Go to Post If the left side of your brain controls the right side of your body then left handers are the only ones in "their right mind". - Al Skierkiewicz [more]
Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
Unread 13-01-2015, 10:31
SquishyIce's Avatar
SquishyIce SquishyIce is offline
FRC #1405 (Finney Falcons)
Team Role: Electrical
SquishyIce can only hope to improve
Talon SRX Data Port Header
I've been trying to find a header that would work with the ribbon cable that connects to the data port header on the SRX, and I think I've found it: http://www.digikey.com/product-detai...C10K-ND/755176 Will this part work? If not, could someone direct me to one that will?
"MAKE IT WORK, DAVID"
Unread 13-01-2015, 10:33
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: Talon SRX Data Port Header
That part will not work. That is a .1" spaced header. The Talon SRX uses a .05" spaced header. I don't have a link handy to a part but I can find one later if someone doesn't beat me to it.
Also, don't forget your team's digikey voucher if you order anything from them.
EDIT:
Links:
I think these are all valid but double check them. It kind of depends on what you want. The .05 pitch makes these things tiny.
http://www.digikey.com/product-detai...627-ND/3883661
http://www.digikey.com/product-detai...629-ND/3883266
http://www.digikey.com/product-detai...5-5-ND/2264346
http://www.digikey.com/product-detai...389-ND/2264370
http://www.digikey.com/product-detai...383-ND/2264364
Unread 13-01-2015, 11:01
SquishyIce's Avatar
Thanks a ton! I've been looking at making a custom breakout for the SRX, and depending on the path forward, that female header may come in very handy. Thanks again for your help!
Unread 16-01-2015, 16:14
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
I am also thinking of making a different (better) SRX encoder breakout board.
Here's what it needs:
A 5 pin 0.1" header to match the Cui AMT103-V pinout, including Index
Two 2 pin 0.1" headers for the limit switches
A 3 pin 0.1" header for the analog pot sensor
A set of mounting screws so you can stick it to the robot!
Who wants some?
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 16-01-2015, 17:38
AKA: David Forbes
I think a breakout board on the Talon might make more sense than having it at the end of a ribbon cable. A nice connector is this one:
Digikey 609-3754-ND
The board wants to be designed so that it is centered on the Talon when the plug is centered in the header.
--David Forbes
Unread 16-01-2015, 19:19
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Speaking of the data port, the product description lists the Talon as being able to communicate over CAN and PWM, but also SPI and UART. Has anyone seen anything regarding the SPI and UART? The terms don't show up in the manuals.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 16-01-2015, 19:39
picklednerd picklednerd is offline
AKA: Bailey Blankenship
picklednerd is an unknown quantity at this point
Our team actually felt the exact same way about the current Talon breakouts; we aren't fans of the ribbon cables. We just finished designing two Talon boards, a breakout and a 5v to 3.3v analog converter, that mount directly to the Talon SRX. I've attached the white paper we've written, which includes all of the parts links on Digikey. If you'd like Gerber files or the Altium project files, I'd be happy to send them.
Unread 16-01-2015, 19:47
Are you saying you will be mounting the Talon to a PCB board instead of mounting it to a heat-sink surface?
Unread 16-01-2015, 22:55
SquishyIce's Avatar
Interesting design ideas... We were toying with the idea of mounting directly to the talon, but we went with (ironically) more ribbon cables. We basically feed all the data ribbon cables into one board that puts all the signals into a 34-pin ribbon cable which goes out to a board closer to the actual encoders and whatnot to reduce on messing with getting the encoder wires all the way back. I may end up adapting picklenerd's design into a board that supports multiple talons...I hadn't thought of using a jumper to switch between 5v and 3.3v for the quad. encoders. Maybe I'll revise our current design if we get a bit of pocket change, we JUST ordered boards tonight.
Unread 17-01-2015, 00:40
marshall's Avatar
The breakout will be mounted to the top of the Talon. The Talon will be mounted to the chassis. At least, that is the current plan.
Unread 17-01-2015, 00:58
Don't forget the TIM. It's explicitly permitted in the 2015 rules.
Unread 17-01-2015, 04:18
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
something like this? needs mtg holes though...
Unread 17-01-2015, 09:11
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
better version...
Unread 17-01-2015, 09:23
marshall's Avatar
Originally Posted by wireties View Post
better version...
Interesting. I'm digging the convergent evolution with these designs.
Are you at all worried about shorting on the bottom side of your board?
Unread 21-01-2015, 15:40
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
We're about to order some advanced circuits "barebones" compatible boards (bottom traces/pins steer clear of SRX body). We're going exclusively with AMT102V encoders, so the pinout /voltages matches those. I'll post back with info on how they turn out...
