Go to Post I also would not recommend shipping the gerbils with the robot. - Stuart [more]
Unread 17-01-2015, 11:26
aweso_meme aweso_meme is offline
FRC #4687
aweso_meme is an unknown quantity at this point
Trying Target permanent loop
Hello all,
I hit the run button on the eclipse program, and then I hit the button WPILIB Java Deploy. This has worked many, many times before. Now, the program compiles and everything, but does not complete the build. My output log ends with [echo] Trying Target: roboRIO-4687.local. It still says the program is building, as I am able to hit the red square stop sign. I am able o access the RoboRio through 172.22.11.2 on Google Chrome. What is going on? If any extra information is needed, please ask.
ATTEMPTED FIXES (Will update):
Use a Printer Cable (USB in computer, Square with cut off corners in RoboRIO)
Use an Ethernet Cable
Replace Battery
Restart Computer
Turn Robot on and off
Unread 17-01-2015, 11:35
FRC #4687
Re: Trying Target permanent loop
Problem fixed by a restart of Eclipse, then closing all programs related to the robot (Driver station, eclipse, smartdashboard, etc.) and then restart the computer a second time. Connection was established using a printer cable, USB side in the computer.
