Go to Post The more you cling to the misfortunes that have already befallen you, the less you'll be able move forward from here. - Kevin Sevcik [more]
Unread 17-01-2015, 20:38
JML's Avatar
JML JML is offline
Jlyon
AKA: Jlyon
FRC #3044 (0xBe4)
JML is an unknown quantity at this point
CANJaguars With Robo-Rio
Hello everyone,
Our team has been trying to use Jaguars with the new control system, however we are unable to see the jaguars through the robo rio web interface. they are correctly attached to the can system as we are able to see systems connected "down the line" from them. Any help would be appreciated.
Unread 17-01-2015, 20:40
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Re: CANJaguars With Robo-Rio
IIRC to give the Jaguars CAN IDs you have to use BDC-Comm, which is really hard to find a working version of. It took our team forever to find a version that actually worked with the new firmware and then we ended up scrapping CAN in the end.
College sux yo
Unread 17-01-2015, 21:03
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
It's possible to get the hi/lo wires swapped in the jags, and since they pass the signal through, you may see the downstream items if the wires get swapped back.
Unread 17-01-2015, 21:09
x86_4819's Avatar
x86_4819 x86_4819 is offline
computer-whisperer
AKA: Christian Balcom
FRC #4819 (Flat Mountain Mechanics)
x86_4819 is on a distinguished road
BDC-comm comes with the standard FRC tools package, found in Documents\FRC. We used it without problem to flash our new jaguars earlier this week.
My Github Repositories
