Go to Post *POP!* I suppose I'll have to change my hair style to the John V-Neun now. - Billfred [more]
Unread 17-01-2015, 19:05
dumbuya dumbuya is offline
FRC #1769
dumbuya is an unknown quantity at this point
Air Compressor not turning off.
Maybe some of you experience team out there has this issue.
We have a pneumatic setup everything work except that the
compressor is not turning off. The manual indicate somewhere that this year we do not need to include compressor control in the programming, the PCM should handle that.
Veteran teams out using pneumatics, what do you find to be true?
Is our problem a programming issue?
Unread 17-01-2015, 19:09
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Air Compressor not turning off.
Do you have a pressure switch wired in?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Did you plumb and wire the pressure switch correctly? Does the compressor continue to run after the pressure significantly exceeds 120 psi (ie 130+ psi?). Is the compressor and pressure switch wired to the PCM?
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 17-01-2015, 19:11
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
It's almost certainly not a programming issue. Something may be wrong with the pressure switch. Have you verified it's functioning properly.
Unread 17-01-2015, 19:19
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Can we get a picture of the setup of the wiring and everything else. We may be able to spot issues.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 17-01-2015, 19:44
FRC #1769
We ran the sample code and tested the cylinder and work fine. But we noticed the compressor is not turning off. The pressure switch and compressor are both wired in PCM.
How do we wire the pressure switch correctly? I understand that it is not polarized.
I will try to get in a pic for you. Any of you using pneumatics this year?
Unread 17-01-2015, 19:47
FRC #1769
Yeah it was about 135 psi and didnt turn off.
We plan to be, but we probably won't have the system in a testable state for about a week.
Do you have a gauge to check the pressure? If it is over 120 something is wrong. If you have a leak it might never get to 120. Or if you have a rediculous amount of storage it would take a while to reach full pressure.
Ours ran, filled up, and shut off just as it should
Edit: try another pressure switch or double check the connections on the pressure switch. If wires are shorted it will continue running. Look for loose strands at the PCM connections.
Andrew Basse
Unread 17-01-2015, 20:07
AKA: Roger Moore
We haven't decided yet. We were about to get pneumatics working today but we couldn't connect to the robot to test.
Stronghold
Student 2013-2016
Unread 17-01-2015, 20:15
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
I second the request for wiring pictures. Did you try a difference pressure switch?
Your system should never allow you to get that high. Where was your emergency relief valve?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 17-01-2015, 20:39
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
The relief valve commonly doesn't bleed air until 130-135 anyway.
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 17-01-2015, 20:53
WDB WDB is offline
FRC #2363
WDB is an unknown quantity at this point
We had the exact same issue today. Swapped out the pressure switch, triple-checked everything and it still didn't turn off. We finally tried a different PCM that hadn't been updated and it worked! Compressor switched off as expected. The firmware version of the working PCM was 1.60 and the version that did not work was the newer 1.62.
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
It's required by the rules to bleed at 125 psi. If yours doesn't, you need to adjust it.
Unread 17-01-2015, 21:13
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
We had this same problem today. We discovered that the newest version of the firmware causes this problem. We reflashed back to the previous version and the pressure shutoff switch now works properly again.
To troubleshoot, completely disconnect the pressure switch from the pneumatics module. This should cause the compressor to shut off. (Fail safe) If it keeps running, it's not the switch, it's the firmware.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
