Go to Post I know FIRST is all about changing society. But my approach is one person at a time. - Phil 33 [more]
Unread 15-01-2015, 19:25
Governators3361 Governators3361 is offline
FRC #3361
Governators3361 is an unknown quantity at this point
Mounting mecanum wheels... please help?
This is our first year using mecanum wheels; we have no experience with them. Furthermore, just before the build season, our only engineering coach found out that she pretty much wouldn't be available at any point, so we are short on professional advice.
The attached image is the general frame of our drivetrain, but is definitely subject to change, and is really all the metal we have to use for the drivetrain. It is 32 inches long by 25 inches wide, and this is not changing unless it absolutely has to. We are using the Cim motors that came in the kit of parts and we have enough AndyMark gearboxes to put one on each wheel. Our issue with this is the amount of room available in which to put gearboxes.
The mecanum wheels are 6 inches in diameter and 1.8 inches wide. Right now we are planning to have them roughly 20 inches apart. We would greatly appreciate suggestions on how to mount the wheels and the gearboxes, and if there is an ideal alternative to gearboxes, how to best reduce the RPM from motor to wheel, including specifics of gear size and distance between them. Thanks in advance for any help you are willing to give!
Unread 15-01-2015, 20:38
E_puello E_puello is offline
FRC #3161 (Tronic Titans)
E_puello is a jewel in the roughE_puello is a jewel in the roughE_puello is a jewel in the roughE_puello is a jewel in the rough
Re: Mounting mecanum wheels... please help?
http://www.andymark.com/product-p/am-14u2-mk6.htm
this might be what you are looking for
Unread 15-01-2015, 20:46
MHSrobotics2853's Avatar
MHSrobotics2853 MHSrobotics2853 is offline
Mililani Robotics
FRC #2853 (Trobobots)
MHSrobotics2853 is just really niceMHSrobotics2853 is just really niceMHSrobotics2853 is just really niceMHSrobotics2853 is just really niceMHSrobotics2853 is just really nice
We mounted mecanums on the kitbot frame, without the kit mentioned above. Distance between the center of the wheels is about 19". We used second stage planetary gearboxes. To mount the gearbox, you will need a plate w/ three holes (for the gearbox) that extends out and mounts to a side of the frame. We used two holes on each side of the plate.
I have attached a two pictures:
http://imgur.com/a/1X2if
and a video of it driving:
https://www.youtube.com/watch?v=uQbVDzJR3bc
Also, a couple of notes on our drive:
There's a ~40lb steel block mounted in the middle to simulate the weight of the actual robot. We started with first stage planetaries, but they didn't generate enough torque to strafe. We switched over to second stage and it strafes fine.
Unread 15-01-2015, 21:31
Monochron's Avatar
Monochron Monochron is online now
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Any thoughts on how structurally stable the side plates will be with those portions of fins removed?
Unread 15-01-2015, 21:43
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
I assume that it would be similar to that of last year's AM14U frame.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 15-01-2015, 21:52
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
http://www.andymark.com/SearchResult...rch=nano+tubes
we love these nano tubes. gear boxes and barrings are within the tube. cims mount directly to them and they work very well for mecanum and other drives. but they are a bit expensive. you may be able to use some of your AM credits towards them.
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 16-01-2015, 07:00
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Assuming that the GB mounting plate is solid aluminium, I'd say the rigidity would be fairly similar. It would be almost unnoticable if you extended the mounting plate so there was ~20mm of overlap with the still existing flanges.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 16-01-2015, 10:37
FRC #3361
Do you think it would be possible for us to use the AndyMark gearboxes provided in the kit of parts? Additionally, why do single stage gearboxes cause a problem with strafing?
Unread 16-01-2015, 11:00
Monochron's Avatar
Engineering Mentor
The ToughBox Minis can be mounted with mecanums but it is my understanding that you have to do a lot more machining than if you are using the ToughBox Nanos or 671 or something similar. If you search the forum you can find some pictures of other teams that have done it, but the one I remember mounted the gearboxes below the frame on a seperate plate. There could be easier ways, I haven't looked into it much.
Single stage gearboxes won't cause any strafing problems, just be aware that you may need additional reduction stages to get a slow enough speed. Most single stage COTS gearboxes aren't geared much more than 6:1 or so which, depending on your wheel size, might be faster that you want.
Unread 16-01-2015, 15:06
Monochron's Avatar
Engineering Mentor
For people mourning mecanums to the AM14U2, how are you securing the other end of the shaft driving the wheel? The corresponding hold in the outer plate has a diameter of 0.675", so you can't put a .5" Hex bearing in there. Or are you cantilevering it?
It looks like the Upgrade kit that AndyMark is selling has the outer plate attached and I'm guessing the shaft isn't cantilevered, but I can't tell by the pictures shown.
Unread 16-01-2015, 16:59
Mililani Robotics
They didn't generate enough torque to strafe in our case. We speculate it was a combination of that and our slightly bent frame. Weight distribution/contact w/ground is terribly important with mecanum drive - they need to turn at the same rate and exert the same force.
Unread 16-01-2015, 21:47
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
The shafts on both this year's and last year's mecanum upgrade kits were cantilevered. We didn't experience any issues last year, though, so I wouldn't expect this to be too much of a problem. The shafts are durable.
Unread 16-01-2015, 23:08
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We're going with mecanums, but with a twist... one pair is direct drive, while the other is chained. Pic of our frame:
Basically, The back wheels are direct driven, and we cut out holes for 1/2 bearings to fully support the wheel, centered on one of the smaller holes along the bottom. The other wheels will be run on a dead shaft in the front, chained to the motors that are in the middle. They are all run using KoP gear boxes (we had two we never used last year and guess what? Same gear reduction!). We're avoiding cutting out any of the flanges on the frame, and instead are building a mount for the gearbox that will stand it off .625" (i think), which is the width of the flange. This also required turning custom axles, as the normal KoP output shaft isn't long enough once we move the gear boxes off the frame like that.
The 6" white wheels in the pic were just used to ensure proper clearances with the front and back frame members... the mecanum wheels aren't in the shop yet.
2016: Lake Superior WFFA
Unread 18-01-2015, 12:24
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We used tough box nanos which allowed there to be room but it was a nightmare of drilling. Would run from using mecanum wheels on the kop chassi if you could.
Unread 18-01-2015, 20:15
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
We have cantilevered the wheels off the transmissions with no problems.
We have used Toughbox mini's 12.75:1 with 8" wheels. That's what we plan to use this year. Seem to work OK.
Normally you have to run some rod from the transmissions on one side to the ones on the other side to stabilize the whole setup.
