Go to Post Pompous boasts dont get you anywhere. Results get your name on the book... - Jeremy_Mc [more]
Unread 13-01-2015, 19:15
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Thumbs up Vision Tracking Solution
I am proud to announce Team 3019's Vision tracking in java!
I have found that the libraries from First are too unreliable or do not even work and have researched a solution to tracking a yellow tote with or without the retro-reflective tape with green led ring-light. The solution I created runs on the driver-station computer meaning it will not interfere with the RobotRio's processing power but should take up more bandwidth.
I commented the code to describe my methodology and tried to make it as readable as possible. The program does not have a graphical user interface (gui) as it is the bare bones vision tracking without distance or any information based purely based on location of it relative to the point (0,0).
If you are going to use it all I ask is to give credit where credit is due.
Cheers!
Github Link
Unread 13-01-2015, 22:30
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Re: Vision Tracking Solution
Interesting solution, nice work on it. It's very sleek and simple.
Unread 13-01-2015, 23:46
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Good job! It takes a lot of work to do just this, believe it or not.
If you want to take it one step further, you can figure out the angle the camera(robot) needs to move to make the center of the object the center of the image.
Simply solve this proportion
Image width/Fov_x= distance from the center of the image/degrees
be careful though, the origin of the image in opencv is the top left, so you have to do a linear remapping of the point so the origin is the center of the screen!
proof of concept: In 2013 we used this x rotation value to line up with the 3 pt goal autonomously using a pid as shown slightly in this video: http://youtu.be/VhE10dNBxXs?t=27s
Those micro adjustments were not done by our driver, but rather by simply pushing a button on the controller to line up.
This is just food for thought. Take it as you will. (You can also calculate distance to your target if your camera height and angle stay constant, that involves y rotation )
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 16-01-2015, 19:59
aaronjeline aaronjeline is offline
Aaron
FRC #1719 (Umbrella Corporation)
aaronjeline is an unknown quantity at this point
Hey, sorry for being a tad scrubby, but where is the OpenCV Library you are using?
Unread 17-01-2015, 01:04
Head programmer
It is openCV 2.4.10 downloadable here
Unread 17-01-2015, 15:13
Aaron
Continuing in my eternal scrubiness, I got the library working fine, but I keep getting an error on
System.loadLibrary(Core.NATIVE_LIBRARY_NAME);
NATIVE_LIBRARY_NAME cannot be resolved or is not a field
Any ideas? All the imports are working, and code referencing objects/fields in the library aren't throwing any errors.
I'd appreciate any help I could get.
Unread 17-01-2015, 18:54
Head programmer
for version 2.4.10 the string value is "opencv_java2410"
Unread 18-01-2015, 15:37
gegozi gegozi is offline
gegozi is an unknown quantity at this point
Hello,
I am wondering if other FRC teams are allowed to copy this code.
Thanks.
Unread 18-01-2015, 16:00
Head programmer
Originally Posted by gegozi View Post
Hello,
Thanks.
of course! Just give credit to my team(3019) that's all I ask!
Unread 20-01-2015, 22:51
Head programmer
Updated! fixed a big memory leak!
Unread 07-02-2015, 09:31
popcorn107 popcorn107 is offline
FRC #2386
popcorn107 is an unknown quantity at this point
At the moment we are trying to get our robot to center itself with the bin by rotating (later on by strafing as well). How might we go about getting the center of the bin from your program? First time trying to implement Vision and am having some troubles fully understanding.
Unread 07-02-2015, 15:32
WillNess's Avatar
WillNess WillNess is offline
Programmer
AKA: Will Ness
FRC #4944 (The Hi Fives)
WillNess is just really niceWillNess is just really niceWillNess is just really niceWillNess is just really nice
The import for opencv "highgui" is not working, like it can't find it. Any help would be appreciated.
Outreach Lead // Lead Programmer // Junior
2014 FRC:
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Utah
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Colorado
2015 FRC:
Creativity In Engineering & Semifinalist @ Arizona West
Unread 07-02-2015, 23:21
Head programmer
This solution uses opencv 2.4.10 not 3.0
Unread 08-02-2015, 18:44
WillNess's Avatar
Programmer
AKA: Will Ness
Thanks I believed that worked. But when we're creating java classes on roborio, we get errors. We have installed the libraries for OpenCV.
2014 FRC:
2015 FRC:
Unread 08-02-2015, 21:38
Head programmer
It's meant to be run on the driverstation laptop not the actual robot
