14:38:11,128- DownloadController: Loading login page
14/Jan/2015 14:41:36,529- DownloadController: Loading unknown page
14/Jan/2015 14:41:37,191- DownloadController: Signed in and have the .tar.gz link.
14/Jan/2015 14:41:37,257- DownloadProgressController: Initial url is https://edelivery.oracle.com/akam/ot...un_2014.tar.gz
14/Jan/2015 14:41:37,678- DownloadProgressController: Final url is http://download.oracle.com/otn/java/...ee653c15768069
14/Jan/2015 14:41:37,680- DownloadProgressController: Starting JRE download. File size is 121568917 bytes
14/Jan/2015 14:41:37,683- DownloadController: Loading unknown page
14/Jan/2015 14:42:26,971- DownloadProgressController: Downloaded JRE
14/Jan/2015 14:42:27,022- MainApp: Found JRE, checking hash
14/Jan/2015 14:42:28,143- MainApp: Computed hash is 082F08397B0D3F63844AB472B5111C8C, official hash is 082F08397B0D3F63844AB472B5111C8C
14/Jan/2015 14:42:52,585- UntarController: Starting decompress of file C:\Users\3539\wpilib\tools\.\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\3539\wpilib\tools\.
14/Jan/2015 14:42:52,602- UntarController: Untarring ejdk1.8.0_06/bin/
14/Jan/2015 14:42:52,603- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.sh
14/Jan/2015 14:42:52,618- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.bat
14/Jan/2015 14:42:52,661- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.config.properties
14/Jan/2015 14:42:52,749- UntarController: Untarring ejdk1.8.0_06/doc/
14/Jan/2015 14:42:52,750- UntarController: Untarring ejdk1.8.0_06/lib/
14/Jan/2015 14:42:52,750- UntarController: Untarring ejdk1.8.0_06/lib/JRECreate.jar
14/Jan/2015 14:42:52,762- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/
14/Jan/2015 14:42:52,762- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/
14/Jan/2015 14:42:52,763- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/
14/Jan/2015 14:42:52,764- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/
14/Jan/2015 14:42:52,765- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklist
14/Jan/2015 14:42:52,770- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/US_export_policy.jar
14/Jan/2015 14:42:52,772- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.security
14/Jan/2015 14:42:52,785- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.policy
14/Jan/2015 14:42:52,787- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/local_policy.jar
14/Jan/2015 14:42:52,788- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklisted.certs
14/Jan/2015 14:42:52,792- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/trusted.libraries
14/Jan/2015 14:42:52,793- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/cacerts
14/Jan/2015 14:42:52,828- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.bfc
14/Jan/2015 14:42:52,849- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.bfc
14/Jan/2015 14:42:52,852- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/meta-index
14/Jan/2015 14:42:52,857- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.bfc
14/Jan/2015 14:42:52,861- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/resources.jar
14/Jan/2015 14:42:52,889- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.properties.src
14/Jan/2015 14:42:52,893- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/classlist
14/Jan/2015 14:42:52,926- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/net.properties
14/Jan/2015 14:42:52,928- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management-agent.jar
14/Jan/2015 14:42:52,959- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr.jar
14/Jan/2015 14:42:52,968- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jvm.hprof.txt
14/Jan/2015 14:42:52,971- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/calendars.properties
14/Jan/2015 14:42:52,973- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/
14/Jan/2015 14:42:52,974- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/
14/Jan/2015 14:42:52,974- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkNoDrop32x32.gif
14/Jan/2015 14:42:52,993- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/cursors.properties
14/Jan/2015 14:42:52,996- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkDrop32x32.gif
14/Jan/2015 14:42:52,999- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/invalid32x32.gif
14/Jan/2015 14:42:53,001- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveNoDrop32x32.gif
14/Jan/2015 14:42:53,003- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyNoDrop32x32.gif
14/Jan/2015 14:42:53,004- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveDrop32x32.gif
14/Jan/2015 14:42:53,005- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyDrop32x32.gif
14/Jan/2015 14:42:53,006- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/charsets.jar
14/Jan/2015 14:42:53,045- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/
14/Jan/2015 14:42:53,046- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.password.template
14/Jan/2015 14:42:53,048- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/snmp.acl.template
14/Jan/2015 14:42:53,050- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.access
14/Jan/2015 14:42:53,051- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/management.properties
14/Jan/2015 14:42:53,055- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/
14/Jan/2015 14:42:53,056- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiBold.ttf
14/Jan/2015 14:42:53,063- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightItalic.ttf
14/Jan/2015 14:42:53,069- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiItalic.ttf
14/Jan/2015 14:42:53,076- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterBold.ttf
14/Jan/2015 14:42:53,086- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansDemiBold.ttf
14/Jan/2015 14:42:53,096- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightRegular.ttf
14/Jan/2015 14:42:53,138- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansRegular.ttf
14/Jan/2015 14:42:53,156- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterRegular.ttf
14/Jan/2015 14:42:53,167- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/fonts.dir
14/Jan/2015 14:42:53,172- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/content-types.properties
14/Jan/2015 14:42:53,202- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/rt.jar
14/Jan/2015 14:42:53,873- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jexec
14/Jan/2015 14:42:54,013- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.properties.src
14/Jan/2015 14:42:54,023- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/applet/
14/Jan/2015 14:42:54,024- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/
14/Jan/2015 14:42:54,024- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunec.jar
14/Jan/2015 14:42:54,253- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/cldrdata.jar
14/Jan/2015 14:42:54,338- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/meta-index
14/Jan/2015 14:42:54,341- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunjce_provider.jar
14/Jan/2015 14:42:54,351- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/localedata.jar
14/Jan/2015 14:42:54,378- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/zipfs.jar
14/Jan/2015 14:42:54,383- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/dnsns.jar
14/Jan/2015 14:42:54,404- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/nashorn.jar
14/Jan/2015 14:42:54,440- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunpkcs11.jar
14/Jan/2015 14:42:54,450- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/
14/Jan/2015 14:42:54,451- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/profile.jfc
14/Jan/2015 14:42:54,454- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/default.jfc
14/Jan/2015 14:42:54,458- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/
14/Jan/2015 14:42:54,458- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/LINEAR_RGB.pf
14/Jan/2015 14:42:54,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/CIEXYZ.pf
14/Jan/2015 14:42:54,463- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/GRAY.pf
14/Jan/2015 14:42:54,466- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/sRGB.pf
14/Jan/2015 14:42:54,468- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/PYCC.pf
14/Jan/2015 14:42:54,476- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/logging.properties
14/Jan/2015 14:42:54,478- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/tzdb.dat
14/Jan/2015 14:42:54,502- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:42:54,510- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.bfc
14/Jan/2015 14:42:54,514- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/
14/Jan/2015 14:42:54,515- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterBoldOblique.ttf
14/Jan/2015 14:42:54,520- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterOblique.ttf
14/Jan/2015 14:42:54,526- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansOblique.ttf
14/Jan/2015 14:42:54,536- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansDemiOblique.ttf
14/Jan/2015 14:42:54,541- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/fonts.dir
14/Jan/2015 14:42:54,544- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfontj2d.properties
14/Jan/2015 14:42:54,549- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.properties.src
14/Jan/2015 14:42:54,552- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/sound.properties
14/Jan/2015 14:42:54,554- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.properties.src
14/Jan/2015 14:42:54,556- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.properties.src
14/Jan/2015 14:42:54,560- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.properties.src
14/Jan/2015 14:42:54,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/currency.data
14/Jan/2015 14:42:54,570- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jce.jar
14/Jan/2015 14:42:54,575- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jsse.jar
14/Jan/2015 14:42:54,584- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.bfc
14/Jan/2015 14:42:54,588- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/
14/Jan/2015 14:42:54,589- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdt_socket.so
14/Jan/2015 14:42:54,592- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2gss.so
14/Jan/2015 14:42:54,596- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libhprof.so
14/Jan/2015 14:42:54,601- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/
14/Jan/2015 14:42:54,602- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/Xusage.txt
14/Jan/2015 14:42:54,675- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjvm.so
14/Jan/2015 14:42:54,783- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjsig.so
14/Jan/2015 14:42:54,784- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pcsc.so
14/Jan/2015 14:42:54,787- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/
14/Jan/2015 14:42:54,788- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjsig.so
14/Jan/2015 14:42:54,788- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjvm.so
14/Jan/2015 14:42:54,871- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/Xusage.txt
14/Jan/2015 14:42:54,872- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libinstrument.so
14/Jan/2015 14:42:54,876- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnpt.so
14/Jan/2015 14:42:54,880- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdcpr.so
14/Jan/2015 14:42:54,886- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/
14/Jan/2015 14:42:54,886- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:42:54,887- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjvm.so
14/Jan/2015 14:42:54,933- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjsig.so
14/Jan/2015 14:42:54,934- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsplashscreen.so
14/Jan/2015 14:42:54,941- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnet.so
14/Jan/2015 14:42:54,952- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsdt.so
14/Jan/2015 14:42:54,955- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsound.so
14/Jan/2015 14:42:54,957- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnio.so
14/Jan/2015 14:42:54,962- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:42:54,969- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsoundalsa.so
14/Jan/2015 14:42:54,972- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjaas_unix.so
14/Jan/2015 14:42:54,975- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libkcms.so
14/Jan/2015 14:42:54,983- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/
14/Jan/2015 14:42:54,983- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/libjli.so
14/Jan/2015 14:42:54,987- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmanagement.so
14/Jan/2015 14:42:54,996- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libt2k.so
14/Jan/2015 14:42:55,008- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjawt.so
14/Jan/2015 14:42:55,011- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsunec.so
14/Jan/2015 14:42:55,017- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jvm.cfg
14/Jan/2015 14:42:55,030- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjdwp.so
14/Jan/2015 14:42:55,038- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libunpack.so
14/Jan/2015 14:42:55,043- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/liblcms.so
14/Jan/2015 14:42:55,053- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt_headless.so
14/Jan/2015 14:42:55,057- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libfontmanager.so
14/Jan/2015 14:42:55,067- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjpeg.so
14/Jan/2015 14:42:55,072- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libzip.so
14/Jan/2015 14:42:55,077- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt.so
14/Jan/2015 14:42:55,087- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsig.so
14/Jan/2015 14:42:55,090- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmlib_image.so
14/Jan/2015 14:42:55,106- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libverify.so
14/Jan/2015 14:42:55,110- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjfr.so
14/Jan/2015 14:42:55,112- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsctp.so
14/Jan/2015 14:42:55,117- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pkcs11.so
14/Jan/2015 14:42:55,120- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava.so
14/Jan/2015 14:42:55,125- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfont.properties.ja
14/Jan/2015 14:42:55,127- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.bfc
14/Jan/2015 14:42:55,132- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/flavormap.properties
14/Jan/2015 14:42:55,156- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME.txt
14/Jan/2015 14:42:55,162- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/
14/Jan/2015 14:42:55,163- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/orbd
14/Jan/2015 14:42:55,168- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/keytool
14/Jan/2015 14:42:55,172- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmid
14/Jan/2015 14:42:55,174- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmiregistry
14/Jan/2015 14:42:55,177- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/pack200
14/Jan/2015 14:42:55,181- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/policytool
14/Jan/2015 14:42:55,186- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/servertool
14/Jan/2015 14:42:55,189- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/jjs
14/Jan/2015 14:42:55,191- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/tnameserv
14/Jan/2015 14:42:55,194- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/java
14/Jan/2015 14:42:55,212- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/unpack200
14/Jan/2015 14:42:55,220- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/COPYRIGHT
14/Jan/2015 14:42:55,221- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/release
14/Jan/2015 14:42:55,224- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME-JAVAFX.txt
14/Jan/2015 14:42:55,233- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/README
14/Jan/2015 14:42:55,235- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/
14/Jan/2015 14:42:55,236- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/
14/Jan/2015 14:42:55,236- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jsse.jar
14/Jan/2015 14:42:55,244- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/
14/Jan/2015 14:42:55,245- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.access
14/Jan/2015 14:42:55,247- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/management.properties
14/Jan/2015 14:42:55,251- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/snmp.acl.template
14/Jan/2015 14:42:55,253- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.password.template
14/Jan/2015 14:42:55,254- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/classlist
14/Jan/2015 14:42:55,259- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/
14/Jan/2015 14:42:55,259- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/localedata.jar
14/Jan/2015 14:42:55,283- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunjce_provider.jar
14/Jan/2015 14:42:55,291- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/meta-index
14/Jan/2015 14:42:55,293- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunpkcs11.jar
14/Jan/2015 14:42:55,304- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunec.jar
14/Jan/2015 14:42:55,364- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/currency.data
14/Jan/2015 14:42:55,367- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/meta-index
14/Jan/2015 14:42:55,382- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:42:55,390- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jce.jar
14/Jan/2015 14:42:55,394- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/
14/Jan/2015 14:42:55,395- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsctp.so
14/Jan/2015 14:42:55,399- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pcsc.so
14/Jan/2015 14:42:55,401- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava.so
14/Jan/2015 14:42:55,407- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsig.so
14/Jan/2015 14:42:55,408- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/
14/Jan/2015 14:42:55,408- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjsig.so
14/Jan/2015 14:42:55,409- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjvm.so
14/Jan/2015 14:42:55,491- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/Xusage.txt
14/Jan/2015 14:42:55,492- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libhprof.so
14/Jan/2015 14:42:55,498- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jvm.cfg
14/Jan/2015 14:42:55,500- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2gss.so
14/Jan/2015 14:42:55,503- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/
14/Jan/2015 14:42:55,504- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/Xusage.txt
14/Jan/2015 14:42:55,505- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjvm.so
14/Jan/2015 14:42:55,616- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjsig.so
14/Jan/2015 14:42:55,616- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libzip.so
14/Jan/2015 14:42:55,620- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pkcs11.so
14/Jan/2015 14:42:55,623- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/
14/Jan/2015 14:42:55,624- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/libjli.so
14/Jan/2015 14:42:55,628- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/
14/Jan/2015 14:42:55,628- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:42:55,631- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjvm.so
14/Jan/2015 14:42:55,674- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjsig.so
14/Jan/2015 14:42:55,675- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:42:55,678- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsdt.so
14/Jan/2015 14:42:55,681- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libmanagement.so
14/Jan/2015 14:42:55,686- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnio.so
14/Jan/2015 14:42:55,690- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjaas_unix.so
14/Jan/2015 14:42:55,691- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnpt.so
14/Jan/2015 14:42:55,692- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsunec.so
14/Jan/2015 14:42:55,702- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libinstrument.so
14/Jan/2015 14:42:55,706- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libverify.so
14/Jan/2015 14:42:55,711- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnet.so
14/Jan/2015 14:42:55,718- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/tzdb.dat
14/Jan/2015 14:42:55,723- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/content-types.properties
14/Jan/2015 14:42:55,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/rt.jar
14/Jan/2015 14:42:56,058- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management-agent.jar
14/Jan/2015 14:42:56,059- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/net.properties
14/Jan/2015 14:42:56,060- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/logging.properties
14/Jan/2015 14:42:56,060- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jvm.hprof.txt
14/Jan/2015 14:42:56,061- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/
14/Jan/2015 14:42:56,061- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/US_export_policy.jar
14/Jan/2015 14:42:56,063- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.policy
14/Jan/2015 14:42:56,065- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/trusted.libraries
14/Jan/2015 14:42:56,066- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/cacerts
14/Jan/2015 14:42:56,072- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/blacklist
14/Jan/2015 14:42:56,073- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.security
14/Jan/2015 14:42:56,077- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/local_policy.jar
14/Jan/2015 14:42:56,078- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/calendars.properties
14/Jan/2015 14:42:56,080- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/resources.jar
14/Jan/2015 14:42:56,092- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/
14/Jan/2015 14:42:56,092- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/java
14/Jan/2015 14:42:56,093- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/keytool
14/Jan/2015 14:42:56,094- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmiregistry
14/Jan/2015 14:42:56,095- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmid
14/Jan/2015 14:42:56,097- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/release
14/Jan/2015 14:42:56,101- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/
14/Jan/2015 14:42:56,102- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/
14/Jan/2015 14:42:56,103- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/
14/Jan/2015 14:42:56,104- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/
14/Jan/2015 14:42:56,105- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/libj2pkcs11.so
14/Jan/2015 14:42:56,108- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/
14/Jan/2015 14:42:56,108- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/sunpkcs11.jar
14/Jan/2015 14:42:56,116- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/
14/Jan/2015 14:42:56,117- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/
14/Jan/2015 14:42:56,117- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/
14/Jan/2015 14:42:56,118- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/nashorn.jar
14/Jan/2015 14:42:56,151- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/
14/Jan/2015 14:42:56,151- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/
14/Jan/2015 14:42:56,151- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/
14/Jan/2015 14:42:56,152- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/localedata.jar
14/Jan/2015 14:42:56,177- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/
14/Jan/2015 14:42:56,177- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/
14/Jan/2015 14:42:56,178- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/
14/Jan/2015 14:42:56,178- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/libsunec.so
14/Jan/2015 14:42:56,185- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/
14/Jan/2015 14:42:56,185- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/sunec.jar
14/Jan/2015 14:42:56,248- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/
14/Jan/2015 14:42:56,248- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/
14/Jan/2015 14:42:56,249- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/
14/Jan/2015 14:42:56,249- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libdt_socket.so
14/Jan/2015 14:42:56,252- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjdwp.so
14/Jan/2015 14:42:56,258- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:42:56,261- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libnpt.so
14/Jan/2015 14:42:56,263- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libhprof.so
14/Jan/2015 14:42:56,269- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/jvm.hprof.txt
14/Jan/2015 14:42:56,270- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/
14/Jan/2015 14:42:56,271- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/
14/Jan/2015 14:42:56,271- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/gcf.jar
14/Jan/2015 14:42:56,379- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/
14/Jan/2015 14:42:56,380- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/
14/Jan/2015 14:42:56,381- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/charsets.jar
14/Jan/2015 14:42:56,423- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/
14/Jan/2015 14:42:56,423- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/
14/Jan/2015 14:42:56,424- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/
14/Jan/2015 14:42:56,424- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjsig.so
14/Jan/2015 14:42:56,425- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjava.so
14/Jan/2015 14:42:56,431- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/
14/Jan/2015 14:42:56,432- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/libjli.so
14/Jan/2015 14:42:56,436- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libzip.so
14/Jan/2015 14:42:56,442- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jvm.cfg
14/Jan/2015 14:42:56,444- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libsunec.so
14/Jan/2015 14:42:56,451- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/
14/Jan/2015 14:42:56,460- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:42:56,462- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjvm.so
14/Jan/2015 14:42:56,507- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjsig.so
14/Jan/2015 14:42:56,508- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libverify.so
14/Jan/2015 14:42:56,511- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/
14/Jan/2015 14:42:56,512- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjvm.so
14/Jan/2015 14:42:56,620- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjsig.so
14/Jan/2015 14:42:56,620- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/Xusage.txt
14/Jan/2015 14:42:56,622- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libj2pkcs11.so
14/Jan/2015 14:42:56,625- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnio.so
14/Jan/2015 14:42:56,632- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnet.so
14/Jan/2015 14:42:56,636- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/
14/Jan/2015 14:42:56,637- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjvm.so
14/Jan/2015 14:42:56,720- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjsig.so
14/Jan/2015 14:42:56,721- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/Xusage.txt
14/Jan/2015 14:42:56,723- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/rt.jar
14/Jan/2015 14:42:56,981- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/meta-index
14/Jan/2015 14:42:56,984- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/
14/Jan/2015 14:42:56,985- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/cacerts
14/Jan/2015 14:42:56,989- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/US_export_policy.jar
14/Jan/2015 14:42:56,991- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.security
14/Jan/2015 14:42:56,994- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/blacklist
14/Jan/2015 14:42:56,998- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/local_policy.jar
14/Jan/2015 14:42:56,999- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/trusted.libraries
14/Jan/2015 14:42:57,000- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.policy
14/Jan/2015 14:42:57,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jce.jar
14/Jan/2015 14:42:57,007- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/logging.properties
14/Jan/2015 14:42:57,009- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/resources.jar
14/Jan/2015 14:42:57,022- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:42:57,030- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/
14/Jan/2015 14:42:57,031- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/localedata.jar
14/Jan/2015 14:42:57,055- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/meta-index
14/Jan/2015 14:42:57,056- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunpkcs11.jar
14/Jan/2015 14:42:57,064- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunec.jar
14/Jan/2015 14:42:57,128- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunjce_provider.jar
14/Jan/2015 14:42:57,138- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/currency.data
14/Jan/2015 14:42:57,139- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/calendars.properties
14/Jan/2015 14:42:57,140- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/classlist
14/Jan/2015 14:42:57,144- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/tzdb.dat
14/Jan/2015 14:42:57,151- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/net.properties
14/Jan/2015 14:42:57,152- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jsse.jar
14/Jan/2015 14:42:57,162- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/content-types.properties
14/Jan/2015 14:42:57,164- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/release
14/Jan/2015 14:42:57,167- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/
14/Jan/2015 14:42:57,167- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmiregistry
14/Jan/2015 14:42:57,169- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmid
14/Jan/2015 14:42:57,170- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/keytool
14/Jan/2015 14:42:57,171- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/java
14/Jan/2015 14:42:57,173- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/
14/Jan/2015 14:42:57,173- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/release
14/Jan/2015 14:42:57,178- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/
14/Jan/2015 14:42:57,178- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/classlist
14/Jan/2015 14:42:57,184- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/rt.jar
14/Jan/2015 14:42:57,328- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/tzdb.dat
14/Jan/2015 14:42:57,334- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/net.properties
14/Jan/2015 14:42:57,336- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/calendars.properties
14/Jan/2015 14:42:57,338- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:42:57,345- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/currency.data
14/Jan/2015 14:42:57,348- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jsse.jar
14/Jan/2015 14:42:57,356- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/meta-index
14/Jan/2015 14:42:57,359- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/content-types.properties
14/Jan/2015 14:42:57,360- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/
14/Jan/2015 14:42:57,361- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/US_export_policy.jar
14/Jan/2015 14:42:57,362- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/cacerts
14/Jan/2015 14:42:57,369- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.security
14/Jan/2015 14:42:57,374- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/local_policy.jar
14/Jan/2015 14:42:57,376- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.policy
14/Jan/2015 14:42:57,377- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/trusted.libraries
14/Jan/2015 14:42:57,378- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/blacklist
14/Jan/2015 14:42:57,380- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/
14/Jan/2015 14:42:57,381- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunpkcs11.jar
14/Jan/2015 14:42:57,388- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/meta-index
14/Jan/2015 14:42:57,389- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunec.jar
14/Jan/2015 14:42:57,452- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/localedata.jar
14/Jan/2015 14:42:57,480- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunjce_provider.jar
14/Jan/2015 14:42:57,488- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jce.jar
14/Jan/2015 14:42:57,493- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/resources.jar
14/Jan/2015 14:42:57,499- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/logging.properties
14/Jan/2015 14:42:57,501- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/
14/Jan/2015 14:42:57,502- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libverify.so
14/Jan/2015 14:42:57,505- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/
14/Jan/2015 14:42:57,506- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/libjli.so
14/Jan/2015 14:42:57,510- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libzip.so
14/Jan/2015 14:42:57,516- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/
14/Jan/2015 14:42:57,517- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjvm.so
14/Jan/2015 14:42:57,559- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjsig.so
14/Jan/2015 14:42:57,560- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:42:57,561- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnet.so
14/Jan/2015 14:42:57,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jvm.cfg
14/Jan/2015 14:42:57,569- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnio.so
14/Jan/2015 14:42:57,573- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libj2pkcs11.so
14/Jan/2015 14:42:57,576- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjava.so
14/Jan/2015 14:42:57,582- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/
14/Jan/2015 14:42:57,582- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjsig.so
14/Jan/2015 14:42:57,583- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/Xusage.txt
14/Jan/2015 14:42:57,584- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjvm.so
14/Jan/2015 14:42:57,696- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjsig.so
14/Jan/2015 14:42:57,697- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/
14/Jan/2015 14:42:57,698- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjsig.so
14/Jan/2015 14:42:57,699- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/Xusage.txt
14/Jan/2015 14:42:57,701- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjvm.so
14/Jan/2015 14:42:57,785- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libsunec.so
14/Jan/2015 14:42:57,791- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/
14/Jan/2015 14:42:57,792- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/keytool
14/Jan/2015 14:42:57,792- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/java
14/Jan/2015 14:42:57,794- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/
14/Jan/2015 14:42:57,847- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/
14/Jan/2015 14:42:57,847- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/
14/Jan/2015 14:42:57,848- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/
14/Jan/2015 14:42:57,848- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/
14/Jan/2015 14:42:57,848- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/jfxrt-controls.jar
14/Jan/2015 14:42:57,900- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/
14/Jan/2015 14:42:57,900- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/
14/Jan/2015 14:42:57,901- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.platform.properties
14/Jan/2015 14:42:57,904- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.properties
14/Jan/2015 14:42:57,908- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/
14/Jan/2015 14:42:57,909- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/liblens_porting.so
14/Jan/2015 14:42:57,914- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_iio.so
14/Jan/2015 14:42:57,922- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_sw.so
14/Jan/2015 14:42:57,926- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font_t2k.so
14/Jan/2015 14:42:57,953- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_eglfb.so
14/Jan/2015 14:42:57,974- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass.so
14/Jan/2015 14:42:57,987- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font.so
14/Jan/2015 14:42:57,993- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_es2_eglfb.so
14/Jan/2015 14:42:58,003- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_common.so
14/Jan/2015 14:42:58,011- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_dfb.so
14/Jan/2015 14:42:58,022- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/
14/Jan/2015 14:42:58,022- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/jfxrt-graphics.jar
14/Jan/2015 14:42:58,219- CreateJreController: Staring JRE Creation
14/Jan/2015 14:42:58,219- CreateJreController: Creator location: C:\Users\3539\wpilib\tools\.\ejdk1.8.0_06\lib\JREC reate.jar
14/Jan/2015 14:42:58,219- CreateJreController: Command: [java, -jar, C:\Users\3539\wpilib\tools\.\ejdk1.8.0_06\lib\JREC reate.jar, --dest, JRE, --profile, compact2, --vm, client, --keep-debug-info, --debug]
14/Jan/2015 14:42:59,085- CreateJreController: Successfully Created JRE!
14/Jan/2015 14:43:03,762- ConnectRoboRioController: Connecting to roborio-3539.local
14/Jan/2015 14:43:03,763- ConnectRoboRioController: Checking for mDNS connection to the roboRio
14/Jan/2015 14:43:07,078- ConnectRoboRioController: Found mDNS connection
14/Jan/2015 14:43:07,079- ConnectRoboRioController: Connected to the roboRio at roborio-3539.local
14/Jan/2015 14:43:07,119- DeployController: Starting zip
14/Jan/2015 14:43:07,127- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE, putting tar entry is JRE
14/Jan/2015 14:43:07,128- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\bin, putting tar entry is JRE/bin
14/Jan/2015 14:43:07,128- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\bin\java, putting tar entry is JRE/bin/java
14/Jan/2015 14:43:07,130- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\bin\keytool, putting tar entry is JRE/bin/keytool
14/Jan/2015 14:43:07,132- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\bin\rmid, putting tar entry is JRE/bin/rmid
14/Jan/2015 14:43:07,133- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\bin\rmiregistry, putting tar entry is JRE/bin/rmiregistry
14/Jan/2015 14:43:07,134- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\bom, putting tar entry is JRE/bom
14/Jan/2015 14:43:07,135- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib, putting tar entry is JRE/lib
14/Jan/2015 14:43:07,136- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm, putting tar entry is JRE/lib/arm
14/Jan/2015 14:43:07,137- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\client, putting tar entry is JRE/lib/arm/client
14/Jan/2015 14:43:07,137- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\client\li bjsig.so, putting tar entry is JRE/lib/arm/client/libjsig.so
14/Jan/2015 14:43:07,138- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\client\li bjvm.so, putting tar entry is JRE/lib/arm/client/libjvm.so
14/Jan/2015 14:43:07,589- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\client\Xu sage.txt, putting tar entry is JRE/lib/arm/client/Xusage.txt
14/Jan/2015 14:43:07,589- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\jli, putting tar entry is JRE/lib/arm/jli
14/Jan/2015 14:43:07,590- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\jli\libjl i.so, putting tar entry is JRE/lib/arm/jli/libjli.so
14/Jan/2015 14:43:07,600- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\jvm.cfg, putting tar entry is JRE/lib/arm/jvm.cfg
14/Jan/2015 14:43:07,601- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libdt_soc ket.so, putting tar entry is JRE/lib/arm/libdt_socket.so
14/Jan/2015 14:43:07,605- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libhprof. so, putting tar entry is JRE/lib/arm/libhprof.so
14/Jan/2015 14:43:07,618- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libjava.s o, putting tar entry is JRE/lib/arm/libjava.so
14/Jan/2015 14:43:07,634- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libjava_c rw_demo.so, putting tar entry is JRE/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:43:07,638- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libjdwp.s o, putting tar entry is JRE/lib/arm/libjdwp.so
14/Jan/2015 14:43:07,659- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libjsig.s o, putting tar entry is JRE/lib/arm/libjsig.so
14/Jan/2015 14:43:07,662- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libnet.so , putting tar entry is JRE/lib/arm/libnet.so
14/Jan/2015 14:43:07,671- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libnio.so , putting tar entry is JRE/lib/arm/libnio.so
14/Jan/2015 14:43:07,679- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libnpt.so , putting tar entry is JRE/lib/arm/libnpt.so
14/Jan/2015 14:43:07,682- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libverify .so, putting tar entry is JRE/lib/arm/libverify.so
14/Jan/2015 14:43:07,688- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libzip.so , putting tar entry is JRE/lib/arm/libzip.so
14/Jan/2015 14:43:07,699- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\calendars.pro perties, putting tar entry is JRE/lib/calendars.properties
14/Jan/2015 14:43:07,700- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\classlist, putting tar entry is JRE/lib/classlist
14/Jan/2015 14:43:07,709- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\content-types.properties, putting tar entry is JRE/lib/content-types.properties
14/Jan/2015 14:43:07,713- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\currency.data , putting tar entry is JRE/lib/currency.data
14/Jan/2015 14:43:07,715- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\ext, putting tar entry is JRE/lib/ext
14/Jan/2015 14:43:07,716- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\ext\meta-index, putting tar entry is JRE/lib/ext/meta-index
14/Jan/2015 14:43:07,717- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\ext\sunjce_pr ovider.jar, putting tar entry is JRE/lib/ext/sunjce_provider.jar
14/Jan/2015 14:43:07,739- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\hijrah-config-umalqura.properties, putting tar entry is JRE/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:43:07,747- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\jce.jar, putting tar entry is JRE/lib/jce.jar
14/Jan/2015 14:43:07,759- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\jsse.jar, putting tar entry is JRE/lib/jsse.jar
14/Jan/2015 14:43:07,788- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\jvm.hprof.txt , putting tar entry is JRE/lib/jvm.hprof.txt
14/Jan/2015 14:43:07,789- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\logging.prope rties, putting tar entry is JRE/lib/logging.properties
14/Jan/2015 14:43:07,790- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\meta-index, putting tar entry is JRE/lib/meta-index
14/Jan/2015 14:43:07,791- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\net.propertie s, putting tar entry is JRE/lib/net.properties
14/Jan/2015 14:43:07,792- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\resources.jar , putting tar entry is JRE/lib/resources.jar
14/Jan/2015 14:43:07,832- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\rt.jar, putting tar entry is JRE/lib/rt.jar
14/Jan/2015 14:43:08,886- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security, putting tar entry is JRE/lib/security
14/Jan/2015 14:43:08,886- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\blac klist, putting tar entry is JRE/lib/security/blacklist
14/Jan/2015 14:43:08,887- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\cace rts, putting tar entry is JRE/lib/security/cacerts
14/Jan/2015 14:43:08,897- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\java .policy, putting tar entry is JRE/lib/security/java.policy
14/Jan/2015 14:43:08,898- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\java .security, putting tar entry is JRE/lib/security/java.security
14/Jan/2015 14:43:08,903- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\loca l_policy.jar, putting tar entry is JRE/lib/security/local_policy.jar
14/Jan/2015 14:43:08,904- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\trus ted.libraries, putting tar entry is JRE/lib/security/trusted.libraries
14/Jan/2015 14:43:08,904- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\US_e xport_policy.jar, putting tar entry is JRE/lib/security/US_export_policy.jar
14/Jan/2015 14:43:08,905- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\tzdb.dat, putting tar entry is JRE/lib/tzdb.dat
14/Jan/2015 14:43:08,919- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\release, putting tar entry is JRE/release
14/Jan/2015 14:43:09,941- DeployController: Failure to send JRE to the roboRio
com.jcraft.jsch.JSchException: java.net.ConnectException: Connection refused: connect
at com.jcraft.jsch.Util.createSocket(Util.java:349) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:215) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:183) ~[java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController.lambda$initialize$10(DeployControlle r.java:85) [java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController$$Lambda$237/997278.run(Unknown Source) [java-installer.jar:?]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_25]
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method) ~[?:1.8.0_25]
at java.net.DualStackPlainSocketImpl.socketConnect(Un known Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connectToAddress( Unknown Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.PlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.SocksSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.Socket.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.Socket.<init>(Unknown Source) ~[?:1.8.0_25]
at com.jcraft.jsch.Util.createSocket(Util.java:343) ~[java-installer.jar:?]
... 5 more
14/Jan/2015 14:45:35,983- MainApp: Exiting installer from popup
14/Jan/2015 14:45:50,337- MainApp: Found JRE, checking hash
14/Jan/2015 14:45:51,442- MainApp: Computed hash is 082F08397B0D3F63844AB472B5111C8C, official hash is 082F08397B0D3F63844AB472B5111C8C
14/Jan/2015 14:45:52,711- UntarController: Starting decompress of file C:\Users\3539\wpilib\tools\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\3539\wpilib\tools
14/Jan/2015 14:45:52,727- UntarController: Untarring ejdk1.8.0_06/bin/
14/Jan/2015 14:45:52,727- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.sh
14/Jan/2015 14:45:52,729- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.bat
14/Jan/2015 14:45:52,730- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.config.properties
14/Jan/2015 14:45:52,732- UntarController: Untarring ejdk1.8.0_06/doc/
14/Jan/2015 14:45:52,732- UntarController: Untarring ejdk1.8.0_06/lib/
14/Jan/2015 14:45:52,732- UntarController: Untarring ejdk1.8.0_06/lib/JRECreate.jar
14/Jan/2015 14:45:52,748- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/
14/Jan/2015 14:45:52,749- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/
14/Jan/2015 14:45:52,750- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/
14/Jan/2015 14:45:52,750- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/
14/Jan/2015 14:45:52,750- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklist
14/Jan/2015 14:45:52,752- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/US_export_policy.jar
14/Jan/2015 14:45:52,754- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.security
14/Jan/2015 14:45:52,760- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.policy
14/Jan/2015 14:45:52,762- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/local_policy.jar
14/Jan/2015 14:45:52,763- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklisted.certs
14/Jan/2015 14:45:52,764- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/trusted.libraries
14/Jan/2015 14:45:52,765- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/cacerts
14/Jan/2015 14:45:52,772- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.bfc
14/Jan/2015 14:45:52,773- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.bfc
14/Jan/2015 14:45:52,780- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/meta-index
14/Jan/2015 14:45:52,782- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.bfc
14/Jan/2015 14:45:52,785- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/resources.jar
14/Jan/2015 14:45:52,813- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.properties.src
14/Jan/2015 14:45:52,817- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/classlist
14/Jan/2015 14:45:52,822- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/net.properties
14/Jan/2015 14:45:52,824- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management-agent.jar
14/Jan/2015 14:45:52,825- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr.jar
14/Jan/2015 14:45:52,834- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jvm.hprof.txt
14/Jan/2015 14:45:52,835- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/calendars.properties
14/Jan/2015 14:45:52,837- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/
14/Jan/2015 14:45:52,837- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/
14/Jan/2015 14:45:52,838- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkNoDrop32x32.gif
14/Jan/2015 14:45:52,840- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/cursors.properties
14/Jan/2015 14:45:52,841- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkDrop32x32.gif
14/Jan/2015 14:45:52,842- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/invalid32x32.gif
14/Jan/2015 14:45:52,844- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveNoDrop32x32.gif
14/Jan/2015 14:45:52,847- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyNoDrop32x32.gif
14/Jan/2015 14:45:52,850- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveDrop32x32.gif
14/Jan/2015 14:45:52,851- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyDrop32x32.gif
14/Jan/2015 14:45:52,852- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/charsets.jar
14/Jan/2015 14:45:52,898- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/
14/Jan/2015 14:45:52,898- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.password.template
14/Jan/2015 14:45:52,910- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/snmp.acl.template
14/Jan/2015 14:45:52,913- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.access
14/Jan/2015 14:45:52,914- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/management.properties
14/Jan/2015 14:45:52,918- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/
14/Jan/2015 14:45:52,919- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiBold.ttf
14/Jan/2015 14:45:52,926- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightItalic.ttf
14/Jan/2015 14:45:52,933- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiItalic.ttf
14/Jan/2015 14:45:52,941- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterBold.ttf
14/Jan/2015 14:45:52,951- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansDemiBold.ttf
14/Jan/2015 14:45:52,964- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightRegular.ttf
14/Jan/2015 14:45:52,978- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansRegular.ttf
14/Jan/2015 14:45:53,004- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterRegular.ttf
14/Jan/2015 14:45:53,015- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/fonts.dir
14/Jan/2015 14:45:53,017- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/content-types.properties
14/Jan/2015 14:45:53,018- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/rt.jar
14/Jan/2015 14:45:53,669- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jexec
14/Jan/2015 14:45:53,670- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.properties.src
14/Jan/2015 14:45:53,676- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/applet/
14/Jan/2015 14:45:53,677- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/
14/Jan/2015 14:45:53,677- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunec.jar
14/Jan/2015 14:45:53,739- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/cldrdata.jar
14/Jan/2015 14:45:53,818- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/meta-index
14/Jan/2015 14:45:53,820- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunjce_provider.jar
14/Jan/2015 14:45:53,829- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/localedata.jar
14/Jan/2015 14:45:53,856- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/zipfs.jar
14/Jan/2015 14:45:53,861- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/dnsns.jar
14/Jan/2015 14:45:53,879- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/nashorn.jar
14/Jan/2015 14:45:53,917- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunpkcs11.jar
14/Jan/2015 14:45:53,927- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/
14/Jan/2015 14:45:53,927- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/profile.jfc
14/Jan/2015 14:45:53,930- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/default.jfc
14/Jan/2015 14:45:53,933- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/
14/Jan/2015 14:45:53,934- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/LINEAR_RGB.pf
14/Jan/2015 14:45:53,935- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/CIEXYZ.pf
14/Jan/2015 14:45:53,939- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/GRAY.pf
14/Jan/2015 14:45:53,940- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/sRGB.pf
14/Jan/2015 14:45:53,942- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/PYCC.pf
14/Jan/2015 14:45:53,951- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/logging.properties
14/Jan/2015 14:45:53,952- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/tzdb.dat
14/Jan/2015 14:45:53,959- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:45:53,967- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.bfc
14/Jan/2015 14:45:53,970- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/
14/Jan/2015 14:45:53,970- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterBoldOblique.ttf
14/Jan/2015 14:45:53,980- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterOblique.ttf
14/Jan/2015 14:45:53,986- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansOblique.ttf
14/Jan/2015 14:45:53,996- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansDemiOblique.ttf
14/Jan/2015 14:45:54,001- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/fonts.dir
14/Jan/2015 14:45:54,003- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfontj2d.properties
14/Jan/2015 14:45:54,010- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.properties.src
14/Jan/2015 14:45:54,014- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/sound.properties
14/Jan/2015 14:45:54,015- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.properties.src
14/Jan/2015 14:45:54,016- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.properties.src
14/Jan/2015 14:45:54,019- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.properties.src
14/Jan/2015 14:45:54,024- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/currency.data
14/Jan/2015 14:45:54,025- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jce.jar
14/Jan/2015 14:45:54,030- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jsse.jar
14/Jan/2015 14:45:54,039- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.bfc
14/Jan/2015 14:45:54,040- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/
14/Jan/2015 14:45:54,040- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdt_socket.so
14/Jan/2015 14:45:54,043- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2gss.so
14/Jan/2015 14:45:54,047- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libhprof.so
14/Jan/2015 14:45:54,057- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/
14/Jan/2015 14:45:54,057- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/Xusage.txt
14/Jan/2015 14:45:54,059- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjvm.so
14/Jan/2015 14:45:54,170- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjsig.so
14/Jan/2015 14:45:54,170- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pcsc.so
14/Jan/2015 14:45:54,173- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/
14/Jan/2015 14:45:54,173- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjsig.so
14/Jan/2015 14:45:54,174- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjvm.so
14/Jan/2015 14:45:54,261- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/Xusage.txt
14/Jan/2015 14:45:54,262- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libinstrument.so
14/Jan/2015 14:45:54,266- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnpt.so
14/Jan/2015 14:45:54,267- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdcpr.so
14/Jan/2015 14:45:54,274- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/
14/Jan/2015 14:45:54,274- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:45:54,275- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjvm.so
14/Jan/2015 14:45:54,324- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjsig.so
14/Jan/2015 14:45:54,324- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsplashscreen.so
14/Jan/2015 14:45:54,331- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnet.so
14/Jan/2015 14:45:54,335- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsdt.so
14/Jan/2015 14:45:54,336- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsound.so
14/Jan/2015 14:45:54,338- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnio.so
14/Jan/2015 14:45:54,343- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:45:54,347- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsoundalsa.so
14/Jan/2015 14:45:54,350- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjaas_unix.so
14/Jan/2015 14:45:54,351- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libkcms.so
14/Jan/2015 14:45:54,360- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/
14/Jan/2015 14:45:54,361- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/libjli.so
14/Jan/2015 14:45:54,364- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmanagement.so
14/Jan/2015 14:45:54,368- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libt2k.so
14/Jan/2015 14:45:54,378- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjawt.so
14/Jan/2015 14:45:54,379- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsunec.so
14/Jan/2015 14:45:54,390- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jvm.cfg
14/Jan/2015 14:45:54,392- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjdwp.so
14/Jan/2015 14:45:54,399- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libunpack.so
14/Jan/2015 14:45:54,404- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/liblcms.so
14/Jan/2015 14:45:54,414- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt_headless.so
14/Jan/2015 14:45:54,417- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libfontmanager.so
14/Jan/2015 14:45:54,427- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjpeg.so
14/Jan/2015 14:45:54,434- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libzip.so
14/Jan/2015 14:45:54,440- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt.so
14/Jan/2015 14:45:54,452- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsig.so
14/Jan/2015 14:45:54,454- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmlib_image.so
14/Jan/2015 14:45:54,470- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libverify.so
14/Jan/2015 14:45:54,476- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjfr.so
14/Jan/2015 14:45:54,480- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsctp.so
14/Jan/2015 14:45:54,483- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pkcs11.so
14/Jan/2015 14:45:54,487- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava.so
14/Jan/2015 14:45:54,494- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfont.properties.ja
14/Jan/2015 14:45:54,496- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.bfc
14/Jan/2015 14:45:54,497- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/flavormap.properties
14/Jan/2015 14:45:54,498- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME.txt
14/Jan/2015 14:45:54,506- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/
14/Jan/2015 14:45:54,506- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/orbd
14/Jan/2015 14:45:54,509- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/keytool
14/Jan/2015 14:45:54,511- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmid
14/Jan/2015 14:45:54,512- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmiregistry
14/Jan/2015 14:45:54,514- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/pack200
14/Jan/2015 14:45:54,515- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/policytool
14/Jan/2015 14:45:54,518- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/servertool
14/Jan/2015 14:45:54,520- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/jjs
14/Jan/2015 14:45:54,523- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/tnameserv
14/Jan/2015 14:45:54,525- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/java
14/Jan/2015 14:45:54,526- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/unpack200
14/Jan/2015 14:45:54,532- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/COPYRIGHT
14/Jan/2015 14:45:54,534- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/release
14/Jan/2015 14:45:54,535- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME-JAVAFX.txt
14/Jan/2015 14:45:54,545- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/README
14/Jan/2015 14:45:54,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/
14/Jan/2015 14:45:54,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/
14/Jan/2015 14:45:54,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jsse.jar
14/Jan/2015 14:45:54,557- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/
14/Jan/2015 14:45:54,558- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.access
14/Jan/2015 14:45:54,559- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/management.properties
14/Jan/2015 14:45:54,564- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/snmp.acl.template
14/Jan/2015 14:45:54,565- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.password.template
14/Jan/2015 14:45:54,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/classlist
14/Jan/2015 14:45:54,574- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/
14/Jan/2015 14:45:54,575- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/localedata.jar
14/Jan/2015 14:45:54,600- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunjce_provider.jar
14/Jan/2015 14:45:54,609- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/meta-index
14/Jan/2015 14:45:54,611- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunpkcs11.jar
14/Jan/2015 14:45:54,620- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunec.jar
14/Jan/2015 14:45:54,691- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/currency.data
14/Jan/2015 14:45:54,692- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/meta-index
14/Jan/2015 14:45:54,693- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:45:54,700- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jce.jar
14/Jan/2015 14:45:54,706- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/
14/Jan/2015 14:45:54,706- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsctp.so
14/Jan/2015 14:45:54,709- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pcsc.so
14/Jan/2015 14:45:54,710- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava.so
14/Jan/2015 14:45:54,717- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsig.so
14/Jan/2015 14:45:54,719- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/
14/Jan/2015 14:45:54,720- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjsig.so
14/Jan/2015 14:45:54,721- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjvm.so
14/Jan/2015 14:45:54,805- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/Xusage.txt
14/Jan/2015 14:45:54,806- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libhprof.so
14/Jan/2015 14:45:54,810- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jvm.cfg
14/Jan/2015 14:45:54,811- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2gss.so
14/Jan/2015 14:45:54,816- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/
14/Jan/2015 14:45:54,817- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/Xusage.txt
14/Jan/2015 14:45:54,818- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjvm.so
14/Jan/2015 14:45:54,933- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjsig.so
14/Jan/2015 14:45:54,934- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libzip.so
14/Jan/2015 14:45:54,939- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pkcs11.so
14/Jan/2015 14:45:54,942- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/
14/Jan/2015 14:45:54,943- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/libjli.so
14/Jan/2015 14:45:54,947- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/
14/Jan/2015 14:45:54,948- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:45:54,950- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjvm.so
14/Jan/2015 14:45:54,998- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjsig.so
14/Jan/2015 14:45:54,999- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:45:55,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsdt.so
14/Jan/2015 14:45:55,003- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libmanagement.so
14/Jan/2015 14:45:55,008- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnio.so
14/Jan/2015 14:45:55,012- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjaas_unix.so
14/Jan/2015 14:45:55,013- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnpt.so
14/Jan/2015 14:45:55,014- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsunec.so
14/Jan/2015 14:45:55,021- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libinstrument.so
14/Jan/2015 14:45:55,026- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libverify.so
14/Jan/2015 14:45:55,029- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnet.so
14/Jan/2015 14:45:55,033- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/tzdb.dat
14/Jan/2015 14:45:55,039- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/content-types.properties
14/Jan/2015 14:45:55,041- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/rt.jar
14/Jan/2015 14:45:55,361- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management-agent.jar
14/Jan/2015 14:45:55,362- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/net.properties
14/Jan/2015 14:45:55,363- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/logging.properties
14/Jan/2015 14:45:55,364- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jvm.hprof.txt
14/Jan/2015 14:45:55,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/
14/Jan/2015 14:45:55,366- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/US_export_policy.jar
14/Jan/2015 14:45:55,367- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.policy
14/Jan/2015 14:45:55,368- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/trusted.libraries
14/Jan/2015 14:45:55,368- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/cacerts
14/Jan/2015 14:45:55,374- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/blacklist
14/Jan/2015 14:45:55,375- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.security
14/Jan/2015 14:45:55,379- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/local_policy.jar
14/Jan/2015 14:45:55,380- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/calendars.properties
14/Jan/2015 14:45:55,382- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/resources.jar
14/Jan/2015 14:45:55,397- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/
14/Jan/2015 14:45:55,398- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/java
14/Jan/2015 14:45:55,399- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/keytool
14/Jan/2015 14:45:55,400- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmiregistry
14/Jan/2015 14:45:55,401- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmid
14/Jan/2015 14:45:55,403- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/release
14/Jan/2015 14:45:55,405- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/
14/Jan/2015 14:45:55,405- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/
14/Jan/2015 14:45:55,405- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/
14/Jan/2015 14:45:55,406- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/
14/Jan/2015 14:45:55,406- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/libj2pkcs11.so
14/Jan/2015 14:45:55,411- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/
14/Jan/2015 14:45:55,411- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/sunpkcs11.jar
14/Jan/2015 14:45:55,419- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/
14/Jan/2015 14:45:55,419- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/
14/Jan/2015 14:45:55,420- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/
14/Jan/2015 14:45:55,420- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/nashorn.jar
14/Jan/2015 14:45:55,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/
14/Jan/2015 14:45:55,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/
14/Jan/2015 14:45:55,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/
14/Jan/2015 14:45:55,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/localedata.jar
14/Jan/2015 14:45:55,486- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/
14/Jan/2015 14:45:55,486- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/
14/Jan/2015 14:45:55,487- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/
14/Jan/2015 14:45:55,487- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/libsunec.so
14/Jan/2015 14:45:55,495- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/
14/Jan/2015 14:45:55,495- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/sunec.jar
14/Jan/2015 14:45:55,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/
14/Jan/2015 14:45:55,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/
14/Jan/2015 14:45:55,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/
14/Jan/2015 14:45:55,567- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libdt_socket.so
14/Jan/2015 14:45:55,570- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjdwp.so
14/Jan/2015 14:45:55,577- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:45:55,580- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libnpt.so
14/Jan/2015 14:45:55,582- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libhprof.so
14/Jan/2015 14:45:55,589- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/jvm.hprof.txt
14/Jan/2015 14:45:55,590- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/
14/Jan/2015 14:45:55,591- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/
14/Jan/2015 14:45:55,591- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/gcf.jar
14/Jan/2015 14:45:55,668- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/
14/Jan/2015 14:45:55,668- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/
14/Jan/2015 14:45:55,668- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/charsets.jar
14/Jan/2015 14:45:55,708- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/
14/Jan/2015 14:45:55,709- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/
14/Jan/2015 14:45:55,709- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/
14/Jan/2015 14:45:55,709- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjsig.so
14/Jan/2015 14:45:55,710- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjava.so
14/Jan/2015 14:45:55,718- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/
14/Jan/2015 14:45:55,719- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/libjli.so
14/Jan/2015 14:45:55,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libzip.so
14/Jan/2015 14:45:55,728- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jvm.cfg
14/Jan/2015 14:45:55,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libsunec.so
14/Jan/2015 14:45:55,735- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/
14/Jan/2015 14:45:55,736- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:45:55,737- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjvm.so
14/Jan/2015 14:45:55,783- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjsig.so
14/Jan/2015 14:45:55,783- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libverify.so
14/Jan/2015 14:45:55,791- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/
14/Jan/2015 14:45:55,791- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjvm.so
14/Jan/2015 14:45:55,899- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjsig.so
14/Jan/2015 14:45:55,900- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/Xusage.txt
14/Jan/2015 14:45:55,901- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libj2pkcs11.so
14/Jan/2015 14:45:55,906- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnio.so
14/Jan/2015 14:45:55,915- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnet.so
14/Jan/2015 14:45:55,920- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/
14/Jan/2015 14:45:55,921- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjvm.so
14/Jan/2015 14:45:56,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjsig.so
14/Jan/2015 14:45:56,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/Xusage.txt
14/Jan/2015 14:45:56,003- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/rt.jar
14/Jan/2015 14:45:56,241- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/meta-index
14/Jan/2015 14:45:56,242- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/
14/Jan/2015 14:45:56,242- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/cacerts
14/Jan/2015 14:45:56,247- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/US_export_policy.jar
14/Jan/2015 14:45:56,249- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.security
14/Jan/2015 14:45:56,254- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/blacklist
14/Jan/2015 14:45:56,255- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/local_policy.jar
14/Jan/2015 14:45:56,257- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/trusted.libraries
14/Jan/2015 14:45:56,257- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.policy
14/Jan/2015 14:45:56,258- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jce.jar
14/Jan/2015 14:45:56,263- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/logging.properties
14/Jan/2015 14:45:56,264- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/resources.jar
14/Jan/2015 14:45:56,275- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:45:56,283- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/
14/Jan/2015 14:45:56,283- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/localedata.jar
14/Jan/2015 14:45:56,307- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/meta-index
14/Jan/2015 14:45:56,307- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunpkcs11.jar
14/Jan/2015 14:45:56,317- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunec.jar
14/Jan/2015 14:45:56,372- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunjce_provider.jar
14/Jan/2015 14:45:56,380- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/currency.data
14/Jan/2015 14:45:56,382- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/calendars.properties
14/Jan/2015 14:45:56,386- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/classlist
14/Jan/2015 14:45:56,393- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/tzdb.dat
14/Jan/2015 14:45:56,399- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/net.properties
14/Jan/2015 14:45:56,401- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jsse.jar
14/Jan/2015 14:45:56,410- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/content-types.properties
14/Jan/2015 14:45:56,411- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/release
14/Jan/2015 14:45:56,412- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/
14/Jan/2015 14:45:56,413- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmiregistry
14/Jan/2015 14:45:56,414- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmid
14/Jan/2015 14:45:56,416- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/keytool
14/Jan/2015 14:45:56,418- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/java
14/Jan/2015 14:45:56,419- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/
14/Jan/2015 14:45:56,419- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/release
14/Jan/2015 14:45:56,420- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/
14/Jan/2015 14:45:56,420- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/classlist
14/Jan/2015 14:45:56,427- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/rt.jar
14/Jan/2015 14:45:56,597- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/tzdb.dat
14/Jan/2015 14:45:56,606- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/net.properties
14/Jan/2015 14:45:56,608- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/calendars.properties
14/Jan/2015 14:45:56,609- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:45:56,617- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/currency.data
14/Jan/2015 14:45:56,619- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jsse.jar
14/Jan/2015 14:45:56,629- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/meta-index
14/Jan/2015 14:45:56,630- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/content-types.properties
14/Jan/2015 14:45:56,632- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/
14/Jan/2015 14:45:56,632- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/US_export_policy.jar
14/Jan/2015 14:45:56,633- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/cacerts
14/Jan/2015 14:45:56,640- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.security
14/Jan/2015 14:45:56,645- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/local_policy.jar
14/Jan/2015 14:45:56,648- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.policy
14/Jan/2015 14:45:56,650- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/trusted.libraries
14/Jan/2015 14:45:56,651- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/blacklist
14/Jan/2015 14:45:56,652- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/
14/Jan/2015 14:45:56,653- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunpkcs11.jar
14/Jan/2015 14:45:56,662- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/meta-index
14/Jan/2015 14:45:56,664- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunec.jar
14/Jan/2015 14:45:56,733- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/localedata.jar
14/Jan/2015 14:45:56,758- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunjce_provider.jar
14/Jan/2015 14:45:56,766- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jce.jar
14/Jan/2015 14:45:56,772- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/resources.jar
14/Jan/2015 14:45:56,781- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/logging.properties
14/Jan/2015 14:45:56,782- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/
14/Jan/2015 14:45:56,782- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libverify.so
14/Jan/2015 14:45:56,785- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/
14/Jan/2015 14:45:56,785- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/libjli.so
14/Jan/2015 14:45:56,791- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libzip.so
14/Jan/2015 14:45:56,795- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/
14/Jan/2015 14:45:56,796- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjvm.so
14/Jan/2015 14:45:56,840- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjsig.so
14/Jan/2015 14:45:56,841- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:45:56,842- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnet.so
14/Jan/2015 14:45:56,848- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jvm.cfg
14/Jan/2015 14:45:56,850- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnio.so
14/Jan/2015 14:45:56,855- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libj2pkcs11.so
14/Jan/2015 14:45:56,859- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjava.so
14/Jan/2015 14:45:56,864- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/
14/Jan/2015 14:45:56,864- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjsig.so
14/Jan/2015 14:45:56,865- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/Xusage.txt
14/Jan/2015 14:45:56,866- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjvm.so
14/Jan/2015 14:45:56,983- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjsig.so
14/Jan/2015 14:45:56,985- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/
14/Jan/2015 14:45:56,985- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjsig.so
14/Jan/2015 14:45:56,985- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/Xusage.txt
14/Jan/2015 14:45:56,987- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjvm.so
14/Jan/2015 14:45:57,073- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libsunec.so
14/Jan/2015 14:45:57,080- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/
14/Jan/2015 14:45:57,081- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/keytool
14/Jan/2015 14:45:57,082- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/java
14/Jan/2015 14:45:57,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/
14/Jan/2015 14:45:57,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/
14/Jan/2015 14:45:57,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/
14/Jan/2015 14:45:57,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/
14/Jan/2015 14:45:57,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/
14/Jan/2015 14:45:57,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/jfxrt-controls.jar
14/Jan/2015 14:45:57,138- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/
14/Jan/2015 14:45:57,139- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/
14/Jan/2015 14:45:57,139- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.platform.properties
14/Jan/2015 14:45:57,140- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.properties
14/Jan/2015 14:45:57,141- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/
14/Jan/2015 14:45:57,142- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/liblens_porting.so
14/Jan/2015 14:45:57,145- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_iio.so
14/Jan/2015 14:45:57,153- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_sw.so
14/Jan/2015 14:45:57,159- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font_t2k.so
14/Jan/2015 14:45:57,179- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_eglfb.so
14/Jan/2015 14:45:57,186- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass.so
14/Jan/2015 14:45:57,195- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font.so
14/Jan/2015 14:45:57,198- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_es2_eglfb.so
14/Jan/2015 14:45:57,202- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_common.so
14/Jan/2015 14:45:57,207- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_dfb.so
14/Jan/2015 14:45:57,214- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/
14/Jan/2015 14:45:57,214- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/jfxrt-graphics.jar
14/Jan/2015 14:45:57,329- CreateJreController: Staring JRE Creation
14/Jan/2015 14:45:57,329- CreateJreController: Creator location: C:\Users\3539\wpilib\tools\ejdk1.8.0_06\lib\JRECre ate.jar
14/Jan/2015 14:45:57,329- CreateJreController: Command: [java, -jar, C:\Users\3539\wpilib\tools\ejdk1.8.0_06\lib\JRECre ate.jar, --dest, JRE, --profile, compact2, --vm, client, --keep-debug-info, --debug]
14/Jan/2015 14:45:57,745- CreateJreController: Successfully Created JRE!
14/Jan/2015 14:46:07,909- ConnectRoboRioController: Connecting to roborio-3539.local
14/Jan/2015 14:46:07,910- ConnectRoboRioController: Checking for mDNS connection to the roboRio
14/Jan/2015 14:46:11,227- ConnectRoboRioController: Found mDNS connection
14/Jan/2015 14:46:11,227- ConnectRoboRioController: Connected to the roboRio at roborio-3539.local
14/Jan/2015 14:46:11,270- DeployController: Removed the old tgz file
14/Jan/2015 14:46:11,270- DeployController: Starting zip
14/Jan/2015 14:46:11,276- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE, putting tar entry is JRE
14/Jan/2015 14:46:11,277- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin, putting tar entry is JRE/bin
14/Jan/2015 14:46:11,278- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\java, putting tar entry is JRE/bin/java
14/Jan/2015 14:46:11,279- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\keytool, putting tar entry is JRE/bin/keytool
14/Jan/2015 14:46:11,280- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\rmid, putting tar entry is JRE/bin/rmid
14/Jan/2015 14:46:11,281- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\rmiregistry, putting tar entry is JRE/bin/rmiregistry
14/Jan/2015 14:46:11,283- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bom, putting tar entry is JRE/bom
14/Jan/2015 14:46:11,284- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib, putting tar entry is JRE/lib
14/Jan/2015 14:46:11,284- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm, putting tar entry is JRE/lib/arm
14/Jan/2015 14:46:11,285- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client, putting tar entry is JRE/lib/arm/client
14/Jan/2015 14:46:11,286- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\libj sig.so, putting tar entry is JRE/lib/arm/client/libjsig.so
14/Jan/2015 14:46:11,286- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\libj vm.so, putting tar entry is JRE/lib/arm/client/libjvm.so
14/Jan/2015 14:46:11,723- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\Xusa ge.txt, putting tar entry is JRE/lib/arm/client/Xusage.txt
14/Jan/2015 14:46:11,724- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jli, putting tar entry is JRE/lib/arm/jli
14/Jan/2015 14:46:11,724- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jli\libjli. so, putting tar entry is JRE/lib/arm/jli/libjli.so
14/Jan/2015 14:46:11,736- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jvm.cfg, putting tar entry is JRE/lib/arm/jvm.cfg
14/Jan/2015 14:46:11,737- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libdt_socke t.so, putting tar entry is JRE/lib/arm/libdt_socket.so
14/Jan/2015 14:46:11,741- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libhprof.so , putting tar entry is JRE/lib/arm/libhprof.so
14/Jan/2015 14:46:11,755- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjava.so, putting tar entry is JRE/lib/arm/libjava.so
14/Jan/2015 14:46:11,774- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjava_crw _demo.so, putting tar entry is JRE/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:46:11,778- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjdwp.so, putting tar entry is JRE/lib/arm/libjdwp.so
14/Jan/2015 14:46:11,798- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjsig.so, putting tar entry is JRE/lib/arm/libjsig.so
14/Jan/2015 14:46:11,801- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnet.so, putting tar entry is JRE/lib/arm/libnet.so
14/Jan/2015 14:46:11,813- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnio.so, putting tar entry is JRE/lib/arm/libnio.so
14/Jan/2015 14:46:11,821- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnpt.so, putting tar entry is JRE/lib/arm/libnpt.so
14/Jan/2015 14:46:11,824- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libverify.s o, putting tar entry is JRE/lib/arm/libverify.so
14/Jan/2015 14:46:11,829- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libzip.so, putting tar entry is JRE/lib/arm/libzip.so
14/Jan/2015 14:46:11,845- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\calendars.prope rties, putting tar entry is JRE/lib/calendars.properties
14/Jan/2015 14:46:11,846- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\classlist, putting tar entry is JRE/lib/classlist
14/Jan/2015 14:46:11,856- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\content-types.properties, putting tar entry is JRE/lib/content-types.properties
14/Jan/2015 14:46:11,857- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\currency.data, putting tar entry is JRE/lib/currency.data
14/Jan/2015 14:46:11,858- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext, putting tar entry is JRE/lib/ext
14/Jan/2015 14:46:11,858- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext\meta-index, putting tar entry is JRE/lib/ext/meta-index
14/Jan/2015 14:46:11,859- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext\sunjce_prov ider.jar, putting tar entry is JRE/lib/ext/sunjce_provider.jar
14/Jan/2015 14:46:11,882- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\hijrah-config-umalqura.properties, putting tar entry is JRE/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:46:11,891- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jce.jar, putting tar entry is JRE/lib/jce.jar
14/Jan/2015 14:46:11,903- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jsse.jar, putting tar entry is JRE/lib/jsse.jar
14/Jan/2015 14:46:11,930- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jvm.hprof.txt, putting tar entry is JRE/lib/jvm.hprof.txt
14/Jan/2015 14:46:11,931- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\logging.propert ies, putting tar entry is JRE/lib/logging.properties
14/Jan/2015 14:46:11,932- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\meta-index, putting tar entry is JRE/lib/meta-index
14/Jan/2015 14:46:11,934- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\net.properties, putting tar entry is JRE/lib/net.properties
14/Jan/2015 14:46:11,936- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\resources.jar, putting tar entry is JRE/lib/resources.jar
14/Jan/2015 14:46:11,978- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\rt.jar, putting tar entry is JRE/lib/rt.jar
14/Jan/2015 14:46:12,971- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security, putting tar entry is JRE/lib/security
14/Jan/2015 14:46:12,971- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\blackl ist, putting tar entry is JRE/lib/security/blacklist
14/Jan/2015 14:46:12,973- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\cacert s, putting tar entry is JRE/lib/security/cacerts
14/Jan/2015 14:46:12,981- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\java.p olicy, putting tar entry is JRE/lib/security/java.policy
14/Jan/2015 14:46:12,982- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\java.s ecurity, putting tar entry is JRE/lib/security/java.security
14/Jan/2015 14:46:12,989- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\local_ policy.jar, putting tar entry is JRE/lib/security/local_policy.jar
14/Jan/2015 14:46:12,991- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\truste d.libraries, putting tar entry is JRE/lib/security/trusted.libraries
14/Jan/2015 14:46:12,991- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\US_exp ort_policy.jar, putting tar entry is JRE/lib/security/US_export_policy.jar
14/Jan/2015 14:46:12,993- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\tzdb.dat, putting tar entry is JRE/lib/tzdb.dat
14/Jan/2015 14:46:13,005- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\release, putting tar entry is JRE/release
14/Jan/2015 14:46:14,047- DeployController: Failure to send JRE to the roboRio
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController$$Lambda$160/14508651.run(Unknown Source) [java-installer.jar:?]
... 5 more
14/Jan/2015 15:24:39,400- MainApp: Exiting installer from popup
14/Jan/2015 15:24:45,389- MainApp: Found JRE, checking hash
14/Jan/2015 15:24:46,537- MainApp: Computed hash is 082F08397B0D3F63844AB472B5111C8C, official hash is 082F08397B0D3F63844AB472B5111C8C
14/Jan/2015 15:24:48,672- UntarController: Starting decompress of file C:\Users\3539\wpilib\tools\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\3539\wpilib\tools
14/Jan/2015 15:24:48,687- UntarController: Untarring ejdk1.8.0_06/bin/
14/Jan/2015 15:24:48,688- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.sh
14/Jan/2015 15:24:48,695- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.bat
14/Jan/2015 15:24:48,697- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.config.properties
14/Jan/2015 15:24:48,708- UntarController: Untarring ejdk1.8.0_06/doc/
14/Jan/2015 15:24:48,708- UntarController: Untarring ejdk1.8.0_06/lib/
14/Jan/2015 15:24:48,709- UntarController: Untarring ejdk1.8.0_06/lib/JRECreate.jar
14/Jan/2015 15:24:48,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/
14/Jan/2015 15:24:48,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/
14/Jan/2015 15:24:48,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/
14/Jan/2015 15:24:48,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/
14/Jan/2015 15:24:48,726- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklist
14/Jan/2015 15:24:48,727- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/US_export_policy.jar
14/Jan/2015 15:24:48,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.security
14/Jan/2015 15:24:48,733- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.policy
14/Jan/2015 15:24:48,735- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/local_policy.jar
14/Jan/2015 15:24:48,736- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklisted.certs
14/Jan/2015 15:24:48,737- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/trusted.libraries
14/Jan/2015 15:24:48,738- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/cacerts
14/Jan/2015 15:24:48,756- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.bfc
14/Jan/2015 15:24:48,758- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.bfc
14/Jan/2015 15:24:48,759- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/meta-index
14/Jan/2015 15:24:48,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.bfc
14/Jan/2015 15:24:48,762- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/resources.jar
14/Jan/2015 15:24:48,787- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.properties.src
14/Jan/2015 15:24:48,791- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/classlist
14/Jan/2015 15:24:48,813- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/net.properties
14/Jan/2015 15:24:48,814- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management-agent.jar
14/Jan/2015 15:24:48,815- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr.jar
14/Jan/2015 15:24:48,825- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jvm.hprof.txt
14/Jan/2015 15:24:48,827- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/calendars.properties
14/Jan/2015 15:24:48,837- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/
14/Jan/2015 15:24:48,837- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/
14/Jan/2015 15:24:48,838- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkNoDrop32x32.gif
14/Jan/2015 15:24:48,847- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/cursors.properties
14/Jan/2015 15:24:48,848- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkDrop32x32.gif
14/Jan/2015 15:24:48,850- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/invalid32x32.gif
14/Jan/2015 15:24:48,852- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveNoDrop32x32.gif
14/Jan/2015 15:24:48,853- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyNoDrop32x32.gif
14/Jan/2015 15:24:48,854- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveDrop32x32.gif
14/Jan/2015 15:24:48,855- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyDrop32x32.gif
14/Jan/2015 15:24:48,861- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/charsets.jar
14/Jan/2015 15:24:48,904- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/
14/Jan/2015 15:24:48,905- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.password.template
14/Jan/2015 15:24:48,906- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/snmp.acl.template
14/Jan/2015 15:24:48,909- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.access
14/Jan/2015 15:24:48,910- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/management.properties
14/Jan/2015 15:24:48,914- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/
14/Jan/2015 15:24:48,914- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiBold.ttf
14/Jan/2015 15:24:48,948- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightItalic.ttf
14/Jan/2015 15:24:48,957- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiItalic.ttf
14/Jan/2015 15:24:48,963- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterBold.ttf
14/Jan/2015 15:24:48,972- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansDemiBold.ttf
14/Jan/2015 15:24:48,985- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightRegular.ttf
14/Jan/2015 15:24:49,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansRegular.ttf
14/Jan/2015 15:24:49,021- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterRegular.ttf
14/Jan/2015 15:24:49,035- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/fonts.dir
14/Jan/2015 15:24:49,036- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/content-types.properties
14/Jan/2015 15:24:49,038- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/rt.jar
14/Jan/2015 15:24:49,723- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jexec
14/Jan/2015 15:24:49,726- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.properties.src
14/Jan/2015 15:24:49,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/applet/
14/Jan/2015 15:24:49,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/
14/Jan/2015 15:24:49,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunec.jar
14/Jan/2015 15:24:49,911- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/cldrdata.jar
14/Jan/2015 15:24:49,992- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/meta-index
14/Jan/2015 15:24:49,996- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunjce_provider.jar
14/Jan/2015 15:24:50,003- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/localedata.jar
14/Jan/2015 15:24:50,030- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/zipfs.jar
14/Jan/2015 15:24:50,034- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/dnsns.jar
14/Jan/2015 15:24:50,071- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/nashorn.jar
14/Jan/2015 15:24:50,107- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunpkcs11.jar
14/Jan/2015 15:24:50,115- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/
14/Jan/2015 15:24:50,115- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/profile.jfc
14/Jan/2015 15:24:50,118- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/default.jfc
14/Jan/2015 15:24:50,124- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/
14/Jan/2015 15:24:50,124- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/LINEAR_RGB.pf
14/Jan/2015 15:24:50,126- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/CIEXYZ.pf
14/Jan/2015 15:24:50,130- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/GRAY.pf
14/Jan/2015 15:24:50,131- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/sRGB.pf
14/Jan/2015 15:24:50,133- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/PYCC.pf
14/Jan/2015 15:24:50,143- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/logging.properties
14/Jan/2015 15:24:50,144- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/tzdb.dat
14/Jan/2015 15:24:50,153- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:24:50,162- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.bfc
14/Jan/2015 15:24:50,166- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/
14/Jan/2015 15:24:50,166- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterBoldOblique.ttf
14/Jan/2015 15:24:50,170- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterOblique.ttf
14/Jan/2015 15:24:50,178- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansOblique.ttf
14/Jan/2015 15:24:50,186- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansDemiOblique.ttf
14/Jan/2015 15:24:50,193- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/fonts.dir
14/Jan/2015 15:24:50,196- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfontj2d.properties
14/Jan/2015 15:24:50,199- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.properties.src
14/Jan/2015 15:24:50,203- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/sound.properties
14/Jan/2015 15:24:50,204- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.properties.src
14/Jan/2015 15:24:50,206- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.properties.src
14/Jan/2015 15:24:50,210- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.properties.src
14/Jan/2015 15:24:50,213- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/currency.data
14/Jan/2015 15:24:50,219- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jce.jar
14/Jan/2015 15:24:50,227- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jsse.jar
14/Jan/2015 15:24:50,236- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.bfc
14/Jan/2015 15:24:50,238- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/
14/Jan/2015 15:24:50,238- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdt_socket.so
14/Jan/2015 15:24:50,258- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2gss.so
14/Jan/2015 15:24:50,261- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libhprof.so
14/Jan/2015 15:24:50,266- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/
14/Jan/2015 15:24:50,266- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/Xusage.txt
14/Jan/2015 15:24:50,267- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjvm.so
14/Jan/2015 15:24:50,379- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjsig.so
14/Jan/2015 15:24:50,380- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pcsc.so
14/Jan/2015 15:24:50,382- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/
14/Jan/2015 15:24:50,382- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjsig.so
14/Jan/2015 15:24:50,383- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjvm.so
14/Jan/2015 15:24:50,471- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/Xusage.txt
14/Jan/2015 15:24:50,472- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libinstrument.so
14/Jan/2015 15:24:50,478- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnpt.so
14/Jan/2015 15:24:50,480- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdcpr.so
14/Jan/2015 15:24:50,488- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/
14/Jan/2015 15:24:50,488- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:24:50,490- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjvm.so
14/Jan/2015 15:24:50,607- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjsig.so
14/Jan/2015 15:24:50,608- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsplashscreen.so
14/Jan/2015 15:24:50,618- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnet.so
14/Jan/2015 15:24:50,993- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsdt.so
14/Jan/2015 15:24:50,995- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsound.so
14/Jan/2015 15:24:50,997- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnio.so
14/Jan/2015 15:24:51,001- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:24:51,004- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsoundalsa.so
14/Jan/2015 15:24:51,010- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjaas_unix.so
14/Jan/2015 15:24:51,012- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libkcms.so
14/Jan/2015 15:24:51,026- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/
14/Jan/2015 15:24:51,026- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/libjli.so
14/Jan/2015 15:24:51,032- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmanagement.so
14/Jan/2015 15:24:51,193- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libt2k.so
14/Jan/2015 15:24:51,202- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjawt.so
14/Jan/2015 15:24:51,203- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsunec.so
14/Jan/2015 15:24:51,211- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jvm.cfg
14/Jan/2015 15:24:51,212- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjdwp.so
14/Jan/2015 15:24:51,220- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libunpack.so
14/Jan/2015 15:24:51,226- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/liblcms.so
14/Jan/2015 15:24:51,234- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt_headless.so
14/Jan/2015 15:24:51,237- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libfontmanager.so
14/Jan/2015 15:24:51,246- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjpeg.so
14/Jan/2015 15:24:51,252- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libzip.so
14/Jan/2015 15:24:51,256- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt.so
14/Jan/2015 15:24:51,268- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsig.so
14/Jan/2015 15:24:51,270- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmlib_image.so
14/Jan/2015 15:24:51,286- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libverify.so
14/Jan/2015 15:24:51,292- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjfr.so
14/Jan/2015 15:24:51,296- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsctp.so
14/Jan/2015 15:24:51,300- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pkcs11.so
14/Jan/2015 15:24:51,305- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava.so
14/Jan/2015 15:24:51,312- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfont.properties.ja
14/Jan/2015 15:24:51,313- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.bfc
14/Jan/2015 15:24:51,317- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/flavormap.properties
14/Jan/2015 15:24:51,319- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME.txt
14/Jan/2015 15:24:51,424- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/
14/Jan/2015 15:24:51,425- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/orbd
14/Jan/2015 15:24:51,428- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/keytool
14/Jan/2015 15:24:51,429- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmid
14/Jan/2015 15:24:51,430- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmiregistry
14/Jan/2015 15:24:51,431- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/pack200
14/Jan/2015 15:24:51,452- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/policytool
14/Jan/2015 15:24:51,453- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/servertool
14/Jan/2015 15:24:51,454- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/jjs
14/Jan/2015 15:24:51,455- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/tnameserv
14/Jan/2015 15:24:51,457- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/java
14/Jan/2015 15:24:51,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/unpack200
14/Jan/2015 15:24:51,464- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/COPYRIGHT
14/Jan/2015 15:24:51,465- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/release
14/Jan/2015 15:24:51,467- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME-JAVAFX.txt
14/Jan/2015 15:24:51,476- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/README
14/Jan/2015 15:24:51,477- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/
14/Jan/2015 15:24:51,478- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/
14/Jan/2015 15:24:51,478- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jsse.jar
14/Jan/2015 15:24:51,486- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/
14/Jan/2015 15:24:51,487- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.access
14/Jan/2015 15:24:51,488- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/management.properties
14/Jan/2015 15:24:51,494- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/snmp.acl.template
14/Jan/2015 15:24:51,495- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.password.template
14/Jan/2015 15:24:51,497- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/classlist
14/Jan/2015 15:24:51,505- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/
14/Jan/2015 15:24:51,505- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/localedata.jar
14/Jan/2015 15:24:51,532- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunjce_provider.jar
14/Jan/2015 15:24:51,541- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/meta-index
14/Jan/2015 15:24:51,542- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunpkcs11.jar
14/Jan/2015 15:24:51,551- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunec.jar
14/Jan/2015 15:24:51,608- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/currency.data
14/Jan/2015 15:24:51,610- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/meta-index
14/Jan/2015 15:24:51,611- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:24:51,619- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jce.jar
14/Jan/2015 15:24:51,626- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/
14/Jan/2015 15:24:51,626- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsctp.so
14/Jan/2015 15:24:51,629- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pcsc.so
14/Jan/2015 15:24:51,631- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava.so
14/Jan/2015 15:24:51,635- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsig.so
14/Jan/2015 15:24:51,637- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/
14/Jan/2015 15:24:51,637- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjsig.so
14/Jan/2015 15:24:51,637- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjvm.so
14/Jan/2015 15:24:51,717- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/Xusage.txt
14/Jan/2015 15:24:51,718- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libhprof.so
14/Jan/2015 15:24:51,723- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jvm.cfg
14/Jan/2015 15:24:51,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2gss.so
14/Jan/2015 15:24:51,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/
14/Jan/2015 15:24:51,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/Xusage.txt
14/Jan/2015 15:24:51,730- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjvm.so
14/Jan/2015 15:24:51,837- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjsig.so
14/Jan/2015 15:24:51,837- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libzip.so
14/Jan/2015 15:24:51,842- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pkcs11.so
14/Jan/2015 15:24:51,845- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/
14/Jan/2015 15:24:51,846- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/libjli.so
14/Jan/2015 15:24:51,850- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/
14/Jan/2015 15:24:51,850- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:24:51,852- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjvm.so
14/Jan/2015 15:24:51,918- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjsig.so
14/Jan/2015 15:24:51,919- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:24:51,922- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsdt.so
14/Jan/2015 15:24:51,927- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libmanagement.so
14/Jan/2015 15:24:51,932- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnio.so
14/Jan/2015 15:24:51,937- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjaas_unix.so
14/Jan/2015 15:24:51,938- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnpt.so
14/Jan/2015 15:24:51,942- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsunec.so
14/Jan/2015 15:24:51,958- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libinstrument.so
14/Jan/2015 15:24:51,962- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libverify.so
14/Jan/2015 15:24:51,966- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnet.so
14/Jan/2015 15:24:51,969- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/tzdb.dat
14/Jan/2015 15:24:51,976- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/content-types.properties
14/Jan/2015 15:24:51,978- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/rt.jar
14/Jan/2015 15:24:52,320- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management-agent.jar
14/Jan/2015 15:24:52,321- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/net.properties
14/Jan/2015 15:24:52,323- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/logging.properties
14/Jan/2015 15:24:52,325- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jvm.hprof.txt
14/Jan/2015 15:24:52,326- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/
14/Jan/2015 15:24:52,327- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/US_export_policy.jar
14/Jan/2015 15:24:52,328- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.policy
14/Jan/2015 15:24:52,329- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/trusted.libraries
14/Jan/2015 15:24:52,329- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/cacerts
14/Jan/2015 15:24:52,334- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/blacklist
14/Jan/2015 15:24:52,336- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.security
14/Jan/2015 15:24:52,340- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/local_policy.jar
14/Jan/2015 15:24:52,342- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/calendars.properties
14/Jan/2015 15:24:52,343- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/resources.jar
14/Jan/2015 15:24:52,360- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/
14/Jan/2015 15:24:52,360- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/java
14/Jan/2015 15:24:52,361- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/keytool
14/Jan/2015 15:24:52,362- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmiregistry
14/Jan/2015 15:24:52,363- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmid
14/Jan/2015 15:24:52,364- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/release
14/Jan/2015 15:24:52,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/
14/Jan/2015 15:24:52,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/
14/Jan/2015 15:24:52,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/
14/Jan/2015 15:24:52,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/
14/Jan/2015 15:24:52,366- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/libj2pkcs11.so
14/Jan/2015 15:24:52,369- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/
14/Jan/2015 15:24:52,369- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/sunpkcs11.jar
14/Jan/2015 15:24:52,377- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/
14/Jan/2015 15:24:52,377- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/
14/Jan/2015 15:24:52,377- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/
14/Jan/2015 15:24:52,377- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/nashorn.jar
14/Jan/2015 15:24:52,416- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/
14/Jan/2015 15:24:52,416- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/
14/Jan/2015 15:24:52,416- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/
14/Jan/2015 15:24:52,417- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/localedata.jar
14/Jan/2015 15:24:52,463- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/
14/Jan/2015 15:24:52,463- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/
14/Jan/2015 15:24:52,463- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/
14/Jan/2015 15:24:52,464- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/libsunec.so
14/Jan/2015 15:24:52,470- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/
14/Jan/2015 15:24:52,471- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/sunec.jar
14/Jan/2015 15:24:52,561- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/
14/Jan/2015 15:24:52,561- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/
14/Jan/2015 15:24:52,561- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/
14/Jan/2015 15:24:52,562- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libdt_socket.so
14/Jan/2015 15:24:52,565- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjdwp.so
14/Jan/2015 15:24:52,572- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:24:52,577- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libnpt.so
14/Jan/2015 15:24:52,584- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libhprof.so
14/Jan/2015 15:24:52,591- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/jvm.hprof.txt
14/Jan/2015 15:24:52,593- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/
14/Jan/2015 15:24:52,594- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/
14/Jan/2015 15:24:52,594- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/gcf.jar
14/Jan/2015 15:24:52,719- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/
14/Jan/2015 15:24:52,720- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/
14/Jan/2015 15:24:52,720- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/charsets.jar
14/Jan/2015 15:24:52,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/
14/Jan/2015 15:24:52,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/
14/Jan/2015 15:24:52,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/
14/Jan/2015 15:24:52,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjsig.so
14/Jan/2015 15:24:52,762- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjava.so
14/Jan/2015 15:24:52,767- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/
14/Jan/2015 15:24:52,768- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/libjli.so
14/Jan/2015 15:24:52,771- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libzip.so
14/Jan/2015 15:24:52,777- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jvm.cfg
14/Jan/2015 15:24:52,778- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libsunec.so
14/Jan/2015 15:24:52,785- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/
14/Jan/2015 15:24:52,786- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:24:52,787- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjvm.so
14/Jan/2015 15:24:52,841- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjsig.so
14/Jan/2015 15:24:52,842- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libverify.so
14/Jan/2015 15:24:52,846- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/
14/Jan/2015 15:24:52,846- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjvm.so
14/Jan/2015 15:24:52,966- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjsig.so
14/Jan/2015 15:24:52,966- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/Xusage.txt
14/Jan/2015 15:24:52,967- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libj2pkcs11.so
14/Jan/2015 15:24:52,970- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnio.so
14/Jan/2015 15:24:52,975- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnet.so
14/Jan/2015 15:24:52,978- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/
14/Jan/2015 15:24:52,979- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjvm.so
14/Jan/2015 15:24:53,065- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjsig.so
14/Jan/2015 15:24:53,065- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/Xusage.txt
14/Jan/2015 15:24:53,066- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/rt.jar
14/Jan/2015 15:24:53,324- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/meta-index
14/Jan/2015 15:24:53,325- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/
14/Jan/2015 15:24:53,326- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/cacerts
14/Jan/2015 15:24:53,330- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/US_export_policy.jar
14/Jan/2015 15:24:53,331- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.security
14/Jan/2015 15:24:53,335- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/blacklist
14/Jan/2015 15:24:53,336- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/local_policy.jar
14/Jan/2015 15:24:53,337- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/trusted.libraries
14/Jan/2015 15:24:53,338- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.policy
14/Jan/2015 15:24:53,341- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jce.jar
14/Jan/2015 15:24:53,347- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/logging.properties
14/Jan/2015 15:24:53,351- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/resources.jar
14/Jan/2015 15:24:53,367- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:24:53,375- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/
14/Jan/2015 15:24:53,376- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/localedata.jar
14/Jan/2015 15:24:53,401- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/meta-index
14/Jan/2015 15:24:53,402- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunpkcs11.jar
14/Jan/2015 15:24:53,411- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunec.jar
14/Jan/2015 15:24:53,499- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunjce_provider.jar
14/Jan/2015 15:24:53,510- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/currency.data
14/Jan/2015 15:24:53,512- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/calendars.properties
14/Jan/2015 15:24:53,513- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/classlist
14/Jan/2015 15:24:53,518- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/tzdb.dat
14/Jan/2015 15:24:53,528- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/net.properties
14/Jan/2015 15:24:53,529- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jsse.jar
14/Jan/2015 15:24:53,538- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/content-types.properties
14/Jan/2015 15:24:53,541- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/release
14/Jan/2015 15:24:53,542- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/
14/Jan/2015 15:24:53,542- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmiregistry
14/Jan/2015 15:24:53,543- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmid
14/Jan/2015 15:24:53,545- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/keytool
14/Jan/2015 15:24:53,546- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/java
14/Jan/2015 15:24:53,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/
14/Jan/2015 15:24:53,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/release
14/Jan/2015 15:24:53,551- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/
14/Jan/2015 15:24:53,552- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/classlist
14/Jan/2015 15:24:53,560- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/rt.jar
14/Jan/2015 15:24:53,727- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/tzdb.dat
14/Jan/2015 15:24:53,733- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/net.properties
14/Jan/2015 15:24:53,734- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/calendars.properties
14/Jan/2015 15:24:53,735- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:24:53,742- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/currency.data
14/Jan/2015 15:24:53,743- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jsse.jar
14/Jan/2015 15:24:53,754- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/meta-index
14/Jan/2015 15:24:53,759- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/content-types.properties
14/Jan/2015 15:24:53,760- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/
14/Jan/2015 15:24:53,760- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/US_export_policy.jar
14/Jan/2015 15:24:53,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/cacerts
14/Jan/2015 15:24:53,766- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.security
14/Jan/2015 15:24:53,769- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/local_policy.jar
14/Jan/2015 15:24:53,770- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.policy
14/Jan/2015 15:24:53,771- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/trusted.libraries
14/Jan/2015 15:24:53,771- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/blacklist
14/Jan/2015 15:24:53,776- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/
14/Jan/2015 15:24:53,776- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunpkcs11.jar
14/Jan/2015 15:24:53,789- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/meta-index
14/Jan/2015 15:24:53,795- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunec.jar
14/Jan/2015 15:24:53,876- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/localedata.jar
14/Jan/2015 15:24:53,903- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunjce_provider.jar
14/Jan/2015 15:24:53,913- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jce.jar
14/Jan/2015 15:24:53,918- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/resources.jar
14/Jan/2015 15:24:53,925- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/logging.properties
14/Jan/2015 15:24:53,926- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/
14/Jan/2015 15:24:53,927- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libverify.so
14/Jan/2015 15:24:53,930- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/
14/Jan/2015 15:24:53,931- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/libjli.so
14/Jan/2015 15:24:53,935- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libzip.so
14/Jan/2015 15:24:53,940- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/
14/Jan/2015 15:24:53,941- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjvm.so
14/Jan/2015 15:24:53,987- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjsig.so
14/Jan/2015 15:24:53,987- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:24:53,989- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnet.so
14/Jan/2015 15:24:53,994- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jvm.cfg
14/Jan/2015 15:24:53,995- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnio.so
14/Jan/2015 15:24:54,000- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libj2pkcs11.so
14/Jan/2015 15:24:54,004- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjava.so
14/Jan/2015 15:24:54,010- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/
14/Jan/2015 15:24:54,011- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjsig.so
14/Jan/2015 15:24:54,011- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/Xusage.txt
14/Jan/2015 15:24:54,013- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjvm.so
14/Jan/2015 15:24:54,124- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjsig.so
14/Jan/2015 15:24:54,126- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/
14/Jan/2015 15:24:54,126- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjsig.so
14/Jan/2015 15:24:54,127- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/Xusage.txt
14/Jan/2015 15:24:54,128- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjvm.so
14/Jan/2015 15:24:54,215- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libsunec.so
14/Jan/2015 15:24:54,222- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/
14/Jan/2015 15:24:54,223- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/keytool
14/Jan/2015 15:24:54,224- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/java
14/Jan/2015 15:24:54,226- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/
14/Jan/2015 15:24:54,226- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/
14/Jan/2015 15:24:54,226- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/
14/Jan/2015 15:24:54,226- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/
14/Jan/2015 15:24:54,227- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/
14/Jan/2015 15:24:54,227- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/jfxrt-controls.jar
14/Jan/2015 15:24:54,277- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/
14/Jan/2015 15:24:54,278- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/
14/Jan/2015 15:24:54,278- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.platform.properties
14/Jan/2015 15:24:54,279- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.properties
14/Jan/2015 15:24:54,281- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/
14/Jan/2015 15:24:54,281- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/liblens_porting.so
14/Jan/2015 15:24:54,285- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_iio.so
14/Jan/2015 15:24:54,295- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_sw.so
14/Jan/2015 15:24:54,302- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font_t2k.so
14/Jan/2015 15:24:54,321- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_eglfb.so
14/Jan/2015 15:24:54,329- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass.so
14/Jan/2015 15:24:54,335- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font.so
14/Jan/2015 15:24:54,338- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_es2_eglfb.so
14/Jan/2015 15:24:54,342- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_common.so
14/Jan/2015 15:24:54,346- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_dfb.so
14/Jan/2015 15:24:54,353- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/
14/Jan/2015 15:24:54,354- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/jfxrt-graphics.jar
14/Jan/2015 15:24:54,471- CreateJreController: Staring JRE Creation
14/Jan/2015 15:24:54,472- CreateJreController: Creator location: C:\Users\3539\wpilib\tools\ejdk1.8.0_06\lib\JRECre ate.jar
14/Jan/2015 15:24:54,472- CreateJreController: Command: [java, -jar, C:\Users\3539\wpilib\tools\ejdk1.8.0_06\lib\JRECre ate.jar, --dest, JRE, --profile, compact2, --vm, client, --keep-debug-info, --debug]
14/Jan/2015 15:24:58,131- CreateJreController: Successfully Created JRE!
14/Jan/2015 15:25:10,311- ConnectRoboRioController: Connecting to roborio-3539.local
14/Jan/2015 15:25:10,312- ConnectRoboRioController: Checking for mDNS connection to the roboRio
14/Jan/2015 15:25:13,775- ConnectRoboRioController: Found mDNS connection
14/Jan/2015 15:25:13,776- ConnectRoboRioController: Connected to the roboRio at roborio-3539.local
14/Jan/2015 15:25:13,811- DeployController: Removed the old tgz file
14/Jan/2015 15:25:13,811- DeployController: Starting zip
14/Jan/2015 15:25:13,816- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE, putting tar entry is JRE
14/Jan/2015 15:25:13,816- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin, putting tar entry is JRE/bin
14/Jan/2015 15:25:13,817- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\java, putting tar entry is JRE/bin/java
14/Jan/2015 15:25:13,818- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\keytool, putting tar entry is JRE/bin/keytool
14/Jan/2015 15:25:13,824- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\rmid, putting tar entry is JRE/bin/rmid
14/Jan/2015 15:25:13,826- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\rmiregistry, putting tar entry is JRE/bin/rmiregistry
14/Jan/2015 15:25:13,827- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bom, putting tar entry is JRE/bom
14/Jan/2015 15:25:13,828- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib, putting tar entry is JRE/lib
14/Jan/2015 15:25:13,828- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm, putting tar entry is JRE/lib/arm
14/Jan/2015 15:25:13,829- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client, putting tar entry is JRE/lib/arm/client
14/Jan/2015 15:25:13,829- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\libj sig.so, putting tar entry is JRE/lib/arm/client/libjsig.so
14/Jan/2015 15:25:13,830- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\libj vm.so, putting tar entry is JRE/lib/arm/client/libjvm.so
14/Jan/2015 15:25:14,257- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\Xusa ge.txt, putting tar entry is JRE/lib/arm/client/Xusage.txt
14/Jan/2015 15:25:14,258- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jli, putting tar entry is JRE/lib/arm/jli
14/Jan/2015 15:25:14,259- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jli\libjli. so, putting tar entry is JRE/lib/arm/jli/libjli.so
14/Jan/2015 15:25:14,269- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jvm.cfg, putting tar entry is JRE/lib/arm/jvm.cfg
14/Jan/2015 15:25:14,270- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libdt_socke t.so, putting tar entry is JRE/lib/arm/libdt_socket.so
14/Jan/2015 15:25:14,273- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libhprof.so , putting tar entry is JRE/lib/arm/libhprof.so
14/Jan/2015 15:25:14,287- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjava.so, putting tar entry is JRE/lib/arm/libjava.so
14/Jan/2015 15:25:14,306- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjava_crw _demo.so, putting tar entry is JRE/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:25:14,310- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjdwp.so, putting tar entry is JRE/lib/arm/libjdwp.so
14/Jan/2015 15:25:14,330- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjsig.so, putting tar entry is JRE/lib/arm/libjsig.so
14/Jan/2015 15:25:14,331- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnet.so, putting tar entry is JRE/lib/arm/libnet.so
14/Jan/2015 15:25:14,342- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnio.so, putting tar entry is JRE/lib/arm/libnio.so
14/Jan/2015 15:25:14,349- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnpt.so, putting tar entry is JRE/lib/arm/libnpt.so
14/Jan/2015 15:25:14,356- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libverify.s o, putting tar entry is JRE/lib/arm/libverify.so
14/Jan/2015 15:25:14,362- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libzip.so, putting tar entry is JRE/lib/arm/libzip.so
14/Jan/2015 15:25:14,372- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\calendars.prope rties, putting tar entry is JRE/lib/calendars.properties
14/Jan/2015 15:25:14,373- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\classlist, putting tar entry is JRE/lib/classlist
14/Jan/2015 15:25:14,383- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\content-types.properties, putting tar entry is JRE/lib/content-types.properties
14/Jan/2015 15:25:14,386- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\currency.data, putting tar entry is JRE/lib/currency.data
14/Jan/2015 15:25:14,387- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext, putting tar entry is JRE/lib/ext
14/Jan/2015 15:25:14,387- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext\meta-index, putting tar entry is JRE/lib/ext/meta-index
14/Jan/2015 15:25:14,388- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext\sunjce_prov ider.jar, putting tar entry is JRE/lib/ext/sunjce_provider.jar
14/Jan/2015 15:25:14,410- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\hijrah-config-umalqura.properties, putting tar entry is JRE/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:25:14,419- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jce.jar, putting tar entry is JRE/lib/jce.jar
14/Jan/2015 15:25:14,431- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jsse.jar, putting tar entry is JRE/lib/jsse.jar
14/Jan/2015 15:25:14,459- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jvm.hprof.txt, putting tar entry is JRE/lib/jvm.hprof.txt
14/Jan/2015 15:25:14,459- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\logging.propert ies, putting tar entry is JRE/lib/logging.properties
14/Jan/2015 15:25:14,460- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\meta-index, putting tar entry is JRE/lib/meta-index
14/Jan/2015 15:25:14,461- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\net.properties, putting tar entry is JRE/lib/net.properties
14/Jan/2015 15:25:14,462- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\resources.jar, putting tar entry is JRE/lib/resources.jar
14/Jan/2015 15:25:14,506- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\rt.jar, putting tar entry is JRE/lib/rt.jar
14/Jan/2015 15:25:15,512- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security, putting tar entry is JRE/lib/security
14/Jan/2015 15:25:15,512- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\blackl ist, putting tar entry is JRE/lib/security/blacklist
14/Jan/2015 15:25:15,514- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\cacert s, putting tar entry is JRE/lib/security/cacerts
14/Jan/2015 15:25:15,524- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\java.p olicy, putting tar entry is JRE/lib/security/java.policy
14/Jan/2015 15:25:15,525- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\java.s ecurity, putting tar entry is JRE/lib/security/java.security
14/Jan/2015 15:25:15,530- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\local_ policy.jar, putting tar entry is JRE/lib/security/local_policy.jar
14/Jan/2015 15:25:15,532- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\truste d.libraries, putting tar entry is JRE/lib/security/trusted.libraries
14/Jan/2015 15:25:15,532- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\US_exp ort_policy.jar, putting tar entry is JRE/lib/security/US_export_policy.jar
14/Jan/2015 15:25:15,535- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\tzdb.dat, putting tar entry is JRE/lib/tzdb.dat
14/Jan/2015 15:25:15,547- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\release, putting tar entry is JRE/release
14/Jan/2015 15:25:16,578- DeployController: Failure to send JRE to the roboRio
com.jcraft.jsch.JSchException: java.net.ConnectException: Connection refused: connect
at com.jcraft.jsch.Util.createSocket(Util.java:349) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:215) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:183) ~[java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController.lambda$initialize$10(DeployControlle r.java:85) [java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController$$Lambda$161/9505331.run(Unknown Source) [java-installer.jar:?]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_25]
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method) ~[?:1.8.0_25]
at java.net.DualStackPlainSocketImpl.socketConnect(Un known Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connectToAddress( Unknown Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.PlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.SocksSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.Socket.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.Socket.<init>(Unknown Source) ~[?:1.8.0_25]
at com.jcraft.jsch.Util.createSocket(Util.java:343) ~[java-installer.jar:?]
... 5 more
14/Jan/2015 15:25:59,931- MainApp: Exiting installer from popup
14/Jan/2015 15:58:09,177- MainApp: Found JRE, checking hash
14/Jan/2015 15:58:10,216- MainApp: Computed hash is 082F08397B0D3F63844AB472B5111C8C, official hash is 082F08397B0D3F63844AB472B5111C8C
14/Jan/2015 15:58:12,572- UntarController: Starting decompress of file C:\Users\3539\wpilib\tools\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\3539\wpilib\tools
14/Jan/2015 15:58:12,582- UntarController: Untarring ejdk1.8.0_06/bin/
14/Jan/2015 15:58:12,582- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.sh
14/Jan/2015 15:58:12,584- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.bat
14/Jan/2015 15:58:12,585- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.config.properties
14/Jan/2015 15:58:12,636- UntarController: Untarring ejdk1.8.0_06/doc/
14/Jan/2015 15:58:12,637- UntarController: Untarring ejdk1.8.0_06/lib/
14/Jan/2015 15:58:12,637- UntarController: Untarring ejdk1.8.0_06/lib/JRECreate.jar
14/Jan/2015 15:58:12,651- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/
14/Jan/2015 15:58:12,652- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/
14/Jan/2015 15:58:12,652- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/
14/Jan/2015 15:58:12,652- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/
14/Jan/2015 15:58:12,653- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklist
14/Jan/2015 15:58:12,654- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/US_export_policy.jar
14/Jan/2015 15:58:12,655- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.security
14/Jan/2015 15:58:12,670- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.policy
14/Jan/2015 15:58:12,672- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/local_policy.jar
14/Jan/2015 15:58:12,673- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklisted.certs
14/Jan/2015 15:58:12,674- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/trusted.libraries
14/Jan/2015 15:58:12,674- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/cacerts
14/Jan/2015 15:58:12,692- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.bfc
14/Jan/2015 15:58:12,693- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.bfc
14/Jan/2015 15:58:12,695- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/meta-index
14/Jan/2015 15:58:12,696- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.bfc
14/Jan/2015 15:58:12,697- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/resources.jar
14/Jan/2015 15:58:12,721- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.properties.src
14/Jan/2015 15:58:12,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/classlist
14/Jan/2015 15:58:12,745- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/net.properties
14/Jan/2015 15:58:12,746- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management-agent.jar
14/Jan/2015 15:58:12,747- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr.jar
14/Jan/2015 15:58:12,754- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jvm.hprof.txt
14/Jan/2015 15:58:12,756- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/calendars.properties
14/Jan/2015 15:58:12,757- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/
14/Jan/2015 15:58:12,757- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/
14/Jan/2015 15:58:12,757- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkNoDrop32x32.gif
14/Jan/2015 15:58:12,768- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/cursors.properties
14/Jan/2015 15:58:12,770- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkDrop32x32.gif
14/Jan/2015 15:58:12,771- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/invalid32x32.gif
14/Jan/2015 15:58:12,772- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveNoDrop32x32.gif
14/Jan/2015 15:58:12,773- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyNoDrop32x32.gif
14/Jan/2015 15:58:12,774- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveDrop32x32.gif
14/Jan/2015 15:58:12,774- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyDrop32x32.gif
14/Jan/2015 15:58:12,775- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/charsets.jar
14/Jan/2015 15:58:12,818- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/
14/Jan/2015 15:58:12,819- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.password.template
14/Jan/2015 15:58:12,820- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/snmp.acl.template
14/Jan/2015 15:58:12,821- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.access
14/Jan/2015 15:58:12,822- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/management.properties
14/Jan/2015 15:58:12,825- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/
14/Jan/2015 15:58:12,826- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiBold.ttf
14/Jan/2015 15:58:12,832- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightItalic.ttf
14/Jan/2015 15:58:12,838- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiItalic.ttf
14/Jan/2015 15:58:12,844- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterBold.ttf
14/Jan/2015 15:58:12,853- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansDemiBold.ttf
14/Jan/2015 15:58:12,863- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightRegular.ttf
14/Jan/2015 15:58:12,876- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansRegular.ttf
14/Jan/2015 15:58:12,894- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterRegular.ttf
14/Jan/2015 15:58:12,903- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/fonts.dir
14/Jan/2015 15:58:12,905- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/content-types.properties
14/Jan/2015 15:58:12,906- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/rt.jar
14/Jan/2015 15:58:13,534- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jexec
14/Jan/2015 15:58:13,536- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.properties.src
14/Jan/2015 15:58:13,539- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/applet/
14/Jan/2015 15:58:13,540- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/
14/Jan/2015 15:58:13,540- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunec.jar
14/Jan/2015 15:58:13,783- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/cldrdata.jar
14/Jan/2015 15:58:13,905- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/meta-index
14/Jan/2015 15:58:13,921- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunjce_provider.jar
14/Jan/2015 15:58:13,933- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/localedata.jar
14/Jan/2015 15:58:13,968- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/zipfs.jar
14/Jan/2015 15:58:13,974- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/dnsns.jar
14/Jan/2015 15:58:14,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/nashorn.jar
14/Jan/2015 15:58:14,051- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunpkcs11.jar
14/Jan/2015 15:58:14,062- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/
14/Jan/2015 15:58:14,062- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/profile.jfc
14/Jan/2015 15:58:14,067- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/default.jfc
14/Jan/2015 15:58:14,072- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/
14/Jan/2015 15:58:14,072- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/LINEAR_RGB.pf
14/Jan/2015 15:58:14,073- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/CIEXYZ.pf
14/Jan/2015 15:58:14,078- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/GRAY.pf
14/Jan/2015 15:58:14,080- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/sRGB.pf
14/Jan/2015 15:58:14,086- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/PYCC.pf
14/Jan/2015 15:58:14,098- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/logging.properties
14/Jan/2015 15:58:14,100- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/tzdb.dat
14/Jan/2015 15:58:14,121- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:58:14,130- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.bfc
14/Jan/2015 15:58:14,136- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/
14/Jan/2015 15:58:14,137- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterBoldOblique.ttf
14/Jan/2015 15:58:14,143- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterOblique.ttf
14/Jan/2015 15:58:14,152- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansOblique.ttf
14/Jan/2015 15:58:14,164- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansDemiOblique.ttf
14/Jan/2015 15:58:14,172- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/fonts.dir
14/Jan/2015 15:58:14,176- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfontj2d.properties
14/Jan/2015 15:58:14,181- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.properties.src
14/Jan/2015 15:58:14,186- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/sound.properties
14/Jan/2015 15:58:14,188- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.properties.src
14/Jan/2015 15:58:14,190- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.properties.src
14/Jan/2015 15:58:14,194- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.properties.src
14/Jan/2015 15:58:14,199- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/currency.data
14/Jan/2015 15:58:14,202- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jce.jar
14/Jan/2015 15:58:14,209- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jsse.jar
14/Jan/2015 15:58:14,222- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.bfc
14/Jan/2015 15:58:14,223- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/
14/Jan/2015 15:58:14,223- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdt_socket.so
14/Jan/2015 15:58:14,246- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2gss.so
14/Jan/2015 15:58:14,254- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libhprof.so
14/Jan/2015 15:58:14,265- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/
14/Jan/2015 15:58:14,266- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/Xusage.txt
14/Jan/2015 15:58:14,269- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjvm.so
14/Jan/2015 15:58:14,435- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjsig.so
14/Jan/2015 15:58:14,436- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pcsc.so
14/Jan/2015 15:58:14,438- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/
14/Jan/2015 15:58:14,438- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjsig.so
14/Jan/2015 15:58:14,439- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjvm.so
14/Jan/2015 15:58:14,553- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/Xusage.txt
14/Jan/2015 15:58:14,554- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libinstrument.so
14/Jan/2015 15:58:14,645- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnpt.so
14/Jan/2015 15:58:14,646- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdcpr.so
14/Jan/2015 15:58:14,652- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/
14/Jan/2015 15:58:14,653- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:58:14,654- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjvm.so
14/Jan/2015 15:58:14,696- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjsig.so
14/Jan/2015 15:58:14,696- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsplashscreen.so
14/Jan/2015 15:58:14,705- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnet.so
14/Jan/2015 15:58:14,715- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsdt.so
14/Jan/2015 15:58:14,717- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsound.so
14/Jan/2015 15:58:14,719- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnio.so
14/Jan/2015 15:58:14,722- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:58:14,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsoundalsa.so
14/Jan/2015 15:58:14,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjaas_unix.so
14/Jan/2015 15:58:14,731- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libkcms.so
14/Jan/2015 15:58:14,740- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/
14/Jan/2015 15:58:14,740- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/libjli.so
14/Jan/2015 15:58:14,745- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmanagement.so
14/Jan/2015 15:58:14,759- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libt2k.so
14/Jan/2015 15:58:14,768- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjawt.so
14/Jan/2015 15:58:14,769- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsunec.so
14/Jan/2015 15:58:14,775- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jvm.cfg
14/Jan/2015 15:58:14,776- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjdwp.so
14/Jan/2015 15:58:14,783- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libunpack.so
14/Jan/2015 15:58:14,788- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/liblcms.so
14/Jan/2015 15:58:14,795- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt_headless.so
14/Jan/2015 15:58:14,800- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libfontmanager.so
14/Jan/2015 15:58:14,808- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjpeg.so
14/Jan/2015 15:58:14,814- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libzip.so
14/Jan/2015 15:58:14,819- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt.so
14/Jan/2015 15:58:14,829- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsig.so
14/Jan/2015 15:58:14,831- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmlib_image.so
14/Jan/2015 15:58:14,845- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libverify.so
14/Jan/2015 15:58:14,851- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjfr.so
14/Jan/2015 15:58:14,854- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsctp.so
14/Jan/2015 15:58:14,857- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pkcs11.so
14/Jan/2015 15:58:14,860- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava.so
14/Jan/2015 15:58:14,866- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfont.properties.ja
14/Jan/2015 15:58:14,868- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.bfc
14/Jan/2015 15:58:14,869- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/flavormap.properties
14/Jan/2015 15:58:14,870- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME.txt
14/Jan/2015 15:58:14,904- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/
14/Jan/2015 15:58:14,904- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/orbd
14/Jan/2015 15:58:14,907- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/keytool
14/Jan/2015 15:58:14,909- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmid
14/Jan/2015 15:58:14,910- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmiregistry
14/Jan/2015 15:58:14,913- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/pack200
14/Jan/2015 15:58:14,916- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/policytool
14/Jan/2015 15:58:14,917- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/servertool
14/Jan/2015 15:58:14,919- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/jjs
14/Jan/2015 15:58:14,920- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/tnameserv
14/Jan/2015 15:58:14,921- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/java
14/Jan/2015 15:58:14,922- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/unpack200
14/Jan/2015 15:58:14,927- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/COPYRIGHT
14/Jan/2015 15:58:14,930- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/release
14/Jan/2015 15:58:14,932- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME-JAVAFX.txt
14/Jan/2015 15:58:14,940- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/README
14/Jan/2015 15:58:14,941- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/
14/Jan/2015 15:58:14,941- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/
14/Jan/2015 15:58:14,941- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jsse.jar
14/Jan/2015 15:58:14,950- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/
14/Jan/2015 15:58:14,951- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.access
14/Jan/2015 15:58:14,952- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/management.properties
14/Jan/2015 15:58:14,956- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/snmp.acl.template
14/Jan/2015 15:58:14,957- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.password.template
14/Jan/2015 15:58:14,959- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/classlist
14/Jan/2015 15:58:14,963- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/
14/Jan/2015 15:58:14,964- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/localedata.jar
14/Jan/2015 15:58:14,990- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunjce_provider.jar
14/Jan/2015 15:58:15,001- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/meta-index
14/Jan/2015 15:58:15,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunpkcs11.jar
14/Jan/2015 15:58:15,011- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunec.jar
14/Jan/2015 15:58:15,079- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/currency.data
14/Jan/2015 15:58:15,082- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/meta-index
14/Jan/2015 15:58:15,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:58:15,092- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jce.jar
14/Jan/2015 15:58:15,097- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/
14/Jan/2015 15:58:15,098- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsctp.so
14/Jan/2015 15:58:15,101- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pcsc.so
14/Jan/2015 15:58:15,103- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava.so
14/Jan/2015 15:58:15,107- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsig.so
14/Jan/2015 15:58:15,109- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/
14/Jan/2015 15:58:15,109- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjsig.so
14/Jan/2015 15:58:15,109- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjvm.so
14/Jan/2015 15:58:15,186- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/Xusage.txt
14/Jan/2015 15:58:15,187- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libhprof.so
14/Jan/2015 15:58:15,192- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jvm.cfg
14/Jan/2015 15:58:15,193- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2gss.so
14/Jan/2015 15:58:15,196- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/
14/Jan/2015 15:58:15,196- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/Xusage.txt
14/Jan/2015 15:58:15,197- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjvm.so
14/Jan/2015 15:58:15,302- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjsig.so
14/Jan/2015 15:58:15,303- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libzip.so
14/Jan/2015 15:58:15,306- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pkcs11.so
14/Jan/2015 15:58:15,310- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/
14/Jan/2015 15:58:15,310- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/libjli.so
14/Jan/2015 15:58:15,314- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/
14/Jan/2015 15:58:15,315- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:58:15,316- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjvm.so
14/Jan/2015 15:58:15,358- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjsig.so
14/Jan/2015 15:58:15,358- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:58:15,361- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsdt.so
14/Jan/2015 15:58:15,362- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libmanagement.so
14/Jan/2015 15:58:15,366- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnio.so
14/Jan/2015 15:58:15,370- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjaas_unix.so
14/Jan/2015 15:58:15,371- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnpt.so
14/Jan/2015 15:58:15,373- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsunec.so
14/Jan/2015 15:58:15,379- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libinstrument.so
14/Jan/2015 15:58:15,382- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libverify.so
14/Jan/2015 15:58:15,386- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnet.so
14/Jan/2015 15:58:15,389- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/tzdb.dat
14/Jan/2015 15:58:15,395- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/content-types.properties
14/Jan/2015 15:58:15,396- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/rt.jar
14/Jan/2015 15:58:15,686- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management-agent.jar
14/Jan/2015 15:58:15,687- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/net.properties
14/Jan/2015 15:58:15,689- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/logging.properties
14/Jan/2015 15:58:15,690- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jvm.hprof.txt
14/Jan/2015 15:58:15,691- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/
14/Jan/2015 15:58:15,691- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/US_export_policy.jar
14/Jan/2015 15:58:15,692- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.policy
14/Jan/2015 15:58:15,693- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/trusted.libraries
14/Jan/2015 15:58:15,693- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/cacerts
14/Jan/2015 15:58:15,699- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/blacklist
14/Jan/2015 15:58:15,700- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.security
14/Jan/2015 15:58:15,704- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/local_policy.jar
14/Jan/2015 15:58:15,705- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/calendars.properties
14/Jan/2015 15:58:15,706- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/resources.jar
14/Jan/2015 15:58:15,718- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/
14/Jan/2015 15:58:15,719- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/java
14/Jan/2015 15:58:15,720- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/keytool
14/Jan/2015 15:58:15,721- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmiregistry
14/Jan/2015 15:58:15,722- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmid
14/Jan/2015 15:58:15,723- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/release
14/Jan/2015 15:58:15,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/
14/Jan/2015 15:58:15,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/
14/Jan/2015 15:58:15,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/
14/Jan/2015 15:58:15,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/
14/Jan/2015 15:58:15,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/libj2pkcs11.so
14/Jan/2015 15:58:15,728- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/
14/Jan/2015 15:58:15,728- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/sunpkcs11.jar
14/Jan/2015 15:58:15,736- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/
14/Jan/2015 15:58:15,736- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/
14/Jan/2015 15:58:15,736- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/
14/Jan/2015 15:58:15,737- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/nashorn.jar
14/Jan/2015 15:58:15,769- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/
14/Jan/2015 15:58:15,769- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/
14/Jan/2015 15:58:15,769- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/
14/Jan/2015 15:58:15,769- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/localedata.jar
14/Jan/2015 15:58:15,793- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/
14/Jan/2015 15:58:15,793- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/
14/Jan/2015 15:58:15,793- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/
14/Jan/2015 15:58:15,793- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/libsunec.so
14/Jan/2015 15:58:15,800- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/
14/Jan/2015 15:58:15,801- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/sunec.jar
14/Jan/2015 15:58:15,857- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/
14/Jan/2015 15:58:15,857- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/
14/Jan/2015 15:58:15,858- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/
14/Jan/2015 15:58:15,858- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libdt_socket.so
14/Jan/2015 15:58:15,861- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjdwp.so
14/Jan/2015 15:58:15,868- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:58:15,871- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libnpt.so
14/Jan/2015 15:58:15,872- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libhprof.so
14/Jan/2015 15:58:15,876- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/jvm.hprof.txt
14/Jan/2015 15:58:15,877- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/
14/Jan/2015 15:58:15,878- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/
14/Jan/2015 15:58:15,878- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/gcf.jar
14/Jan/2015 15:58:15,940- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/
14/Jan/2015 15:58:15,940- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/
14/Jan/2015 15:58:15,940- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/charsets.jar
14/Jan/2015 15:58:15,977- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/
14/Jan/2015 15:58:15,977- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/
14/Jan/2015 15:58:15,977- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/
14/Jan/2015 15:58:15,977- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjsig.so
14/Jan/2015 15:58:15,978- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjava.so
14/Jan/2015 15:58:15,984- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/
14/Jan/2015 15:58:15,990- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/libjli.so
14/Jan/2015 15:58:15,995- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libzip.so
14/Jan/2015 15:58:16,000- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jvm.cfg
14/Jan/2015 15:58:16,001- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libsunec.so
14/Jan/2015 15:58:16,007- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/
14/Jan/2015 15:58:16,007- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:58:16,008- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjvm.so
14/Jan/2015 15:58:16,050- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjsig.so
14/Jan/2015 15:58:16,050- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libverify.so
14/Jan/2015 15:58:16,054- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/
14/Jan/2015 15:58:16,054- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjvm.so
14/Jan/2015 15:58:16,218- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjsig.so
14/Jan/2015 15:58:16,219- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/Xusage.txt
14/Jan/2015 15:58:16,376- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libj2pkcs11.so
14/Jan/2015 15:58:16,380- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnio.so
14/Jan/2015 15:58:16,384- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnet.so
14/Jan/2015 15:58:16,388- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/
14/Jan/2015 15:58:16,388- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjvm.so
14/Jan/2015 15:58:16,467- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjsig.so
14/Jan/2015 15:58:16,468- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/Xusage.txt
14/Jan/2015 15:58:16,469- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/rt.jar
14/Jan/2015 15:58:16,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/meta-index
14/Jan/2015 15:58:16,726- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/
14/Jan/2015 15:58:16,726- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/cacerts
14/Jan/2015 15:58:16,732- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/US_export_policy.jar
14/Jan/2015 15:58:16,734- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.security
14/Jan/2015 15:58:16,738- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/blacklist
14/Jan/2015 15:58:16,739- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/local_policy.jar
14/Jan/2015 15:58:16,740- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/trusted.libraries
14/Jan/2015 15:58:16,741- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.policy
14/Jan/2015 15:58:16,742- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jce.jar
14/Jan/2015 15:58:16,748- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/logging.properties
14/Jan/2015 15:58:16,749- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/resources.jar
14/Jan/2015 15:58:16,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:58:16,771- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/
14/Jan/2015 15:58:16,772- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/localedata.jar
14/Jan/2015 15:58:16,797- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/meta-index
14/Jan/2015 15:58:16,799- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunpkcs11.jar
14/Jan/2015 15:58:16,806- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunec.jar
14/Jan/2015 15:58:16,863- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunjce_provider.jar
14/Jan/2015 15:58:16,871- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/currency.data
14/Jan/2015 15:58:16,873- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/calendars.properties
14/Jan/2015 15:58:16,874- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/classlist
14/Jan/2015 15:58:16,878- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/tzdb.dat
14/Jan/2015 15:58:16,885- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/net.properties
14/Jan/2015 15:58:16,886- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jsse.jar
14/Jan/2015 15:58:16,894- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/content-types.properties
14/Jan/2015 15:58:16,896- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/release
14/Jan/2015 15:58:16,897- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/
14/Jan/2015 15:58:16,897- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmiregistry
14/Jan/2015 15:58:16,899- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmid
14/Jan/2015 15:58:16,900- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/keytool
14/Jan/2015 15:58:16,901- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/java
14/Jan/2015 15:58:16,902- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/
14/Jan/2015 15:58:16,902- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/release
14/Jan/2015 15:58:16,903- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/
14/Jan/2015 15:58:16,903- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/classlist
14/Jan/2015 15:58:16,907- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/rt.jar
14/Jan/2015 15:58:17,047- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/tzdb.dat
14/Jan/2015 15:58:17,053- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/net.properties
14/Jan/2015 15:58:17,054- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/calendars.properties
14/Jan/2015 15:58:17,055- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:58:17,063- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/currency.data
14/Jan/2015 15:58:17,065- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jsse.jar
14/Jan/2015 15:58:17,073- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/meta-index
14/Jan/2015 15:58:17,075- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/content-types.properties
14/Jan/2015 15:58:17,076- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/
14/Jan/2015 15:58:17,076- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/US_export_policy.jar
14/Jan/2015 15:58:17,077- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/cacerts
14/Jan/2015 15:58:17,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.security
14/Jan/2015 15:58:17,087- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/local_policy.jar
14/Jan/2015 15:58:17,088- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.policy
14/Jan/2015 15:58:17,089- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/trusted.libraries
14/Jan/2015 15:58:17,090- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/blacklist
14/Jan/2015 15:58:17,091- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/
14/Jan/2015 15:58:17,091- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunpkcs11.jar
14/Jan/2015 15:58:17,099- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/meta-index
14/Jan/2015 15:58:17,100- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunec.jar
14/Jan/2015 15:58:17,155- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/localedata.jar
14/Jan/2015 15:58:17,179- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunjce_provider.jar
14/Jan/2015 15:58:17,187- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jce.jar
14/Jan/2015 15:58:17,191- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/resources.jar
14/Jan/2015 15:58:17,197- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/logging.properties
14/Jan/2015 15:58:17,199- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/
14/Jan/2015 15:58:17,199- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libverify.so
14/Jan/2015 15:58:17,202- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/
14/Jan/2015 15:58:17,203- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/libjli.so
14/Jan/2015 15:58:17,206- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libzip.so
14/Jan/2015 15:58:17,211- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/
14/Jan/2015 15:58:17,211- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjvm.so
14/Jan/2015 15:58:17,253- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjsig.so
14/Jan/2015 15:58:17,253- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:58:17,255- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnet.so
14/Jan/2015 15:58:17,258- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jvm.cfg
14/Jan/2015 15:58:17,260- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnio.so
14/Jan/2015 15:58:17,262- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libj2pkcs11.so
14/Jan/2015 15:58:17,267- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjava.so
14/Jan/2015 15:58:17,272- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/
14/Jan/2015 15:58:17,272- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjsig.so
14/Jan/2015 15:58:17,272- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/Xusage.txt
14/Jan/2015 15:58:17,273- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjvm.so
14/Jan/2015 15:58:17,377- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjsig.so
14/Jan/2015 15:58:17,378- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/
14/Jan/2015 15:58:17,378- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjsig.so
14/Jan/2015 15:58:17,379- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/Xusage.txt
14/Jan/2015 15:58:17,381- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjvm.so
14/Jan/2015 15:58:17,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libsunec.so
14/Jan/2015 15:58:17,465- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/
14/Jan/2015 15:58:17,466- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/keytool
14/Jan/2015 15:58:17,467- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/java
14/Jan/2015 15:58:17,468- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/
14/Jan/2015 15:58:17,468- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/
14/Jan/2015 15:58:17,468- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/
14/Jan/2015 15:58:17,468- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/
14/Jan/2015 15:58:17,469- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/
14/Jan/2015 15:58:17,469- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/jfxrt-controls.jar
14/Jan/2015 15:58:17,518- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/
14/Jan/2015 15:58:17,518- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/
14/Jan/2015 15:58:17,518- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.platform.properties
14/Jan/2015 15:58:17,520- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.properties
14/Jan/2015 15:58:17,521- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/
14/Jan/2015 15:58:17,521- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/liblens_porting.so
14/Jan/2015 15:58:17,525- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_iio.so
14/Jan/2015 15:58:17,534- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_sw.so
14/Jan/2015 15:58:17,538- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font_t2k.so
14/Jan/2015 15:58:17,557- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_eglfb.so
14/Jan/2015 15:58:17,565- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass.so
14/Jan/2015 15:58:17,571- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font.so
14/Jan/2015 15:58:17,575- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_es2_eglfb.so
14/Jan/2015 15:58:17,579- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_common.so
14/Jan/2015 15:58:17,584- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_dfb.so
14/Jan/2015 15:58:17,591- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/
14/Jan/2015 15:58:17,591- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/jfxrt-graphics.jar
14/Jan/2015 15:58:17,711- CreateJreController: Staring JRE Creation
14/Jan/2015 15:58:17,711- CreateJreController: Creator location: C:\Users\3539\wpilib\tools\ejdk1.8.0_06\lib\JRECre ate.jar
14/Jan/2015 15:58:17,711- CreateJreController: Command: [java, -jar, C:\Users\3539\wpilib\tools\ejdk1.8.0_06\lib\JRECre ate.jar, --dest, JRE, --profile, compact2, --vm, client, --keep-debug-info, --debug]
14/Jan/2015 15:58:18,142- CreateJreController: Successfully Created JRE!
14/Jan/2015 15:59:30,780- ConnectRoboRioController: Connecting to roborio-3539.local
14/Jan/2015 15:59:30,781- ConnectRoboRioController: Checking for mDNS connection to the roboRio
14/Jan/2015 15:59:37,065- ConnectRoboRioController: Could not connect to the roboRio at roborio-3539.local
java.net.UnknownHostException: roborio-3539.local
at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method) ~[?:1.8.0_25]
at java.net.InetAddress$2.lookupAllHostAddr(Unknown Source) ~[?:1.8.0_25]
at java.net.InetAddress.getAddressesFromNameService(U nknown Source) ~[?:1.8.0_25]
at java.net.InetAddress.getAllByName0(Unknown Source) ~[?:1.8.0_25]
at java.net.InetAddress.getAllByName(Unknown Source) ~[?:1.8.0_25]
at java.net.InetAddress.getByName(Unknown Source) ~[?:1.8.0_25]
at edu.wpi.first.wpilib.javainstaller.Controllers.Con nectRoboRioController.checkReachable(ConnectRoboRi oController.java:137) [java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Con nectRoboRioController.lambda$handleNext$19(Connect RoboRioController.java:101) [java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Con nectRoboRioController$$Lambda$158/5862715.run(Unknown Source) [java-installer.jar:?]
14/Jan/2015 15:59:37,078- ConnectRoboRioController: No mDNS connection found, checking for USB Connection to the roboRio
14/Jan/2015 15:59:38,082- ConnectRoboRioController: Found USB connection to the roboRio
14/Jan/2015 15:59:38,083- ConnectRoboRioController: Connected to the roboRio at 172.22.11.2
14/Jan/2015 15:59:38,126- DeployController: Removed the old tgz file
14/Jan/2015 15:59:38,126- DeployController: Starting zip
14/Jan/2015 15:59:38,134- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE, putting tar entry is JRE
14/Jan/2015 15:59:38,135- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin, putting tar entry is JRE/bin
14/Jan/2015 15:59:38,136- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\java, putting tar entry is JRE/bin/java
14/Jan/2015 15:59:38,138- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\keytool, putting tar entry is JRE/bin/keytool
14/Jan/2015 15:59:38,140- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\rmid, putting tar entry is JRE/bin/rmid
14/Jan/2015 15:59:38,141- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\rmiregistry, putting tar entry is JRE/bin/rmiregistry
14/Jan/2015 15:59:38,143- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bom, putting tar entry is JRE/bom
14/Jan/2015 15:59:38,144- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib, putting tar entry is JRE/lib
14/Jan/2015 15:59:38,146- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm, putting tar entry is JRE/lib/arm
14/Jan/2015 15:59:38,147- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client, putting tar entry is JRE/lib/arm/client
14/Jan/2015 15:59:38,147- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\libj sig.so, putting tar entry is JRE/lib/arm/client/libjsig.so
14/Jan/2015 15:59:38,148- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\libj vm.so, putting tar entry is JRE/lib/arm/client/libjvm.so
14/Jan/2015 15:59:38,545- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\Xusa ge.txt, putting tar entry is JRE/lib/arm/client/Xusage.txt
14/Jan/2015 15:59:38,546- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jli, putting tar entry is JRE/lib/arm/jli
14/Jan/2015 15:59:38,546- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jli\libjli. so, putting tar entry is JRE/lib/arm/jli/libjli.so
14/Jan/2015 15:59:38,556- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jvm.cfg, putting tar entry is JRE/lib/arm/jvm.cfg
14/Jan/2015 15:59:38,556- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libdt_socke t.so, putting tar entry is JRE/lib/arm/libdt_socket.so
14/Jan/2015 15:59:38,559- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libhprof.so , putting tar entry is JRE/lib/arm/libhprof.so
14/Jan/2015 15:59:38,572- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjava.so, putting tar entry is JRE/lib/arm/libjava.so
14/Jan/2015 15:59:38,587- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjava_crw _demo.so, putting tar entry is JRE/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:59:38,592- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjdwp.so, putting tar entry is JRE/lib/arm/libjdwp.so
14/Jan/2015 15:59:38,611- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjsig.so, putting tar entry is JRE/lib/arm/libjsig.so
14/Jan/2015 15:59:38,613- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnet.so, putting tar entry is JRE/lib/arm/libnet.so
14/Jan/2015 15:59:38,622- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnio.so, putting tar entry is JRE/lib/arm/libnio.so
14/Jan/2015 15:59:38,629- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnpt.so, putting tar entry is JRE/lib/arm/libnpt.so
14/Jan/2015 15:59:38,631- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libverify.s o, putting tar entry is JRE/lib/arm/libverify.so
14/Jan/2015 15:59:38,637- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libzip.so, putting tar entry is JRE/lib/arm/libzip.so
14/Jan/2015 15:59:38,647- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\calendars.prope rties, putting tar entry is JRE/lib/calendars.properties
14/Jan/2015 15:59:38,648- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\classlist, putting tar entry is JRE/lib/classlist
14/Jan/2015 15:59:38,657- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\content-types.properties, putting tar entry is JRE/lib/content-types.properties
14/Jan/2015 15:59:38,659- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\currency.data, putting tar entry is JRE/lib/currency.data
14/Jan/2015 15:59:38,660- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext, putting tar entry is JRE/lib/ext
14/Jan/2015 15:59:38,660- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext\meta-index, putting tar entry is JRE/lib/ext/meta-index
14/Jan/2015 15:59:38,661- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext\sunjce_prov ider.jar, putting tar entry is JRE/lib/ext/sunjce_provider.jar
14/Jan/2015 15:59:38,684- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\hijrah-config-umalqura.properties, putting tar entry is JRE/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:59:38,691- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jce.jar, putting tar entry is JRE/lib/jce.jar
14/Jan/2015 15:59:38,702- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jsse.jar, putting tar entry is JRE/lib/jsse.jar
14/Jan/2015 15:59:38,726- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jvm.hprof.txt, putting tar entry is JRE/lib/jvm.hprof.txt
14/Jan/2015 15:59:38,727- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\logging.propert ies, putting tar entry is JRE/lib/logging.properties
14/Jan/2015 15:59:38,729- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\meta-index, putting tar entry is JRE/lib/meta-index
14/Jan/2015 15:59:38,730- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\net.properties, putting tar entry is JRE/lib/net.properties
14/Jan/2015 15:59:38,731- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\resources.jar, putting tar entry is JRE/lib/resources.jar
14/Jan/2015 15:59:38,767- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\rt.jar, putting tar entry is JRE/lib/rt.jar
14/Jan/2015 15:59:39,666- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security, putting tar entry is JRE/lib/security
14/Jan/2015 15:59:39,667- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\blackl ist, putting tar entry is JRE/lib/security/blacklist
14/Jan/2015 15:59:39,668- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\cacert s, putting tar entry is JRE/lib/security/cacerts
14/Jan/2015 15:59:39,676- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\java.p olicy, putting tar entry is JRE/lib/security/java.policy
14/Jan/2015 15:59:39,678- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\java.s ecurity, putting tar entry is JRE/lib/security/java.security
14/Jan/2015 15:59:39,683- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\local_ policy.jar, putting tar entry is JRE/lib/security/local_policy.jar
14/Jan/2015 15:59:39,684- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\truste d.libraries, putting tar entry is JRE/lib/security/trusted.libraries
14/Jan/2015 15:59:39,685- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\US_exp ort_policy.jar, putting tar entry is JRE/lib/security/US_export_policy.jar
14/Jan/2015 15:59:39,686- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\tzdb.dat, putting tar entry is JRE/lib/tzdb.dat
14/Jan/2015 15:59:39,697- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\release, putting tar entry is JRE/release
14/Jan/2015 15:59:40,806- DeployController: Failure to send JRE to the roboRio
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController$$Lambda$160/26264387.run(Unknown Source) [java-installer.jar:?]
... 5 more
14/Jan/2015 16:00:26,655- MainApp: Exiting installer from popup
Unread 14-01-2015, 16:03
jagow100's Avatar
jagow100 jagow100 is offline
FRC #3539 (Byting Bulldogs)
jagow100 is an unknown quantity at this point
Re: Issue putting the java on the roboRIO
14/Jan/2015 14:37:03,670- InternetController: Starting internet check
14/Jan/2015 14:37:03,784- InternetController: Internet check successful, moving to download
14/Jan/2015 14:37:03,924- DownloadController: Loading download page page
14/Jan/2015 14:37:03,925- DownloadController: Loading download page page
14/Jan/2015 14:37:05,893- DownloadController: Loading download page page
14/Jan/2015 14:37:58,396- DownloadController: Loading unknown page
14/Jan/2015 14:37:58,397- DownloadController: Loading unknown page
14/Jan/2015 14:37:59,822- DownloadController: Loading unknown page
14/Jan/2015 14:37:59,849- DownloadController: Loading login page
14/Jan/2015 14:38:00,847- DownloadController: Loading login page
14/Jan/2015 14:38:10,657- DownloadController: Loading unknown page
14/Jan/2015 14:38:10,908- DownloadController: Loading unknown page
14/Jan/2015 14:38:10,918- DownloadController: Loading login page
14/Jan/2015 14:38:11,128- DownloadController: Loading login page
14/Jan/2015 14:41:36,529- DownloadController: Loading unknown page
14/Jan/2015 14:41:37,191- DownloadController: Signed in and have the .tar.gz link.
14/Jan/2015 14:41:37,257- DownloadProgressController: Initial url is https://edelivery.oracle.com/akam/ot...un_2014.tar.gz
14/Jan/2015 14:41:37,678- DownloadProgressController: Final url is http://download.oracle.com/otn/java/...ee653c15768069
14/Jan/2015 14:41:37,680- DownloadProgressController: Starting JRE download. File size is 121568917 bytes
14/Jan/2015 14:41:37,683- DownloadController: Loading unknown page
14/Jan/2015 14:42:26,971- DownloadProgressController: Downloaded JRE
14/Jan/2015 14:42:27,022- MainApp: Found JRE, checking hash
14/Jan/2015 14:42:28,143- MainApp: Computed hash is 082F08397B0D3F63844AB472B5111C8C, official hash is 082F08397B0D3F63844AB472B5111C8C
14/Jan/2015 14:42:52,585- UntarController: Starting decompress of file C:\Users\3539\wpilib\tools\.\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\3539\wpilib\tools\.
14/Jan/2015 14:42:52,602- UntarController: Untarring ejdk1.8.0_06/bin/
14/Jan/2015 14:42:52,603- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.sh
14/Jan/2015 14:42:52,618- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.bat
14/Jan/2015 14:42:52,661- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.config.properties
14/Jan/2015 14:42:52,749- UntarController: Untarring ejdk1.8.0_06/doc/
14/Jan/2015 14:42:52,750- UntarController: Untarring ejdk1.8.0_06/lib/
14/Jan/2015 14:42:52,750- UntarController: Untarring ejdk1.8.0_06/lib/JRECreate.jar
14/Jan/2015 14:42:52,762- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/
14/Jan/2015 14:42:52,762- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/
14/Jan/2015 14:42:52,763- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/
14/Jan/2015 14:42:52,764- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/
14/Jan/2015 14:42:52,765- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklist
14/Jan/2015 14:42:52,770- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/US_export_policy.jar
14/Jan/2015 14:42:52,772- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.security
14/Jan/2015 14:42:52,785- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.policy
14/Jan/2015 14:42:52,787- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/local_policy.jar
14/Jan/2015 14:42:52,788- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklisted.certs
14/Jan/2015 14:42:52,792- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/trusted.libraries
14/Jan/2015 14:42:52,793- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/cacerts
14/Jan/2015 14:42:52,828- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.bfc
14/Jan/2015 14:42:52,849- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.bfc
14/Jan/2015 14:42:52,852- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/meta-index
14/Jan/2015 14:42:52,857- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.bfc
14/Jan/2015 14:42:52,861- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/resources.jar
14/Jan/2015 14:42:52,889- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.properties.src
14/Jan/2015 14:42:52,893- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/classlist
14/Jan/2015 14:42:52,926- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/net.properties
14/Jan/2015 14:42:52,928- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management-agent.jar
14/Jan/2015 14:42:52,959- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr.jar
14/Jan/2015 14:42:52,968- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jvm.hprof.txt
14/Jan/2015 14:42:52,971- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/calendars.properties
14/Jan/2015 14:42:52,973- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/
14/Jan/2015 14:42:52,974- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/
14/Jan/2015 14:42:52,974- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkNoDrop32x32.gif
14/Jan/2015 14:42:52,993- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/cursors.properties
14/Jan/2015 14:42:52,996- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkDrop32x32.gif
14/Jan/2015 14:42:52,999- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/invalid32x32.gif
14/Jan/2015 14:42:53,001- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveNoDrop32x32.gif
14/Jan/2015 14:42:53,003- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyNoDrop32x32.gif
14/Jan/2015 14:42:53,004- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveDrop32x32.gif
14/Jan/2015 14:42:53,005- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyDrop32x32.gif
14/Jan/2015 14:42:53,006- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/charsets.jar
14/Jan/2015 14:42:53,045- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/
14/Jan/2015 14:42:53,046- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.password.template
14/Jan/2015 14:42:53,048- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/snmp.acl.template
14/Jan/2015 14:42:53,050- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.access
14/Jan/2015 14:42:53,051- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/management.properties
14/Jan/2015 14:42:53,055- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/
14/Jan/2015 14:42:53,056- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiBold.ttf
14/Jan/2015 14:42:53,063- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightItalic.ttf
14/Jan/2015 14:42:53,069- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiItalic.ttf
14/Jan/2015 14:42:53,076- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterBold.ttf
14/Jan/2015 14:42:53,086- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansDemiBold.ttf
14/Jan/2015 14:42:53,096- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightRegular.ttf
14/Jan/2015 14:42:53,138- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansRegular.ttf
14/Jan/2015 14:42:53,156- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterRegular.ttf
14/Jan/2015 14:42:53,167- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/fonts.dir
14/Jan/2015 14:42:53,172- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/content-types.properties
14/Jan/2015 14:42:53,202- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/rt.jar
14/Jan/2015 14:42:53,873- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jexec
14/Jan/2015 14:42:54,013- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.properties.src
14/Jan/2015 14:42:54,023- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/applet/
14/Jan/2015 14:42:54,024- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/
14/Jan/2015 14:42:54,024- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunec.jar
14/Jan/2015 14:42:54,253- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/cldrdata.jar
14/Jan/2015 14:42:54,338- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/meta-index
14/Jan/2015 14:42:54,341- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunjce_provider.jar
14/Jan/2015 14:42:54,351- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/localedata.jar
14/Jan/2015 14:42:54,378- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/zipfs.jar
14/Jan/2015 14:42:54,383- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/dnsns.jar
14/Jan/2015 14:42:54,404- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/nashorn.jar
14/Jan/2015 14:42:54,440- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunpkcs11.jar
14/Jan/2015 14:42:54,450- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/
14/Jan/2015 14:42:54,451- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/profile.jfc
14/Jan/2015 14:42:54,454- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/default.jfc
14/Jan/2015 14:42:54,458- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/
14/Jan/2015 14:42:54,458- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/LINEAR_RGB.pf
14/Jan/2015 14:42:54,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/CIEXYZ.pf
14/Jan/2015 14:42:54,463- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/GRAY.pf
14/Jan/2015 14:42:54,466- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/sRGB.pf
14/Jan/2015 14:42:54,468- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/PYCC.pf
14/Jan/2015 14:42:54,476- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/logging.properties
14/Jan/2015 14:42:54,478- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/tzdb.dat
14/Jan/2015 14:42:54,502- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:42:54,510- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.bfc
14/Jan/2015 14:42:54,514- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/
14/Jan/2015 14:42:54,515- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterBoldOblique.ttf
14/Jan/2015 14:42:54,520- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterOblique.ttf
14/Jan/2015 14:42:54,526- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansOblique.ttf
14/Jan/2015 14:42:54,536- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansDemiOblique.ttf
14/Jan/2015 14:42:54,541- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/fonts.dir
14/Jan/2015 14:42:54,544- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfontj2d.properties
14/Jan/2015 14:42:54,549- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.properties.src
14/Jan/2015 14:42:54,552- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/sound.properties
14/Jan/2015 14:42:54,554- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.properties.src
14/Jan/2015 14:42:54,556- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.properties.src
14/Jan/2015 14:42:54,560- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.properties.src
14/Jan/2015 14:42:54,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/currency.data
14/Jan/2015 14:42:54,570- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jce.jar
14/Jan/2015 14:42:54,575- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jsse.jar
14/Jan/2015 14:42:54,584- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.bfc
14/Jan/2015 14:42:54,588- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/
14/Jan/2015 14:42:54,589- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdt_socket.so
14/Jan/2015 14:42:54,592- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2gss.so
14/Jan/2015 14:42:54,596- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libhprof.so
14/Jan/2015 14:42:54,601- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/
14/Jan/2015 14:42:54,602- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/Xusage.txt
14/Jan/2015 14:42:54,675- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjvm.so
14/Jan/2015 14:42:54,783- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjsig.so
14/Jan/2015 14:42:54,784- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pcsc.so
14/Jan/2015 14:42:54,787- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/
14/Jan/2015 14:42:54,788- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjsig.so
14/Jan/2015 14:42:54,788- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjvm.so
14/Jan/2015 14:42:54,871- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/Xusage.txt
14/Jan/2015 14:42:54,872- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libinstrument.so
14/Jan/2015 14:42:54,876- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnpt.so
14/Jan/2015 14:42:54,880- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdcpr.so
14/Jan/2015 14:42:54,886- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/
14/Jan/2015 14:42:54,886- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:42:54,887- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjvm.so
14/Jan/2015 14:42:54,933- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjsig.so
14/Jan/2015 14:42:54,934- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsplashscreen.so
14/Jan/2015 14:42:54,941- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnet.so
14/Jan/2015 14:42:54,952- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsdt.so
14/Jan/2015 14:42:54,955- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsound.so
14/Jan/2015 14:42:54,957- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnio.so
14/Jan/2015 14:42:54,962- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:42:54,969- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsoundalsa.so
14/Jan/2015 14:42:54,972- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjaas_unix.so
14/Jan/2015 14:42:54,975- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libkcms.so
14/Jan/2015 14:42:54,983- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/
14/Jan/2015 14:42:54,983- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/libjli.so
14/Jan/2015 14:42:54,987- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmanagement.so
14/Jan/2015 14:42:54,996- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libt2k.so
14/Jan/2015 14:42:55,008- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjawt.so
14/Jan/2015 14:42:55,011- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsunec.so
14/Jan/2015 14:42:55,017- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jvm.cfg
14/Jan/2015 14:42:55,030- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjdwp.so
14/Jan/2015 14:42:55,038- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libunpack.so
14/Jan/2015 14:42:55,043- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/liblcms.so
14/Jan/2015 14:42:55,053- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt_headless.so
14/Jan/2015 14:42:55,057- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libfontmanager.so
14/Jan/2015 14:42:55,067- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjpeg.so
14/Jan/2015 14:42:55,072- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libzip.so
14/Jan/2015 14:42:55,077- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt.so
14/Jan/2015 14:42:55,087- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsig.so
14/Jan/2015 14:42:55,090- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmlib_image.so
14/Jan/2015 14:42:55,106- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libverify.so
14/Jan/2015 14:42:55,110- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjfr.so
14/Jan/2015 14:42:55,112- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsctp.so
14/Jan/2015 14:42:55,117- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pkcs11.so
14/Jan/2015 14:42:55,120- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava.so
14/Jan/2015 14:42:55,125- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfont.properties.ja
14/Jan/2015 14:42:55,127- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.bfc
14/Jan/2015 14:42:55,132- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/flavormap.properties
14/Jan/2015 14:42:55,156- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME.txt
14/Jan/2015 14:42:55,162- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/
14/Jan/2015 14:42:55,163- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/orbd
14/Jan/2015 14:42:55,168- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/keytool
14/Jan/2015 14:42:55,172- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmid
14/Jan/2015 14:42:55,174- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmiregistry
14/Jan/2015 14:42:55,177- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/pack200
14/Jan/2015 14:42:55,181- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/policytool
14/Jan/2015 14:42:55,186- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/servertool
14/Jan/2015 14:42:55,189- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/jjs
14/Jan/2015 14:42:55,191- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/tnameserv
14/Jan/2015 14:42:55,194- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/java
14/Jan/2015 14:42:55,212- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/unpack200
14/Jan/2015 14:42:55,220- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/COPYRIGHT
14/Jan/2015 14:42:55,221- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/release
14/Jan/2015 14:42:55,224- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME-JAVAFX.txt
14/Jan/2015 14:42:55,233- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/README
14/Jan/2015 14:42:55,235- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/
14/Jan/2015 14:42:55,236- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/
14/Jan/2015 14:42:55,236- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jsse.jar
14/Jan/2015 14:42:55,244- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/
14/Jan/2015 14:42:55,245- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.access
14/Jan/2015 14:42:55,247- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/management.properties
14/Jan/2015 14:42:55,251- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/snmp.acl.template
14/Jan/2015 14:42:55,253- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.password.template
14/Jan/2015 14:42:55,254- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/classlist
14/Jan/2015 14:42:55,259- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/
14/Jan/2015 14:42:55,259- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/localedata.jar
14/Jan/2015 14:42:55,283- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunjce_provider.jar
14/Jan/2015 14:42:55,291- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/meta-index
14/Jan/2015 14:42:55,293- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunpkcs11.jar
14/Jan/2015 14:42:55,304- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunec.jar
14/Jan/2015 14:42:55,364- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/currency.data
14/Jan/2015 14:42:55,367- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/meta-index
14/Jan/2015 14:42:55,382- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:42:55,390- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jce.jar
14/Jan/2015 14:42:55,394- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/
14/Jan/2015 14:42:55,395- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsctp.so
14/Jan/2015 14:42:55,399- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pcsc.so
14/Jan/2015 14:42:55,401- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava.so
14/Jan/2015 14:42:55,407- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsig.so
14/Jan/2015 14:42:55,408- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/
14/Jan/2015 14:42:55,408- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjsig.so
14/Jan/2015 14:42:55,409- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjvm.so
14/Jan/2015 14:42:55,491- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/Xusage.txt
14/Jan/2015 14:42:55,492- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libhprof.so
14/Jan/2015 14:42:55,498- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jvm.cfg
14/Jan/2015 14:42:55,500- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2gss.so
14/Jan/2015 14:42:55,503- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/
14/Jan/2015 14:42:55,504- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/Xusage.txt
14/Jan/2015 14:42:55,505- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjvm.so
14/Jan/2015 14:42:55,616- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjsig.so
14/Jan/2015 14:42:55,616- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libzip.so
14/Jan/2015 14:42:55,620- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pkcs11.so
14/Jan/2015 14:42:55,623- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/
14/Jan/2015 14:42:55,624- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/libjli.so
14/Jan/2015 14:42:55,628- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/
14/Jan/2015 14:42:55,628- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:42:55,631- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjvm.so
14/Jan/2015 14:42:55,674- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjsig.so
14/Jan/2015 14:42:55,675- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:42:55,678- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsdt.so
14/Jan/2015 14:42:55,681- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libmanagement.so
14/Jan/2015 14:42:55,686- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnio.so
14/Jan/2015 14:42:55,690- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjaas_unix.so
14/Jan/2015 14:42:55,691- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnpt.so
14/Jan/2015 14:42:55,692- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsunec.so
14/Jan/2015 14:42:55,702- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libinstrument.so
14/Jan/2015 14:42:55,706- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libverify.so
14/Jan/2015 14:42:55,711- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnet.so
14/Jan/2015 14:42:55,718- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/tzdb.dat
14/Jan/2015 14:42:55,723- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/content-types.properties
14/Jan/2015 14:42:55,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/rt.jar
14/Jan/2015 14:42:56,058- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management-agent.jar
14/Jan/2015 14:42:56,059- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/net.properties
14/Jan/2015 14:42:56,060- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/logging.properties
14/Jan/2015 14:42:56,060- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jvm.hprof.txt
14/Jan/2015 14:42:56,061- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/
14/Jan/2015 14:42:56,061- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/US_export_policy.jar
14/Jan/2015 14:42:56,063- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.policy
14/Jan/2015 14:42:56,065- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/trusted.libraries
14/Jan/2015 14:42:56,066- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/cacerts
14/Jan/2015 14:42:56,072- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/blacklist
14/Jan/2015 14:42:56,073- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.security
14/Jan/2015 14:42:56,077- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/local_policy.jar
14/Jan/2015 14:42:56,078- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/calendars.properties
14/Jan/2015 14:42:56,080- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/resources.jar
14/Jan/2015 14:42:56,092- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/
14/Jan/2015 14:42:56,092- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/java
14/Jan/2015 14:42:56,093- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/keytool
14/Jan/2015 14:42:56,094- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmiregistry
14/Jan/2015 14:42:56,095- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmid
14/Jan/2015 14:42:56,097- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/release
14/Jan/2015 14:42:56,101- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/
14/Jan/2015 14:42:56,102- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/
14/Jan/2015 14:42:56,103- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/
14/Jan/2015 14:42:56,104- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/
14/Jan/2015 14:42:56,105- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/libj2pkcs11.so
14/Jan/2015 14:42:56,108- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/
14/Jan/2015 14:42:56,108- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/sunpkcs11.jar
14/Jan/2015 14:42:56,116- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/
14/Jan/2015 14:42:56,117- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/
14/Jan/2015 14:42:56,117- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/
14/Jan/2015 14:42:56,118- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/nashorn.jar
14/Jan/2015 14:42:56,151- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/
14/Jan/2015 14:42:56,151- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/
14/Jan/2015 14:42:56,151- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/
14/Jan/2015 14:42:56,152- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/localedata.jar
14/Jan/2015 14:42:56,177- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/
14/Jan/2015 14:42:56,177- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/
14/Jan/2015 14:42:56,178- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/
14/Jan/2015 14:42:56,178- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/libsunec.so
14/Jan/2015 14:42:56,185- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/
14/Jan/2015 14:42:56,185- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/sunec.jar
14/Jan/2015 14:42:56,248- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/
14/Jan/2015 14:42:56,248- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/
14/Jan/2015 14:42:56,249- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/
14/Jan/2015 14:42:56,249- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libdt_socket.so
14/Jan/2015 14:42:56,252- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjdwp.so
14/Jan/2015 14:42:56,258- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:42:56,261- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libnpt.so
14/Jan/2015 14:42:56,263- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libhprof.so
14/Jan/2015 14:42:56,269- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/jvm.hprof.txt
14/Jan/2015 14:42:56,270- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/
14/Jan/2015 14:42:56,271- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/
14/Jan/2015 14:42:56,271- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/gcf.jar
14/Jan/2015 14:42:56,379- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/
14/Jan/2015 14:42:56,380- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/
14/Jan/2015 14:42:56,381- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/charsets.jar
14/Jan/2015 14:42:56,423- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/
14/Jan/2015 14:42:56,423- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/
14/Jan/2015 14:42:56,424- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/
14/Jan/2015 14:42:56,424- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjsig.so
14/Jan/2015 14:42:56,425- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjava.so
14/Jan/2015 14:42:56,431- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/
14/Jan/2015 14:42:56,432- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/libjli.so
14/Jan/2015 14:42:56,436- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libzip.so
14/Jan/2015 14:42:56,442- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jvm.cfg
14/Jan/2015 14:42:56,444- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libsunec.so
14/Jan/2015 14:42:56,451- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/
14/Jan/2015 14:42:56,460- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:42:56,462- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjvm.so
14/Jan/2015 14:42:56,507- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjsig.so
14/Jan/2015 14:42:56,508- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libverify.so
14/Jan/2015 14:42:56,511- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/
14/Jan/2015 14:42:56,512- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjvm.so
14/Jan/2015 14:42:56,620- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjsig.so
14/Jan/2015 14:42:56,620- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/Xusage.txt
14/Jan/2015 14:42:56,622- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libj2pkcs11.so
14/Jan/2015 14:42:56,625- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnio.so
14/Jan/2015 14:42:56,632- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnet.so
14/Jan/2015 14:42:56,636- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/
14/Jan/2015 14:42:56,637- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjvm.so
14/Jan/2015 14:42:56,720- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjsig.so
14/Jan/2015 14:42:56,721- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/Xusage.txt
14/Jan/2015 14:42:56,723- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/rt.jar
14/Jan/2015 14:42:56,981- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/meta-index
14/Jan/2015 14:42:56,984- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/
14/Jan/2015 14:42:56,985- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/cacerts
14/Jan/2015 14:42:56,989- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/US_export_policy.jar
14/Jan/2015 14:42:56,991- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.security
14/Jan/2015 14:42:56,994- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/blacklist
14/Jan/2015 14:42:56,998- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/local_policy.jar
14/Jan/2015 14:42:56,999- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/trusted.libraries
14/Jan/2015 14:42:57,000- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.policy
14/Jan/2015 14:42:57,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jce.jar
14/Jan/2015 14:42:57,007- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/logging.properties
14/Jan/2015 14:42:57,009- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/resources.jar
14/Jan/2015 14:42:57,022- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:42:57,030- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/
14/Jan/2015 14:42:57,031- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/localedata.jar
14/Jan/2015 14:42:57,055- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/meta-index
14/Jan/2015 14:42:57,056- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunpkcs11.jar
14/Jan/2015 14:42:57,064- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunec.jar
14/Jan/2015 14:42:57,128- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunjce_provider.jar
14/Jan/2015 14:42:57,138- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/currency.data
14/Jan/2015 14:42:57,139- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/calendars.properties
14/Jan/2015 14:42:57,140- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/classlist
14/Jan/2015 14:42:57,144- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/tzdb.dat
14/Jan/2015 14:42:57,151- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/net.properties
14/Jan/2015 14:42:57,152- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jsse.jar
14/Jan/2015 14:42:57,162- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/content-types.properties
14/Jan/2015 14:42:57,164- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/release
14/Jan/2015 14:42:57,167- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/
14/Jan/2015 14:42:57,167- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmiregistry
14/Jan/2015 14:42:57,169- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmid
14/Jan/2015 14:42:57,170- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/keytool
14/Jan/2015 14:42:57,171- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/java
14/Jan/2015 14:42:57,173- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/
14/Jan/2015 14:42:57,173- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/release
14/Jan/2015 14:42:57,178- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/
14/Jan/2015 14:42:57,178- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/classlist
14/Jan/2015 14:42:57,184- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/rt.jar
14/Jan/2015 14:42:57,328- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/tzdb.dat
14/Jan/2015 14:42:57,334- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/net.properties
14/Jan/2015 14:42:57,336- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/calendars.properties
14/Jan/2015 14:42:57,338- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:42:57,345- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/currency.data
14/Jan/2015 14:42:57,348- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jsse.jar
14/Jan/2015 14:42:57,356- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/meta-index
14/Jan/2015 14:42:57,359- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/content-types.properties
14/Jan/2015 14:42:57,360- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/
14/Jan/2015 14:42:57,361- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/US_export_policy.jar
14/Jan/2015 14:42:57,362- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/cacerts
14/Jan/2015 14:42:57,369- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.security
14/Jan/2015 14:42:57,374- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/local_policy.jar
14/Jan/2015 14:42:57,376- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.policy
14/Jan/2015 14:42:57,377- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/trusted.libraries
14/Jan/2015 14:42:57,378- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/blacklist
14/Jan/2015 14:42:57,380- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/
14/Jan/2015 14:42:57,381- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunpkcs11.jar
14/Jan/2015 14:42:57,388- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/meta-index
14/Jan/2015 14:42:57,389- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunec.jar
14/Jan/2015 14:42:57,452- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/localedata.jar
14/Jan/2015 14:42:57,480- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunjce_provider.jar
14/Jan/2015 14:42:57,488- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jce.jar
14/Jan/2015 14:42:57,493- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/resources.jar
14/Jan/2015 14:42:57,499- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/logging.properties
14/Jan/2015 14:42:57,501- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/
14/Jan/2015 14:42:57,502- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libverify.so
14/Jan/2015 14:42:57,505- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/
14/Jan/2015 14:42:57,506- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/libjli.so
14/Jan/2015 14:42:57,510- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libzip.so
14/Jan/2015 14:42:57,516- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/
14/Jan/2015 14:42:57,517- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjvm.so
14/Jan/2015 14:42:57,559- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjsig.so
14/Jan/2015 14:42:57,560- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:42:57,561- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnet.so
14/Jan/2015 14:42:57,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jvm.cfg
14/Jan/2015 14:42:57,569- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnio.so
14/Jan/2015 14:42:57,573- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libj2pkcs11.so
14/Jan/2015 14:42:57,576- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjava.so
14/Jan/2015 14:42:57,582- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/
14/Jan/2015 14:42:57,582- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjsig.so
14/Jan/2015 14:42:57,583- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/Xusage.txt
14/Jan/2015 14:42:57,584- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjvm.so
14/Jan/2015 14:42:57,696- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjsig.so
14/Jan/2015 14:42:57,697- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/
14/Jan/2015 14:42:57,698- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjsig.so
14/Jan/2015 14:42:57,699- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/Xusage.txt
14/Jan/2015 14:42:57,701- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjvm.so
14/Jan/2015 14:42:57,785- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libsunec.so
14/Jan/2015 14:42:57,791- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/
14/Jan/2015 14:42:57,792- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/keytool
14/Jan/2015 14:42:57,792- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/java
14/Jan/2015 14:42:57,794- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/
14/Jan/2015 14:42:57,847- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/
14/Jan/2015 14:42:57,847- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/
14/Jan/2015 14:42:57,848- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/
14/Jan/2015 14:42:57,848- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/
14/Jan/2015 14:42:57,848- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/jfxrt-controls.jar
14/Jan/2015 14:42:57,900- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/
14/Jan/2015 14:42:57,900- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/
14/Jan/2015 14:42:57,901- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.platform.properties
14/Jan/2015 14:42:57,904- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.properties
14/Jan/2015 14:42:57,908- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/
14/Jan/2015 14:42:57,909- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/liblens_porting.so
14/Jan/2015 14:42:57,914- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_iio.so
14/Jan/2015 14:42:57,922- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_sw.so
14/Jan/2015 14:42:57,926- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font_t2k.so
14/Jan/2015 14:42:57,953- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_eglfb.so
14/Jan/2015 14:42:57,974- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass.so
14/Jan/2015 14:42:57,987- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font.so
14/Jan/2015 14:42:57,993- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_es2_eglfb.so
14/Jan/2015 14:42:58,003- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_common.so
14/Jan/2015 14:42:58,011- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_dfb.so
14/Jan/2015 14:42:58,022- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/
14/Jan/2015 14:42:58,022- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/jfxrt-graphics.jar
14/Jan/2015 14:42:58,219- CreateJreController: Staring JRE Creation
14/Jan/2015 14:42:58,219- CreateJreController: Creator location: C:\Users\3539\wpilib\tools\.\ejdk1.8.0_06\lib\JREC reate.jar
14/Jan/2015 14:42:58,219- CreateJreController: Command: [java, -jar, C:\Users\3539\wpilib\tools\.\ejdk1.8.0_06\lib\JREC reate.jar, --dest, JRE, --profile, compact2, --vm, client, --keep-debug-info, --debug]
14/Jan/2015 14:42:59,085- CreateJreController: Successfully Created JRE!
14/Jan/2015 14:43:03,762- ConnectRoboRioController: Connecting to roborio-3539.local
14/Jan/2015 14:43:03,763- ConnectRoboRioController: Checking for mDNS connection to the roboRio
14/Jan/2015 14:43:07,078- ConnectRoboRioController: Found mDNS connection
14/Jan/2015 14:43:07,079- ConnectRoboRioController: Connected to the roboRio at roborio-3539.local
14/Jan/2015 14:43:07,119- DeployController: Starting zip
14/Jan/2015 14:43:07,127- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE, putting tar entry is JRE
14/Jan/2015 14:43:07,128- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\bin, putting tar entry is JRE/bin
14/Jan/2015 14:43:07,128- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\bin\java, putting tar entry is JRE/bin/java
14/Jan/2015 14:43:07,130- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\bin\keytool, putting tar entry is JRE/bin/keytool
14/Jan/2015 14:43:07,132- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\bin\rmid, putting tar entry is JRE/bin/rmid
14/Jan/2015 14:43:07,133- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\bin\rmiregistry, putting tar entry is JRE/bin/rmiregistry
14/Jan/2015 14:43:07,134- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\bom, putting tar entry is JRE/bom
14/Jan/2015 14:43:07,135- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib, putting tar entry is JRE/lib
14/Jan/2015 14:43:07,136- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm, putting tar entry is JRE/lib/arm
14/Jan/2015 14:43:07,137- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\client, putting tar entry is JRE/lib/arm/client
14/Jan/2015 14:43:07,137- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\client\li bjsig.so, putting tar entry is JRE/lib/arm/client/libjsig.so
14/Jan/2015 14:43:07,138- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\client\li bjvm.so, putting tar entry is JRE/lib/arm/client/libjvm.so
14/Jan/2015 14:43:07,589- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\client\Xu sage.txt, putting tar entry is JRE/lib/arm/client/Xusage.txt
14/Jan/2015 14:43:07,589- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\jli, putting tar entry is JRE/lib/arm/jli
14/Jan/2015 14:43:07,590- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\jli\libjl i.so, putting tar entry is JRE/lib/arm/jli/libjli.so
14/Jan/2015 14:43:07,600- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\jvm.cfg, putting tar entry is JRE/lib/arm/jvm.cfg
14/Jan/2015 14:43:07,601- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libdt_soc ket.so, putting tar entry is JRE/lib/arm/libdt_socket.so
14/Jan/2015 14:43:07,605- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libhprof. so, putting tar entry is JRE/lib/arm/libhprof.so
14/Jan/2015 14:43:07,618- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libjava.s o, putting tar entry is JRE/lib/arm/libjava.so
14/Jan/2015 14:43:07,634- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libjava_c rw_demo.so, putting tar entry is JRE/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:43:07,638- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libjdwp.s o, putting tar entry is JRE/lib/arm/libjdwp.so
14/Jan/2015 14:43:07,659- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libjsig.s o, putting tar entry is JRE/lib/arm/libjsig.so
14/Jan/2015 14:43:07,662- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libnet.so , putting tar entry is JRE/lib/arm/libnet.so
14/Jan/2015 14:43:07,671- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libnio.so , putting tar entry is JRE/lib/arm/libnio.so
14/Jan/2015 14:43:07,679- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libnpt.so , putting tar entry is JRE/lib/arm/libnpt.so
14/Jan/2015 14:43:07,682- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libverify .so, putting tar entry is JRE/lib/arm/libverify.so
14/Jan/2015 14:43:07,688- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\arm\libzip.so , putting tar entry is JRE/lib/arm/libzip.so
14/Jan/2015 14:43:07,699- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\calendars.pro perties, putting tar entry is JRE/lib/calendars.properties
14/Jan/2015 14:43:07,700- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\classlist, putting tar entry is JRE/lib/classlist
14/Jan/2015 14:43:07,709- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\content-types.properties, putting tar entry is JRE/lib/content-types.properties
14/Jan/2015 14:43:07,713- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\currency.data , putting tar entry is JRE/lib/currency.data
14/Jan/2015 14:43:07,715- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\ext, putting tar entry is JRE/lib/ext
14/Jan/2015 14:43:07,716- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\ext\meta-index, putting tar entry is JRE/lib/ext/meta-index
14/Jan/2015 14:43:07,717- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\ext\sunjce_pr ovider.jar, putting tar entry is JRE/lib/ext/sunjce_provider.jar
14/Jan/2015 14:43:07,739- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\hijrah-config-umalqura.properties, putting tar entry is JRE/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:43:07,747- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\jce.jar, putting tar entry is JRE/lib/jce.jar
14/Jan/2015 14:43:07,759- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\jsse.jar, putting tar entry is JRE/lib/jsse.jar
14/Jan/2015 14:43:07,788- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\jvm.hprof.txt , putting tar entry is JRE/lib/jvm.hprof.txt
14/Jan/2015 14:43:07,789- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\logging.prope rties, putting tar entry is JRE/lib/logging.properties
14/Jan/2015 14:43:07,790- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\meta-index, putting tar entry is JRE/lib/meta-index
14/Jan/2015 14:43:07,791- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\net.propertie s, putting tar entry is JRE/lib/net.properties
14/Jan/2015 14:43:07,792- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\resources.jar , putting tar entry is JRE/lib/resources.jar
14/Jan/2015 14:43:07,832- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\rt.jar, putting tar entry is JRE/lib/rt.jar
14/Jan/2015 14:43:08,886- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security, putting tar entry is JRE/lib/security
14/Jan/2015 14:43:08,886- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\blac klist, putting tar entry is JRE/lib/security/blacklist
14/Jan/2015 14:43:08,887- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\cace rts, putting tar entry is JRE/lib/security/cacerts
14/Jan/2015 14:43:08,897- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\java .policy, putting tar entry is JRE/lib/security/java.policy
14/Jan/2015 14:43:08,898- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\java .security, putting tar entry is JRE/lib/security/java.security
14/Jan/2015 14:43:08,903- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\loca l_policy.jar, putting tar entry is JRE/lib/security/local_policy.jar
14/Jan/2015 14:43:08,904- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\trus ted.libraries, putting tar entry is JRE/lib/security/trusted.libraries
14/Jan/2015 14:43:08,904- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\security\US_e xport_policy.jar, putting tar entry is JRE/lib/security/US_export_policy.jar
14/Jan/2015 14:43:08,905- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\lib\tzdb.dat, putting tar entry is JRE/lib/tzdb.dat
14/Jan/2015 14:43:08,919- DeployController: Processing file C:\Users\3539\wpilib\tools\.\JRE\release, putting tar entry is JRE/release
14/Jan/2015 14:43:09,941- DeployController: Failure to send JRE to the roboRio
com.jcraft.jsch.JSchException: java.net.ConnectException: Connection refused: connect
at com.jcraft.jsch.Util.createSocket(Util.java:349) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:215) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:183) ~[java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController.lambda$initialize$10(DeployControlle r.java:85) [java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController$$Lambda$237/997278.run(Unknown Source) [java-installer.jar:?]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_25]
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method) ~[?:1.8.0_25]
at java.net.DualStackPlainSocketImpl.socketConnect(Un known Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connectToAddress( Unknown Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.PlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.SocksSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.Socket.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.Socket.<init>(Unknown Source) ~[?:1.8.0_25]
at com.jcraft.jsch.Util.createSocket(Util.java:343) ~[java-installer.jar:?]
... 5 more
14/Jan/2015 14:45:35,983- MainApp: Exiting installer from popup
14/Jan/2015 14:45:50,337- MainApp: Found JRE, checking hash
14/Jan/2015 14:45:51,442- MainApp: Computed hash is 082F08397B0D3F63844AB472B5111C8C, official hash is 082F08397B0D3F63844AB472B5111C8C
14/Jan/2015 14:45:52,711- UntarController: Starting decompress of file C:\Users\3539\wpilib\tools\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\3539\wpilib\tools
14/Jan/2015 14:45:52,727- UntarController: Untarring ejdk1.8.0_06/bin/
14/Jan/2015 14:45:52,727- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.sh
14/Jan/2015 14:45:52,729- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.bat
14/Jan/2015 14:45:52,730- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.config.properties
14/Jan/2015 14:45:52,732- UntarController: Untarring ejdk1.8.0_06/doc/
14/Jan/2015 14:45:52,732- UntarController: Untarring ejdk1.8.0_06/lib/
14/Jan/2015 14:45:52,732- UntarController: Untarring ejdk1.8.0_06/lib/JRECreate.jar
14/Jan/2015 14:45:52,748- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/
14/Jan/2015 14:45:52,749- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/
14/Jan/2015 14:45:52,750- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/
14/Jan/2015 14:45:52,750- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/
14/Jan/2015 14:45:52,750- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklist
14/Jan/2015 14:45:52,752- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/US_export_policy.jar
14/Jan/2015 14:45:52,754- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.security
14/Jan/2015 14:45:52,760- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.policy
14/Jan/2015 14:45:52,762- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/local_policy.jar
14/Jan/2015 14:45:52,763- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklisted.certs
14/Jan/2015 14:45:52,764- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/trusted.libraries
14/Jan/2015 14:45:52,765- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/cacerts
14/Jan/2015 14:45:52,772- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.bfc
14/Jan/2015 14:45:52,773- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.bfc
14/Jan/2015 14:45:52,780- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/meta-index
14/Jan/2015 14:45:52,782- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.bfc
14/Jan/2015 14:45:52,785- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/resources.jar
14/Jan/2015 14:45:52,813- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.properties.src
14/Jan/2015 14:45:52,817- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/classlist
14/Jan/2015 14:45:52,822- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/net.properties
14/Jan/2015 14:45:52,824- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management-agent.jar
14/Jan/2015 14:45:52,825- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr.jar
14/Jan/2015 14:45:52,834- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jvm.hprof.txt
14/Jan/2015 14:45:52,835- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/calendars.properties
14/Jan/2015 14:45:52,837- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/
14/Jan/2015 14:45:52,837- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/
14/Jan/2015 14:45:52,838- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkNoDrop32x32.gif
14/Jan/2015 14:45:52,840- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/cursors.properties
14/Jan/2015 14:45:52,841- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkDrop32x32.gif
14/Jan/2015 14:45:52,842- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/invalid32x32.gif
14/Jan/2015 14:45:52,844- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveNoDrop32x32.gif
14/Jan/2015 14:45:52,847- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyNoDrop32x32.gif
14/Jan/2015 14:45:52,850- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveDrop32x32.gif
14/Jan/2015 14:45:52,851- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyDrop32x32.gif
14/Jan/2015 14:45:52,852- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/charsets.jar
14/Jan/2015 14:45:52,898- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/
14/Jan/2015 14:45:52,898- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.password.template
14/Jan/2015 14:45:52,910- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/snmp.acl.template
14/Jan/2015 14:45:52,913- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.access
14/Jan/2015 14:45:52,914- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/management.properties
14/Jan/2015 14:45:52,918- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/
14/Jan/2015 14:45:52,919- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiBold.ttf
14/Jan/2015 14:45:52,926- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightItalic.ttf
14/Jan/2015 14:45:52,933- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiItalic.ttf
14/Jan/2015 14:45:52,941- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterBold.ttf
14/Jan/2015 14:45:52,951- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansDemiBold.ttf
14/Jan/2015 14:45:52,964- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightRegular.ttf
14/Jan/2015 14:45:52,978- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansRegular.ttf
14/Jan/2015 14:45:53,004- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterRegular.ttf
14/Jan/2015 14:45:53,015- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/fonts.dir
14/Jan/2015 14:45:53,017- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/content-types.properties
14/Jan/2015 14:45:53,018- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/rt.jar
14/Jan/2015 14:45:53,669- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jexec
14/Jan/2015 14:45:53,670- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.properties.src
14/Jan/2015 14:45:53,676- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/applet/
14/Jan/2015 14:45:53,677- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/
14/Jan/2015 14:45:53,677- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunec.jar
14/Jan/2015 14:45:53,739- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/cldrdata.jar
14/Jan/2015 14:45:53,818- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/meta-index
14/Jan/2015 14:45:53,820- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunjce_provider.jar
14/Jan/2015 14:45:53,829- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/localedata.jar
14/Jan/2015 14:45:53,856- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/zipfs.jar
14/Jan/2015 14:45:53,861- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/dnsns.jar
14/Jan/2015 14:45:53,879- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/nashorn.jar
14/Jan/2015 14:45:53,917- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunpkcs11.jar
14/Jan/2015 14:45:53,927- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/
14/Jan/2015 14:45:53,927- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/profile.jfc
14/Jan/2015 14:45:53,930- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/default.jfc
14/Jan/2015 14:45:53,933- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/
14/Jan/2015 14:45:53,934- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/LINEAR_RGB.pf
14/Jan/2015 14:45:53,935- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/CIEXYZ.pf
14/Jan/2015 14:45:53,939- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/GRAY.pf
14/Jan/2015 14:45:53,940- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/sRGB.pf
14/Jan/2015 14:45:53,942- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/PYCC.pf
14/Jan/2015 14:45:53,951- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/logging.properties
14/Jan/2015 14:45:53,952- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/tzdb.dat
14/Jan/2015 14:45:53,959- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:45:53,967- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.bfc
14/Jan/2015 14:45:53,970- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/
14/Jan/2015 14:45:53,970- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterBoldOblique.ttf
14/Jan/2015 14:45:53,980- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterOblique.ttf
14/Jan/2015 14:45:53,986- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansOblique.ttf
14/Jan/2015 14:45:53,996- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansDemiOblique.ttf
14/Jan/2015 14:45:54,001- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/fonts.dir
14/Jan/2015 14:45:54,003- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfontj2d.properties
14/Jan/2015 14:45:54,010- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.properties.src
14/Jan/2015 14:45:54,014- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/sound.properties
14/Jan/2015 14:45:54,015- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.properties.src
14/Jan/2015 14:45:54,016- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.properties.src
14/Jan/2015 14:45:54,019- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.properties.src
14/Jan/2015 14:45:54,024- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/currency.data
14/Jan/2015 14:45:54,025- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jce.jar
14/Jan/2015 14:45:54,030- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jsse.jar
14/Jan/2015 14:45:54,039- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.bfc
14/Jan/2015 14:45:54,040- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/
14/Jan/2015 14:45:54,040- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdt_socket.so
14/Jan/2015 14:45:54,043- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2gss.so
14/Jan/2015 14:45:54,047- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libhprof.so
14/Jan/2015 14:45:54,057- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/
14/Jan/2015 14:45:54,057- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/Xusage.txt
14/Jan/2015 14:45:54,059- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjvm.so
14/Jan/2015 14:45:54,170- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjsig.so
14/Jan/2015 14:45:54,170- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pcsc.so
14/Jan/2015 14:45:54,173- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/
14/Jan/2015 14:45:54,173- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjsig.so
14/Jan/2015 14:45:54,174- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjvm.so
14/Jan/2015 14:45:54,261- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/Xusage.txt
14/Jan/2015 14:45:54,262- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libinstrument.so
14/Jan/2015 14:45:54,266- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnpt.so
14/Jan/2015 14:45:54,267- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdcpr.so
14/Jan/2015 14:45:54,274- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/
14/Jan/2015 14:45:54,274- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:45:54,275- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjvm.so
14/Jan/2015 14:45:54,324- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjsig.so
14/Jan/2015 14:45:54,324- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsplashscreen.so
14/Jan/2015 14:45:54,331- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnet.so
14/Jan/2015 14:45:54,335- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsdt.so
14/Jan/2015 14:45:54,336- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsound.so
14/Jan/2015 14:45:54,338- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnio.so
14/Jan/2015 14:45:54,343- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:45:54,347- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsoundalsa.so
14/Jan/2015 14:45:54,350- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjaas_unix.so
14/Jan/2015 14:45:54,351- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libkcms.so
14/Jan/2015 14:45:54,360- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/
14/Jan/2015 14:45:54,361- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/libjli.so
14/Jan/2015 14:45:54,364- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmanagement.so
14/Jan/2015 14:45:54,368- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libt2k.so
14/Jan/2015 14:45:54,378- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjawt.so
14/Jan/2015 14:45:54,379- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsunec.so
14/Jan/2015 14:45:54,390- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jvm.cfg
14/Jan/2015 14:45:54,392- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjdwp.so
14/Jan/2015 14:45:54,399- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libunpack.so
14/Jan/2015 14:45:54,404- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/liblcms.so
14/Jan/2015 14:45:54,414- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt_headless.so
14/Jan/2015 14:45:54,417- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libfontmanager.so
14/Jan/2015 14:45:54,427- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjpeg.so
14/Jan/2015 14:45:54,434- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libzip.so
14/Jan/2015 14:45:54,440- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt.so
14/Jan/2015 14:45:54,452- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsig.so
14/Jan/2015 14:45:54,454- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmlib_image.so
14/Jan/2015 14:45:54,470- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libverify.so
14/Jan/2015 14:45:54,476- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjfr.so
14/Jan/2015 14:45:54,480- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsctp.so
14/Jan/2015 14:45:54,483- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pkcs11.so
14/Jan/2015 14:45:54,487- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava.so
14/Jan/2015 14:45:54,494- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfont.properties.ja
14/Jan/2015 14:45:54,496- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.bfc
14/Jan/2015 14:45:54,497- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/flavormap.properties
14/Jan/2015 14:45:54,498- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME.txt
14/Jan/2015 14:45:54,506- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/
14/Jan/2015 14:45:54,506- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/orbd
14/Jan/2015 14:45:54,509- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/keytool
14/Jan/2015 14:45:54,511- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmid
14/Jan/2015 14:45:54,512- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmiregistry
14/Jan/2015 14:45:54,514- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/pack200
14/Jan/2015 14:45:54,515- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/policytool
14/Jan/2015 14:45:54,518- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/servertool
14/Jan/2015 14:45:54,520- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/jjs
14/Jan/2015 14:45:54,523- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/tnameserv
14/Jan/2015 14:45:54,525- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/java
14/Jan/2015 14:45:54,526- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/unpack200
14/Jan/2015 14:45:54,532- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/COPYRIGHT
14/Jan/2015 14:45:54,534- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/release
14/Jan/2015 14:45:54,535- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME-JAVAFX.txt
14/Jan/2015 14:45:54,545- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/README
14/Jan/2015 14:45:54,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/
14/Jan/2015 14:45:54,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/
14/Jan/2015 14:45:54,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jsse.jar
14/Jan/2015 14:45:54,557- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/
14/Jan/2015 14:45:54,558- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.access
14/Jan/2015 14:45:54,559- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/management.properties
14/Jan/2015 14:45:54,564- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/snmp.acl.template
14/Jan/2015 14:45:54,565- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.password.template
14/Jan/2015 14:45:54,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/classlist
14/Jan/2015 14:45:54,574- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/
14/Jan/2015 14:45:54,575- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/localedata.jar
14/Jan/2015 14:45:54,600- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunjce_provider.jar
14/Jan/2015 14:45:54,609- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/meta-index
14/Jan/2015 14:45:54,611- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunpkcs11.jar
14/Jan/2015 14:45:54,620- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunec.jar
14/Jan/2015 14:45:54,691- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/currency.data
14/Jan/2015 14:45:54,692- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/meta-index
14/Jan/2015 14:45:54,693- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:45:54,700- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jce.jar
14/Jan/2015 14:45:54,706- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/
14/Jan/2015 14:45:54,706- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsctp.so
14/Jan/2015 14:45:54,709- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pcsc.so
14/Jan/2015 14:45:54,710- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava.so
14/Jan/2015 14:45:54,717- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsig.so
14/Jan/2015 14:45:54,719- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/
14/Jan/2015 14:45:54,720- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjsig.so
14/Jan/2015 14:45:54,721- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjvm.so
14/Jan/2015 14:45:54,805- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/Xusage.txt
14/Jan/2015 14:45:54,806- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libhprof.so
14/Jan/2015 14:45:54,810- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jvm.cfg
14/Jan/2015 14:45:54,811- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2gss.so
14/Jan/2015 14:45:54,816- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/
14/Jan/2015 14:45:54,817- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/Xusage.txt
14/Jan/2015 14:45:54,818- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjvm.so
14/Jan/2015 14:45:54,933- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjsig.so
14/Jan/2015 14:45:54,934- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libzip.so
14/Jan/2015 14:45:54,939- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pkcs11.so
14/Jan/2015 14:45:54,942- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/
14/Jan/2015 14:45:54,943- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/libjli.so
14/Jan/2015 14:45:54,947- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/
14/Jan/2015 14:45:54,948- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:45:54,950- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjvm.so
14/Jan/2015 14:45:54,998- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjsig.so
14/Jan/2015 14:45:54,999- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:45:55,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsdt.so
14/Jan/2015 14:45:55,003- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libmanagement.so
14/Jan/2015 14:45:55,008- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnio.so
14/Jan/2015 14:45:55,012- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjaas_unix.so
14/Jan/2015 14:45:55,013- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnpt.so
14/Jan/2015 14:45:55,014- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsunec.so
14/Jan/2015 14:45:55,021- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libinstrument.so
14/Jan/2015 14:45:55,026- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libverify.so
14/Jan/2015 14:45:55,029- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnet.so
14/Jan/2015 14:45:55,033- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/tzdb.dat
14/Jan/2015 14:45:55,039- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/content-types.properties
14/Jan/2015 14:45:55,041- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/rt.jar
14/Jan/2015 14:45:55,361- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management-agent.jar
14/Jan/2015 14:45:55,362- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/net.properties
14/Jan/2015 14:45:55,363- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/logging.properties
14/Jan/2015 14:45:55,364- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jvm.hprof.txt
14/Jan/2015 14:45:55,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/
14/Jan/2015 14:45:55,366- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/US_export_policy.jar
14/Jan/2015 14:45:55,367- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.policy
14/Jan/2015 14:45:55,368- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/trusted.libraries
14/Jan/2015 14:45:55,368- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/cacerts
14/Jan/2015 14:45:55,374- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/blacklist
14/Jan/2015 14:45:55,375- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.security
14/Jan/2015 14:45:55,379- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/local_policy.jar
14/Jan/2015 14:45:55,380- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/calendars.properties
14/Jan/2015 14:45:55,382- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/resources.jar
14/Jan/2015 14:45:55,397- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/
14/Jan/2015 14:45:55,398- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/java
14/Jan/2015 14:45:55,399- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/keytool
14/Jan/2015 14:45:55,400- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmiregistry
14/Jan/2015 14:45:55,401- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmid
14/Jan/2015 14:45:55,403- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/release
14/Jan/2015 14:45:55,405- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/
14/Jan/2015 14:45:55,405- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/
14/Jan/2015 14:45:55,405- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/
14/Jan/2015 14:45:55,406- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/
14/Jan/2015 14:45:55,406- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/libj2pkcs11.so
14/Jan/2015 14:45:55,411- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/
14/Jan/2015 14:45:55,411- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/sunpkcs11.jar
14/Jan/2015 14:45:55,419- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/
14/Jan/2015 14:45:55,419- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/
14/Jan/2015 14:45:55,420- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/
14/Jan/2015 14:45:55,420- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/nashorn.jar
14/Jan/2015 14:45:55,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/
14/Jan/2015 14:45:55,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/
14/Jan/2015 14:45:55,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/
14/Jan/2015 14:45:55,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/localedata.jar
14/Jan/2015 14:45:55,486- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/
14/Jan/2015 14:45:55,486- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/
14/Jan/2015 14:45:55,487- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/
14/Jan/2015 14:45:55,487- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/libsunec.so
14/Jan/2015 14:45:55,495- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/
14/Jan/2015 14:45:55,495- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/sunec.jar
14/Jan/2015 14:45:55,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/
14/Jan/2015 14:45:55,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/
14/Jan/2015 14:45:55,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/
14/Jan/2015 14:45:55,567- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libdt_socket.so
14/Jan/2015 14:45:55,570- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjdwp.so
14/Jan/2015 14:45:55,577- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:45:55,580- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libnpt.so
14/Jan/2015 14:45:55,582- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libhprof.so
14/Jan/2015 14:45:55,589- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/jvm.hprof.txt
14/Jan/2015 14:45:55,590- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/
14/Jan/2015 14:45:55,591- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/
14/Jan/2015 14:45:55,591- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/gcf.jar
14/Jan/2015 14:45:55,668- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/
14/Jan/2015 14:45:55,668- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/
14/Jan/2015 14:45:55,668- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/charsets.jar
14/Jan/2015 14:45:55,708- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/
14/Jan/2015 14:45:55,709- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/
14/Jan/2015 14:45:55,709- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/
14/Jan/2015 14:45:55,709- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjsig.so
14/Jan/2015 14:45:55,710- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjava.so
14/Jan/2015 14:45:55,718- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/
14/Jan/2015 14:45:55,719- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/libjli.so
14/Jan/2015 14:45:55,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libzip.so
14/Jan/2015 14:45:55,728- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jvm.cfg
14/Jan/2015 14:45:55,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libsunec.so
14/Jan/2015 14:45:55,735- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/
14/Jan/2015 14:45:55,736- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:45:55,737- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjvm.so
14/Jan/2015 14:45:55,783- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjsig.so
14/Jan/2015 14:45:55,783- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libverify.so
14/Jan/2015 14:45:55,791- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/
14/Jan/2015 14:45:55,791- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjvm.so
14/Jan/2015 14:45:55,899- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjsig.so
14/Jan/2015 14:45:55,900- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/Xusage.txt
14/Jan/2015 14:45:55,901- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libj2pkcs11.so
14/Jan/2015 14:45:55,906- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnio.so
14/Jan/2015 14:45:55,915- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnet.so
14/Jan/2015 14:45:55,920- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/
14/Jan/2015 14:45:55,921- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjvm.so
14/Jan/2015 14:45:56,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjsig.so
14/Jan/2015 14:45:56,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/Xusage.txt
14/Jan/2015 14:45:56,003- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/rt.jar
14/Jan/2015 14:45:56,241- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/meta-index
14/Jan/2015 14:45:56,242- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/
14/Jan/2015 14:45:56,242- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/cacerts
14/Jan/2015 14:45:56,247- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/US_export_policy.jar
14/Jan/2015 14:45:56,249- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.security
14/Jan/2015 14:45:56,254- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/blacklist
14/Jan/2015 14:45:56,255- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/local_policy.jar
14/Jan/2015 14:45:56,257- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/trusted.libraries
14/Jan/2015 14:45:56,257- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.policy
14/Jan/2015 14:45:56,258- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jce.jar
14/Jan/2015 14:45:56,263- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/logging.properties
14/Jan/2015 14:45:56,264- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/resources.jar
14/Jan/2015 14:45:56,275- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:45:56,283- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/
14/Jan/2015 14:45:56,283- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/localedata.jar
14/Jan/2015 14:45:56,307- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/meta-index
14/Jan/2015 14:45:56,307- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunpkcs11.jar
14/Jan/2015 14:45:56,317- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunec.jar
14/Jan/2015 14:45:56,372- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunjce_provider.jar
14/Jan/2015 14:45:56,380- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/currency.data
14/Jan/2015 14:45:56,382- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/calendars.properties
14/Jan/2015 14:45:56,386- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/classlist
14/Jan/2015 14:45:56,393- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/tzdb.dat
14/Jan/2015 14:45:56,399- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/net.properties
14/Jan/2015 14:45:56,401- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jsse.jar
14/Jan/2015 14:45:56,410- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/content-types.properties
14/Jan/2015 14:45:56,411- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/release
14/Jan/2015 14:45:56,412- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/
14/Jan/2015 14:45:56,413- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmiregistry
14/Jan/2015 14:45:56,414- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmid
14/Jan/2015 14:45:56,416- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/keytool
14/Jan/2015 14:45:56,418- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/java
14/Jan/2015 14:45:56,419- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/
14/Jan/2015 14:45:56,419- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/release
14/Jan/2015 14:45:56,420- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/
14/Jan/2015 14:45:56,420- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/classlist
14/Jan/2015 14:45:56,427- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/rt.jar
14/Jan/2015 14:45:56,597- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/tzdb.dat
14/Jan/2015 14:45:56,606- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/net.properties
14/Jan/2015 14:45:56,608- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/calendars.properties
14/Jan/2015 14:45:56,609- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:45:56,617- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/currency.data
14/Jan/2015 14:45:56,619- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jsse.jar
14/Jan/2015 14:45:56,629- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/meta-index
14/Jan/2015 14:45:56,630- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/content-types.properties
14/Jan/2015 14:45:56,632- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/
14/Jan/2015 14:45:56,632- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/US_export_policy.jar
14/Jan/2015 14:45:56,633- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/cacerts
14/Jan/2015 14:45:56,640- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.security
14/Jan/2015 14:45:56,645- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/local_policy.jar
14/Jan/2015 14:45:56,648- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.policy
14/Jan/2015 14:45:56,650- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/trusted.libraries
14/Jan/2015 14:45:56,651- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/blacklist
14/Jan/2015 14:45:56,652- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/
14/Jan/2015 14:45:56,653- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunpkcs11.jar
14/Jan/2015 14:45:56,662- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/meta-index
14/Jan/2015 14:45:56,664- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunec.jar
14/Jan/2015 14:45:56,733- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/localedata.jar
14/Jan/2015 14:45:56,758- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunjce_provider.jar
14/Jan/2015 14:45:56,766- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jce.jar
14/Jan/2015 14:45:56,772- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/resources.jar
14/Jan/2015 14:45:56,781- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/logging.properties
14/Jan/2015 14:45:56,782- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/
14/Jan/2015 14:45:56,782- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libverify.so
14/Jan/2015 14:45:56,785- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/
14/Jan/2015 14:45:56,785- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/libjli.so
14/Jan/2015 14:45:56,791- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libzip.so
14/Jan/2015 14:45:56,795- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/
14/Jan/2015 14:45:56,796- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjvm.so
14/Jan/2015 14:45:56,840- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjsig.so
14/Jan/2015 14:45:56,841- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/Xusage.txt
14/Jan/2015 14:45:56,842- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnet.so
14/Jan/2015 14:45:56,848- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jvm.cfg
14/Jan/2015 14:45:56,850- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnio.so
14/Jan/2015 14:45:56,855- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libj2pkcs11.so
14/Jan/2015 14:45:56,859- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjava.so
14/Jan/2015 14:45:56,864- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/
14/Jan/2015 14:45:56,864- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjsig.so
14/Jan/2015 14:45:56,865- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/Xusage.txt
14/Jan/2015 14:45:56,866- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjvm.so
14/Jan/2015 14:45:56,983- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjsig.so
14/Jan/2015 14:45:56,985- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/
14/Jan/2015 14:45:56,985- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjsig.so
14/Jan/2015 14:45:56,985- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/Xusage.txt
14/Jan/2015 14:45:56,987- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjvm.so
14/Jan/2015 14:45:57,073- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libsunec.so
14/Jan/2015 14:45:57,080- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/
14/Jan/2015 14:45:57,081- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/keytool
14/Jan/2015 14:45:57,082- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/java
14/Jan/2015 14:45:57,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/
14/Jan/2015 14:45:57,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/
14/Jan/2015 14:45:57,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/
14/Jan/2015 14:45:57,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/
14/Jan/2015 14:45:57,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/
14/Jan/2015 14:45:57,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/jfxrt-controls.jar
14/Jan/2015 14:45:57,138- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/
14/Jan/2015 14:45:57,139- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/
14/Jan/2015 14:45:57,139- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.platform.properties
14/Jan/2015 14:45:57,140- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.properties
14/Jan/2015 14:45:57,141- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/
14/Jan/2015 14:45:57,142- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/liblens_porting.so
14/Jan/2015 14:45:57,145- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_iio.so
14/Jan/2015 14:45:57,153- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_sw.so
14/Jan/2015 14:45:57,159- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font_t2k.so
14/Jan/2015 14:45:57,179- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_eglfb.so
14/Jan/2015 14:45:57,186- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass.so
14/Jan/2015 14:45:57,195- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font.so
14/Jan/2015 14:45:57,198- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_es2_eglfb.so
14/Jan/2015 14:45:57,202- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_common.so
14/Jan/2015 14:45:57,207- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_dfb.so
14/Jan/2015 14:45:57,214- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/
14/Jan/2015 14:45:57,214- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/jfxrt-graphics.jar
14/Jan/2015 14:45:57,329- CreateJreController: Staring JRE Creation
14/Jan/2015 14:45:57,329- CreateJreController: Creator location: C:\Users\3539\wpilib\tools\ejdk1.8.0_06\lib\JRECre ate.jar
14/Jan/2015 14:45:57,329- CreateJreController: Command: [java, -jar, C:\Users\3539\wpilib\tools\ejdk1.8.0_06\lib\JRECre ate.jar, --dest, JRE, --profile, compact2, --vm, client, --keep-debug-info, --debug]
14/Jan/2015 14:45:57,745- CreateJreController: Successfully Created JRE!
14/Jan/2015 14:46:07,909- ConnectRoboRioController: Connecting to roborio-3539.local
14/Jan/2015 14:46:07,910- ConnectRoboRioController: Checking for mDNS connection to the roboRio
14/Jan/2015 14:46:11,227- ConnectRoboRioController: Found mDNS connection
14/Jan/2015 14:46:11,227- ConnectRoboRioController: Connected to the roboRio at roborio-3539.local
14/Jan/2015 14:46:11,270- DeployController: Removed the old tgz file
14/Jan/2015 14:46:11,270- DeployController: Starting zip
14/Jan/2015 14:46:11,276- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE, putting tar entry is JRE
14/Jan/2015 14:46:11,277- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin, putting tar entry is JRE/bin
14/Jan/2015 14:46:11,278- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\java, putting tar entry is JRE/bin/java
14/Jan/2015 14:46:11,279- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\keytool, putting tar entry is JRE/bin/keytool
14/Jan/2015 14:46:11,280- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\rmid, putting tar entry is JRE/bin/rmid
14/Jan/2015 14:46:11,281- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\rmiregistry, putting tar entry is JRE/bin/rmiregistry
14/Jan/2015 14:46:11,283- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bom, putting tar entry is JRE/bom
14/Jan/2015 14:46:11,284- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib, putting tar entry is JRE/lib
14/Jan/2015 14:46:11,284- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm, putting tar entry is JRE/lib/arm
14/Jan/2015 14:46:11,285- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client, putting tar entry is JRE/lib/arm/client
14/Jan/2015 14:46:11,286- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\libj sig.so, putting tar entry is JRE/lib/arm/client/libjsig.so
14/Jan/2015 14:46:11,286- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\libj vm.so, putting tar entry is JRE/lib/arm/client/libjvm.so
14/Jan/2015 14:46:11,723- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\Xusa ge.txt, putting tar entry is JRE/lib/arm/client/Xusage.txt
14/Jan/2015 14:46:11,724- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jli, putting tar entry is JRE/lib/arm/jli
14/Jan/2015 14:46:11,724- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jli\libjli. so, putting tar entry is JRE/lib/arm/jli/libjli.so
14/Jan/2015 14:46:11,736- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jvm.cfg, putting tar entry is JRE/lib/arm/jvm.cfg
14/Jan/2015 14:46:11,737- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libdt_socke t.so, putting tar entry is JRE/lib/arm/libdt_socket.so
14/Jan/2015 14:46:11,741- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libhprof.so , putting tar entry is JRE/lib/arm/libhprof.so
14/Jan/2015 14:46:11,755- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjava.so, putting tar entry is JRE/lib/arm/libjava.so
14/Jan/2015 14:46:11,774- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjava_crw _demo.so, putting tar entry is JRE/lib/arm/libjava_crw_demo.so
14/Jan/2015 14:46:11,778- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjdwp.so, putting tar entry is JRE/lib/arm/libjdwp.so
14/Jan/2015 14:46:11,798- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjsig.so, putting tar entry is JRE/lib/arm/libjsig.so
14/Jan/2015 14:46:11,801- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnet.so, putting tar entry is JRE/lib/arm/libnet.so
14/Jan/2015 14:46:11,813- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnio.so, putting tar entry is JRE/lib/arm/libnio.so
14/Jan/2015 14:46:11,821- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnpt.so, putting tar entry is JRE/lib/arm/libnpt.so
14/Jan/2015 14:46:11,824- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libverify.s o, putting tar entry is JRE/lib/arm/libverify.so
14/Jan/2015 14:46:11,829- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libzip.so, putting tar entry is JRE/lib/arm/libzip.so
14/Jan/2015 14:46:11,845- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\calendars.prope rties, putting tar entry is JRE/lib/calendars.properties
14/Jan/2015 14:46:11,846- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\classlist, putting tar entry is JRE/lib/classlist
14/Jan/2015 14:46:11,856- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\content-types.properties, putting tar entry is JRE/lib/content-types.properties
14/Jan/2015 14:46:11,857- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\currency.data, putting tar entry is JRE/lib/currency.data
14/Jan/2015 14:46:11,858- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext, putting tar entry is JRE/lib/ext
14/Jan/2015 14:46:11,858- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext\meta-index, putting tar entry is JRE/lib/ext/meta-index
14/Jan/2015 14:46:11,859- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext\sunjce_prov ider.jar, putting tar entry is JRE/lib/ext/sunjce_provider.jar
14/Jan/2015 14:46:11,882- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\hijrah-config-umalqura.properties, putting tar entry is JRE/lib/hijrah-config-umalqura.properties
14/Jan/2015 14:46:11,891- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jce.jar, putting tar entry is JRE/lib/jce.jar
14/Jan/2015 14:46:11,903- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jsse.jar, putting tar entry is JRE/lib/jsse.jar
14/Jan/2015 14:46:11,930- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jvm.hprof.txt, putting tar entry is JRE/lib/jvm.hprof.txt
14/Jan/2015 14:46:11,931- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\logging.propert ies, putting tar entry is JRE/lib/logging.properties
14/Jan/2015 14:46:11,932- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\meta-index, putting tar entry is JRE/lib/meta-index
14/Jan/2015 14:46:11,934- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\net.properties, putting tar entry is JRE/lib/net.properties
14/Jan/2015 14:46:11,936- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\resources.jar, putting tar entry is JRE/lib/resources.jar
14/Jan/2015 14:46:11,978- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\rt.jar, putting tar entry is JRE/lib/rt.jar
14/Jan/2015 14:46:12,971- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security, putting tar entry is JRE/lib/security
14/Jan/2015 14:46:12,971- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\blackl ist, putting tar entry is JRE/lib/security/blacklist
14/Jan/2015 14:46:12,973- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\cacert s, putting tar entry is JRE/lib/security/cacerts
14/Jan/2015 14:46:12,981- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\java.p olicy, putting tar entry is JRE/lib/security/java.policy
14/Jan/2015 14:46:12,982- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\java.s ecurity, putting tar entry is JRE/lib/security/java.security
14/Jan/2015 14:46:12,989- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\local_ policy.jar, putting tar entry is JRE/lib/security/local_policy.jar
14/Jan/2015 14:46:12,991- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\truste d.libraries, putting tar entry is JRE/lib/security/trusted.libraries
14/Jan/2015 14:46:12,991- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\US_exp ort_policy.jar, putting tar entry is JRE/lib/security/US_export_policy.jar
14/Jan/2015 14:46:12,993- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\tzdb.dat, putting tar entry is JRE/lib/tzdb.dat
14/Jan/2015 14:46:13,005- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\release, putting tar entry is JRE/release
14/Jan/2015 14:46:14,047- DeployController: Failure to send JRE to the roboRio
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController$$Lambda$160/14508651.run(Unknown Source) [java-installer.jar:?]
... 5 more
14/Jan/2015 15:24:39,400- MainApp: Exiting installer from popup
14/Jan/2015 15:24:45,389- MainApp: Found JRE, checking hash
14/Jan/2015 15:24:46,537- MainApp: Computed hash is 082F08397B0D3F63844AB472B5111C8C, official hash is 082F08397B0D3F63844AB472B5111C8C
14/Jan/2015 15:24:48,672- UntarController: Starting decompress of file C:\Users\3539\wpilib\tools\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\3539\wpilib\tools
14/Jan/2015 15:24:48,687- UntarController: Untarring ejdk1.8.0_06/bin/
14/Jan/2015 15:24:48,688- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.sh
14/Jan/2015 15:24:48,695- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.bat
14/Jan/2015 15:24:48,697- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.config.properties
14/Jan/2015 15:24:48,708- UntarController: Untarring ejdk1.8.0_06/doc/
14/Jan/2015 15:24:48,708- UntarController: Untarring ejdk1.8.0_06/lib/
14/Jan/2015 15:24:48,709- UntarController: Untarring ejdk1.8.0_06/lib/JRECreate.jar
14/Jan/2015 15:24:48,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/
14/Jan/2015 15:24:48,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/
14/Jan/2015 15:24:48,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/
14/Jan/2015 15:24:48,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/
14/Jan/2015 15:24:48,726- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklist
14/Jan/2015 15:24:48,727- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/US_export_policy.jar
14/Jan/2015 15:24:48,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.security
14/Jan/2015 15:24:48,733- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.policy
14/Jan/2015 15:24:48,735- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/local_policy.jar
14/Jan/2015 15:24:48,736- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklisted.certs
14/Jan/2015 15:24:48,737- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/trusted.libraries
14/Jan/2015 15:24:48,738- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/cacerts
14/Jan/2015 15:24:48,756- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.bfc
14/Jan/2015 15:24:48,758- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.bfc
14/Jan/2015 15:24:48,759- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/meta-index
14/Jan/2015 15:24:48,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.bfc
14/Jan/2015 15:24:48,762- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/resources.jar
14/Jan/2015 15:24:48,787- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.properties.src
14/Jan/2015 15:24:48,791- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/classlist
14/Jan/2015 15:24:48,813- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/net.properties
14/Jan/2015 15:24:48,814- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management-agent.jar
14/Jan/2015 15:24:48,815- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr.jar
14/Jan/2015 15:24:48,825- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jvm.hprof.txt
14/Jan/2015 15:24:48,827- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/calendars.properties
14/Jan/2015 15:24:48,837- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/
14/Jan/2015 15:24:48,837- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/
14/Jan/2015 15:24:48,838- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkNoDrop32x32.gif
14/Jan/2015 15:24:48,847- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/cursors.properties
14/Jan/2015 15:24:48,848- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkDrop32x32.gif
14/Jan/2015 15:24:48,850- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/invalid32x32.gif
14/Jan/2015 15:24:48,852- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveNoDrop32x32.gif
14/Jan/2015 15:24:48,853- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyNoDrop32x32.gif
14/Jan/2015 15:24:48,854- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveDrop32x32.gif
14/Jan/2015 15:24:48,855- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyDrop32x32.gif
14/Jan/2015 15:24:48,861- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/charsets.jar
14/Jan/2015 15:24:48,904- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/
14/Jan/2015 15:24:48,905- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.password.template
14/Jan/2015 15:24:48,906- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/snmp.acl.template
14/Jan/2015 15:24:48,909- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.access
14/Jan/2015 15:24:48,910- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/management.properties
14/Jan/2015 15:24:48,914- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/
14/Jan/2015 15:24:48,914- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiBold.ttf
14/Jan/2015 15:24:48,948- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightItalic.ttf
14/Jan/2015 15:24:48,957- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiItalic.ttf
14/Jan/2015 15:24:48,963- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterBold.ttf
14/Jan/2015 15:24:48,972- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansDemiBold.ttf
14/Jan/2015 15:24:48,985- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightRegular.ttf
14/Jan/2015 15:24:49,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansRegular.ttf
14/Jan/2015 15:24:49,021- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterRegular.ttf
14/Jan/2015 15:24:49,035- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/fonts.dir
14/Jan/2015 15:24:49,036- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/content-types.properties
14/Jan/2015 15:24:49,038- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/rt.jar
14/Jan/2015 15:24:49,723- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jexec
14/Jan/2015 15:24:49,726- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.properties.src
14/Jan/2015 15:24:49,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/applet/
14/Jan/2015 15:24:49,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/
14/Jan/2015 15:24:49,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunec.jar
14/Jan/2015 15:24:49,911- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/cldrdata.jar
14/Jan/2015 15:24:49,992- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/meta-index
14/Jan/2015 15:24:49,996- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunjce_provider.jar
14/Jan/2015 15:24:50,003- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/localedata.jar
14/Jan/2015 15:24:50,030- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/zipfs.jar
14/Jan/2015 15:24:50,034- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/dnsns.jar
14/Jan/2015 15:24:50,071- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/nashorn.jar
14/Jan/2015 15:24:50,107- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunpkcs11.jar
14/Jan/2015 15:24:50,115- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/
14/Jan/2015 15:24:50,115- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/profile.jfc
14/Jan/2015 15:24:50,118- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/default.jfc
14/Jan/2015 15:24:50,124- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/
14/Jan/2015 15:24:50,124- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/LINEAR_RGB.pf
14/Jan/2015 15:24:50,126- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/CIEXYZ.pf
14/Jan/2015 15:24:50,130- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/GRAY.pf
14/Jan/2015 15:24:50,131- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/sRGB.pf
14/Jan/2015 15:24:50,133- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/PYCC.pf
14/Jan/2015 15:24:50,143- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/logging.properties
14/Jan/2015 15:24:50,144- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/tzdb.dat
14/Jan/2015 15:24:50,153- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:24:50,162- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.bfc
14/Jan/2015 15:24:50,166- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/
14/Jan/2015 15:24:50,166- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterBoldOblique.ttf
14/Jan/2015 15:24:50,170- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterOblique.ttf
14/Jan/2015 15:24:50,178- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansOblique.ttf
14/Jan/2015 15:24:50,186- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansDemiOblique.ttf
14/Jan/2015 15:24:50,193- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/fonts.dir
14/Jan/2015 15:24:50,196- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfontj2d.properties
14/Jan/2015 15:24:50,199- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.properties.src
14/Jan/2015 15:24:50,203- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/sound.properties
14/Jan/2015 15:24:50,204- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.properties.src
14/Jan/2015 15:24:50,206- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.properties.src
14/Jan/2015 15:24:50,210- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.properties.src
14/Jan/2015 15:24:50,213- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/currency.data
14/Jan/2015 15:24:50,219- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jce.jar
14/Jan/2015 15:24:50,227- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jsse.jar
14/Jan/2015 15:24:50,236- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.bfc
14/Jan/2015 15:24:50,238- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/
14/Jan/2015 15:24:50,238- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdt_socket.so
14/Jan/2015 15:24:50,258- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2gss.so
14/Jan/2015 15:24:50,261- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libhprof.so
14/Jan/2015 15:24:50,266- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/
14/Jan/2015 15:24:50,266- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/Xusage.txt
14/Jan/2015 15:24:50,267- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjvm.so
14/Jan/2015 15:24:50,379- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjsig.so
14/Jan/2015 15:24:50,380- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pcsc.so
14/Jan/2015 15:24:50,382- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/
14/Jan/2015 15:24:50,382- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjsig.so
14/Jan/2015 15:24:50,383- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjvm.so
14/Jan/2015 15:24:50,471- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/Xusage.txt
14/Jan/2015 15:24:50,472- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libinstrument.so
14/Jan/2015 15:24:50,478- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnpt.so
14/Jan/2015 15:24:50,480- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdcpr.so
14/Jan/2015 15:24:50,488- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/
14/Jan/2015 15:24:50,488- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:24:50,490- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjvm.so
14/Jan/2015 15:24:50,607- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjsig.so
14/Jan/2015 15:24:50,608- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsplashscreen.so
14/Jan/2015 15:24:50,618- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnet.so
14/Jan/2015 15:24:50,993- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsdt.so
14/Jan/2015 15:24:50,995- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsound.so
14/Jan/2015 15:24:50,997- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnio.so
14/Jan/2015 15:24:51,001- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:24:51,004- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsoundalsa.so
14/Jan/2015 15:24:51,010- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjaas_unix.so
14/Jan/2015 15:24:51,012- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libkcms.so
14/Jan/2015 15:24:51,026- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/
14/Jan/2015 15:24:51,026- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/libjli.so
14/Jan/2015 15:24:51,032- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmanagement.so
14/Jan/2015 15:24:51,193- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libt2k.so
14/Jan/2015 15:24:51,202- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjawt.so
14/Jan/2015 15:24:51,203- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsunec.so
14/Jan/2015 15:24:51,211- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jvm.cfg
14/Jan/2015 15:24:51,212- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjdwp.so
14/Jan/2015 15:24:51,220- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libunpack.so
14/Jan/2015 15:24:51,226- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/liblcms.so
14/Jan/2015 15:24:51,234- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt_headless.so
14/Jan/2015 15:24:51,237- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libfontmanager.so
14/Jan/2015 15:24:51,246- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjpeg.so
14/Jan/2015 15:24:51,252- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libzip.so
14/Jan/2015 15:24:51,256- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt.so
14/Jan/2015 15:24:51,268- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsig.so
14/Jan/2015 15:24:51,270- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmlib_image.so
14/Jan/2015 15:24:51,286- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libverify.so
14/Jan/2015 15:24:51,292- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjfr.so
14/Jan/2015 15:24:51,296- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsctp.so
14/Jan/2015 15:24:51,300- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pkcs11.so
14/Jan/2015 15:24:51,305- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava.so
14/Jan/2015 15:24:51,312- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfont.properties.ja
14/Jan/2015 15:24:51,313- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.bfc
14/Jan/2015 15:24:51,317- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/flavormap.properties
14/Jan/2015 15:24:51,319- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME.txt
14/Jan/2015 15:24:51,424- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/
14/Jan/2015 15:24:51,425- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/orbd
14/Jan/2015 15:24:51,428- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/keytool
14/Jan/2015 15:24:51,429- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmid
14/Jan/2015 15:24:51,430- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmiregistry
14/Jan/2015 15:24:51,431- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/pack200
14/Jan/2015 15:24:51,452- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/policytool
14/Jan/2015 15:24:51,453- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/servertool
14/Jan/2015 15:24:51,454- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/jjs
14/Jan/2015 15:24:51,455- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/tnameserv
14/Jan/2015 15:24:51,457- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/java
14/Jan/2015 15:24:51,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/unpack200
14/Jan/2015 15:24:51,464- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/COPYRIGHT
14/Jan/2015 15:24:51,465- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/release
14/Jan/2015 15:24:51,467- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME-JAVAFX.txt
14/Jan/2015 15:24:51,476- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/README
14/Jan/2015 15:24:51,477- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/
14/Jan/2015 15:24:51,478- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/
14/Jan/2015 15:24:51,478- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jsse.jar
14/Jan/2015 15:24:51,486- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/
14/Jan/2015 15:24:51,487- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.access
14/Jan/2015 15:24:51,488- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/management.properties
14/Jan/2015 15:24:51,494- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/snmp.acl.template
14/Jan/2015 15:24:51,495- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.password.template
14/Jan/2015 15:24:51,497- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/classlist
14/Jan/2015 15:24:51,505- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/
14/Jan/2015 15:24:51,505- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/localedata.jar
14/Jan/2015 15:24:51,532- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunjce_provider.jar
14/Jan/2015 15:24:51,541- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/meta-index
14/Jan/2015 15:24:51,542- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunpkcs11.jar
14/Jan/2015 15:24:51,551- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunec.jar
14/Jan/2015 15:24:51,608- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/currency.data
14/Jan/2015 15:24:51,610- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/meta-index
14/Jan/2015 15:24:51,611- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:24:51,619- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jce.jar
14/Jan/2015 15:24:51,626- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/
14/Jan/2015 15:24:51,626- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsctp.so
14/Jan/2015 15:24:51,629- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pcsc.so
14/Jan/2015 15:24:51,631- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava.so
14/Jan/2015 15:24:51,635- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsig.so
14/Jan/2015 15:24:51,637- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/
14/Jan/2015 15:24:51,637- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjsig.so
14/Jan/2015 15:24:51,637- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjvm.so
14/Jan/2015 15:24:51,717- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/Xusage.txt
14/Jan/2015 15:24:51,718- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libhprof.so
14/Jan/2015 15:24:51,723- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jvm.cfg
14/Jan/2015 15:24:51,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2gss.so
14/Jan/2015 15:24:51,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/
14/Jan/2015 15:24:51,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/Xusage.txt
14/Jan/2015 15:24:51,730- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjvm.so
14/Jan/2015 15:24:51,837- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjsig.so
14/Jan/2015 15:24:51,837- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libzip.so
14/Jan/2015 15:24:51,842- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pkcs11.so
14/Jan/2015 15:24:51,845- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/
14/Jan/2015 15:24:51,846- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/libjli.so
14/Jan/2015 15:24:51,850- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/
14/Jan/2015 15:24:51,850- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:24:51,852- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjvm.so
14/Jan/2015 15:24:51,918- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjsig.so
14/Jan/2015 15:24:51,919- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:24:51,922- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsdt.so
14/Jan/2015 15:24:51,927- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libmanagement.so
14/Jan/2015 15:24:51,932- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnio.so
14/Jan/2015 15:24:51,937- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjaas_unix.so
14/Jan/2015 15:24:51,938- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnpt.so
14/Jan/2015 15:24:51,942- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsunec.so
14/Jan/2015 15:24:51,958- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libinstrument.so
14/Jan/2015 15:24:51,962- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libverify.so
14/Jan/2015 15:24:51,966- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnet.so
14/Jan/2015 15:24:51,969- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/tzdb.dat
14/Jan/2015 15:24:51,976- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/content-types.properties
14/Jan/2015 15:24:51,978- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/rt.jar
14/Jan/2015 15:24:52,320- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management-agent.jar
14/Jan/2015 15:24:52,321- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/net.properties
14/Jan/2015 15:24:52,323- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/logging.properties
14/Jan/2015 15:24:52,325- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jvm.hprof.txt
14/Jan/2015 15:24:52,326- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/
14/Jan/2015 15:24:52,327- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/US_export_policy.jar
14/Jan/2015 15:24:52,328- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.policy
14/Jan/2015 15:24:52,329- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/trusted.libraries
14/Jan/2015 15:24:52,329- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/cacerts
14/Jan/2015 15:24:52,334- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/blacklist
14/Jan/2015 15:24:52,336- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.security
14/Jan/2015 15:24:52,340- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/local_policy.jar
14/Jan/2015 15:24:52,342- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/calendars.properties
14/Jan/2015 15:24:52,343- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/resources.jar
14/Jan/2015 15:24:52,360- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/
14/Jan/2015 15:24:52,360- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/java
14/Jan/2015 15:24:52,361- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/keytool
14/Jan/2015 15:24:52,362- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmiregistry
14/Jan/2015 15:24:52,363- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmid
14/Jan/2015 15:24:52,364- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/release
14/Jan/2015 15:24:52,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/
14/Jan/2015 15:24:52,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/
14/Jan/2015 15:24:52,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/
14/Jan/2015 15:24:52,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/
14/Jan/2015 15:24:52,366- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/libj2pkcs11.so
14/Jan/2015 15:24:52,369- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/
14/Jan/2015 15:24:52,369- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/sunpkcs11.jar
14/Jan/2015 15:24:52,377- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/
14/Jan/2015 15:24:52,377- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/
14/Jan/2015 15:24:52,377- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/
14/Jan/2015 15:24:52,377- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/nashorn.jar
14/Jan/2015 15:24:52,416- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/
14/Jan/2015 15:24:52,416- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/
14/Jan/2015 15:24:52,416- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/
14/Jan/2015 15:24:52,417- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/localedata.jar
14/Jan/2015 15:24:52,463- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/
14/Jan/2015 15:24:52,463- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/
14/Jan/2015 15:24:52,463- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/
14/Jan/2015 15:24:52,464- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/libsunec.so
14/Jan/2015 15:24:52,470- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/
14/Jan/2015 15:24:52,471- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/sunec.jar
14/Jan/2015 15:24:52,561- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/
14/Jan/2015 15:24:52,561- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/
14/Jan/2015 15:24:52,561- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/
14/Jan/2015 15:24:52,562- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libdt_socket.so
14/Jan/2015 15:24:52,565- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjdwp.so
14/Jan/2015 15:24:52,572- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:24:52,577- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libnpt.so
14/Jan/2015 15:24:52,584- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libhprof.so
14/Jan/2015 15:24:52,591- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/jvm.hprof.txt
14/Jan/2015 15:24:52,593- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/
14/Jan/2015 15:24:52,594- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/
14/Jan/2015 15:24:52,594- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/gcf.jar
14/Jan/2015 15:24:52,719- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/
14/Jan/2015 15:24:52,720- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/
14/Jan/2015 15:24:52,720- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/charsets.jar
14/Jan/2015 15:24:52,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/
14/Jan/2015 15:24:52,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/
14/Jan/2015 15:24:52,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/
14/Jan/2015 15:24:52,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjsig.so
14/Jan/2015 15:24:52,762- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjava.so
14/Jan/2015 15:24:52,767- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/
14/Jan/2015 15:24:52,768- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/libjli.so
14/Jan/2015 15:24:52,771- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libzip.so
14/Jan/2015 15:24:52,777- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jvm.cfg
14/Jan/2015 15:24:52,778- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libsunec.so
14/Jan/2015 15:24:52,785- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/
14/Jan/2015 15:24:52,786- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:24:52,787- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjvm.so
14/Jan/2015 15:24:52,841- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjsig.so
14/Jan/2015 15:24:52,842- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libverify.so
14/Jan/2015 15:24:52,846- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/
14/Jan/2015 15:24:52,846- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjvm.so
14/Jan/2015 15:24:52,966- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjsig.so
14/Jan/2015 15:24:52,966- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/Xusage.txt
14/Jan/2015 15:24:52,967- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libj2pkcs11.so
14/Jan/2015 15:24:52,970- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnio.so
14/Jan/2015 15:24:52,975- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnet.so
14/Jan/2015 15:24:52,978- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/
14/Jan/2015 15:24:52,979- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjvm.so
14/Jan/2015 15:24:53,065- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjsig.so
14/Jan/2015 15:24:53,065- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/Xusage.txt
14/Jan/2015 15:24:53,066- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/rt.jar
14/Jan/2015 15:24:53,324- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/meta-index
14/Jan/2015 15:24:53,325- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/
14/Jan/2015 15:24:53,326- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/cacerts
14/Jan/2015 15:24:53,330- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/US_export_policy.jar
14/Jan/2015 15:24:53,331- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.security
14/Jan/2015 15:24:53,335- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/blacklist
14/Jan/2015 15:24:53,336- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/local_policy.jar
14/Jan/2015 15:24:53,337- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/trusted.libraries
14/Jan/2015 15:24:53,338- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.policy
14/Jan/2015 15:24:53,341- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jce.jar
14/Jan/2015 15:24:53,347- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/logging.properties
14/Jan/2015 15:24:53,351- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/resources.jar
14/Jan/2015 15:24:53,367- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:24:53,375- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/
14/Jan/2015 15:24:53,376- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/localedata.jar
14/Jan/2015 15:24:53,401- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/meta-index
14/Jan/2015 15:24:53,402- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunpkcs11.jar
14/Jan/2015 15:24:53,411- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunec.jar
14/Jan/2015 15:24:53,499- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunjce_provider.jar
14/Jan/2015 15:24:53,510- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/currency.data
14/Jan/2015 15:24:53,512- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/calendars.properties
14/Jan/2015 15:24:53,513- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/classlist
14/Jan/2015 15:24:53,518- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/tzdb.dat
14/Jan/2015 15:24:53,528- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/net.properties
14/Jan/2015 15:24:53,529- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jsse.jar
14/Jan/2015 15:24:53,538- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/content-types.properties
14/Jan/2015 15:24:53,541- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/release
14/Jan/2015 15:24:53,542- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/
14/Jan/2015 15:24:53,542- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmiregistry
14/Jan/2015 15:24:53,543- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmid
14/Jan/2015 15:24:53,545- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/keytool
14/Jan/2015 15:24:53,546- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/java
14/Jan/2015 15:24:53,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/
14/Jan/2015 15:24:53,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/release
14/Jan/2015 15:24:53,551- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/
14/Jan/2015 15:24:53,552- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/classlist
14/Jan/2015 15:24:53,560- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/rt.jar
14/Jan/2015 15:24:53,727- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/tzdb.dat
14/Jan/2015 15:24:53,733- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/net.properties
14/Jan/2015 15:24:53,734- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/calendars.properties
14/Jan/2015 15:24:53,735- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:24:53,742- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/currency.data
14/Jan/2015 15:24:53,743- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jsse.jar
14/Jan/2015 15:24:53,754- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/meta-index
14/Jan/2015 15:24:53,759- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/content-types.properties
14/Jan/2015 15:24:53,760- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/
14/Jan/2015 15:24:53,760- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/US_export_policy.jar
14/Jan/2015 15:24:53,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/cacerts
14/Jan/2015 15:24:53,766- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.security
14/Jan/2015 15:24:53,769- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/local_policy.jar
14/Jan/2015 15:24:53,770- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.policy
14/Jan/2015 15:24:53,771- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/trusted.libraries
14/Jan/2015 15:24:53,771- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/blacklist
14/Jan/2015 15:24:53,776- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/
14/Jan/2015 15:24:53,776- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunpkcs11.jar
14/Jan/2015 15:24:53,789- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/meta-index
14/Jan/2015 15:24:53,795- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunec.jar
14/Jan/2015 15:24:53,876- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/localedata.jar
14/Jan/2015 15:24:53,903- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunjce_provider.jar
14/Jan/2015 15:24:53,913- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jce.jar
14/Jan/2015 15:24:53,918- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/resources.jar
14/Jan/2015 15:24:53,925- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/logging.properties
14/Jan/2015 15:24:53,926- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/
14/Jan/2015 15:24:53,927- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libverify.so
14/Jan/2015 15:24:53,930- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/
14/Jan/2015 15:24:53,931- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/libjli.so
14/Jan/2015 15:24:53,935- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libzip.so
14/Jan/2015 15:24:53,940- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/
14/Jan/2015 15:24:53,941- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjvm.so
14/Jan/2015 15:24:53,987- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjsig.so
14/Jan/2015 15:24:53,987- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:24:53,989- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnet.so
14/Jan/2015 15:24:53,994- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jvm.cfg
14/Jan/2015 15:24:53,995- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnio.so
14/Jan/2015 15:24:54,000- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libj2pkcs11.so
14/Jan/2015 15:24:54,004- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjava.so
14/Jan/2015 15:24:54,010- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/
14/Jan/2015 15:24:54,011- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjsig.so
14/Jan/2015 15:24:54,011- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/Xusage.txt
14/Jan/2015 15:24:54,013- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjvm.so
14/Jan/2015 15:24:54,124- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjsig.so
14/Jan/2015 15:24:54,126- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/
14/Jan/2015 15:24:54,126- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjsig.so
14/Jan/2015 15:24:54,127- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/Xusage.txt
14/Jan/2015 15:24:54,128- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjvm.so
14/Jan/2015 15:24:54,215- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libsunec.so
14/Jan/2015 15:24:54,222- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/
14/Jan/2015 15:24:54,223- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/keytool
14/Jan/2015 15:24:54,224- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/java
14/Jan/2015 15:24:54,226- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/
14/Jan/2015 15:24:54,226- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/
14/Jan/2015 15:24:54,226- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/
14/Jan/2015 15:24:54,226- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/
14/Jan/2015 15:24:54,227- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/
14/Jan/2015 15:24:54,227- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/jfxrt-controls.jar
14/Jan/2015 15:24:54,277- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/
14/Jan/2015 15:24:54,278- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/
14/Jan/2015 15:24:54,278- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.platform.properties
14/Jan/2015 15:24:54,279- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.properties
14/Jan/2015 15:24:54,281- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/
14/Jan/2015 15:24:54,281- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/liblens_porting.so
14/Jan/2015 15:24:54,285- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_iio.so
14/Jan/2015 15:24:54,295- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_sw.so
14/Jan/2015 15:24:54,302- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font_t2k.so
14/Jan/2015 15:24:54,321- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_eglfb.so
14/Jan/2015 15:24:54,329- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass.so
14/Jan/2015 15:24:54,335- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font.so
14/Jan/2015 15:24:54,338- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_es2_eglfb.so
14/Jan/2015 15:24:54,342- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_common.so
14/Jan/2015 15:24:54,346- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_dfb.so
14/Jan/2015 15:24:54,353- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/
14/Jan/2015 15:24:54,354- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/jfxrt-graphics.jar
14/Jan/2015 15:24:54,471- CreateJreController: Staring JRE Creation
14/Jan/2015 15:24:54,472- CreateJreController: Creator location: C:\Users\3539\wpilib\tools\ejdk1.8.0_06\lib\JRECre ate.jar
14/Jan/2015 15:24:54,472- CreateJreController: Command: [java, -jar, C:\Users\3539\wpilib\tools\ejdk1.8.0_06\lib\JRECre ate.jar, --dest, JRE, --profile, compact2, --vm, client, --keep-debug-info, --debug]
14/Jan/2015 15:24:58,131- CreateJreController: Successfully Created JRE!
14/Jan/2015 15:25:10,311- ConnectRoboRioController: Connecting to roborio-3539.local
14/Jan/2015 15:25:10,312- ConnectRoboRioController: Checking for mDNS connection to the roboRio
14/Jan/2015 15:25:13,775- ConnectRoboRioController: Found mDNS connection
14/Jan/2015 15:25:13,776- ConnectRoboRioController: Connected to the roboRio at roborio-3539.local
14/Jan/2015 15:25:13,811- DeployController: Removed the old tgz file
14/Jan/2015 15:25:13,811- DeployController: Starting zip
14/Jan/2015 15:25:13,816- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE, putting tar entry is JRE
14/Jan/2015 15:25:13,816- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin, putting tar entry is JRE/bin
14/Jan/2015 15:25:13,817- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\java, putting tar entry is JRE/bin/java
14/Jan/2015 15:25:13,818- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\keytool, putting tar entry is JRE/bin/keytool
14/Jan/2015 15:25:13,824- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\rmid, putting tar entry is JRE/bin/rmid
14/Jan/2015 15:25:13,826- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\rmiregistry, putting tar entry is JRE/bin/rmiregistry
14/Jan/2015 15:25:13,827- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bom, putting tar entry is JRE/bom
14/Jan/2015 15:25:13,828- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib, putting tar entry is JRE/lib
14/Jan/2015 15:25:13,828- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm, putting tar entry is JRE/lib/arm
14/Jan/2015 15:25:13,829- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client, putting tar entry is JRE/lib/arm/client
14/Jan/2015 15:25:13,829- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\libj sig.so, putting tar entry is JRE/lib/arm/client/libjsig.so
14/Jan/2015 15:25:13,830- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\libj vm.so, putting tar entry is JRE/lib/arm/client/libjvm.so
14/Jan/2015 15:25:14,257- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\Xusa ge.txt, putting tar entry is JRE/lib/arm/client/Xusage.txt
14/Jan/2015 15:25:14,258- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jli, putting tar entry is JRE/lib/arm/jli
14/Jan/2015 15:25:14,259- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jli\libjli. so, putting tar entry is JRE/lib/arm/jli/libjli.so
14/Jan/2015 15:25:14,269- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jvm.cfg, putting tar entry is JRE/lib/arm/jvm.cfg
14/Jan/2015 15:25:14,270- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libdt_socke t.so, putting tar entry is JRE/lib/arm/libdt_socket.so
14/Jan/2015 15:25:14,273- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libhprof.so , putting tar entry is JRE/lib/arm/libhprof.so
14/Jan/2015 15:25:14,287- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjava.so, putting tar entry is JRE/lib/arm/libjava.so
14/Jan/2015 15:25:14,306- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjava_crw _demo.so, putting tar entry is JRE/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:25:14,310- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjdwp.so, putting tar entry is JRE/lib/arm/libjdwp.so
14/Jan/2015 15:25:14,330- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjsig.so, putting tar entry is JRE/lib/arm/libjsig.so
14/Jan/2015 15:25:14,331- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnet.so, putting tar entry is JRE/lib/arm/libnet.so
14/Jan/2015 15:25:14,342- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnio.so, putting tar entry is JRE/lib/arm/libnio.so
14/Jan/2015 15:25:14,349- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnpt.so, putting tar entry is JRE/lib/arm/libnpt.so
14/Jan/2015 15:25:14,356- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libverify.s o, putting tar entry is JRE/lib/arm/libverify.so
14/Jan/2015 15:25:14,362- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libzip.so, putting tar entry is JRE/lib/arm/libzip.so
14/Jan/2015 15:25:14,372- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\calendars.prope rties, putting tar entry is JRE/lib/calendars.properties
14/Jan/2015 15:25:14,373- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\classlist, putting tar entry is JRE/lib/classlist
14/Jan/2015 15:25:14,383- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\content-types.properties, putting tar entry is JRE/lib/content-types.properties
14/Jan/2015 15:25:14,386- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\currency.data, putting tar entry is JRE/lib/currency.data
14/Jan/2015 15:25:14,387- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext, putting tar entry is JRE/lib/ext
14/Jan/2015 15:25:14,387- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext\meta-index, putting tar entry is JRE/lib/ext/meta-index
14/Jan/2015 15:25:14,388- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext\sunjce_prov ider.jar, putting tar entry is JRE/lib/ext/sunjce_provider.jar
14/Jan/2015 15:25:14,410- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\hijrah-config-umalqura.properties, putting tar entry is JRE/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:25:14,419- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jce.jar, putting tar entry is JRE/lib/jce.jar
14/Jan/2015 15:25:14,431- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jsse.jar, putting tar entry is JRE/lib/jsse.jar
14/Jan/2015 15:25:14,459- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jvm.hprof.txt, putting tar entry is JRE/lib/jvm.hprof.txt
14/Jan/2015 15:25:14,459- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\logging.propert ies, putting tar entry is JRE/lib/logging.properties
14/Jan/2015 15:25:14,460- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\meta-index, putting tar entry is JRE/lib/meta-index
14/Jan/2015 15:25:14,461- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\net.properties, putting tar entry is JRE/lib/net.properties
14/Jan/2015 15:25:14,462- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\resources.jar, putting tar entry is JRE/lib/resources.jar
14/Jan/2015 15:25:14,506- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\rt.jar, putting tar entry is JRE/lib/rt.jar
14/Jan/2015 15:25:15,512- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security, putting tar entry is JRE/lib/security
14/Jan/2015 15:25:15,512- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\blackl ist, putting tar entry is JRE/lib/security/blacklist
14/Jan/2015 15:25:15,514- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\cacert s, putting tar entry is JRE/lib/security/cacerts
14/Jan/2015 15:25:15,524- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\java.p olicy, putting tar entry is JRE/lib/security/java.policy
14/Jan/2015 15:25:15,525- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\java.s ecurity, putting tar entry is JRE/lib/security/java.security
14/Jan/2015 15:25:15,530- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\local_ policy.jar, putting tar entry is JRE/lib/security/local_policy.jar
14/Jan/2015 15:25:15,532- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\truste d.libraries, putting tar entry is JRE/lib/security/trusted.libraries
14/Jan/2015 15:25:15,532- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\US_exp ort_policy.jar, putting tar entry is JRE/lib/security/US_export_policy.jar
14/Jan/2015 15:25:15,535- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\tzdb.dat, putting tar entry is JRE/lib/tzdb.dat
14/Jan/2015 15:25:15,547- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\release, putting tar entry is JRE/release
14/Jan/2015 15:25:16,578- DeployController: Failure to send JRE to the roboRio
com.jcraft.jsch.JSchException: java.net.ConnectException: Connection refused: connect
at com.jcraft.jsch.Util.createSocket(Util.java:349) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:215) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:183) ~[java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController.lambda$initialize$10(DeployControlle r.java:85) [java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController$$Lambda$161/9505331.run(Unknown Source) [java-installer.jar:?]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_25]
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method) ~[?:1.8.0_25]
at java.net.DualStackPlainSocketImpl.socketConnect(Un known Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connectToAddress( Unknown Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.PlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.SocksSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.Socket.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.Socket.<init>(Unknown Source) ~[?:1.8.0_25]
at com.jcraft.jsch.Util.createSocket(Util.java:343) ~[java-installer.jar:?]
... 5 more
14/Jan/2015 15:25:59,931- MainApp: Exiting installer from popup
14/Jan/2015 15:58:09,177- MainApp: Found JRE, checking hash
14/Jan/2015 15:58:10,216- MainApp: Computed hash is 082F08397B0D3F63844AB472B5111C8C, official hash is 082F08397B0D3F63844AB472B5111C8C
14/Jan/2015 15:58:12,572- UntarController: Starting decompress of file C:\Users\3539\wpilib\tools\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\3539\wpilib\tools
14/Jan/2015 15:58:12,582- UntarController: Untarring ejdk1.8.0_06/bin/
14/Jan/2015 15:58:12,582- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.sh
14/Jan/2015 15:58:12,584- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.bat
14/Jan/2015 15:58:12,585- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.config.properties
14/Jan/2015 15:58:12,636- UntarController: Untarring ejdk1.8.0_06/doc/
14/Jan/2015 15:58:12,637- UntarController: Untarring ejdk1.8.0_06/lib/
14/Jan/2015 15:58:12,637- UntarController: Untarring ejdk1.8.0_06/lib/JRECreate.jar
14/Jan/2015 15:58:12,651- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/
14/Jan/2015 15:58:12,652- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/
14/Jan/2015 15:58:12,652- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/
14/Jan/2015 15:58:12,652- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/
14/Jan/2015 15:58:12,653- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklist
14/Jan/2015 15:58:12,654- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/US_export_policy.jar
14/Jan/2015 15:58:12,655- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.security
14/Jan/2015 15:58:12,670- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.policy
14/Jan/2015 15:58:12,672- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/local_policy.jar
14/Jan/2015 15:58:12,673- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklisted.certs
14/Jan/2015 15:58:12,674- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/trusted.libraries
14/Jan/2015 15:58:12,674- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/cacerts
14/Jan/2015 15:58:12,692- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.bfc
14/Jan/2015 15:58:12,693- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.bfc
14/Jan/2015 15:58:12,695- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/meta-index
14/Jan/2015 15:58:12,696- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.bfc
14/Jan/2015 15:58:12,697- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/resources.jar
14/Jan/2015 15:58:12,721- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.properties.src
14/Jan/2015 15:58:12,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/classlist
14/Jan/2015 15:58:12,745- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/net.properties
14/Jan/2015 15:58:12,746- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management-agent.jar
14/Jan/2015 15:58:12,747- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr.jar
14/Jan/2015 15:58:12,754- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jvm.hprof.txt
14/Jan/2015 15:58:12,756- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/calendars.properties
14/Jan/2015 15:58:12,757- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/
14/Jan/2015 15:58:12,757- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/
14/Jan/2015 15:58:12,757- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkNoDrop32x32.gif
14/Jan/2015 15:58:12,768- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/cursors.properties
14/Jan/2015 15:58:12,770- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkDrop32x32.gif
14/Jan/2015 15:58:12,771- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/invalid32x32.gif
14/Jan/2015 15:58:12,772- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveNoDrop32x32.gif
14/Jan/2015 15:58:12,773- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyNoDrop32x32.gif
14/Jan/2015 15:58:12,774- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveDrop32x32.gif
14/Jan/2015 15:58:12,774- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyDrop32x32.gif
14/Jan/2015 15:58:12,775- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/charsets.jar
14/Jan/2015 15:58:12,818- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/
14/Jan/2015 15:58:12,819- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.password.template
14/Jan/2015 15:58:12,820- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/snmp.acl.template
14/Jan/2015 15:58:12,821- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.access
14/Jan/2015 15:58:12,822- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/management.properties
14/Jan/2015 15:58:12,825- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/
14/Jan/2015 15:58:12,826- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiBold.ttf
14/Jan/2015 15:58:12,832- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightItalic.ttf
14/Jan/2015 15:58:12,838- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiItalic.ttf
14/Jan/2015 15:58:12,844- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterBold.ttf
14/Jan/2015 15:58:12,853- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansDemiBold.ttf
14/Jan/2015 15:58:12,863- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightRegular.ttf
14/Jan/2015 15:58:12,876- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansRegular.ttf
14/Jan/2015 15:58:12,894- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterRegular.ttf
14/Jan/2015 15:58:12,903- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/fonts.dir
14/Jan/2015 15:58:12,905- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/content-types.properties
14/Jan/2015 15:58:12,906- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/rt.jar
14/Jan/2015 15:58:13,534- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jexec
14/Jan/2015 15:58:13,536- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.properties.src
14/Jan/2015 15:58:13,539- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/applet/
14/Jan/2015 15:58:13,540- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/
14/Jan/2015 15:58:13,540- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunec.jar
14/Jan/2015 15:58:13,783- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/cldrdata.jar
14/Jan/2015 15:58:13,905- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/meta-index
14/Jan/2015 15:58:13,921- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunjce_provider.jar
14/Jan/2015 15:58:13,933- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/localedata.jar
14/Jan/2015 15:58:13,968- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/zipfs.jar
14/Jan/2015 15:58:13,974- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/dnsns.jar
14/Jan/2015 15:58:14,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/nashorn.jar
14/Jan/2015 15:58:14,051- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunpkcs11.jar
14/Jan/2015 15:58:14,062- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/
14/Jan/2015 15:58:14,062- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/profile.jfc
14/Jan/2015 15:58:14,067- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/default.jfc
14/Jan/2015 15:58:14,072- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/
14/Jan/2015 15:58:14,072- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/LINEAR_RGB.pf
14/Jan/2015 15:58:14,073- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/CIEXYZ.pf
14/Jan/2015 15:58:14,078- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/GRAY.pf
14/Jan/2015 15:58:14,080- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/sRGB.pf
14/Jan/2015 15:58:14,086- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/PYCC.pf
14/Jan/2015 15:58:14,098- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/logging.properties
14/Jan/2015 15:58:14,100- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/tzdb.dat
14/Jan/2015 15:58:14,121- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:58:14,130- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.bfc
14/Jan/2015 15:58:14,136- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/
14/Jan/2015 15:58:14,137- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterBoldOblique.ttf
14/Jan/2015 15:58:14,143- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterOblique.ttf
14/Jan/2015 15:58:14,152- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansOblique.ttf
14/Jan/2015 15:58:14,164- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansDemiOblique.ttf
14/Jan/2015 15:58:14,172- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/fonts.dir
14/Jan/2015 15:58:14,176- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfontj2d.properties
14/Jan/2015 15:58:14,181- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.properties.src
14/Jan/2015 15:58:14,186- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/sound.properties
14/Jan/2015 15:58:14,188- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.properties.src
14/Jan/2015 15:58:14,190- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.properties.src
14/Jan/2015 15:58:14,194- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.properties.src
14/Jan/2015 15:58:14,199- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/currency.data
14/Jan/2015 15:58:14,202- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jce.jar
14/Jan/2015 15:58:14,209- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jsse.jar
14/Jan/2015 15:58:14,222- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.bfc
14/Jan/2015 15:58:14,223- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/
14/Jan/2015 15:58:14,223- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdt_socket.so
14/Jan/2015 15:58:14,246- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2gss.so
14/Jan/2015 15:58:14,254- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libhprof.so
14/Jan/2015 15:58:14,265- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/
14/Jan/2015 15:58:14,266- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/Xusage.txt
14/Jan/2015 15:58:14,269- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjvm.so
14/Jan/2015 15:58:14,435- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjsig.so
14/Jan/2015 15:58:14,436- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pcsc.so
14/Jan/2015 15:58:14,438- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/
14/Jan/2015 15:58:14,438- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjsig.so
14/Jan/2015 15:58:14,439- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjvm.so
14/Jan/2015 15:58:14,553- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/Xusage.txt
14/Jan/2015 15:58:14,554- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libinstrument.so
14/Jan/2015 15:58:14,645- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnpt.so
14/Jan/2015 15:58:14,646- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdcpr.so
14/Jan/2015 15:58:14,652- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/
14/Jan/2015 15:58:14,653- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:58:14,654- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjvm.so
14/Jan/2015 15:58:14,696- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjsig.so
14/Jan/2015 15:58:14,696- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsplashscreen.so
14/Jan/2015 15:58:14,705- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnet.so
14/Jan/2015 15:58:14,715- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsdt.so
14/Jan/2015 15:58:14,717- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsound.so
14/Jan/2015 15:58:14,719- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnio.so
14/Jan/2015 15:58:14,722- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:58:14,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsoundalsa.so
14/Jan/2015 15:58:14,729- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjaas_unix.so
14/Jan/2015 15:58:14,731- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libkcms.so
14/Jan/2015 15:58:14,740- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/
14/Jan/2015 15:58:14,740- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/libjli.so
14/Jan/2015 15:58:14,745- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmanagement.so
14/Jan/2015 15:58:14,759- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libt2k.so
14/Jan/2015 15:58:14,768- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjawt.so
14/Jan/2015 15:58:14,769- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsunec.so
14/Jan/2015 15:58:14,775- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jvm.cfg
14/Jan/2015 15:58:14,776- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjdwp.so
14/Jan/2015 15:58:14,783- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libunpack.so
14/Jan/2015 15:58:14,788- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/liblcms.so
14/Jan/2015 15:58:14,795- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt_headless.so
14/Jan/2015 15:58:14,800- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libfontmanager.so
14/Jan/2015 15:58:14,808- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjpeg.so
14/Jan/2015 15:58:14,814- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libzip.so
14/Jan/2015 15:58:14,819- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt.so
14/Jan/2015 15:58:14,829- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsig.so
14/Jan/2015 15:58:14,831- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmlib_image.so
14/Jan/2015 15:58:14,845- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libverify.so
14/Jan/2015 15:58:14,851- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjfr.so
14/Jan/2015 15:58:14,854- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsctp.so
14/Jan/2015 15:58:14,857- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pkcs11.so
14/Jan/2015 15:58:14,860- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava.so
14/Jan/2015 15:58:14,866- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfont.properties.ja
14/Jan/2015 15:58:14,868- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.bfc
14/Jan/2015 15:58:14,869- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/flavormap.properties
14/Jan/2015 15:58:14,870- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME.txt
14/Jan/2015 15:58:14,904- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/
14/Jan/2015 15:58:14,904- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/orbd
14/Jan/2015 15:58:14,907- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/keytool
14/Jan/2015 15:58:14,909- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmid
14/Jan/2015 15:58:14,910- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmiregistry
14/Jan/2015 15:58:14,913- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/pack200
14/Jan/2015 15:58:14,916- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/policytool
14/Jan/2015 15:58:14,917- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/servertool
14/Jan/2015 15:58:14,919- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/jjs
14/Jan/2015 15:58:14,920- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/tnameserv
14/Jan/2015 15:58:14,921- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/java
14/Jan/2015 15:58:14,922- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/unpack200
14/Jan/2015 15:58:14,927- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/COPYRIGHT
14/Jan/2015 15:58:14,930- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/release
14/Jan/2015 15:58:14,932- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME-JAVAFX.txt
14/Jan/2015 15:58:14,940- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/README
14/Jan/2015 15:58:14,941- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/
14/Jan/2015 15:58:14,941- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/
14/Jan/2015 15:58:14,941- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jsse.jar
14/Jan/2015 15:58:14,950- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/
14/Jan/2015 15:58:14,951- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.access
14/Jan/2015 15:58:14,952- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/management.properties
14/Jan/2015 15:58:14,956- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/snmp.acl.template
14/Jan/2015 15:58:14,957- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.password.template
14/Jan/2015 15:58:14,959- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/classlist
14/Jan/2015 15:58:14,963- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/
14/Jan/2015 15:58:14,964- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/localedata.jar
14/Jan/2015 15:58:14,990- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunjce_provider.jar
14/Jan/2015 15:58:15,001- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/meta-index
14/Jan/2015 15:58:15,002- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunpkcs11.jar
14/Jan/2015 15:58:15,011- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunec.jar
14/Jan/2015 15:58:15,079- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/currency.data
14/Jan/2015 15:58:15,082- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/meta-index
14/Jan/2015 15:58:15,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:58:15,092- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jce.jar
14/Jan/2015 15:58:15,097- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/
14/Jan/2015 15:58:15,098- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsctp.so
14/Jan/2015 15:58:15,101- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pcsc.so
14/Jan/2015 15:58:15,103- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava.so
14/Jan/2015 15:58:15,107- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsig.so
14/Jan/2015 15:58:15,109- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/
14/Jan/2015 15:58:15,109- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjsig.so
14/Jan/2015 15:58:15,109- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjvm.so
14/Jan/2015 15:58:15,186- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/Xusage.txt
14/Jan/2015 15:58:15,187- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libhprof.so
14/Jan/2015 15:58:15,192- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jvm.cfg
14/Jan/2015 15:58:15,193- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2gss.so
14/Jan/2015 15:58:15,196- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/
14/Jan/2015 15:58:15,196- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/Xusage.txt
14/Jan/2015 15:58:15,197- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjvm.so
14/Jan/2015 15:58:15,302- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjsig.so
14/Jan/2015 15:58:15,303- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libzip.so
14/Jan/2015 15:58:15,306- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pkcs11.so
14/Jan/2015 15:58:15,310- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/
14/Jan/2015 15:58:15,310- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/libjli.so
14/Jan/2015 15:58:15,314- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/
14/Jan/2015 15:58:15,315- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:58:15,316- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjvm.so
14/Jan/2015 15:58:15,358- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjsig.so
14/Jan/2015 15:58:15,358- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:58:15,361- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsdt.so
14/Jan/2015 15:58:15,362- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libmanagement.so
14/Jan/2015 15:58:15,366- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnio.so
14/Jan/2015 15:58:15,370- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjaas_unix.so
14/Jan/2015 15:58:15,371- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnpt.so
14/Jan/2015 15:58:15,373- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsunec.so
14/Jan/2015 15:58:15,379- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libinstrument.so
14/Jan/2015 15:58:15,382- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libverify.so
14/Jan/2015 15:58:15,386- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnet.so
14/Jan/2015 15:58:15,389- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/tzdb.dat
14/Jan/2015 15:58:15,395- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/content-types.properties
14/Jan/2015 15:58:15,396- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/rt.jar
14/Jan/2015 15:58:15,686- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management-agent.jar
14/Jan/2015 15:58:15,687- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/net.properties
14/Jan/2015 15:58:15,689- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/logging.properties
14/Jan/2015 15:58:15,690- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jvm.hprof.txt
14/Jan/2015 15:58:15,691- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/
14/Jan/2015 15:58:15,691- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/US_export_policy.jar
14/Jan/2015 15:58:15,692- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.policy
14/Jan/2015 15:58:15,693- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/trusted.libraries
14/Jan/2015 15:58:15,693- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/cacerts
14/Jan/2015 15:58:15,699- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/blacklist
14/Jan/2015 15:58:15,700- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.security
14/Jan/2015 15:58:15,704- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/local_policy.jar
14/Jan/2015 15:58:15,705- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/calendars.properties
14/Jan/2015 15:58:15,706- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/resources.jar
14/Jan/2015 15:58:15,718- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/
14/Jan/2015 15:58:15,719- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/java
14/Jan/2015 15:58:15,720- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/keytool
14/Jan/2015 15:58:15,721- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmiregistry
14/Jan/2015 15:58:15,722- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmid
14/Jan/2015 15:58:15,723- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/release
14/Jan/2015 15:58:15,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/
14/Jan/2015 15:58:15,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/
14/Jan/2015 15:58:15,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/
14/Jan/2015 15:58:15,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/
14/Jan/2015 15:58:15,724- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/libj2pkcs11.so
14/Jan/2015 15:58:15,728- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/
14/Jan/2015 15:58:15,728- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/sunpkcs11.jar
14/Jan/2015 15:58:15,736- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/
14/Jan/2015 15:58:15,736- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/
14/Jan/2015 15:58:15,736- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/
14/Jan/2015 15:58:15,737- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/nashorn.jar
14/Jan/2015 15:58:15,769- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/
14/Jan/2015 15:58:15,769- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/
14/Jan/2015 15:58:15,769- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/
14/Jan/2015 15:58:15,769- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/localedata.jar
14/Jan/2015 15:58:15,793- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/
14/Jan/2015 15:58:15,793- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/
14/Jan/2015 15:58:15,793- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/
14/Jan/2015 15:58:15,793- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/libsunec.so
14/Jan/2015 15:58:15,800- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/
14/Jan/2015 15:58:15,801- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/sunec.jar
14/Jan/2015 15:58:15,857- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/
14/Jan/2015 15:58:15,857- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/
14/Jan/2015 15:58:15,858- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/
14/Jan/2015 15:58:15,858- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libdt_socket.so
14/Jan/2015 15:58:15,861- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjdwp.so
14/Jan/2015 15:58:15,868- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:58:15,871- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libnpt.so
14/Jan/2015 15:58:15,872- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libhprof.so
14/Jan/2015 15:58:15,876- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/jvm.hprof.txt
14/Jan/2015 15:58:15,877- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/
14/Jan/2015 15:58:15,878- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/
14/Jan/2015 15:58:15,878- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/gcf.jar
14/Jan/2015 15:58:15,940- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/
14/Jan/2015 15:58:15,940- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/
14/Jan/2015 15:58:15,940- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/charsets.jar
14/Jan/2015 15:58:15,977- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/
14/Jan/2015 15:58:15,977- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/
14/Jan/2015 15:58:15,977- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/
14/Jan/2015 15:58:15,977- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjsig.so
14/Jan/2015 15:58:15,978- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjava.so
14/Jan/2015 15:58:15,984- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/
14/Jan/2015 15:58:15,990- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/libjli.so
14/Jan/2015 15:58:15,995- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libzip.so
14/Jan/2015 15:58:16,000- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jvm.cfg
14/Jan/2015 15:58:16,001- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libsunec.so
14/Jan/2015 15:58:16,007- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/
14/Jan/2015 15:58:16,007- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:58:16,008- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjvm.so
14/Jan/2015 15:58:16,050- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjsig.so
14/Jan/2015 15:58:16,050- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libverify.so
14/Jan/2015 15:58:16,054- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/
14/Jan/2015 15:58:16,054- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjvm.so
14/Jan/2015 15:58:16,218- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjsig.so
14/Jan/2015 15:58:16,219- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/Xusage.txt
14/Jan/2015 15:58:16,376- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libj2pkcs11.so
14/Jan/2015 15:58:16,380- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnio.so
14/Jan/2015 15:58:16,384- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnet.so
14/Jan/2015 15:58:16,388- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/
14/Jan/2015 15:58:16,388- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjvm.so
14/Jan/2015 15:58:16,467- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjsig.so
14/Jan/2015 15:58:16,468- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/Xusage.txt
14/Jan/2015 15:58:16,469- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/rt.jar
14/Jan/2015 15:58:16,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/meta-index
14/Jan/2015 15:58:16,726- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/
14/Jan/2015 15:58:16,726- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/cacerts
14/Jan/2015 15:58:16,732- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/US_export_policy.jar
14/Jan/2015 15:58:16,734- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.security
14/Jan/2015 15:58:16,738- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/blacklist
14/Jan/2015 15:58:16,739- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/local_policy.jar
14/Jan/2015 15:58:16,740- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/trusted.libraries
14/Jan/2015 15:58:16,741- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.policy
14/Jan/2015 15:58:16,742- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jce.jar
14/Jan/2015 15:58:16,748- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/logging.properties
14/Jan/2015 15:58:16,749- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/resources.jar
14/Jan/2015 15:58:16,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:58:16,771- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/
14/Jan/2015 15:58:16,772- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/localedata.jar
14/Jan/2015 15:58:16,797- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/meta-index
14/Jan/2015 15:58:16,799- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunpkcs11.jar
14/Jan/2015 15:58:16,806- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunec.jar
14/Jan/2015 15:58:16,863- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunjce_provider.jar
14/Jan/2015 15:58:16,871- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/currency.data
14/Jan/2015 15:58:16,873- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/calendars.properties
14/Jan/2015 15:58:16,874- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/classlist
14/Jan/2015 15:58:16,878- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/tzdb.dat
14/Jan/2015 15:58:16,885- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/net.properties
14/Jan/2015 15:58:16,886- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jsse.jar
14/Jan/2015 15:58:16,894- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/content-types.properties
14/Jan/2015 15:58:16,896- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/release
14/Jan/2015 15:58:16,897- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/
14/Jan/2015 15:58:16,897- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmiregistry
14/Jan/2015 15:58:16,899- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmid
14/Jan/2015 15:58:16,900- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/keytool
14/Jan/2015 15:58:16,901- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/java
14/Jan/2015 15:58:16,902- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/
14/Jan/2015 15:58:16,902- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/release
14/Jan/2015 15:58:16,903- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/
14/Jan/2015 15:58:16,903- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/classlist
14/Jan/2015 15:58:16,907- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/rt.jar
14/Jan/2015 15:58:17,047- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/tzdb.dat
14/Jan/2015 15:58:17,053- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/net.properties
14/Jan/2015 15:58:17,054- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/calendars.properties
14/Jan/2015 15:58:17,055- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:58:17,063- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/currency.data
14/Jan/2015 15:58:17,065- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jsse.jar
14/Jan/2015 15:58:17,073- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/meta-index
14/Jan/2015 15:58:17,075- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/content-types.properties
14/Jan/2015 15:58:17,076- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/
14/Jan/2015 15:58:17,076- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/US_export_policy.jar
14/Jan/2015 15:58:17,077- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/cacerts
14/Jan/2015 15:58:17,083- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.security
14/Jan/2015 15:58:17,087- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/local_policy.jar
14/Jan/2015 15:58:17,088- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.policy
14/Jan/2015 15:58:17,089- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/trusted.libraries
14/Jan/2015 15:58:17,090- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/blacklist
14/Jan/2015 15:58:17,091- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/
14/Jan/2015 15:58:17,091- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunpkcs11.jar
14/Jan/2015 15:58:17,099- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/meta-index
14/Jan/2015 15:58:17,100- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunec.jar
14/Jan/2015 15:58:17,155- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/localedata.jar
14/Jan/2015 15:58:17,179- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunjce_provider.jar
14/Jan/2015 15:58:17,187- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jce.jar
14/Jan/2015 15:58:17,191- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/resources.jar
14/Jan/2015 15:58:17,197- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/logging.properties
14/Jan/2015 15:58:17,199- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/
14/Jan/2015 15:58:17,199- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libverify.so
14/Jan/2015 15:58:17,202- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/
14/Jan/2015 15:58:17,203- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/libjli.so
14/Jan/2015 15:58:17,206- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libzip.so
14/Jan/2015 15:58:17,211- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/
14/Jan/2015 15:58:17,211- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjvm.so
14/Jan/2015 15:58:17,253- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjsig.so
14/Jan/2015 15:58:17,253- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/Xusage.txt
14/Jan/2015 15:58:17,255- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnet.so
14/Jan/2015 15:58:17,258- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jvm.cfg
14/Jan/2015 15:58:17,260- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnio.so
14/Jan/2015 15:58:17,262- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libj2pkcs11.so
14/Jan/2015 15:58:17,267- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjava.so
14/Jan/2015 15:58:17,272- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/
14/Jan/2015 15:58:17,272- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjsig.so
14/Jan/2015 15:58:17,272- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/Xusage.txt
14/Jan/2015 15:58:17,273- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjvm.so
14/Jan/2015 15:58:17,377- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjsig.so
14/Jan/2015 15:58:17,378- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/
14/Jan/2015 15:58:17,378- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjsig.so
14/Jan/2015 15:58:17,379- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/Xusage.txt
14/Jan/2015 15:58:17,381- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjvm.so
14/Jan/2015 15:58:17,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libsunec.so
14/Jan/2015 15:58:17,465- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/
14/Jan/2015 15:58:17,466- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/keytool
14/Jan/2015 15:58:17,467- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/java
14/Jan/2015 15:58:17,468- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/
14/Jan/2015 15:58:17,468- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/
14/Jan/2015 15:58:17,468- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/
14/Jan/2015 15:58:17,468- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/
14/Jan/2015 15:58:17,469- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/
14/Jan/2015 15:58:17,469- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/jfxrt-controls.jar
14/Jan/2015 15:58:17,518- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/
14/Jan/2015 15:58:17,518- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/
14/Jan/2015 15:58:17,518- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.platform.properties
14/Jan/2015 15:58:17,520- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.properties
14/Jan/2015 15:58:17,521- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/
14/Jan/2015 15:58:17,521- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/liblens_porting.so
14/Jan/2015 15:58:17,525- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_iio.so
14/Jan/2015 15:58:17,534- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_sw.so
14/Jan/2015 15:58:17,538- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font_t2k.so
14/Jan/2015 15:58:17,557- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_eglfb.so
14/Jan/2015 15:58:17,565- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass.so
14/Jan/2015 15:58:17,571- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font.so
14/Jan/2015 15:58:17,575- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_es2_eglfb.so
14/Jan/2015 15:58:17,579- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_common.so
14/Jan/2015 15:58:17,584- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_dfb.so
14/Jan/2015 15:58:17,591- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/
14/Jan/2015 15:58:17,591- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/jfxrt-graphics.jar
14/Jan/2015 15:58:17,711- CreateJreController: Staring JRE Creation
14/Jan/2015 15:58:17,711- CreateJreController: Creator location: C:\Users\3539\wpilib\tools\ejdk1.8.0_06\lib\JRECre ate.jar
14/Jan/2015 15:58:17,711- CreateJreController: Command: [java, -jar, C:\Users\3539\wpilib\tools\ejdk1.8.0_06\lib\JRECre ate.jar, --dest, JRE, --profile, compact2, --vm, client, --keep-debug-info, --debug]
14/Jan/2015 15:58:18,142- CreateJreController: Successfully Created JRE!
14/Jan/2015 15:59:30,780- ConnectRoboRioController: Connecting to roborio-3539.local
14/Jan/2015 15:59:30,781- ConnectRoboRioController: Checking for mDNS connection to the roboRio
14/Jan/2015 15:59:37,065- ConnectRoboRioController: Could not connect to the roboRio at roborio-3539.local
java.net.UnknownHostException: roborio-3539.local
at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method) ~[?:1.8.0_25]
at java.net.InetAddress$2.lookupAllHostAddr(Unknown Source) ~[?:1.8.0_25]
at java.net.InetAddress.getAddressesFromNameService(U nknown Source) ~[?:1.8.0_25]
at java.net.InetAddress.getAllByName0(Unknown Source) ~[?:1.8.0_25]
at java.net.InetAddress.getAllByName(Unknown Source) ~[?:1.8.0_25]
at java.net.InetAddress.getByName(Unknown Source) ~[?:1.8.0_25]
at edu.wpi.first.wpilib.javainstaller.Controllers.Con nectRoboRioController.checkReachable(ConnectRoboRi oController.java:137) [java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Con nectRoboRioController.lambda$handleNext$19(Connect RoboRioController.java:101) [java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Con nectRoboRioController$$Lambda$158/5862715.run(Unknown Source) [java-installer.jar:?]
14/Jan/2015 15:59:37,078- ConnectRoboRioController: No mDNS connection found, checking for USB Connection to the roboRio
14/Jan/2015 15:59:38,082- ConnectRoboRioController: Found USB connection to the roboRio
14/Jan/2015 15:59:38,083- ConnectRoboRioController: Connected to the roboRio at 172.22.11.2
14/Jan/2015 15:59:38,126- DeployController: Removed the old tgz file
14/Jan/2015 15:59:38,126- DeployController: Starting zip
14/Jan/2015 15:59:38,134- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE, putting tar entry is JRE
14/Jan/2015 15:59:38,135- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin, putting tar entry is JRE/bin
14/Jan/2015 15:59:38,136- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\java, putting tar entry is JRE/bin/java
14/Jan/2015 15:59:38,138- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\keytool, putting tar entry is JRE/bin/keytool
14/Jan/2015 15:59:38,140- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\rmid, putting tar entry is JRE/bin/rmid
14/Jan/2015 15:59:38,141- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bin\rmiregistry, putting tar entry is JRE/bin/rmiregistry
14/Jan/2015 15:59:38,143- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\bom, putting tar entry is JRE/bom
14/Jan/2015 15:59:38,144- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib, putting tar entry is JRE/lib
14/Jan/2015 15:59:38,146- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm, putting tar entry is JRE/lib/arm
14/Jan/2015 15:59:38,147- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client, putting tar entry is JRE/lib/arm/client
14/Jan/2015 15:59:38,147- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\libj sig.so, putting tar entry is JRE/lib/arm/client/libjsig.so
14/Jan/2015 15:59:38,148- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\libj vm.so, putting tar entry is JRE/lib/arm/client/libjvm.so
14/Jan/2015 15:59:38,545- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\client\Xusa ge.txt, putting tar entry is JRE/lib/arm/client/Xusage.txt
14/Jan/2015 15:59:38,546- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jli, putting tar entry is JRE/lib/arm/jli
14/Jan/2015 15:59:38,546- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jli\libjli. so, putting tar entry is JRE/lib/arm/jli/libjli.so
14/Jan/2015 15:59:38,556- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\jvm.cfg, putting tar entry is JRE/lib/arm/jvm.cfg
14/Jan/2015 15:59:38,556- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libdt_socke t.so, putting tar entry is JRE/lib/arm/libdt_socket.so
14/Jan/2015 15:59:38,559- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libhprof.so , putting tar entry is JRE/lib/arm/libhprof.so
14/Jan/2015 15:59:38,572- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjava.so, putting tar entry is JRE/lib/arm/libjava.so
14/Jan/2015 15:59:38,587- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjava_crw _demo.so, putting tar entry is JRE/lib/arm/libjava_crw_demo.so
14/Jan/2015 15:59:38,592- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjdwp.so, putting tar entry is JRE/lib/arm/libjdwp.so
14/Jan/2015 15:59:38,611- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libjsig.so, putting tar entry is JRE/lib/arm/libjsig.so
14/Jan/2015 15:59:38,613- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnet.so, putting tar entry is JRE/lib/arm/libnet.so
14/Jan/2015 15:59:38,622- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnio.so, putting tar entry is JRE/lib/arm/libnio.so
14/Jan/2015 15:59:38,629- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libnpt.so, putting tar entry is JRE/lib/arm/libnpt.so
14/Jan/2015 15:59:38,631- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libverify.s o, putting tar entry is JRE/lib/arm/libverify.so
14/Jan/2015 15:59:38,637- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\arm\libzip.so, putting tar entry is JRE/lib/arm/libzip.so
14/Jan/2015 15:59:38,647- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\calendars.prope rties, putting tar entry is JRE/lib/calendars.properties
14/Jan/2015 15:59:38,648- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\classlist, putting tar entry is JRE/lib/classlist
14/Jan/2015 15:59:38,657- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\content-types.properties, putting tar entry is JRE/lib/content-types.properties
14/Jan/2015 15:59:38,659- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\currency.data, putting tar entry is JRE/lib/currency.data
14/Jan/2015 15:59:38,660- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext, putting tar entry is JRE/lib/ext
14/Jan/2015 15:59:38,660- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext\meta-index, putting tar entry is JRE/lib/ext/meta-index
14/Jan/2015 15:59:38,661- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\ext\sunjce_prov ider.jar, putting tar entry is JRE/lib/ext/sunjce_provider.jar
14/Jan/2015 15:59:38,684- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\hijrah-config-umalqura.properties, putting tar entry is JRE/lib/hijrah-config-umalqura.properties
14/Jan/2015 15:59:38,691- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jce.jar, putting tar entry is JRE/lib/jce.jar
14/Jan/2015 15:59:38,702- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jsse.jar, putting tar entry is JRE/lib/jsse.jar
14/Jan/2015 15:59:38,726- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\jvm.hprof.txt, putting tar entry is JRE/lib/jvm.hprof.txt
14/Jan/2015 15:59:38,727- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\logging.propert ies, putting tar entry is JRE/lib/logging.properties
14/Jan/2015 15:59:38,729- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\meta-index, putting tar entry is JRE/lib/meta-index
14/Jan/2015 15:59:38,730- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\net.properties, putting tar entry is JRE/lib/net.properties
14/Jan/2015 15:59:38,731- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\resources.jar, putting tar entry is JRE/lib/resources.jar
14/Jan/2015 15:59:38,767- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\rt.jar, putting tar entry is JRE/lib/rt.jar
14/Jan/2015 15:59:39,666- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security, putting tar entry is JRE/lib/security
14/Jan/2015 15:59:39,667- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\blackl ist, putting tar entry is JRE/lib/security/blacklist
14/Jan/2015 15:59:39,668- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\cacert s, putting tar entry is JRE/lib/security/cacerts
14/Jan/2015 15:59:39,676- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\java.p olicy, putting tar entry is JRE/lib/security/java.policy
14/Jan/2015 15:59:39,678- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\java.s ecurity, putting tar entry is JRE/lib/security/java.security
14/Jan/2015 15:59:39,683- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\local_ policy.jar, putting tar entry is JRE/lib/security/local_policy.jar
14/Jan/2015 15:59:39,684- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\truste d.libraries, putting tar entry is JRE/lib/security/trusted.libraries
14/Jan/2015 15:59:39,685- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\security\US_exp ort_policy.jar, putting tar entry is JRE/lib/security/US_export_policy.jar
14/Jan/2015 15:59:39,686- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\lib\tzdb.dat, putting tar entry is JRE/lib/tzdb.dat
14/Jan/2015 15:59:39,697- DeployController: Processing file C:\Users\3539\wpilib\tools\JRE\release, putting tar entry is JRE/release
14/Jan/2015 15:59:40,806- DeployController: Failure to send JRE to the roboRio
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController$$Lambda$160/26264387.run(Unknown Source) [java-installer.jar:?]
... 5 more
14/Jan/2015 16:00:26,655- MainApp: Exiting installer from popup
Unread 14-01-2015, 16:15
jagow100's Avatar
jagow100 jagow100 is offline
FRC #3539 (Byting Bulldogs)
jagow100 is an unknown quantity at this point
Re: Issue putting the java on the roboRIO
Here is the log: http://s000.tinyupload.com/index.php...12513858923141
Unread 15-01-2015, 12:06
psatya psatya is offline
FRC #4464
psatya is an unknown quantity at this point
Team 4464 is experiencing the exact same issue. Thanks for you help.
Satya
Unread 15-01-2015, 13:19
The relevant part of the log seems to be this single entry:
com.jcraft.jsch.JSchException: java.net.ConnectException: Connection refused: connect
at com.jcraft.jsch.Util.createSocket(Util.java:349) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:215) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:183) ~[java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController.lambda$initialize$10(DeployControlle r.java:85) [java-installer.jar:?]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_25]
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method) ~[?:1.8.0_25]
at java.net.DualStackPlainSocketImpl.socketConnect(Un known Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connectToAddress( Unknown Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.PlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.SocksSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.Socket.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.Socket.<init>(Unknown Source) ~[?:1.8.0_25]
at com.jcraft.jsch.Util.createSocket(Util.java:343) ~[java-installer.jar:?]
... 5 more
It says the roboRIO didn't accept the network connection. Did you load the proper image on the roboRIO first?
Unread 15-01-2015, 20:39
StemCivics5666 StemCivics5666 is offline
FRC #5666
StemCivics5666 is an unknown quantity at this point
We're having a similar issue... here is the relevant log piece log that we are getting:
15/Jan/2015 20:09:05,803- DownloadProgressController: Could not download the JRE
java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(Unknown Source) ~[?:1.8.0_11]
It was downloading at 3 kb/s, then I went to dinner, and when I came back it had aborted and this message was in the log. Any ideas?
Thanks!
Nathan
Unread 16-01-2015, 16:34
FRC #4464
Hello everybody -
We re-imaged the roboRio and the JRE got installed fine.
Just thought I would give an update.
Unread 21-01-2015, 14:49
Stuart Hunt Stuart Hunt is offline
FRC #5160
Stuart Hunt is an unknown quantity at this point
Team 5160 is having the same issue. We tried reloading the firmware and reimaging it, but nothing is working.
Unread 16-01-2016, 17:27
carmath carmath is offline
FRC #3577 (Saints Robotics)
carmath is an unknown quantity at this point
Team 3577 is having the same issue. We have the correct JRE loaded. It still indicates the connection is refused?
Host OS: Windows 10 10.0, 10.0
Host JVM: Java HotSpot(TM) 64-Bit Server VM 25.66-b18
Target IP: 10.35.77.2
Network interfaces on host:
Realtek PCIe GBE Family Controller: address: 10.35.77.2 netmask: 255.0.0.0 <--- on robot's subnet
National Instruments USBLAN Adapter: address: 172.22.11.1 netmask: 255.255.255.248
Realtek RTL8188CU Wireless LAN 802.11n USB 2.0 Network Adapter: address: 10.19.9.46 netmask: 255.255.0.0
Connecting FTP @10.35.77.2
C:\Users\SaintsRobotics\sunspotfrcsdk\build.xml:79 : The following error occurred while executing this line:
C:\Users\SaintsRobotics\sunspotfrcsdk\ant\configur e.xml:41:
Anyone else fix this yet?
Unread 18-01-2016, 23:00
A "refused connection" might be a sign that your Windows firewall isn't turned off, or that you have an active antimalware process trying to protect you from unexpected network activity.
