Go to Post Here we go again with all kinds of speculation. We can never out guess FIRST. - BobC [more]
Unread 17-01-2015, 19:31
MartianMechanic MartianMechanic is offline
FRC #5750
MartianMechanic is an unknown quantity at this point
Can't connect to D-Link
Hello Everyone.
Mi team is having trouble connecting with the D-Link via the Bridge Configuration Utility. When launching the application, the network interface pop-up appears without any options, even when connected via Ethernet cable.
Does anyone know what the problem might be?
We are a bit desperate; we haven't been able to connect to the robot. FYI we are newbies.
Thanks for the help.
Unread 18-01-2015, 16:06
Re: Can't connect to D-Link
You're using a Mexico-localized version of Windows, aren't you?
Some of the configuration tools get confused when the information they're trying to parse out of Windows doesn't match what they expect. If you have a US-English Windows system, try it instead. If you can't do that, there are manual configuration instructions around somewhere.
Unread 19-01-2015, 22:05
Does it look something like this?
Unread 20-01-2015, 18:07
FRC #5750
Yes, it does. We have already tried connecting it via Ethernet Cable and pressing the Refresh button to no avail.
Unread 20-01-2015, 18:46
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Could you please post the output of ipconfig?
Also, try this procedure for setting it up manually.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 20-01-2015, 19:33
Open your Network and Sharing Center by hovering your cursor over the wireless icon on the toolbar or going through Control Panel.
Then go to Change Adaptor Settings in the left column.
That will give you a list of your active network ports.
Make sure they are Enabled (or right-click on each and choose Enable).
Unread 01-02-2015, 00:28
FRC #5750
All our network ports are enabled, and still we are unable to complete the configuration through the FRC BCU. We have all deployed some code directly to the roboRio but are still unable to connect via wireless.
Unread 01-02-2015, 16:39
Have you followed the advice in the first reply yet?
Unread 02-02-2015, 14:15
FRC #5750
We have tried what Alan Anderson says and it worked. The only problem now is that but it now displays an error when it is trying to locate the bridge at expected IP. We have already tried the solutions listed in the pop-up, but the issue remains. Could someone please tell us what we have got to do?
Unread 02-02-2015, 14:49
...it now displays an error... Could someone please tell us what we have got to do?
You have to tell us what the error says in order for us to know what is not working. Show us a picture if possible.
Unread 02-02-2015, 17:30
FRC #5750
Here is a screenshot
Unread 02-02-2015, 17:42
Is the mode switch on your D-Link truly set to AP 2.4 GHz?
Is the D-Link actually connected to your computer using an Ethernet cable?
Are the power and AP lights on the D-Link indeed lit blue?
Have you disabled all network adapters on the computer except for the one where the D-Link is connected?
Did you try resetting the D-Link to its factory settings (a ten-second reset on powerup) before running the configuration utility?
Unread 02-02-2015, 18:04
FRC #5750
Yes, Mr. Anderson. The D-Link s¡is set to AP 2.4 GHz, its connection to the computer is with an Ethernet cable, we have disabled all network adapters except for the one where the D-Link is connected and we did try resetting the D-Link to its factory settings. We have no idea why this error could be happening.
Unread 02-02-2015, 20:55
Perhaps your D-Link is just broken.
I can think of one further thing to investigate. Please open a command window and run the "ipconfig" command. Copy the output here. Maybe one of us will see something helpful.
Unread 03-02-2015, 18:23
FRC #5750
Here is what it displays when we do that.
Name:	IP config.png
