Go to Post You know what they call the graduate with the lowest GPA in med school? Doctor. You know what they call the fourth robot in the alliance that wins Einstein? Champion. - Billfred [more]
Unread 17-01-2015, 22:51
Chrono7 Chrono7 is offline
FRC #0578
Chrono7 is an unknown quantity at this point
Re: Cannot read PDP Temp or Currents
Originally Posted by ozrien View Post
Can you confirm that the device ID of the PDP is '0'? Check the self-test in the roboRIO web-page config.
http://wpilib.screenstepslive.com/s/...ribution-panel
EDIT:
The article mentions that the default ID '0' should be used for PDP.
"Changing the PDP ID while using C++\Java WPILib is not recommended as there is no way to change the desired node ID in the library. PCM node IDs may be set as desired and addressed using the appropriate Open or Constructor of the Solenoid or Double Solenoid class."
You got it!
That did the trick, the id was set to 3 for some reason.
Thanks very much.
