Go to Post Spell Check is your friend! - dez250 [more]
Unread 16-01-2015, 16:47
JPfrc5039's Avatar
JPfrc5039 JPfrc5039 is offline
Captain - FRC 5039
AKA: Jacob Pullen
FRC #5039 (Green Machine Robotics)
JPfrc5039 is an unknown quantity at this point
Any Good Battery Chargers?
Hey everyone, I'm looking for some good battery chargers. The ones we have from the KOPs are pretty slow. Any help?
Unread 16-01-2015, 16:53
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Any Good Battery Chargers?
I'm basing this reply on the KoP charger from the past that had selectable charge rates:
Do you have it set properly for 6A and 12V? The default rate is 2A, which as you might guess is pretty slow.
It's unsafe to charge a lead acid battery quickly, which is the reason for the 6A charge rate. The charging does take some time, particularly if you have used the battery to a point close to discharge. I've experienced a minimum of 20 minutes charge time per battery per match.
Also, if you want a compact charger for three batteries, this is the most common alternative I've seen used by teams:
http://www.andymark.com/Battery-Char...-p/am-2026.htm
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 16-01-2015, 17:07
Charging rates faster than 6 amps are not allowed. R20 blue box
Unread 16-01-2015, 17:16
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
Seconding the Dual Pro RS3. Buying it on Andymark is more expensive than elsewhere, but it has the battery connectors preinstalled, which you may find worth the extra money.
Unread 16-01-2015, 21:25
DonRotolo's Avatar
Back to humble
FRC #0832
That being said, my advice to you is to wonder why this rule exists. The answer is somewhere here on ChiefDelphi. Hint: It is bad for the battery.
Unread 16-01-2015, 21:36
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
I'll third this. We bought two of these to replace our KOP chargers and haven't looked back. We also set up a battery cart to hold everything. The nicest thing about them is the solid red/green feedback on charging & complete.
Unread 16-01-2015, 22:01
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
If you have enough batteries, this charger works great for us. Running ten batteries puts us in a place where we have never had to worry about having a fully charged battery during a competition. We work our way through batteries and by the time we get to number 5 or 6, number 1 is fully charged. The initial price is a bit surprising, but you get 10 banks for just a little more than 6 with one Andymark sells. The charge is limited to 2 amps per bank, so it isn't fast by any means. But we are still running batteries that are several years old because they are properly maintained using this charger.
Originally Posted by adciv View Post
...The nicest thing about them is the solid red/green feedback on charging & complete.
Our charger also has this, plus at 80% the green indicator blinks to let you know that it is nearly done.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 16-01-2015, 22:30
JPfrc5039's Avatar
Captain - FRC 5039
AKA: Jacob Pullen
Thank you all for the replies!
Unread 17-01-2015, 00:13
philso philso is offline
FRC #2587
$507 with shipping is not too bad. I just bought a 2A/6A/10A car battery charger that can also be used for charging FRC batteries at Walmart for about $30 + tax. The one in your link is certainly much more compact than 10 of the ones I bought.
Unread 17-01-2015, 01:10
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
Ctek MUS 4.3
We have 6 mounted on our battery cart, along with 14 batteries in two rotating competition sets of 6 each plus 2 test batteries. We make our oldest 2 the test batteries.
Unread 17-01-2015, 02:23
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
We are in our third year with a few tournaments behind us. We just recieved our second Dual Pro RS3.
How many batteries does your team have? FRC 4607 CIS has budgeted for an additional two batteries each year (beyond the KOP). Going off of experience, some teams do make calculations for elims based off how prepared your team is.
Being a team that was completely unprepared our Rookie season - and all the speculations that were made by other teams at our pit - we made certain to never be in that position again.
Third Year: We now have 11 Batteries and 3 battery chargers. We are building a charging station that can house 10 batteries (6 charging at any one time) with 4 'ready'. We have designated 1 battery as our 'PIT' battery that has a designated battery charger in the PIT.
Edit: Creating a flow chart and designating a PIT member as a 'Battery Person (boi)' helps eliminate confusion.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 17-01-2015, 03:11
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
That looks nice but reminded me a few years back during a tournament they made an announcement that Gator clamps to charge batteries was not okay but since then I have seen it on and off. Is there anyone who has found a final verdict on it?
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 17-01-2015, 03:49
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
See the last sentence of the blue box under R20: "Batteries should be charged in accordance with manufacturer’s specification. The battery charger output should not exceed 6 amps and they must have the corresponding Anderson connector installed. (Please see the FIRST Safety Manual for additional information.)"
Basically all this means is that you need to cut off the gator clamps and replace them with Anderson connectors.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 17-01-2015, 07:42
This charger has multiple attachments that use plugs to interchange. We wired them directly into some SB-50's we got on Amazon. We also learned that grey sb-50's don't mate to red so we got a milling assignment out of it as well.
Andrew Basse
Unread 17-01-2015, 08:29
One Eyed Man
Alternatively, you can clamp the wire on a KOP battery cable and electrical tape the clamps.
