Go to Post Physics is not a religion. - Jack Jones [more]
Unread 17-01-2015, 16:21
nathanzentner08 nathanzentner08 is offline
FRC #2073
nathanzentner08 is an unknown quantity at this point
Command Based Programming
Im assuming that the command based programming is more even based programming. Create a command, associate it to a JoystickButton and when the button is clicked, the command is run.
I have put printlns in all methods, and am clicking the joystickbutton but nothing is printing.
I have even ran the start on the command, but it is not getting into the execute, or initialize for that matter.
I have also added it to a group and started the group, but nothing.
Ideas?
Unread 17-01-2015, 17:44
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
AlexBrinister will become famous soon enough
Re: Command Based Programming
Could you post your code?
Alex Brinister
Unread 17-01-2015, 17:56
AKA: Brad
#0190 ( Gompei and the Herd)
If you wrote the code by hand (rather than RobotBuilder generated) make sure that you are calling Scheduler.run() in the TeleopPeriodic method like this:
    public void teleopPeriodic() {
        Scheduler.getInstance().run();
That's what actually causes the commands to run each iteration.
Brad Miller
Robotics Resource Center
Unread 17-01-2015, 19:02
BLUEBELL BLUEBELL is offline
FRC #3773
BLUEBELL is an unknown quantity at this point
Would I need to do that with the iterative robot code?
Unread 17-01-2015, 19:03
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
stick to command based its much easier to manage.
Unread 17-01-2015, 19:08
FRC #3773
But if I was going to use iterative would I need the
Unread 17-01-2015, 19:12
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Command based programming is based off of iterative. Instead of putting your code in the xxxPeriodic() methods, you call "Scheduler.getInstance().run();" in them and put your code in commands.
Look at the command based example to see how this is supposed to be done.
