Go to Post Why follow when you can lead? - Elgin Clock [more]
Unread 17-01-2015, 10:24
Mr.Roboto3335's Avatar
Mr.Roboto3335 Mr.Roboto3335 is offline
Wait, What?
AKA: Jimmy
FRC #3335 (Cy-Borgs)
Mr.Roboto3335 is an unknown quantity at this point
Roborio + Motor Controllers
I've been having some trouble getting the motor controllers to connect to the roboRio. When I enable teleop, the motor controllers still flash as if teleop was disabled. I was wondering if this was a wiring or a software issue. Here's my code.
package org.usfirst.frc.team3335.robot;
/* Copyright (c) FIRST 2008. All Rights Reserved.                             */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
import edu.wpi.first.wpilibj.*;
import edu.wpi.first.wpilibj.vision.*;
public class Robot extends IterativeRobot {
	private Joystick controller;
	private RobotDrive drive;
	private SpeedController one, two, three, four, lift;
	//private AxisCamera camera;
	//private DigitalInput limit;
	public void robotInit() {
		joystickInit();
		//sensorInit();
		speedControllerInit();
		robotDriveInit();
	//public void sensorInit() {
		//limit = new DigitalInput(0);
	public void joystickInit() {
		controller = new Joystick(0);
	public void speedControllerInit() {
		one = new Victor(0);
		two = new Victor(1);
		three = new Victor(2);
		four = new Victor(3);
		lift = new Victor(4);
	public void robotDriveInit() {
		drive = new RobotDrive (lift,two, three, four);
	public void autonomousPeriodic() {
	public void teleopPeriodic() {
		double y = getDeadZone(controller.getY(), 0.1);
		double x = getDeadZone(controller.getThrottle(), 0.1);
		drive.arcadeDrive(y, x);
		if (controller.getRawButton(2)) {
			one.set(-1);
		} else if (controller.getRawButton(1)){
			//	&& limit.get())
			one.set(1);
		} else {
			one.set(0);
	public void testPeriodic() {
	public double getDeadZone(double axis, double zone) {
		return Math.abs(axis) > zone ? axis : 0;
Wait, what?
Unread 17-01-2015, 12:47
Wait, What?
AKA: Jimmy
Re: Roborio + Motor Controllers
It was just a wiring issue.
Wait, what?
Unread 17-01-2015, 12:52
Thank you for following up.
Would you mind posting a few more details? Others are reading and this might be a teaching moment.
Unread 17-01-2015, 14:01
Wait, What?
AKA: Jimmy
I recommend that you make sure the pwm cables are not backwards and that your electrician is well rested when wiring.
Wait, what?
