Go to Post The best [fundraiser] that we did was our various little things this year, such as calanders and other things. The worst is not doing one at all. - Joe Matt [more]
Unread 17-01-2015, 21:26
chmconkling's Avatar
chmconkling chmconkling is offline
Jack of all groups. Master at most.
AKA: chris
FRC #2363 (Triple Helix)
chmconkling is an unknown quantity at this point
pic: Good use of a old cRio
Unread 17-01-2015, 21:28
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Re: pic: Good use of a old cRio
Kind of a sad ending to an old workhorse. They were cranky but they could really take a beating.
Unread 17-01-2015, 21:38
Dief Chelphi Dief Chelphi is offline
Junior Member
no team (Unaffiliated)
Rookie Year: 1234
Dief Chelphi is infamous around these partsDief Chelphi is infamous around these partsDief Chelphi is infamous around these parts
It's not like they are expensive or anything.
Unread 17-01-2015, 21:46
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Maybe you can use it to cook corndogs, and have it catch the crumbs!
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 17-01-2015, 22:24
yash101 yash101 is offline
AKA: null
A bit more of a serious reply:
Our team has one (working) cRIO left on our last year's robot for demonstrations. It's nice to have the old cRIOs available, but it is also a total bummer that there is no support for them anymore. There isn't a driver station for it. There aren't programming tools with the right plugins either.
In short, they are quite useless. The dropdown on the DS which presumable allows you to change driver station versions(?) doesn't seem to co-op with the old cRIO either.
If NI and WPI didn't drop support for the old cRIO entirely, it may be of some good use, especially while prototyping. I doubt every team has five RoboRIO's to run those small prototypes. In our team, only the programming team has access to our RoboRIO's because they are under continuous use. After all, the new RoboRIO is quite pricey.
Unread 17-01-2015, 22:44
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Since we have two decent Classmates, I think we'll keep the older one "pure" for running our two cRIO bots. (The third cRIO we own might me more useful with the OP's use case; the useful ethernet port is damaged)
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 17-01-2015, 22:45
Gweiss96's Avatar
Gweiss96 Gweiss96 is offline
AKA: Garrett Weiss
FRC #3309 (Friarbots)
Team Role: Operator
Gweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to behold
We use our old cRios to operate our practice bots.
Unread 17-01-2015, 23:41
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
We dug up some laptops had been gathering dust (we got in 2010 ish once they were too old for a sponsor) and put the 2014 driver station on them. They run XP, so the new driver station won't work.
This is a good end for old XP laptops that aren't worth updating. I'm sure someone you know has one of those lying around. It was by far the easiest installation process of the year. The laptop battery's a little finnicky, but it really does great.
Its sad that this is the only way to make 6 years of robot work. I really hope NI/WPI releases a better solution in the future, but until then, I still get to use the only OS that doesn't give me problems, which I really quite enjoy.
Unread 18-01-2015, 01:34
AKA: null
That's exactly what we did. Our Classmate has a shot battery and isn't really fast enough to be desirable to code on, we decided to just keep it for driving the old robots. Once the old cRIO dies, we might as well get the new driver station
Unread 18-01-2015, 02:11
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Those are some sweet looking mecanums there, I must say. Care to share anything about where those wheels came from?
Unread 18-01-2015, 03:41
wasayanwer97's Avatar
wasayanwer97 wasayanwer97 is offline
Take from the best, invent the rest
AKA: Wasay Anwer
FRC #0668 (The Apes of Wrath)
wasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant future
They look like the AM Mecanum HD.
http://www.andymark.com/8in-Mecanum-...-p/am-2115.htm
"Coming together is a beginning; keeping together is progress; working together is success."- Henry Ford
FRC Team 668: The Apes of Wrath
Pioneer High School, San Jose CA
http://www.theapesofwrath.org
Talking to other FIRSTers is great. Add me on Facebook!
My Page
Unread 18-01-2015, 05:34
mrnoble's Avatar
teacher/coach
Yup. The lighting made me think the rollers were gum-rubber colored.
Unread 18-01-2015, 05:47
AKA: chris
That would be them
Unread 18-01-2015, 05:49
AKA: chris
Btw everyone. That cRio has been touchy on working the last few season, so she is no good.
Unread 18-01-2015, 16:20
In short, they are quite useless...If NI and WPI didn't drop support for the old cRIO entirely, it may be of some good use, especially while prototyping.
Last year's NI LabVIEW for FRC still creates programs; it does not expire. The driver station still works. We're using one of the 8-slot cRIOs for a mecanum testbed.
The 4-slot cRIOs are currently supported with this year's LabVIEW.
