Go to Post We got spirit yes we do! What? You don't have spirit? What's wrong with you? - Koko Ed [more]
Unread 17-01-2015, 15:38
electrical238 electrical238 is offline
FRC #0238
electrical238 is an unknown quantity at this point
Exclamation Mounting the Robo-rio using Zip-ties?
Hi, I'm from team 238 and I've been Trying to figure out the mounting rules for mounting the core electronics. the Robo-rio is giving me some problems for the fact that there are small rectangular holes by the 4 corners of the device. are you meant to put zip-ties through there? I just don't know because last year's rules said that you cant mount anything except for wires, using zip-ties. Thanks.
Unread 17-01-2015, 15:45
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Re: Mounting the Robo-rio using Zip-ties?
Where did it say that?
2016: FRC 865 Mentor
Unread 17-01-2015, 16:41
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
The holes you mention are for zip ties.
There's some images illustrating this here: http://wildstang.org/blog/?p=108
To my knowledge there is no rule prohibiting this method of attachment.
http://team2168.org
Unread 17-01-2015, 16:45
Zekoku Zekoku is offline
FRC #2170
Zekoku is an unknown quantity at this point
If you don't like using zip ties my team has found that wall hangers work well. Otherwise there is no rules against it.
Unread 17-01-2015, 20:36
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
We are using zip ties to mount the RoboRIO on our test chassis. Works great.
Unread 17-01-2015, 20:44
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
The screensteps documentation suggests dual-lock, which is what we are using for electrical components. Should be solid and doesn't require any holes.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 17-01-2015, 23:32
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
In alpha and beta testing, we used zip ties to hold the roboRIO down without issue. We also used velcro on a different one, again without issue. Given the lack of defense in this game, there shouldn't be any big impacts that could cause it to go flying!
2016: Lake Superior WFFA
Unread 18-01-2015, 14:21
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
I think a 40 lb strength zip tie will fit in the hole. How many g's woild the robo rio have to experience to break 4 of them? Would anything else on the robot still be functional after that?
Unread 18-01-2015, 18:07
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We mounted our robo Rio with a big peice of industrial "hook and loop" material stuck to the back
Unread 18-01-2015, 20:16
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The roboRIO is listed at 11.64 ounces, so about 220 G's if you believe the strength ratings of the zip tie, but strength ratings are often very conservative.
Unread 20-01-2015, 15:47
FRC #0238
Thanks guy's, I just said that because last year at a competition we got in trouble with the pits for using zipties for our festos.
Unread 20-01-2015, 16:18
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
If this happens again, politely & with the utmost GP point out the field is largely assembled with zip ties & Velcro.
In more seriousness. Although there are ways not to do it, zip ties are perfectly acceptable to use as a fastener unless there is a specific rule against it. If is an inspector questioning this, I would politely ask for a second opinion and the rule against it.
Unread 20-01-2015, 22:51
dtengineering's Avatar
AKA: Jason Brett
I know when I'm inspecting that if I see a team with something that is rules compliant, but that might interfere with robot reliability that I'll suggest a way to make an improvement.
"This isn't in the rules, and you don't have to change this..." is usually how I begin and, "so that's just a suggestion and it is entirely up to you. This is not an inspection item." is usually how I end. But if someone only heard the middle section of what I was saying... or if the story got relayed to them without the beginning and end parts... then it would be possible for them to think that whatever it is that I am suggesting is an inspection item.
Depending on how something is ziptied, I might make a suggestion on other ways to mount it. But depending on how something is bolted down I might make a suggestion, too. For instance, "I see you've used steel screws to bolt down your speed controllers and electronics. That is perfectly fine and within the rules, but did you know you can save over a pound of weight by using nylon screws? Not only that, but they are non-conductive. You don't need to change anything, but you might want to think about trying that for next year if you are close to your weight limit."
A statement like that could possibly be relayed to another team member as "the inspector said to not use steel screws on the electronics board because they are conductive".
I'm not saying that an inspector didn't question your use of zipties... but maybe they were trying to be helpful? Any chance of that?
Jason
P.S. One of my favorite ways to mount certain pneumatic valves is to run a 1/16" ziptie through the mounting hole and then slide a second ziptie over the end. The "heads" of the zip tie act like the head of a screw and a nut, holding the valve in place without requiring a loop as in most ziptie mountings.
Unread 20-01-2015, 23:49
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I have done this to mount Arduino Unos. It is quite clean looking if you trim the ends well.
Unread 21-01-2015, 00:05
pfreivald's Avatar
AKA: Patrick Freivald
We have always mounted all of our electronics using industrial-strength velcro, and have never had a problem with anything coming off, despite some years playing absolutely brutal defense.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
